11 Best Wireless Microphones for iPhone in 2024
The easiest way to upgrade your iPhone’s audio quality when recording videos is to use an external wireless mic. But since all the brands claim to be number one, it becomes difficult to make the right decision. So, to ease this process, this article provides an overview of features, specifications, pros, and cons of the 11 best wireless microphones for iPhone. There’s also a quick guide to help you choose the right brand and model.
Comparison Table – 11 Best Wireless Microphones for iPhone
ProductPriceConnectivityRangeFrequency ResponsePolar PatternBattery TimeCharging TimeSample RateBit DepthSignal-to-Noise RatioSound Pressure LevelMic Sensitivity
Hollyland Lark M2$179.002.4GHz (AFH)1000ft20Hz to 20kHzOmnidirectionalTX:
Up to 10 hours
Up to 1.5 hours48kHz24-bit> 70dB115dB-37dBV +/- 2dB @1 kHz
Hollyland Lark C1$109.002.4GHz (AFH)650ft20Hz to 20kHzOmnidirectionalTX:
8 hours
1.5 hours48kHz16-bit70dB110dBN/A
Rode Wireless ME$149.002.4GHz 328ft20Hz to 20kHzOmnidirectionalTX:
Up to 7 hours
N/A48kHz24-bit22dBA122dBN/A
Saramonic Blink Me B2$249.002.4GHz digital frequency328ft20Hz to 10kHzOmnidirectionalTX:
6 hours
RX:
24 hours
2.5 hours48kHz16/24-bit> 80dB110dB-32 +/- 2dB
Godox WES1$119.002.4GHz (FHS)656ft20Hz to 20kHzOmnidirectionalTX:
8 hours
2 hoursN/AN/AN/A110dBN/A
7Artisans DMic-S$109.002.4GHz328ft20Hz to 20kHzOmnidirectionalTX:
Up to 8 hours
RX:
Up to 10 hours
N/AN/AN/A> 70dBN/A-42db + 3dB
DJI Mic 2$349.00Bluetooth and 2.4GHz820ft50Hz to 20kHz
20Hz to 20kHz
OmnidirectionalTX:
Up to 6 hours
Up to 1.5 hoursN/AN/A21dBAN/AN/A
SYNCO G1L$88.992.4GHz492ft50Hz to 20kHzOmnidirectionalTX:
Up to 8 hours
Up to 1.5 hours48kHz16-bit> 75dB110dB42dB +/- 3dB
MOVO Mini Di Duo$44.952.4GHz164ft20Hz to 6kHzOmnidirectionalTX:
Up to 10 hours
N/AN/A16-bit77dBN/A-42dB
MAYBESTA AN151$22.09Bluetooth50ftN/AOmnidirectionalTX and RX:
Up to 4.5 hours
2 hoursN/AN/AN/AN/AN/A
AnkerWork M650$219.00LC3Plus656ftN/AOmnidirectionalTX:
Up to 6 hours
N/AN/AN/AN/AN/AN/A
Note: The price for each brand may be subject to change, depending on the pricing policy of the manufacturer, or Amazon store owner.
Here are the details of the 11 best wireless microphones for iPhone.
1. Hollyland Lark M2
image 363
The Lark M2 is the latest wireless microphone from the Hollyland. The system is available in three different versions, including camera, mobile, and combo. While the combo variant is best for all devices, the mobile version comes with lighting and USB-C connectors. Unlike other brands, the transmitter (TX) of Lark M2 has a snug fit without sagging or drooping because of its compact design. As a result, the microphone not only provides comfort but even enhances the audio quality by capturing in-depth audio. On the other hand, you can play audio recordings without unplugging the receiver (RX) from your iPhone.
The Hollyland Lark M2 operates on 2.4GHz Adaptive Frequency Hopping (AFH) technology. At the same time, it features a special metallic mesh to protect against dust particles and several interfering frequencies to ensure the audio remains clean from unwanted noise.
Also, wearing the Lark M2 is a picnic! You can put it on your clothes through the magnetic attachment, clip it on your collar, or simply hang it around your neck like a necklace.
Another interesting thing about the Hollyland Lark M2 is its 300-meter wireless range backed by cutting-edge Laser Direct Structuring (LDS) technology. This ensures stable transmission up to 1000ft. This wireless mic can also capture the nuance of sound with accuracy for delivering polished voice recordings through its 70 dB high signal-to-noise ratio and 115 dB sound pressure level.
