Finding an excellent GoPro wireless microphone can bring more views to your shots and multiply the fun of recording. But since so many brands are there, and each has its own claim of uniqueness, it takes time to choose one. Then comes the budget, which has a big wow factor when getting a wireless mic.
This article intends to provide details for the 6 best wireless GoPro mics. You will explore the features, specs, and uses of all the mentioned microphones. Besides, there’s a brief guide for picking the correct mic for all GoPro camera models. And finally, the comparison chart to help you quickly decide on the best GoPro wireless microphone.
So let’s get started.
How to Choose a GroPro Wireless Microphone?
When selecting the best external mic for GoPro, make sure you have knowledge about the following factors.
a. Quality
Your GoPro wireless microphone must deliver high-quality sound. So when choosing a mic, make sure it covers a wide frequency range. Also, it’s a plus point if it comes with a shock mount.
b. Ease of Use
Choose a mic that is easily controllable. If you are a new user and unknown to technicalities and controls, selecting a microphone with straightforward options like Hollyland Lark M1 is wise.
c. Connectivity
This is the tricky factor. Remember that GoPro Hero 3, Hero 3+, and Hero 4 require a USB connector. Whereas GoPro Hero 5 and later models need a 3.5mm TRS jack and cable to attach a microphone. Therefore, pick a mic that suits your GoPro connectivity port.
d. Microphone Type
A clip-on mic serves to be the best microphone for GoPro. Since it record sounds wirelessly, you can attach the receiver to your GoPro camera and freely roam around to record sound. On the other hand, if you don’t record long-distance shots, then a shotgun microphone can also be a suitable type.
e. Polar Pattern
Although there are numerous polar patterns of mics, you should select an omnidirectional GoPro wireless microphone as it captures excellent quality audio. The second option is going for a supercardioid mic to record clear sounds from the front side only.
Top 6 GoPro Wireless Microphone Models
Here’s the section you have been waiting for. Get ready to explore the five great GoPro wireless microphone brands.
1. Hollyland Lark M1 – The Most Suitable GoPro Wireless Microphone
If you are looking for a lightweight and aesthetically beautiful wireless microphone for GoPro, nothing beats the Hollyland Lark M1. This mic is available with a single and double receiver backed by a powerful transmitter. It is designed specifically to provide a great user experience when connected to your GoPro.
Hollyland Lark M1 packs transmitters and receivers in a solid-body case that works as your charging unit. So say the last prayers to the charging cables because you don’t need them anymore when you have M1. The receiver gets connected to your GoPro through a 3.5mm jack. And with just a push of a button, the receiver gets paired with the transmitter.
Features and Specifications of Hollyland Lark M1
Hollyland Lark M1 have interesting features and specs, making it an ideal GoPro wireless microphone.
- 110dB SPL
- 3.5mm jack for GoPro connectivity
- 650-feet wireless range
- Omnidirectional mic pattern
- 48kHz maximum frequency response
- 2.4Ghz transmitting power
- Noise reduction button
- 8-hour operational time
Pros of Hollyland Lark M1
These are awesome advantages of Hollyland Lark M1 which makes it the best mic for GoPro.
- Top-notch product at an inexpensive price
- Lightweight wireless GoPro mic (11.8g)
- Avoid recording unwanted sounds
- 1.5 hours charging time
- Easy connectivity to GoPro with a 3.5mm jack
- Compatibility with other devices via USB Type C
Cons of Hollyland Lark M1
The Hollyland Lark M1 has no disadvantages when connecting with the GoPro camera. According to the users, Lark M1 is the best GoPro wireless microphone that works smoothly with all GoPro models. There’s negligible sound latency with no sound dropouts.
Quantitative Measurement of Hollyland Lark M1
- Design: 9/10
- Durability: 8/10
- Build quality: 9/10
- Unique features: 9/10
$149.00
2. Hollyland Lark Max
The Hollyland Lark Max is another pick for your GoPro. It is an excellent wireless microphone system that goes with all major GoPro models and other devices, including phones, tablets, computers, and mirrorless cameras. Customized to fulfill the needs of passionate content creators, the Lark Max wireless mic kit provides a series of valuable features to help you overcome several recording challenges with your GoPro device.
One of the biggest boons of Hollyland Lark Max is the inclusion of MaxTimbre Mic technology to ensure you get studio-grade audio no matter what. Besides, this wireless microphone system comes with an Environmental Noise Cancellation (ENC) characteristic to make sure your GoPro recordings have clean audio over a distance of up to 820ft.
