Did you notice any wires or chords while watching reality TV shows or news? You could not. Right? It is the magic of a body microphone or a Lavalier mic. The innovative technology captures quality sound or vocals. A body mic is a compact digital wireless mic. It consists of a clip and lets you attach the mic to your dress. You can stay hands-free, and there is no risk of losing sound quality. Your broadcast system or computer can also be connected to your body mic. But which is the best wireless body microphone? We have provided a brief guide on choosing the right Lavalier microphone.
Consider a few relevant factors for buying the best wireless body microphone –
Directional/omnidirectional
Lavalier mics are available in different versions, like omnidirectional and directional or cardioid. Cardioid mics can differentiate environmental sounds. That is why you can choose them for your outdoor performance or interviews. On the other hand, omnidirectional mics can pick up sound from various angles. You can use these microphones when you deal with studio-based video-capturing projects.
UHF versus VFH Bands
Most wireless microphones run in the UHF band of 450 MHz to 952 MHz. Some models run in the VHF band of 49 MHz to 216 MHz. Though VHF systems are cost-effective, they have fewer channels. They rely on long antennas for operation. UHF systems involve using shorter antennas because of the shorter wavelengths.
Battery quality
The wireless body mic runs on battery. Thus, you should check the battery life when you buy the wireless microphone.
2.4 GHz Band
Some beginner-level microphones run on the 2.4 GHz band. The 2.4 GHz band functions efficiently when you run multiple wireless channels.
So, you have to focus on these factors and buy the best wireless body microphone.
Top-rated wireless body microphones
We have now reviewed the best wireless body microphone models in the market. You can compare them easily and buy the right one.
1. Hollyland Lark M1
Hollyland Lark M1 is one of the top-rated mics if you are concerned about portability and discreteness. The mic transmitters are small; you can clip them onto your clothing. The mic is equipped with LC3 Codec technology and ensures improved Packet loss concealment and higher sound quality.
The audio processing ability of the wireless body mic is quite advanced. It streamlines the way to operate the device and gives the best output.
There is no need to charge the mic frequently, as the battery continues working for 8 hours. The microphone can also automatically detect your mobile volume settings and adjust to them. However, you may also pair your devices manually.
The most important thing we have noticed is the transmission distance of around 650 feet. It is the longest range when compared to other wireless mic’s transmission distance. Furthermore, due to the automatic frequency hopping technology, you will be able to record sound efficiently.
Whether you are vlogging or interviewing, you can use it as the best wireless body mic.
Pros
- Good battery life
- Long transmission range
- Portable and lightweight
Cons
- Need more connection cables.
2. MAYBESTA Wireless Lavalier Lapel Microphone
MAYBEST has designed professional standard microphones with a simple setup. As it is a plug-and-play model, you can just attach the receiver to the iPhone’s charging port. Turn on the mic and capture your songs. The automatic pairing of the mic and the receiver is advantageous. There is no issue with the performance of the wireless microphone. You will find omnidirectional sound and excellent audio quality. Moreover, the high-density mic sponge is spray-proof.
The Lavalier microphone is also equipped with noise-reduction technology. Thus, even if you are at an outdoor site, you can record your voice.
The clip is highly durable. Still, you can hold the mic in your hand. There is no concern about the connectivity and the charging capacity. The built-in battery works continuously for 4.5 hours.
The body mic has been designed to work with different iOS devices.
Pros
- Upgraded wireless clips
- Compact
- Low-priced
- Omnidirectional condenser
Cons
- Need a better battery life.
3. Audio-Technica ATR3350xiS Omni Condenser Microphone
Audio Technica ATR3350XIS is an omnidirectional body mic that reproduces accurate voice. A user-friendly switch and a low-profile design are the major reasons for choosing this mc. As it is a condenser, you can use it for video purposes. The output plug and stereo input are 3.5 mm. Recording audio on the left and right channels is easier.
Other interesting features of the mic are the foam windscreen, headphone adapter, and LR4 battery. As it is a mini mic, you can easily carry it to any place.
Besides, you will find full coverage due to the omnidirectional sound pick-up pattern.