Moreover, the Hollyland Lark M2 has an Environmental Noise Cancellation (ENC) feature for rich tones and crystal-clear sound recordings by suppressing noise in the environment. The entire kit only takes 1.5 hours to get charged with operating time of up to 10 hours. But you can also enjoy up to 40 hours of battery life when the TX and RX units are used with a fully charging case.
Key Specifications of the Hollyland Lark M2
  • 24-bit bit depth
  • 48kHz sample rate
  • 1000ft wireless range
  • Omnidirectional polar pattern
  • 2.4GHz wireless connectivity
  • > 70dB signal-to-noise ratio (SNR)
  • 115dB sound pressure level (SPL)
  • -37dBV +/- 2dB @ 1kHz mic sensitivity
  • Up to 10 hours of battery life (TX and RX)
  • Up to 1.5 hours of charging time (TX and RX)
Pros
  • The design is quite discreet
  • Both TX and RX units pair flawlessly
  • It works on both iPhone and Android phones
  • Excellent audio quality in an affordable price range
Cons
  • So far there have been no major complaints from the users
  • $179.00 (Price of Combo variant as seen on Amazon)
2. Hollyland Lark C1
image 364
The Hollyland Lark C1 is another impeccable wireless microphone for an iPhone. In fact, this model is designed for smartphone creators. So whether you have old iPhone models, the latest iPhone 15, or any Android, if they have a lightning port or a USB-C, Lark C1 will work like magic.
The transmitters of Lark C1 offer a battery life of up to 32 hours when used with a fully charged case. Contrarily, when the TX is completely charged, you can use it for up to 8 hours, which is enough for an entire day recording session. In the meantime, once the TX and RX units are out of the box, you can enjoy a wireless recording range of up to 650 feet.
The Hollyland Lark C1 also ensures effortless connectivity. It is a plug-and-play wireless mic, which eliminates the need for complex configurations. Also, the receiver (RX) unit works as a charging port for your iPhone. That means, once the RX is plugged into the USB-C or lightning port of your iPhone, you can connect your phone’s charger to the RX unit so you don’t run out of battery.
Additionally, the Lark C1 features real-time audio playback through your iPhone’s speaker without plugging out the RX. This microphone also lets you capture detailed sound across 20Hz to 20kHhz frequency ranges due to a 48kHz sample rate and 16-bit bit depth. Plus, it comes with advanced audio processing technology for high audio quality with minimal background noise.
Key Specifications of the Hollyland Lark C1
  • 48kHz sample rate
  • 16-bit bit depth
  • 110dB maximum SPL
  • 70dB signal-to-noise ratio
  • 8 hours of TX battery life
  • Transmission range of up to 650ft
  • 1.5 hours of charging time (TX and RX)
  • 2.4GHz Adaptive Frequency Hopping (AFH) wireless connectivity
Pros
  • It has a user-friendly interface
  • The microphone has a stable wireless range
  • Lark C1 is a MFI-certified wireless microphone
  • The built-in noise-canceling feature improves the overall audio quality
Cons
  • A few users complain about the lack of audible alert for low battery
  • $109.00 (As seen on Amazon)
3. Rode Wireless ME
image 365
The Rode Wireless ME is an MFi-certified wireless microphone for iPhone and other iOS devices. It uses the latest RODE technology to transmit audio signals wirelessly. The system works through the 2.4GHz frequency and provides solid encryption to keep signals secure and stable. Wireless ME offers a wireless transmission range of up to 328ft. The microphone is also compatible with Android and computers. You can connect the receiver to your iPhone, attach the transmitter to your clothing or the subject, and start recording by pressing the record button.
The package comes with a USB and a 3.5mm cable that lets you connect this wireless microphone to your device without a hitch. Also, you can use the MagClip GO to attach the receiver at the back of your magnetic phone. The Wireless ME setup is also very easy. The TX and RX units automatically pair once you take them out of the box.
Talking about the sound quality, the Wireless ME’s transmitters come equipped with built-in, high-quality, omnidirectional microphones. So you can expect great audio for your recorded videos. The device also has a ‘GainAssist’ feature that allows you to adjust the audio levels. This ensures your audio recordings will sound clean and distortion-free.
