The right and reliable microphone can stand out when producing high-quality, transparent, and crisp audio. As podcasting has gained popularity over the last few years, audio quality is essential for a high-quality podcast. So, whether you are looking for an upgrade or just starting as a podcaster, choosing the right microphone can significantly impact your audio quality.
Although your iPhone can record quality podcast audio, you need an external microphone. The podcast microphone you choose can make a difference in achieving high-quality sound. So, for unique benefits, explore the best podcast microphone for iPhone that will take podcasting to another level.
Key Factors to Check for in the Best Podcast Microphone for iPhone
The success of your podcast depends on the high-quality audio. Although the quality of content matters, the most crucial factor attached to the listeners is the quality of your audio. With so many podcast microphones for iPhone, the key factors hereunder will help you choose the podcast microphone for your needs.
Sensitivity
High-sensitive microphones can pick up background noises, and podcasting becomes difficult. Low-sensitive microphones only focus on your voice, rejecting background noises and obstructions, making it an ideal choice for podcasting.
Sound Customization
Digital microphones have advanced technology that brings clarity to duller voices and produces smoothness in audio quality. With digital microphones, you can shape your frequencies and bring smoothness to speech variations.
Frequency Responses
It’s the most crucial factor that determines the range of their pickup. The desirable podcast microphones have more extensive frequency ranges and are equipped with rubber isolation mounts that suppress the noises and produce clear and crisp sound.
Microphone Directionality
It depends on your specific needs. Cardioid microphones focus on the front and omnidirectional sound pickup from all directions, which is best for group podcasts. So, directionality is an individual but crucial factor affecting overall audio quality.
The Best Podcast Microphone for iPhone | Top 6 Pickups
An iPhone microphone can record excellent basic audio, but you need a podcast microphone for exceptional audio quality. There are several versatile microphones, and choosing the best can sometimes become complicated, so we have enlisted the best podcast microphones. So, whichever microphone you select is best to suffice your specific needs.
- Shure MV 88
- Zoom IQ 7
- Rode VideoMic Me-L
- Hollyland Lark M1
- Movo VXR10
- Comica Audio CVM-WS50
Shure MV 88
https://www.shure.com/en-US/products/microphones/mv88?variant=MV88%2FA
The Shure MV 88 is an excellent choice for iPhone podcasting that brings flexibility and reliability while recording. This flexibility comes with a 90⁰ microphone adjustment that will bring clarity to sound regardless of the sound source. You can easily switch between left-right orientation, making it perfect for cardioid and bidirectional podcasting.
Moreover, it provided crisp and high-quality audio of 24-bit/48kHz, essential for podcasts. In addition, you can adjust the 5 EQ bands manually, and you can also change the stereo width, which will capture the specific sound area. It will reduce the impact of noises and will focus on your voice.
- Sleek and comfortable design
- App customization
- Apple MFi-certified podcast microphone
- Excellent sound quality
- It would help if you had an extra wire for a better range
- It can only work when the phone is in flight mode
And the windscreens provide superior sound quality, bringing smoothness and quality to the audio. The Shure MV does not require batteries but produces high-quality audio. The detachable lightning connector makes it the best podcast microphone for iPhone because of its compatibility with all Apple devices.
Quantitative Measurement
- Durability: 9.5/10
- Materials: 9/10
- Design: 9.5/10
- Uniqueness: 9.5/10
Zoom IQ 7
https://zoomcorp.com/en/us/mobile-audio-recorders/ios-microphones/iq7/
If you want to capture and record high-quality audio and video, then Zoom IQ is an intelligent choice with superior stereo. With MIC GAIN, you can easily control the noise levels reducing the background noises, and LED indicators ensure clear and crisp sound.
And the rotating design of IQ7 makes it an ideal choice for recording audio and video in either horizontal or vertical directions. You can register in three ways, 90⁰ which will focus on the center, 120⁰ more comprehensive width range, and MS, which will record the raw audio for afterward adjustment.
- Wider noise pickup
- Convenient and easy to use
- Direct monitor with a headphone jack
- Works only with lightning port
Besides this, it provides high-quality audio 16-bit/48KHz. And with the headphone jack, you can monitor the sound’s real-time quality, which makes it beneficial during editing. And it comes with a mini-tripod which has made podcasting an easy thing to do. The cardioid microphone is easily plugin into the lightning port and records superior quality sound.
- Materials: 9/10
- Design: 9/10
Rode VideoMic Me-L
https://rode.com/en/microphones/mobile/videomic-me-l
Although inexpensive, it’s worth buying a podcast microphone because of its excellent sound quality and broader compatibility. With a 3.5mm jack, you can plug in VideoMic to other devices for real-time audio monitoring. The microphone’s directionality will remove the background noises. And it produces high-quality audio with microphone 1/2″ condenser capsules.
By this, it focuses only on one voice with a frequency range of 20Hz to 20 KHz and provides exceptional and intelligent sound. For seamless podcasting, it’s essential to use it with built-in apps or with a Rode app that will enhance its functionality. With this, it has become the budget-friendly best podcast microphone for iPhone.
