5 Best Wireless Microphone Systems for Church in 2023
Wireless microphone systems have made life much easier, freeing us from the bounds of those connecting cables. Where these are used in recording vlogs, podcasts, and for other purposes, they are a must-needed accessory for church preachers too. With it, preachers can skip the issue of attendees finding difficulty listening to them.
In this comprehensive guide, we will enlist the five best church microphone systems you should consider. To further ease your search for the best one, we have also listed multiple factors that need to be considered when purchasing one. So, what are you waiting for? Let’s dive in to begin the journey of exploration!
What Should Be Considered When Purchasing the Best Wireless Microphone System for Church?
Let’s have a quick read at the factors to consider when purchasing the best church microphone system.
What’s the Budget?
One of the first and foremost things to consider is the church budget. Figure out how much your church administration is willing to pay for the church microphone system. The more you are likely to pay, the longer the system will serve you. So, make a wiser choice and consider our top picks for making an informed purchase decision.
How Many Mics Are Required?
Figure out how many mics are needed. If you need a single mic, simply go with any suitable worthwhile system. However, if you need more than one mic, getting a dual wireless microphone system would be great. It features a single receiver with two mics. In the end, it all depends on the church’s needs.
Buy a Complete Microphone System
The transmitter and receiver are the key components to make your microphone work. Therefore, instead of getting each separately, look for a complete microphone system available at a reasonable price and get it. It’ll most probably cost lesser than buying each component individually.
Our Top Picks of the Best Wireless Microphone System for Church in 2023
Considering the above-mentioned factors and making them the core of our review, we have shortlisted the five best church microphone systems. Each has impressive features and specs that helped them make it to our list. So, be sure to give them a try!
  • Shure BLX288/PG58 Dual-Channel Wireless System
  • Hollyland Lark-M1
  • PRORECK MX66
  • Sennheiser EW 100
  • WENWEN System Pro
1. Shure BLX288/PG58 Dual-Channel Wireless System
Shure has earned a name and fame in the market for the best wireless microphone systems. So, what else could be the first place of our top picks except for its masterpiece? BLX288/PG58 Dual-Channel Wireless System comes with an effective transmitter and two PG58 microphones.
This church microphone system has an appreciable range of 300ft. It can ideally operate in this range if no obstacles are placed within the path. Moreover, these handheld dynamic microphone creation features an LED indicator for low charging.
It’s undoubtedly the ideal bet for those preachers whose main concern is range. Besides being used in church prayers, it can also be used by the preacher when delivering lectures and more.
Pros
  • Exceptional range
  • Good battery life
  • Battery life indicating LED
  • Compact and easily portable design
  • Dual wireless microphone system
Cons
Sometimes there are interferences and crossing of frequencies. However, it doesn’t disturb the sound output that much.
Quantitative Measurements
Durability: 9.5/10
Design: 9.5/10
Uniqueness: 9/10
Ease of Use: 9.5/10
2. Hollyland Lark-M1
Hollyland Lark-M1
Next comes the Hollyland Lark-M1! With a sleek design and compact body, it’s the best microphone for a church pulpit. It ensures optimal performance with the revolutionary noise cancellation algorithm and cutting-edge DSP.
What we liked the most about Hollyland Laark-M1 is its minimal weight and ultra-portability. It weighs just 0.4 oz (11.8g) with a minimal 0.4″ (<1cm) thickness. It comes with a charging case that can conveniently charge and store two transmitters and a receiver.
It’s best to use in churches, owing to its innovative, cutting-edge DSP. This technology works to filter out the ambient noise and delivers the subject voice straight to the listener without compromising an inch on the quality.
Pros
  • Ultra-portable
  • Lightweight
  • 3-Level volume preset
  • 650ft long wireless range
  • Broad compatibility
Cons
For a plethora of cons that users get to enjoy with the Lerk-M1, Hollyland offers a somehow pricier tag. But believe every penny spent is worth it.
Durability: 9/10
Design: 9.5/10
Uniqueness: 9.5/10
Ease of Use: 9.5/10
3. Phoenix Pro True Diversity Dual Wireless Microphone System PTU-2U
If you want your church microphone system to offer a truly diverse experience and sensational voice output, be sure to check out Phenyx Pro! It’s equipped with a robust core that identifies and selects the strongest signal and reflects to ensure noise reduction.