Pros
- Convenient control
- Good headset connection
- Durable clip
Cons
- Internal wires are unsoldered
4. GRTPRTS Dual Wireless Body Microphone
The battery-powered wireless body mic from GRTPRTS has high compatibility with different devices. The mic package comes with a type-C cable and a 3.5mm TRS receiver. You can easily connect the mic to your Android or iOS mobile.
The wireless microphone is an omnidirectional model and captures clear sound. Moreover, the chipset is designed with advanced technology and prevents disturbances from background noise. From YouTubers to filmmakers, everyone can use a microphone.
You will not feel confused even if you use the mic for the first time. Like other body mics, GRTPRTS wireless microphone helps you with a clear setup.
Besides, 2.4GHz wireless technology ensures reliable and smooth connection. You will get a lag-free experience of using the body mic. Make sure that you have chosen the right cable to establish a connection between the receiver and the device.
The battery life is quite good, as it works continuously for 8 hours.
As an Android user, you have to activate the OTG setting and install the Open Camera App. So, set the connection and start using your body microphone for different purposes.
Pros
- Omnidirectional mic
- Quality battery
- Best for high-fidelity recording.
- Designed for indoor and outdoor uses
Cons
- Slightly loose cords
5. GoorDik Wireless Lavalier Lapel Microphone
GoorDik is a reputable brand known for designing portable and innovative microphones. You can use the clip to attach the body mic to your collar or hold it simply in your hand. Many consumers have bought it for karaoke, video conferences, podcasting, and real-time streaming. No matter what your purpose is, the body mic is a great choice.
What’s more, the mic comes with an integrated audio processing chip. Due to the unidirectional cardioid pattern, the microphone can pick up sounds from different directions. So, you can try out this body mic for smooth audio recording.
The important aspect is the high-tech wireless transmission, which is compatible with recording devices. Moreover, you can use it with mixers, amplifiers, and PA speakers. There is a separation cable to let you use the mic on laptops and mobiles. However, you cannot use it with your Macbook.
The mic comes with a standard battery life, which is around 6 hours. It takes 3 to 4 hours to charge the battery. There is also a highly sensitive chip for clear sound pick-up.
GoorDik has used frequency hopping technology to let microphones pair automatically. It prevents the conventional frequency conversion process.
The wireless body mic is made from shock-resistant and anti-drop materials to avoid damage. The user-friendly touch buttons are more sensitive than push-pull switches.
Pros
- Highly sturdy clip
- High-quality voice transmission
- Dual USB charging
Cons
- Need a better receiver
A comparison table
Products | Features | Price |
Hollyland Lark M1 | Noise cancellation chip656ft Wireless Transmission RangeStable audio Wide compatibility | $149 |
MAYBESTA Wireless Lavalier Lapel Microphone | Spray-proof spongeCover 50 feet for signalBattery life- 4.5 hoursClip-on microphone | $25.99 |
Audio-Technica ATR3350xiS Omni Condenser Microphone | Dual-mono 3. 5 mm Omnidirectional pickup patternConvenient control | $24.00 |
GRTPRTS Dual Wireless Body Microphone | Wide compatibilityNoise-reduction micHigh-fidelity recording. | $39.99 |
GoorDik Wireless Lavalier Lapel Microphone | Portable designFrequency hopping mechanismSensitive touch buttons | $25.99 |
We have thoroughly reviewed the best wireless body microphone models. Whether you use the mic in your studio or at home, you can use the wireless body mic or Lavalier mic. High-quality Lavalier microphones are compact, and you can carry them anywhere. You can compare the innovative technologies and batteries integrated into the microphone.
What do you mean by sensitivity of a microphone?
A body mic’s sensitivity is about its capability of converting sound waves into electrical signals. Sensitivity determines how much your mic is able to amplify sound. So, if you need a louder sound and better details, you can choose a highly sensitive lavalier. On the contrary, a body mic with low sensitivity needs higher sound input to get the desired output. For instance, a highly sensitive microphone is the right choice if you want to record whispering or wildlife sounds. Low-sensitive microphones are suitable for recording your live performance.
What are the common applications of a body mic?
Body mics are used in film and TV productions. It is easy to conceal the small microphone in your body.
Is a body mic stereo or mono?
Most body mics are mono and record audio to a single channel. You can set the audio recorder to the mono mode.
Are body mics waterproof?
The best mics have a waterproof design. So, you should check the details before buying the microphone.