- Lightweight and sleek design
- Good sound quality
- Greater frequency range
- Handling noises may pass on to the microphone
- It cannot fix properly with the case
With the cardioid polar pattern, it focuses on the source at 180 degrees, and the furry windshield minimizes the effect of surrounding noises. In addition, with a tripod mount, it can easily set up and produce high-quality sound.
- Durability: 8.5/10
- Materials: 9/10
- Design: 8/10
Hollyland Lark M1
The Hollyland Lark M1 is outstanding with its omnidirectional quality and delivers high-detailed, crisp sound. Its 2.4 GHz of Hoping Technology can provide high-quality sound up to 656 feet away, and Bat Obstacle avoidance technology removes any hindrance or interference. And with built-in voice identification, it can auto-adjust the volume settings.
In addition, the HearClear noise cancellation feature filters out surrounding noises and delivers smooth and natural audio. And it’s an excellent choice for the best podcast microphone for iPhone because it weighs only 11.8 grams and can be fitted with your collar.
And you can enjoy 20 hours of uninterrupted and high-quality podcasting with Lark M1. It can recharge in 1.5 hours, along with the charging case with a USB-C port. And LED flash will let you know about the charging status.
- Three-level volume preset
- HiFi sound quality with rich details
- Super crisp sound
- Greater podcast quality
- Overtime, the case becomes the problem
Furthermore, the cutting-edge design and LC3 Codec technology provide a sampling rate of 48 KHz/16bit. With its plug-and-play design, the receiver and transmitters will automatically pair, and the windscreens eliminate any hindrance. The transmitters can easily clip on your shirt, providing a smooth sound and removing your breathing voices.
- Materials: 9/10
- Design: 8.5/10
- Uniqueness: 8/10
Movo VXR10
https://www.movophoto.com/products/vxr10-universal-cardioid-condenser-mic
The universality of Movo VXR makes it an ideal podcast microphone because of its ability to capture high-quality sound. The cardioid polar pattern makes it the best podcast microphone for iPhone and focuses on what is in front of the microphone. This cardioid provides a highly accurate, super crisp sound.
Moreover, the aluminum design enhances its durability and also minimizes handling noises. It has an exceptional signal-to-noise ratio of 76 dB, enabling it to pick up the desired voice more efficiently. And higher-frequency responses of 35 Hz to 18 KHz capture clear and smooth sound.
- The pickup sounds with wider dimensions
- Supercardioid polar pattern
- Easy to set up and carry
- Small and budget-friendly
- It’s tricky to fit the furry windscreen
- Limited functionality due to lack of battery
With a sturdy shock mount and dead cat windscreen, it clarifies the distorted voice and removes the background noises. It will make an ideal choice for podcasting without the surrounding environment. There is no internal battery, so it will attach to your iPhone lightning connector and can record as long as you want.
- Durability: 8/10
- Materials: 8.5/10
- Design: 8/10
- Uniqueness: 8/10
https://www.comica-audio.com/product/CVM-WS50-22.html
This wireless Lavalier microphone is the best podcast microphone for iPhone that comes with a flexible six channels. In case of any hindrance, you can easily switch between the channels to make your recording seamless. This feature is enormously endorsed by podcasters and vloggers looking for a clear, crisp, and smooth sound.
And the LCD screen will show the channels and audio status and can also be used for real-time monitoring. With this, you can monitor the audio quality while recording to ensure the voice is clear and distortion-free.
- Cordless podcasting
- Long range
- Wider frequency
- Smooth and natural sound
- Airplane mode is necessary to remove static noises
Moreover, Comica Audio uses an Ultra High-Frequency range of 520-526 MHz and can pick up sound clear and high-detailed audio from up to 60 meters. And with its omnidirectional behavior, it picks up noises from every direction by just focusing on the voice source.
The receiver, with its high sensitivity, receives and stores quality audio. And you can podcast for extended periods with its polymer lithium-ion batteries that provide 8 hours of uninterrupted podcasting. Also, you can adjust the volume according to your demands.
- Durability: 8/10
- Materials: 7.5/10
- Design: 9/10
- Uniqueness: 7.5/10
Your podcast’s success depends entirely on the quality of the microphone. The microphone will make you stand out whether you are just starting or a pro in this field. This post has covered the best podcast microphone for iPhone, but choosing the best microphone depends on critical factors and individual needs. These podcast microphones will help you perform your podcast without the surrounding influence.
So, selecting the best podcast microphone is a creative choice that will add value to your podcast and carry your voice to remote areas.
Can I use an iPhone microphone for podcasts?
Iphone phones have built-in apps that can start recording podcasts whenever you want. But to bring clarity and smoothness to the sound, it is recommended to use a podcast microphone that can remove background noises and give you clear and crisp sound.
How should I use iPhone as a USB microphone?
With a USB cable or lightning connector, iPhone is used as an external microphone to record better-quality sound. The phone’s built-in apps, like GarageBand, can also make you use a USB microphone.
How can I use wireless microphones for podcasting on my iPhone?
The wireless microphones can connect with iPhones via Bluetooth or a TRRS cable. There are many wireless microphones, but Hollyland Lark M1 is leading with its ability to capture high-quality sounds and remove background noises.