The Hollyland Lark Max also comes with an 8GB storage capacity with audio backup of up to 14 hours to help you record audio without a camera or other video devices. However, the most stand-out feature of Lark Max is its water-resistant case that surely adds portability and durability. So, the next time you’re out with your GoPro to record adventures, you don’t have to bother about the wet terrains and rainy season. You can travel, explore, and enjoy the journey without worrying about your mics being raptured by rain as long as they are inside the case.
Features and Specifications of Hollyland Lark Max
The Hollyland Lark Max offers a lot of great features, including:
- Magnetic attachment
- 70 dB Signal-to-Noise Ratio
- Less than 2 hours of charging time
- AFH technology for stable transmission
- 820ft (line-of-sight) wireless video transmission
- 7.5 hours of battery time, extendable up to 22 hours
Pros of Hollyland Lark Max
Some notable advantages of Hollyland Lark Max are:
- Superior sound quality
- It has an extended battery life
- Available for 1-person and 2-person
- The kit comes with advanced noise-canceling technology
- Integrated background noise filtering even without activating the noise-canceling option
- Clear and clean connectivity to GoPro and other devices through lightning port, USB-C, and 3.5mm audio jack
Cons of Hollyland Lark Max
A few points that users don’t appreciate about Hollyland Lark Max are:
- Some issues with the transmission in dense and hilly areas
Quantitative Measurement of Hollyland Lark Max
- Design: 8/10
- Durability: 8/10
$179.00 (Price for 1-person version)
3. RODE VideoMicro II
RODE VideoMicro II is one of the best microphones for GoPro that records professional-quality sounds. It is an ultra-compact, easy-to-use, and lightweight wireless microphone ideal for content creation and adventurous filmmaking. It is a battery-less mic, so all you need to do is plug it into your GoPro and start recording.
The VideoMicro II is factory-tuned to capture crystal-clear audio without letting you beat complicated controls, making it a perfect GoPro wireless microphone. It is an impressive and highly directional mic that picks up sound from the front while reducing the back and side noises.
Features and Specifications of RODE VideoMicro II
RODE VideoMicro II consist of the following characteristics:
- 79dB SPL
- 3.5mm TRS connectivity for GoPro
- -39dBV audio sensitivity
- 20hZ to 20kHZ frequency response
- Supercardioid polar pattern
- Shotgun microphone
Pros of RODE VideoMicro II
These are the advantages of using RODE VideoMicro II.
- Simple to use
- Lightweight mic (just 39 grams)
- Great audio quality both outdoors and indoors
- Does not require controls and batteries
Cons of RODE VideoMicro II
Here’s one disadvantage of using RODE VideoMicro II:
- There is no USB Type C output
Quantitative Measurement of RODE VideoMicro II
- Design: 7/10
- Durability: 7/10
- Build quality: 7/10
- Unique features: 7/10
$79.00
4. Sennheiser MKE 200
Sennheiser MKE 200, compared to the company’s previous shotgun microphones, is quite impressive. It is a lightweight, sturdy mic covered in black aluminum build. The fact that it sports a built-in shock mount makes it a good GoPro wireless camera, especially if you are into vlogging.
Sennheiser MKE 200 is simple to attach to your GoPro through a TRS 3.5mm coiled cable. So don’t get confused because the package comes with two TRS to TRS and TRSS cables. One for your GoPro and another for your smartphone. Although MKE 200 is not a perfect mic, it is still a good plug-and-go option.
Features and Specifications of Sennheiser MKE 200
Some best qualities of the Sennheiser MKE 200, which makes it the best GoPro microphone, are:
- 120dB SPL
- -33dBV mic sensitivity
- 40Hz to 20kHz frequency range
- Pressure gradient functioning
Pros of Sennheiser MKE 200
Sennheiser MKE 200 is ideal for GoPro users because of the following factors:
- Highly affordable
- 48-gram weight
- Battery-free operation
- Built-in wind protection
- Directional pickup
- Ultracompact body
Cons of Sennheiser MKE 200
Here are a few reasons why Sennheiser MKE 200 may not satisfy you.
- Only good for medium or close range
- The products lack a light indicator
Quantitative Measurement of Sennheiser MKE 200
- Design: 6/10
- Durability: 7/10
- Unique features: 6/10
$78.99
5. RODE VideoMic Pro
VideoMic Pro is another kid on the block by RODE. It is a professional-grade GoPro wireless microphone that delivers impeccable audio quality. The mic comes with a permanently attached 3.5mm TRS cable for quick connectivity with your GoPro Hero 5 and later versions.
