As the demand for remote work continues to grow, a high-quality USB microphone has become a must-have accessory for voice-over artists, podcasters, and anyone involved in video conferencing. In 2023, the selection of USB microphones is larger than ever, each with its own unique features and selling points. From Blue Yeti’s versatility to the Rode NT-USB’s professional-grade sound, there’s a microphone out there for everyone. In this article, we’ll take a look at the 11 best USB microphones on the market and dive into what makes each one stand out from the rest. Whether you’re a professional or just starting, there’s a microphone that’s perfect for you!
Criteria for Choosing a USB Microphone
When choosing the best microphone for voiceover in 2023, there are several criteria to consider. Some significant of which are as follows:
- Compatibility: Make sure the microphone you choose is compatible with your recording device. Check the technical specifications and ensure that the microphone uses a USB port that your device has, and that it is compatible with your operating system.
- Battery life: If you plan on recording for extended periods of time, it’s crucial to choose a microphone with a long battery life. Look for models with rechargeable batteries that can last for several hours on a single charge.
- Range: The range of a microphone refers to the distance from which it can pick up sound. For voiceover work, you want to ensure that the microphone can pick up your voice clearly from a reasonable distance. Look for models with a range of at least 6-10 feet.
- Frequency response: Frequency response is a measure of the range of frequencies that the microphone can accurately capture. For voiceover work, you want a microphone that can capture the full range of your voice, from low to high frequencies. Look for models with a frequency response range of at least 20Hz to 20kHz.
- Type of microphone: There are two main types of microphones to consider for voiceover work: dynamic and condenser. Dynamic microphones are more rugged and can handle high sound pressure levels, making them ideal for recording loud vocals. Condenser microphones are more sensitive and provide a more detailed and accurate sound. For voiceover work, condenser microphones are generally the preferred choice.
- Polar pattern: The polar pattern of a microphone refers to the direction from which it can pick up sound. For voiceover work, a cardioid polar pattern is generally preferred, as it picks up sound primarily from the front of the microphone while minimizing background noise from the sides and rear. However, an omnidirectional polar pattern may be better suited for recording group dialogue or ambient sound.
Blue Yeti X
The Blue Yeti X is a top-notch microphone perfect for voiceovers, podcasts, and YouTube videos. This USB microphone is a popular choice among at-home recording enthusiasts, offering impressive sound quality and performance at an affordable price.
The Blue Yeti X is a desktop USB microphone with beefier components than its competitors, making it a favorite among the recording crowd. It is ideal for capturing crisp, clear audio outside of a dedicated studio, making it sound like you’re in a professional setting even when you’re just sitting at your desk. The Blue Yeti X is owned by Logitech, and you can use the Logitech G Hub app to access an equalizer and custom voice effects, including “Broadcast” and “Podcast Voice” presets.
Specification | Blue Yeti X |
Brand | Logitech |
Price | $169.99 (currently on sale for $139.99) |
Weight | Not specified |
Polar Pattern | Four different condenser capsules |
Connector Type | USB |
Audio Resolution | 24-bit/192kHz3 |
Additional Features | Customizable multicolour LED level meter |
- High-quality sound and performance
- Easy to set up and use
- Customizable voice effects and equalizer through Logitech G Hub app
- Suitable for various applications, including voiceovers, podcasts, and video content
- May not be the best choice for professional voice actors seeking high-end equipment
Audio-Technica AT4053B
If you’re looking for a microphone that can capture clear and detailed sound for your voiceover work, the Audio-Technica AT4053B is a top-notch choice. With its hypercardioid polar pattern, high SPL handling, and switchable high-pass filter, this microphone is designed to deliver exceptional performance and quality even in noisy environments.
Plus, its rugged design and included accessories make it easy to transport and use on-the-go. Whether you’re a professional voiceover artist or just starting out, the AT4053B is a microphone that’s definitely worth considering for its outstanding value and versatility.
Specification | Audio-Technica AT4053B |
Brand | Audio-Technica |
Price | Approximately $600 USD |
Polar Pattern | Hyper cardioid |
Connector Type | XLR |
Frequency Response | 20 Hz to 20 kHz1 |
Maximum SPL | 145 dB |
Additional Features | Switchable 80 Hz hi-pass filter, 10 dB pad |
- Suitable for various recording applications
- Rugged turned-brass microphone housing for durability
- Transformerless circuitry for low-frequency distortion elimination
- Sensitive to vibrations, requiring high-end shock mounts for boom use
- May sound muddy when used up-close
The Audio-Technica AT4053B has received positive reviews for its professional sound quality and versatility in different recording environments. This microphone is a reliable choice for those seeking a high-quality hypercardioid condenser microphone for studio and live sound applications.