While there is no proper noise cancellation trait, you can use the furry windshields (included in the package) to prevent wind noises from disrupting your recordings.
Key Specifications of the Rode Wireless ME
  • 24-bit bit depth
  • 122dB Max SPL
  • 48kHz sample rate
  • TX battery time of up to 7 hours
  • 2.4GHz transmission technology
  • 328 feet (100 meters) wireless range
  • 22dBA noise level (equivalent to SNR)
Pros
  • Great for various content niches
  • Best for iPhones due to uncomplicated setup
  • The gain adjustment feature helps you fine-tune the recordings
Cons
  • There is no dedicated button to mute the microphone
  • Even the maximum volume is low compared to other brands
  • $149.00 (As seen on Amazon)
4. Saramonic Blink Me B2
image 366
When you see the Saramonic Blink Me B2 for the first time, you may be attracted to its unique design. But apart from appearance, this 2-person wireless microphone has many more features to offer. The two transmitters (TXs) have a circular shape with a touchscreen display. This kit is great at blocking unwanted noises and you can also adjust the intensity of noise reduction.
Although the microphones inside the TX units are small, they offer plenty of useful benefits. The transmitters can record audio for long sessions by ensuring high-quality reproduction of sound. One of the coolest things about the Saramonic Blink Me B2 is the customized AF-coated, Panda Glass, OLED display. You can add your own logo, wallpaper, or an image that will be displayed on the transmitters when they are turned on.
From the compatibility point of view, the Saramonic Blink Me B2 uses a USB-C or 3.5mm to lightning adapter to connect iPhone 15 and previous models along with iPads. The transmitters also have a 24-hour onboard recording functionality and can record audio up to 8GB in a single session. Whereas each TX can independently work for up to 6 hours when fully charged.
Conversely, the RX unit has a battery life of 24 hours even if only 1x transmitter is fully charged. Moreover, this wireless microphone has a mute functionality and gain adjustment. You can also download its exclusive mobile application to experience more advanced features.
Key Specifications of the Saramonic Blink Me B2
  • 110dB Max SPL
  • 48kHz sample rate
  • 16/24-bit bit depth
  • 328ft wireless range
  • 2.4GHz digital frequency
  • TX battery life up to 6 hours
  • RX battery life up to 24 hours
  • 20Hz to 10kHz frequency response
  • -32 +/- 2dB microphone sensitivity
  • More than 80dB signal-to-noise ratio
  • Approx. 2.5 hours charging time (TX/RX)
Pros
  • Effective noise reduction
  • It has an impressive sound quality
  • The customization of the display is very easy
  • The built-in recording adds more convenience to the overall usability
Cons
  • You cannot charge the TX without RX
  • The attachment magnets do not provide a stronghold
  • $249.00 (As seen on Amazon)
5. Godox WES1
image 367
If you’re looking for a super convenient wireless microphone for an iPhone, the Godox WES1 may attract you with its basic features and affordable price. The mic is ideal for vloggers, filmmakers, and livestreamers. The WES1 is an MFi-certified device with a lightning port, ensuring seamless connectivity with all models up to the iPhone 14 series. However, if you want Godox for iPhone 15, you can check out the WES2 since it has a USB-C connector with all other features remaining the same.
The Godox WES1 is a lightweight kit of TX and RX, where the transmitter only weighs 12 grams and the receiver weighs around 7 grams. So, it is more of a travel buddy for creators seeking outstanding audio quality. The audio quality is more than ordinary. The kit offers advanced technology to reduce background noises with a customization option to adjust the levels for noise elimination.
Each TX has an omnidirectional microphone that picks sound from all the corners without degrading the quality. Moreover, it captures detailed audio and can handle high sound levels of up to 110 decibels without distorting the audio.
The Godox WES1 comes with integrated antennas that offer a wireless range of up to 656 feet. This allows you to move around freely within the range to capture audio. Moreover, the WES1 has a straightforward usability. You can also download the Godox Mic app to adjust several settings to achieve your desired audio quality. Besides, you can enjoy a maximum recording time of up to 24 hours when using the transmitters with the case.