Another great feature of it is its adjustable frequency. Phenyx Pro offers an interference-free experience with 1000 adjustable 500MHz-band UHF groups. Other perks you get to enjoy with this church microphone system include the auto-scan feature, studio-level sound, and more.
Its ultimate craftsmanship is another factor that adds to its width. It’s an excellent choice for those looking for a budget-friendly church microphone system.
Pros
  • Eight kinds of EQ modes
  • Removable grille
  • Audio system with 16-bit sound
  • Legible LCD display
Cons
Sometimes voice output becomes static. But on disconnecting and re-connecting this best mic for church worship.
Durability: 9/10
Design: 8/10
Uniqueness: 9/10
Ease of Use: 8.5/10
4. Sennheiser EW 100 G4-835-S
Whether you are a professional church speaker or an occasional one, Sennheiser EW 100 G4-835-S is bound to offer you the ultimate experience. It comes with a dynamic cardioid system specifically engineered for professional use. Its exceptional new-linking technology can allocate fast frequency to up to 12 receivers.
It has 300 feet transmission range, flexible wireless synchronization, and High RF output power (up to 30 mW). This built-to-last and feature-rich masterpiece from Sennheiser comes with multiple frequency ranges.
Are you tired of changing the church mics again and again? Sennheiser EW 100 G4-835-S is built for you with its premium and long-lasting design.
Pros
  • Compatible with up to 20 channels
  • True diversity half-rack receiver
  • Battery life of 8 hours
  • Durably constructed ewG4 transmitters and receivers
  • Integrated mute switch
Cons
On first look, you may find it pricier, but multiple things featured in the package will convince you to consider the price reasonable. It comes with EM 100 G4 true diversity receiver, SKM 100 G4-S handheld transmitter, MZQ 1 microphone clamp, 2 AA batteries, and loads more.
Durability: 8/10
Design: 8.5/10
Uniqueness: 8/10
Ease of Use: 9/10
5. TONOR TW-630 Wireless Microphone
Lastly, we have another best mic for church worship, the TONOR TW-630 Wireless Microphone. It comes with a 200ft operating range, enough for clear voice transmission to every nook and corner of the church. Besides using it in church, you can also use it in conferences, presentations, and more.
It has an operating frequency of UHF 902.28-926.6 MHz, a frequency response of 20 Hz to 20k Hz, and an output impedance of 600 ohms. Additionally, it supports 25 different audio channels to minimize sound interference. Just charge the wireless microphone for around two to three hours and enjoy using it for six continuous hours.
In churches, there isn’t that much need for a diverse range. Understanding this, TONOR has focused on investing in other features that make its creation convenient when freely moving in the church.
Pros
  • Easy to set up
  • Crystal clear voice output with no interference
  • UHF operation for greater distances and number of frequencies
  • 200ft operating range
  • Superior signal stability
Cons
  • Doesn’t feature a mute button; you will need to turn it OFF or ON.
  • Not compatible with phones, computers, and tablets
Durability: 8/10
Design: 8/10
Uniqueness: 8.5/10
Ease of Use: 8/10
A Comprehension Comparison of Our Top Picks
Are you wondering which one is the best out of all the above-mentioned top picks? We have got you covered here, too, with our comprehensive comparison. If we had to choose only one church microphone system, it would undoubtedly be the Hollyland Lark M-1. Its long list of features, premium build, and beautiful appearance answer your curiosity-filled why.
However, if you are searching for a budget-friendly option, rely on Phenyx Pro, and if battery life is your concern, be sure to check out Shure BLX288/PG58 Dual-Channel Wireless System. In short, each selection is best in one aspect or another.
Summing Up!
A wireless microphone system is an ideal accessory for churches and is bound to offer utter convenience to preachers. So, ensure to invest in a long-lasting microphone instead of wasting time and money in buying multiples of the lower price range.
That was all about the best mic for church! From the budget-friendly ones to the innovative and smart ones to more, we have tried to cover multiple top picks in this comprehensive article. Hope you find it worth reading. Stay in touch for more such interesting review articles.
Which Microphone is Best for Church?
It can sometimes become daunting to select only one from a range of many. The same is the case with the church microphone system. However, our selection of the best will help you narrow your choices and make an informed purchase decision.
What Types of Microphone Are Used in Church?
Single or dual wireless microphones make the best microphone for the church pulpit. These give preachers the privilege to move freely when his conveying a message.
How do I Choose a Church microphone system?
Several factors account for making your purchase worthwhile. These include budget, no mics used, church size, portable or fixed, and more.
RELATED POSTS