Rode NT-USB Mini
The Rode NT-USB Mini is a compact yet powerful microphone that is perfect for anyone looking to upgrade their audio quality. With its high-quality condenser capsule and directional cardioid pickup pattern, it captures crystal clear vocals and instruments with ease. Its built-in pop filter and internal shock mount reduce unwanted noise and vibrations, while the adjustable stand allows for flexible positioning.
Plus, the NT-USB Mini is plug-and-play compatible with both Windows and Mac, making it an ideal choice for podcasters, gamers, streamers, and musicians alike. Whether you’re recording your latest podcast episode or laying down some tracks in your home studio, the Rode NT-USB Mini is the perfect microphone for capturing your sound.
Specification | Rode NT-USB Mini |
Brand | Rode |
Price | $99 |
Polar Pattern | Cardioid |
Audio Resolution | 24-bit/48kHz |
Additional Features | Built-in pop filter, headphone output |
- Compact and portable design
- May not have the studio-like quality of more expensive microphones
- Lacks some features found in higher-end models
The Rode NT-USB Mini has received positive reviews for its sound quality, ease of use, and affordability. It is an excellent choice for those just starting out in podcasting, streaming, or voiceover work, offering a balance of quality, performance, and value.
Shure MV7
The Shure MV7 is a versatile microphone that packs a punch in terms of both sound quality and functionality. With its dynamic microphone capsule and adjustable polar patterns, it can handle a wide range of recording applications, from podcasting and broadcasting to vocal and instrument recording. Its built-in headphone jack and touch panel controls make it easy to monitor your sound and adjust settings on the fly, while the included desktop stand and boom arm allow for flexible positioning.
The MV7 also features USB and XLR outputs, giving you the option to connect to a variety of devices, and it’s compatible with Shure’s Motiv app, which offers additional features like EQ and compression. Whether you’re a seasoned pro or just starting out, the Shure MV7 is a top-of-the-line microphone that delivers outstanding performance and versatility.
Specification | Shure MV7 |
Brand | Shure |
Price | $249 |
Polar Pattern | Unidirectional |
Connector Type | USB and XLR |
Additional Features | Voice Isolation Technology, 3.5mm headphone jack, built-in touch panel |
- Dual USB and XLR outputs for versatile connectivity
- Voice Isolation Technology for focused audio capture
- Integration with ShurePlus MOTIV apps for customization
- Pricier than some competitors
- May require additional accessories for optimal performance
The Shure MV7 has received positive reviews for its professional sound quality, ease of use, and versatility in various recording environments. This microphone is a reliable choice for those seeking a high-quality dynamic microphone for podcasting, voiceovers, and other close mic applications.
Samson G-Track Pro
The Samson G-Track Pro is a feature-packed microphone that’s perfect for musicians, podcasters, and streamers. With its dual 1″ condenser capsules and three selectable polar patterns (cardioid, bidirectional, and omnidirectional), it delivers pristine audio quality in any recording situation. The built-in audio interface allows for direct connection to your computer or mobile device, and the included desktop stand and shock mount ensure stable and vibration-free recording.
The G-Track Pro also features a headphone output with independent level control, so you can monitor your sound with zero latency. Additionally, it comes bundled with Samson’s Studio One recording software, giving you everything you need to start recording and producing professional-quality audio. If you’re looking for a high-performance microphone that can handle any recording task, the Samson G-Track Pro is an excellent choice.
Specification | Samson G-Track Pro |
Brand | Samson |
Price | $98 (Available on Amazon) |
Polar Pattern | Multiple polar patterns |
Additional Features | Built-in mixer, instrument input, headphone output |
- Ability to record voice and instrument simultaneously
- Built-in USB audio interface for versatile connectivity
- Multiple polar patterns for tailored recording situations
The Samson G-Track Pro has received positive reviews for its sound quality, ease of use, and versatility in various recording environments. It is an excellent choice for those seeking a high-quality USB microphone with an audio interface for recording voice and instruments at the same time.
AKG Pro Audio Lyra
The AKG Pro Audio Lyra is a cutting-edge microphone that delivers exceptional audio quality and versatility. Its advanced four-capsule array captures rich, detailed sound with outstanding clarity, while the selectable polar patterns (front, front and back, and stereo) allow you to adapt to any recording situation. The Lyra also features built-in headphone monitoring with zero-latency processing, making it easy to monitor your sound in real-time. Its sleek, retro-inspired design features intuitive controls and an integrated desktop stand, making it a breeze to set up and use.
The Lyra is compatible with both Mac and Windows, and comes bundled with AKG’s Studio-Quality Audio Interface, giving you everything you need to start recording professional-quality audio right out of the box. Whether you’re a podcaster, musician, or content creator, the AKG Pro Audio Lyra is a top-of-the-line microphone that will help take your recordings to the next level.