Key Specifications of the Godox WES1
  • 110dB Max SPL
  • TX battery life of up to 8 hours
  • Charging time of up to 2 hours
  • 2.4GHz Frequency Hopping System (FHS)
  • Wireless range of up to 200 meters (656ft)
Pros
  • The entire kit is lightweight and portable
  • Best entry-level wireless mic for iPhone users
  • Strong noise reduction, especially at this price range
Cons
  • The charging case is not durable
  • It lacks many advanced features, such as onboard recording and safety channels
  • $119.00 (As seen on Amazon)
6. 7Artisans DMic-S
image 368
The 7Artisans DMic-S gives you most of the features offered by expensive brands but at a reasonable price. The device comes with 2x transmitters with integrated microphones and a 1x receiver that easily connects your iPhone using an adapter cable. The TX units have built-in features for noise reduction. Plus, you can also use windshields to mitigate the wind noise. Also, both transmitters and a receiver are lightweight and can be worn all day. Also, the kit has an auto gain feature so you can record clear sounds.
The 7Artisans DMic-S’s RX has a safety track feature that records a copy of your original recording at a lower level to avoid distortion. You can use it in case the original recording has accidentally recorded distortion or noise. This wireless microphone also supports CD-grade audio quality due to 24-bit bit depth and 48kHz sample rate.
From a durability point of view, the kit is made with Acrylonitrile butadiene styrene (ABS), a high-quality plastic, which ensures sturdiness and solid performance in various temperatures and recording conditions. The pairing of the TX and RX is also hassle-free since both units automatically pair up.
The receiver also comes with a color screen display to help you monitor various parameters, including sound levels. And guess what? The manufacturers also claim that the DMic-S allows you to monitor audio in real time through the headphone out jack.
Key Specifications of the 7Artisans DMic-S
  • 328ft  wireless transmission range
  • Up to 8 hours of battery life (TX)
  • Up to 10 hours of battery life (RX)
  • -42db + 3dB microphone sensitivity
Pros
  • It has an attractive, diamond-cut design
  • The units quickly pair without interference
  • You can also attach external lavalier mics
  • This microphone has simple controls
Cons
  • No controls for noise adjustments
  • Sometimes the noise reduction may lead to chirping artifacts
  • Some users have reported background hiss sound when not using the mic with the noise reduction feature
7. DJI Mic 2
image 369
While the previous model has a rugged look, the current DJI Mic 2 appears cool and sleek. This wireless microphone transmitter and receiver for iPhone has various great features. Both units come in a charging case made of metal that gives a simple and neat look. The case also has an improved latch that ensures the TX and RX remain safe and free from accidental dropping when the units are kept inside.
The DJI Mic 2 lets you record audio from a distance of up to 820 feet effortlessly. That is why this wireless microphone has been one of the top picks by content creators who mostly do live streaming. The 2x transmitters (TX) stay functional for up to 6 hours when fully charged. But if you want to increase the battery life, you can use the TXs by keeping them in the charging case. Doing so will give you an extended battery time of 18 hours (approx). Plus, the charging case can also charge your phone in case you need to record long sessions.
The DJI Mic 2 picks sound from all directions, especially voices, making it ideal for vlogs and interviews. But don’t worry about the background noise. Because this microphone is intelligent enough to eliminate unwanted background noise to keep your recordings clear even in crowded environments.
On windy days, you can use the windscreen to protect your recordings from harsh wind sounds. But if the sounds are extremely loud, the DJI Mic 2 automatically creates a backup track that’s quieter and can be used as a replacement for the original track.
Key Specifications of the DJI Mic 2
  • 120dB Max SPL
  • 21dBA signal-to-noise ratio
  • BR/EDR Bluetooth protocol
  • Bluetooth and 2.4GHz wireless connectivity
  • Maximum wireless range up to 820ft
  • Up to 1.5 hours required charging time of TX and RX
  • 50Hz to 20kHz low cut (off) frequency response
  • 20Hz to 20kHz low cut (on) frequency response
Pros
  • Durable casing and units
  • It has a discreet design with user-friendly controls
  • The Bluetooth connectivity option adds more convenience for quick filming scenarios
  • The 32-bit float recording helps recover audio recorded in challenging environments
Cons
  • Some iPhone models need external accessories to connect this microphone
  • $349.00 (As seen on Amazon)
8. SYNCO G1L
image 370
The SYNCO G1L is a high-quality, small-size microphone that operates on 2.4GHz wireless connectivity. It is not just a wireless mic system but a voice changer too. So, whether you want your voice to sound echoey, high-pitched, or deep, this mic lets you apply all the effects. This wireless kit comes in two different variants. One is with a Type-C plug (G1T) and the other with a lightning plug (G1L). This means you can connect it to your iPhone and Android smartphones, and even tablets.