Unlike other GoPro cameras by RODE, the VideoMic Pro runs up to 70 hours on a single 9V battery. A dedicated LED changes to red, indicating battery replacement, but the mic stays functional for 10 hours. Moreover, this mic has a built-in shock mount that prevents camera vibrations from being transferred into the audio.
Features and Specifications of RODE VideoMic Pro
Let’s dig into a few more features of RODE VideoMic Pro.
- 134dB SPL
- -32.0dBV microphone sensitivity
- Supercardioid polar pattern microphone
- Shotgun condenser mic
- Line gradient acoustic principle
- 3-stage gain control
- High-pass filter
- Rycote Lyre shock mounting
Pros of RODE VideoMic Pro
The RODE VideoMic Pro has the following benefits:
- Easy usability
- Windshield included for outdoor recording
Cons of RODE VideoMic Pro
Here are a few factors that go against RODE VideoMic Pro:
- Expensive
- Weak windshield
- Fragile manufacturing
- 89-gram weight (lightweight but heavier than RODE VideoMicro II)
- Design: 7/10
- Durability: 6/10
- Build quality: 6/10
$229.00
6. Removu RM – M1+A1
Removu RM – M1+A1 is GoPro wireless microphone made for Hero 4, Hero 3, and Hero 3+. It has one receiver and transmitter (mic) that records good-quality audio. The device is powered by Bluetooth, making a strong pair between the receiver and the mic. This enables you to record sounds even if you’re 33 feet away from the camera.
Removu RM – M1+A1 includes a water housing manufactured with specialized material that makes your mic waterproof. The package includes a GoPro mount, M1 (mic) clip mount, and a USB charging cable.
Features and Specifications of Removu RM – M1+A1
Removu RM – M1+A1 possess the following traits:
- Bluetooth microphone
- Bluetooth GoPro audio pack
- Compatible with other 3.0 Bluetooth camera devices
- Omnidirectional polar pattern
- 6-hours operating time
Pros of Removu RM – M1+A1
Removu RM – M1+A1 has the following benefits:
- Good for indoor and outdoor sound recording
- Exceptional performance under windy weather
Cons of Removu RM – M1+A1
Here’s what users don’t appreciate about Removu RM – M1+A1:
- Bulky design
- It cannot be connected with Hero 5 or later models
- USB to TRS connector does not work most of the time
- It is a heavy microphone weighing around 143 grams
- Design: 5/10
- Durability: 6/10
$77.66
Comparison Table – GoPro Wireless Microphone
Product | Polar Pattern | Mic Type | Battery Time | GoPro Compatibility | Price |
Hollyland Lark M1 | Omnidirectional | Lavalier/Clip-on | 8-hour | Hero 5 and newer models | $149.00 |
Hollyland Lark Max | Omnidirectional | Lavalier/Clip-on | 7.5-hour | Hero 5 and newer models | $179.00 |
RODE VideoMicro II | Supercardioid | Shotgun | No battery required | Hero 5 and newer models. Requires additional TRS to USB connector for older GoPro models. | $79.00 |
Sennheiser MKE 200 | Supercardioid | Shotgun | No battery required | Hero 3,3+, and 4 | $78.99 |
RODE VideoMic Pro | Supercardioid | Shotgun | 70-hour with 9V battery | Hero 5 and newer models | $229.00 |
Removu RM – M1+A1 | Omnidirectional | Lavalier/Clip-on | 6-hour | Hero 3,3+, and 4 | $77.66 |
Not only the price but several factors, like audio quality, frequency, wireless range, and polar pattern, make a great GoPro wireless microphone. From this point of view, the Hollyland Lark M1 is a clear winner.
Hollyland Lark M1 and Lark Max qualify as the best wireless GoPro microphones because of their useful, outstanding clip-on style, omnidirectional sound pick-up, and compatibility. However, Lark Max is the second most expensive microphone for GoPro in this list after RODE VideoMicPro. On the other hand, if you are on a super-tight budget and willing to compromise on the features, then RODE VideoMicro II and Sennheiser MKE 200 are two affordable options.
FAQs – GoPro Wireless Microphone
Q1. Does GoPro have a good built-in mic?
The built-in GoPro mic records good-quality sound. Nevertheless, for professional, clean, and crisp audio recording, you are required to use an external GoPro wireless microphone.
Q2. Can GoPro connect to a wireless microphone?
All GoPro camera models, from Hero 4 to Hero 11, support wireless microphones. But you need a Pro Mic Adapter or Media Mod to use an external wireless mic with HERO 8,9.10, and 11.
Q3. Which company wireless mic is best for GoPro?
Hollyland Lark M1, RODE VideoMicro II, and Sennheiser MKE 200 are the best budget wireless GoPro microphones.