Specification | AKG Pro Audio Lyra |
Brand | AKG |
Price | $149 |
Audio Resolution | 24-bit/192kHz |
Additional Features | Built-in shock mount, internal diffusion |
- Stylish vintage design
The AKG Pro Audio Lyra has received positive reviews for its sound quality, ease of use, and versatility in various recording environments. It is an excellent choice for those seeking a high-quality USB microphone with multiple polar patterns for podcasting, streaming, and voiceovers
HyperX QuadCast S
The HyperX QuadCast S is a powerful and stylish microphone that’s perfect for streamers, podcasters, and content creators. Its dynamic RGB lighting and customizable effects make it a standout addition to any setup, while its advanced four-capsule condenser array captures exceptional audio quality with four selectable polar patterns (stereo, omnidirectional, cardioid, and bidirectional).
The built-in shock mount and pop filter help reduce unwanted noise and vibrations, while the included desktop stand and threaded mount make it easy to position for optimal recording. The QuadCast S also features a tap-to-mute sensor and a convenient headphone jack with independent volume control, so you can monitor your sound with zero latency. Whether you’re streaming your latest gaming session or recording your next podcast, the HyperX QuadCast S is a high-performance microphone that delivers outstanding sound quality and versatility.
Specification | HyperX QuadCast S |
Brand | HyperX |
Price | $139.99-$159.99 |
Weight | 0.56lb |
Polar Pattern | Stereo, Omnidirectional, Cardioid, Bidirectional |
Additional Features | RGB lighting, anti-vibration shock mount, tap-to-mute sensor, built-in pop filter, headphone jack |
- Customizable RGB lighting with dynamic effects
- Built-in anti-vibration shock mount and pop filter
The HyperX QuadCast S has received positive reviews for its sound quality, ease of use, and stunning RGB lighting. It is an excellent choice for those seeking a high-quality USB microphone with customizable lighting and multiple polar patterns for various recording scenarios.
Sennheiser MK8
The Sennheiser MK8 is a professional-grade microphone that delivers exceptional audio quality and versatility for recording vocals, instruments, and speech. With its dual-diaphragm capsule and five selectable polar patterns (omnidirectional, wide cardioid, cardioid, supercardioid, and figure-of-eight), it offers exceptional flexibility in any recording situation.
The MK8 also features high-quality components and a rugged metal housing that ensure reliable performance and durability. Its low self-noise and wide frequency response make it a perfect choice for capturing detailed and nuanced sound, while the included shock mount and pop filter help reduce unwanted noise and vibrations. The MK8 comes with a custom-designed protective case, and its elegant and sleek design is perfect for any studio or stage setting. Whether you’re a professional musician, voiceover artist, or podcaster, the Sennheiser MK8 is a top-of-the-line microphone that delivers outstanding audio quality and versatility.
Specification | Sennheiser MK8 |
Brand | Sennheiser |
Price | $699 |
Polar Pattern | Five switchable polar patterns |
Additional Features | 3-step attenuator, two adjustable filters, 24-carat gold-plated diaphragms, shock-mounted capsule |
- Five switchable polar patterns for versatile recording situations
- Dual-diaphragm design for warmth and clarity
- Sturdy metal housing and shock-mounted capsule
The Sennheiser MK8 has received positive reviews for its sound quality, ease of use, and versatility in various recording environments. It is an excellent choice for those seeking a high-quality dual-diaphragm condenser microphone with multiple polar patterns for advanced home and studio recording.
Beyerdynamic Fox
The Beyerdynamic Fox is a sleek and versatile microphone that offers exceptional sound quality for a range of recording applications. With its large-diaphragm condenser capsule and cardioid polar pattern, it delivers rich and detailed sound with exceptional clarity and accuracy. The Fox also features a built-in audio interface with zero-latency monitoring and intuitive controls, making it easy to adjust settings and monitor your sound in real-time.
The included pop shield and shock mount help reduce unwanted noise and vibrations, while the sturdy and durable construction ensures reliable performance for years to come. The Fox is compatible with both Mac and Windows, and its compact and portable design makes it perfect for recording on the go. Whether you’re a podcaster, musician, or content creator, the Beyerdynamic Fox is a top-of-the-line microphone that delivers outstanding sound quality and versatility.