However, both versions have similar features. But since you are looking for a wireless microphone for an iPhone, you should consider the G1L. If you order the G1T, you will have to purchase the G1L plug separately, or else it won’t work with your iPhone.
Focusing on the SYNCO G1L, this wireless mic can capture sound from up to 492ft. The receiver audio signals are highly encrypted to ensure the audio is secure and interference-free. Moreover, this microphone also offers real time audio monitoring by attaching the headphones.
One of the notable features of the G1L is that you can use the transmitter to charge your iPhone’s battery so you can record without a break. And if you need a break from your session, you can press the dedicated mute button. Additionally, the mic has options like volume adjustment and cutting out low-level sounds to make your recordings better.
Key Specifications of SYNCO G1L
  • 110dB Max SPL
  • 16-bit bit depth
  • 48kHz sample rate
  • Omnidirectional microphone
  • > 75dB signal-to-noise ratio
  • 492ft wireless transmission range
  • TX battery life up to 8 hours
  • TX charging time up to 1.5 hours
  • -42dB +/- 3dB microphone sensitivity
  • 50Hz to 20kHz frequency response
  • 2.4GHz wireless transmission technology
Pros
  • It is a lightweight microphone
  • No batteries are required for the RX
  • The microphone delivers impressive audio quality
  • Affordable mic kit for mobile filmmaking
Cons
  • The voice-changing functionality may not suit all users
  • The microphone lacks a visual representation of output volume levels
  • There may be some issues with wireless range in congested environments
  • $88.99 (As seen on Amazon)
9. MOVO Mini Di Duo
image 371
If you’re looking for a wireless microphone for an iPhone that falls under the price range of fifty bucks, then have a look at the MOVO Mini Di Duo. The device is a great example of a wireless mic that’s super light. The system includes 2x transmitters and a 1x receiver. The TXs are good for recording two people at the same time and can be clipped on the subject’s clothing. Whereas the RX goes straight into your iPhone’s lightning port without needing any adapters.
The MOVO Mini Di Duo is also packed with interesting features. The microphones in each TX  are of high quality which makes your voice sound better than the internal mics of many smartphones. And you can mute the microphone or reduce the background noise by simply clicking the button.
While setting it up with your iPhone requires no special software or adapters, the MOVO Mini Di Duo also offers impressive battery time. You can use this microphone for up to 10 hours, with a maximum wireless range of up to 164 feet. Plus, the brand promises to keep the wireless transmission free from signal interference. Notably, the MOVO Mini Di Duo is an MFi-certified device, which gives it a better position over other brands.
Key Specifications of the MOVO Mini Di Duo
  • 16-bit bit depth
  • 164ft of wireless range
  • 77dB signal-to-noise ratio
  • -42dB microphone sensitivity
  • Up to 10 hours of battery time
  • 20Hz to 6kHz frequency response
Pros
  • Plug-and-play operation with auto-connect functionality
  • Enhanced audio quality than iPhone’s built-in microphone
  • Good at blocking wind and background noises
Cons
  • Some users have reported frequency interference
  • You may need to remove the iPhone case to fix the RX unit firmly
  • $44.95 (As seen on Amazon)
10. MAYBESTA AN151
image 372
The MAYBESTA AN151 is a lav-style wireless microphone system. The device has a lightning port, enabling iPhone users to quickly plug the receiver into their phones and start recording. Both TX and RX units automatically sync up once out of the case. The microphone also has a user-friendly menu and controls, and it delivers outstanding sound quality.
The MAYBESTA AN151 transmitters consist of sensitive microphones, each having a high-density sponge inside. This allows for capturing detailed audio with clarity, no matter if you’re recording indoors or outdoors. This microphone system also comes with the latest noise reduction technology that minimizes background noise to give you more professional-sounding recordings.
Talking of design, the MAYBESTA AN151 is a compact wireless microphone that you can clip on the subject’s shirt. However, it offers a reduced wireless range (only 50ft) compared to other products in this list. So, if you’re audio recordings are intended for short distances, this microphone can be a good option to consider.
