Dual wireless microphones feature two transmitters worn or held by the talent. Along with them, it also has a receiver that catches the wireless signals emitted by the transmitter. The receiver then transforms the signals into audio and delivers them to the amplifier or mixer via a cable.
These are basically used for recording presentations or two-person interviews. With it, you can enjoy that much-needed fuller range of sound when you mic the speaker in different spots. However, most people run the mics into the mixer to utilize the signals effectively.
If you plan to get your hands on the best dual wireless microphone, you have landed at the right place. In this article, we will shed light on multiple aspects, including the factors you must consider when looking for the best dual wireless microphone and our top picks for these products. Keep reading to explore!
What to Consider when Choosing the Best Dual Wireless Microphone?
Here is a breakdown of a few factors to consider when choosing the best dual wireless microphone. Let’s have a look!
For What Purpose Will You Use It?
Spend some time searching for the specifications you require to meet your task needs. This is crucial, as you can save loads of your time by targeting only those features you need.
Reliability
The microphone you buy must have ultimate compatibility paired with noise, static, and dropout reduction. Believe without an expensive compander system; your microphone will sound like a pump.
Operating Range
The ideal range of the best dual wireless microphone is 100ft. or more. Any dual wireless microphone system with an operating range below this figure is bound to experience interference issues.
Budget
An undoubtedly important factor in narrowing your choice range. Don’t pay too much; just target the desired features and make the most out of your budget.
Our Top Picks of the Best Dual Wireless Microphone in 2023
Our team has been reviewing multiple wireless dual microphones for years. Here are a few of the best dual wireless microphones of our experts’ choice!
- Hollyland Lark-150 Wireless Microphone Dual Mics
- Rockville RWM1201VH VHF Wireless Dual HandHeld Microphone Mic System
- Rode Wireless GO II – Dual Channel Wireless Microphone System
- Tonor Wireless Microphone
- Sennheiser XSW 1-825
1. Hollyland Lark-150 Wireless Microphone Dual Mics
Designed to record two-person dialogues, Hollyland Lark-150 – the best dual wireless Lavalier microphone system comes with two mics. These ultra-compact mics are bound to offer you an amazing recording experience.
Its amazing features include the noise buffer design, smart signal processing, auto-pairing, and more. It comes with multiple working modes, mono track, stereo track, safety track, and more. When fully charged, each of its transmitters can accompany you for 4 hours.
This duo is indeed an ideal pic for conversational live streaming, travel vlogging, street interviews, and other digital creations.
Pros
- All-match versatility
- Exceptional battery
- Multiple working modes
- Noise buffer design
- Compact design
Cons
- It might be a pricier investment for beginners.
Although, when beginning, you look for budget-friendly equipment, Hollyland Lark-150 is an investment that is worth every penny. You won’t regret a second paying for it.
Quantitative Measurements
Durability: 9.5/10
Design: 9/10
Uniqueness: 9.5/10
Ease of Use: 9.5/10
2. Rockville RWM1201VH VHF Wireless Dual HandHeld Microphone Mic System
Next comes the masterpiece from Rockville, the RWM1202VH! It’s a high-performance, the best dual wireless microphone system with high sensitivity, durable composition, and dual filter design. It comes with multiple frequency groups; you can get one according to your requirements.
Its system has an operating range of 100´-200´ (indoor), 65´-165′ (outdoor), a VHF modulation model, and a dynamic range of 110dB. Whereas the transmitter comes with frequency stability of ±0.005% and RF Output Power of 30mW.
Its comfortable ergonomic design makes it the best fit if you want to limit feedback and interference. Moreover, its transmitter is capable of automatically connecting with the receiver. Isn’t it interesting?
Pros
- Smart and durable construction
- Easy to setup
- Automatic linking
- Compact and easily portable design
- Comes with a 1-year warranty
Cons
- Some users have reported facing interference issues.
However, this issue isn’t common, so you can rely on Rockvile’s ultimate creation for your recordings and streamings.
- Durability: 9/10
- Design: 9/10
- Uniqueness: 9.5/10
- Ease of Use: 9.5/10
3. Rode Wireless GO II – Dual Channel Wireless Microphone System
According to Rode, its Wireless GO II is the world’s smallest and best dual wireless microphone system. Its extremely versatile and ultra-compatible design offers ultimate functionality with groundbreaking and patent-pending technology.