Specification | Beyerdynamic Fox |
Brand | Beyerdynamic |
Price | $89 (available on Amazon) |
Weight | 1lb |
Polar Pattern | Cardioid3 |
Frequency Response | 20 – 20,000 Hz |
Audio Resolution | 24-bit/96kHz |
Additional Features | Zero-latency monitoring, mute button, headphone output, pop filter |
- Portable and durable design
- Comes with useful accessories, such as a pop filter
The Beyerdynamic Fox has received positive reviews for its sound quality, ease of use, and versatility in various recording environments. It is an excellent choice for those seeking a high-quality USB microphone with professional-grade audio quality for podcasting, voiceovers, and music recording
MXL 990 USB
The MXL 990 USB is a versatile and affordable microphone that offers exceptional sound quality for a range of recording applications. With its large 19mm diaphragm condenser capsule and cardioid polar pattern, it captures detailed and natural sound with excellent clarity and warmth.
The 990 USB also features a built-in high-speed USB interface, making it easy to connect to your computer or mobile device and start recording right away. The included desktop stand and USB cable provide a convenient setup, while the compact and lightweight design makes it perfect for recording on the go. The 990 USB is compatible with both Mac and Windows, and works seamlessly with a variety of recording software. Whether you’re a podcaster, musician, or voiceover artist, the MXL 990 USB is an excellent choice for capturing high-quality audio on a budget.
Specification | MXL 990 USB |
Brand | MXL |
Price | Varies by retailer, available on Amazon |
Frequency Response | 20 Hz – 20 kHz |
Additional Features | Gold-sputtered diaphragm, transformer balanced output, custom shock mount, carrying case |
- High-quality sound and performance for its price range
- Suitable for recording vocals, voiceovers, and podcasts
- Comes with useful accessories, such as a custom shock mount and carrying case
The MXL 990 USB has received positive reviews for its sound quality, ease of use, and affordability. It is an excellent choice for those seeking a budget-friendly USB condenser microphone for home studio recording, voiceovers, and podcasts
Neumann TLM 103
The Neumann TLM 103 is a legendary microphone that has become a staple in professional recording studios around the world. With its large-diaphragm cardioid condenser capsule and outstanding frequency response, it delivers exceptional clarity, detail, and warmth for a range of recording applications.
The TLM 103 also features a high-quality transformerless circuit design that provides extremely low self-noise and maximum dynamic range, making it ideal for capturing nuanced and subtle sound. Its elegant and robust construction, combined with its sleek and classic design, make it a standout addition to any studio or stage setting. Whether you’re recording vocals, acoustic instruments, or speech, the Neumann TLM 103 is a top-of-the-line microphone that delivers uncompromising audio quality and unmatched versatility.
Specification | Neumann TLM 103 |
Brand | Neumann |
Price | $1189.5 |
Additional Features | Low self-noise (7 dBA), high SPL handling (138 dB), derived from U 87 capsule |
- Suitable for various recording applications, including vocals and instruments
- Low self-noise and high SPL handling
- Classic Neumann sound with a modern update
- May be expensive for some users
The Neumann TLM 103 has received positive reviews for its sound quality, ease of use, and versatility in various recording environments. It is an excellent choice for those seeking a high-quality large-diaphragm condenser microphone with professional-grade audio quality for voiceovers and studio recording.
In conclusion, whether you are a professional voiceover artist or an amateur content creator, having the right microphone is crucial for delivering high-quality audio. We have explored some of the best microphones for voiceover in 2023 and provided you with options that suit different budgets and recording needs. While all the microphones we have discussed offer exceptional sound quality and features, we have personally chosen the Blue Yeti X as our favourite. Its versatility, build quality, and advanced features make it a standout choice for any voiceover project. Ultimately, the best microphone for you will depend on your specific needs and budget. We hope that this article has helped you make an informed decision and find the perfect microphone to enhance your voiceover work
Q1: What type of microphone is best for voiceover work?
Ans: Large-diaphragm condenser microphones are typically considered the best choice for voiceover work, as they offer excellent sensitivity and accuracy.
Q2: Can I use a USB microphone for voiceover work?
Ans: Yes, USB microphones can be an excellent choice for voiceover work, especially if you’re on a budget or need a portable option. However, keep in mind that they may not offer the same level of audio quality as XLR microphones.
Q3: Do I need a pop filter for my microphone when doing voiceover work?
Ans: Pop filters can be useful for reducing plosive sounds (such as “p” and “b” sounds) that can be distracting in a voiceover recording. While not strictly necessary, a pop filter can help ensure a more professional-sounding recording.
Q4: Can I use my voiceover microphone for recording music or other audio?
Ans: Yes, many of the microphones on this list are versatile enough to be used for recording music, podcasts, and other types of audio. However, keep in mind that some microphones may be better suited for certain types of recordings than others.
Q5: What should I look for when choosing a microphone for voiceover work?
Ans: Some factors to consider when choosing a microphone for voiceover work include sensitivity, frequency response, polar pattern, and build quality. It’s also important to consider your budget, as high-end microphones can be quite expensive