While the MAYBESTA AN151 is suitable for iPhones with a lightning port, you can also attach it to iPads. And since it is not a bulky device, it can be an ideal pick for online teaching, live streaming, vlogs, podcasts, and interviews. Both transmitter and receiver units require charging and give up to 4.5 hours of operation time once completely juiced up.
Key Specifications of the MAYBESTA AN151
  • Bluetooth wireless technology
  • 50ft wireless transmission range
  • Up to 4.5 hours of battery life (TX and RX)
  • 2 hours charging time (TX and RX)
Pros
  • Inexpensive mic, ideal for first-time users
  • Simple setup, best for non-technical users
  • Users prefer this mic for Zoom meetings
Cons
  • Unprofessional audio quality
  • Some users complain that the adapters don’t work to connect this mic with non-lightning devices
  • The microphone has a limited transmission range and may not be able to provide 50ft in some scenarios
  • $22.09 (As seen on Amazon)
11. AnkerWork M650
image 373
The AnkerWork M650 is a dual-channel wireless microphone kit with wide compatibility, including iPhones and other smartphones. The manufacturers claim to provide high-quality audio recording through this device. It is a lightweight microphone that captures clear and accurate voices even in noisy surroundings. Thanks to the integrated VoiceShield technology make that happen.
Setting up the AnkerWork M650 is a piece of cake. All you need to do is open the case and the transmitter and receiver will automatically pair up. It requires an adapter to connect the receiver to any iPhone or Android mobile phone. It has a catchy circular design and you can even use colorful covers to add more attractiveness to the overall appearance.
Moreover, the AnkerWork M650 can send audio signals up to 656 feet. The battery life is also impressive, giving around 15 hours without needing to charge in the middle of the session. While the manufacturers haven’t provided information related to the charging time, the official website only mentions that the device quickly charges up as it comes equipped with fast-charging technology.
Moreover, the AnkerWork M650 comes with several beneficial traits, such as gain control, mono/stereo recording, noise reduction, and mute. You can also fine-tune your audio recording on your iPhone or PC through the AnkerWork software.
Key Specifications of the AnkerWork M650
  • 656ft wireless range
  • Up to 6 hours of TX battery life
  • LC3Plus coding wireless technology
Pros
  • Works great for live streaming
  • It comes with reliable clips to attach the TX
  • The mic has a clean visual display for quick menu adjustment
Cons
  • The manufacturers have provided limited information about the product
  • The noise reduction feature does not perform well in high noisy environments
  • You will have to purchase a separate adapter to use the mic with the iPhone
  • It is an expensive microphone for the features and specifications it provides
  • $219.99 (As seen on Amazon)
Factors to Consider when Choosing Wireless Microphones for iPhone
These seven factors will help you pick the right wireless microphone for your iPhone for the best performance.
a. Compatibility
One of the key considerations is the compatibility of a wireless iPhone microphone. The brand you pick should have the receiver’s connector matching your iPhone’s port. Remember, iPhones before the release of the 15 series have a Lightning port, while the iPhone 15 features a USB-C  port. For instance, if you have an iPhone 13, you should choose a wireless microphone whose RX has a lightning connector. Contrarily, if you have an iPhone 15, try your best to look for a wireless mic with a USB-C connector on the RX unit.
However, some brands allow adapters to let you use wireless microphones with all iPhones and even other smartphones. Still, it is ideal to pick a mic with an RX unit that directly connects your iPhone model for great performance.
b. Wireless Connectivity
Wireless connectivity or technology plays a key role and should be considered as an important factor. Most wireless microphones for iPhones operate either on 2.4GHz or Bluetooth technologies. The 2.4GHz band provides strong signal transmission and is less prone to signal interference, ensuring reliable sound quality.
On the other hand, Bluetooth wireless connection may offer a shorter wireless range and have more interference compared to 2.4GHz. Apart from these two connectivity options, some wireless mics may also have LC3 Plus coding. Although the technology is great at improving audio compression to provide great sound quality, the 2.4GHz remains more beneficial in many scenarios.
c. Wireless Range
The wireless range of an iPhone mic is an extremely vital parameter. Keep in mind that a wireless microphone for an iPhone with a longer range lets you move up to several meters without signal dropouts or loss of signal quality. Conversely, brands that offer shorter ranges may lead to degraded sound output, signal dropouts, and loss, especially in crowded places.