It offers 3.5mm TRS analog output along with universal compatibility. You can connect it to any device you want, whether a computer, mobile or anything else. Other impressive features of it include 128-bit encryption – crystal-clear audio at up to 200m (line of sight), an In-built rechargeable lithium-ion battery, and onboard recording.
If you are a professional vlogger, blogger, or singer or are somehow linked with professional-level recording and live performances, you must try this best dual wireless Lavalier microphone system.
Pros
- Unmatched Versatility
- Ultra-Compact Wireless Audio
- Seamless Connectivity
- Go to User Guide
- 7 hours battery life
Cons
- RODE Central and RODE Connect, the two smart apps offered by the company, are not ultra-compatible. Still, you can make the most of your user experience with this microphone system.
Durability: 9.5/10
Design: 8.5/10
Uniqueness: 9/10
Ease of Use: 8.5/10
4. Sennheiser XSW 1-825
If you are looking for a sleek design best dual wireless microphone system, we suggest getting your hands on the Sennheiser XSW 1-825. It’s a budget-friendly choice for beginners out there. The package includes a single receiver, eight 10-channel compartments, and vibrant-colored indicators.
It comes with a battery life of ten hours, an operating range of around 250ft, and minimal weight. Moreover, it supports one-button scanning, integrated antennas, and 825 cardioid capsules. It’s not only great to use for singers but also for presenters and dancers. You also get hands free feature with it that proves way helpful when you are multitasking.
Pros
- Exceptionally interactive receiver
- Stress-free handling
- Convenient to use
- Great companion for camping trips or open-air events
Cons
With all its impressive pros, XSW 1-825 has only one flaw. Its range is not what one should expect from a microphone system falling in this price range.
Durability: 9/10
Design: 8/10
Uniqueness: 8.5/10
Ease of Use: 9/10
5. Tonor Wireless Microphone
Next on our list of the best dual wireless Lavalier microphone system is the Tonor Wireless Microphone. Its dual-antenna design, cardioid polar pattern, and some other worthwhile features make it a list of our top picks.
Tonor dual microphone system features innovative built-in digital de-coding technology. Its durability and sophistication lie in its sleek matte black finish and sophisticated design. Additionally, it’s easy to set up and work with. All you have to do is to insert the batteries, set it up, and begin recording or performing.
Other notable features of it include its capability to detect the frequency of both microphones. This feature minimizes the signal loss to almost negligible, and that excellent sound quality can’t also go unnoticed. In short, it’s the best buddy for lecturers, performers, and more. You can get maximum voice output with it when used in open-air or small, medium-sized venues.
Pros
- Optimal range of 200 feet
- The best budget-friendly choice on our list
- Comes with plug and play feature
- Works best in open space; hence ideal for performances
Cons
Everything is great except for the battery life, which must be upgraded. Still, it’s not that much less to tempt one to skip getting this dual microphone system.
Durability: 8.5/10
Design: 8.5/10
Uniqueness: 8/10
Ease of Use: 8/10
A Comprehension Comparison of Our Top Picks
Although all of your top picks have some features that make them a unique choice, if you are looking for the best dual wireless microphone system, it would be Hollyland Lark-150. Do check out Hollyland Lark M1. It’s exceptional in performance and works best for almost everyone with its optimal features and reasonable price.
However, if portability is your concern, we suggest using Sennheiser XSW 1-825. Additionally, if you are looking for a budget-friendly buddy, go with Tonor Wireless Microphone.
Wrap Up!
Dual wireless microphone systems come in handy for a plethora of purposes. For whatever purpose you need, our top picks will surely be the best for you. You can blindly rely on any of these.
Hope you find this info helpful; stay tuned for more such comprehensive review articles. Do let me know about your choice of the best dual wireless microphone system in the comment section below.
What does a Dual Microphone do?
Dual wireless microphones utilize digital signal processing technology. These create a noise-canceling or directional microphone using the two omnidirectional microphones.
What is a Dual vs. Single Channel Wireless Microphone?
Dual-channel wireless microphones let you use two at a time; that’s impossible with the single-channel wireless microphone.
Can you Use 2 Wireless Microphones at Once?
Yes, dual wireless microphone systems make it possible to use two microphone systems at once. It has offered ultimate convenience for sure.