So, it is better to opt for a wireless microphone with the highest available range that comes in your budget. This will not only ensure reliable signal transmission but the mic will also provide sufficient audio fidelity even when the transmitter is several hundred feet away from the receiver.
d. Polar Pattern
Most prominent brands have wireless transmitters with omnidirectional polar pattern microphones. Omni mics can capture audio from all directions, which is why manufacturers use them in lavalier-styled microphones. An omnidirectional polar pattern is suitable for capturing multiple audio sources and ambient noises in various recording environments.
That is one of the reasons why wireless microphones are widely used for interviews, vlogs, group discussions, podcasts, and live streaming. But many beginners usually get confused when they see omnidirectional as a standard polar pattern of wireless microphones, and waste time digging for other brands with different patterns due to limited knowledge. Therefore, if your desired microphone model mentions an omnidirectional polar pattern, it means there is no red flag in this context.
e. Battery Life
You may notice that some wireless microphones for iPhones only show the battery life of a transmitter, while the receiver’s battery life is not found in the specifications. This is because the RX is generally powered by your iPhone’s battery. Contrarily, if both RX and TX units have a battery life displayed in the specs, it means that both units run on built-in batteries.
In such cases, you will have to charge both units and consider the battery life of the TX and RX before making the purchase. It is best to choose an iPhone wireless microphone that offers an extended battery life (TX only or both TX and RX) to reduce the need for recharging for continuous use.
f. Frequency Response
Frequency response showcases the ability of a wireless mic to capture different audio frequencies without manipulating the originality. Microphones with wider frequency response can reproduce sound in more detail and high clarity. Compared to the iPhone’s built-in mics, a wireless microphone with a broad frequency range can deliver more natural and nuanced sound. Professionals seek frequency response ranging from 20 Hertz to 20,000 Hertz (20Hz to 20kHz). So pick a mic whose frequency falls under this range for optimal performance.
g. Price
The price may decide the audio quality of a wireless microphone for an iPhone. Typically, higher and mid-priced mics often come with top-notch components, strong build quality, and advanced technology, resulting in cleaner reproduction of audio. Such microphone brands may also provide additional features, including improved connectivity and noise cancellation, which enhances your audio recordings.
On the other hand, lower-priced models may not provide a desirable audio quality, and may also offer fewer features. So, if budget is not an issue, you should opt for high-priced mics. But if price is an issue at the moment, consider mid-priced models to begin your journey.
All wireless microphones for iPhones mentioned here have some special features. However, the Hollyland Lark M2 and Hollyland Lark C1 top the list as they offer seamless connectivity with iPhones, high wireless range, long battery time, noise cancellation, and numerous other unique qualities at affordable pricing. Contrarily, the Rode Wireless ME, Godox WES1, and 7Artisan DMic-S are also mid-priced models to consider. While the Saramonic BlinkME B2, DJI Mic 2, and AnkerWork M650 offer impressive range, they are high-priced options.
On the other hand, if you are on a tight budget or if this is your first time using a wireless mic on an iPhone, you can also opt for low-priced brands, like the MAYBESTA AN151, MOVO Mini Di Duo, and SYNCO G1L. Although they don’t have characteristics even close to the Hollyland or Rode, you can use them to gain some experience.
Frequently Asked Questions about Best Wireless Microphones for iPhone
Q1. How do I make my iPhone sound better?
You should use an external mic to make your iPhone sound professional when recording videos. While you can get wired mics, most users prefer wireless microphones for their iPhones.
Q2. What is the best wireless microphone for noise cancelling iPhones?
The Hollyland Lark M2 is one of the best wireless microphones for iPhones that features advanced noise cancellation technology.
Q3. What mic should I get to record with my iPhone?
Some of the best wireless mics for video recording on iPhone are Hollyland  Lark C1, Hollyland  Lark M2, Saramonic BlinkME B2, and Rode Wireless ME.
Q4. How do I stop my microphone from picking up background noise on my iPhone?
If your built-in iPhone microphone is recording background noise, opt for an external wireless microphone with Active Noise Cancellation or Environmental Noise Cancellation technologies, like the Hollyland Lark M2 or other models by the same manufacturer.
Facebook
Twitter
Pinterest
John Doe
John Doe
Leave a Reply
Your email address will not be published. Required fields are marked *
Related Posts
16 Best DSLR Microphones in 2024
The built-in mics of a DSLR camera can help you record sound. However, it may not be clear and accurate, especially if content creation is
