5 Best Wireless Microphones for Interviews with Pros, Cons, and Prices
Whether you are a journalist or a YouTuber who runs a podcast, you need the best wireless microphone for interviews. However, the problem begins when you plan to get an interview microphone without any knowledge or experience. Remember, pricing is not the only factor in judging an interview mic. There are many more features that you should consider before ordering a product.
So, this article tells you what to consider before choosing a wireless mic suitable for interviews. And most importantly, you will discover the five best microphones for conducting interviews with a comparison table. Each product is mentioned with features, advantages, disadvantages, and ratings out of 10, along with the price.
How to Choose the Best Wireless Microphone for Interviews
Before getting the best wireless microphones for interview, here are a few things you should consider.
a. Budget
A wireless microphone interview may come at different prices. Professional microphones are usually expensive compared to starter wireless mics. Therefore, you must know the purpose of buying a microphone and the amount you are willing to spend.
b. Recording Environment
You must remember the environment in which you will be recording sounds. Ask yourself if you will interview people in a soundproof studio or out in the open. This will help you pick the microphone type correctly.
c. Type
When selecting the best wireless microphone for interviews, the most recommended mic type is lavalier and handheld mics. Both are compatible with different recording devices, including smartphones and DSLR cameras.
d. Polar Pattern
There are four polar patterns – omnidirectional, bidirectional, cardioid, and super-cardioid. For interviews, the experts highly suggest omnidirectional mics as they collect sound from all directions equally. The next choice is cardioid microphones since they pick sounds from the pointing part of the mic.
e. Range
Range is one of the most important factors when choosing the best wireless microphone for interviews. But again, it depends on the recording environment. However, you should pick the mic covering at least 100 meters (328ft).
5 Best Wireless Microphone for Interviews
Want to know which interview mic suits you the best? Here is the list of the five best wireless microphones for interviews.
1. Hollyland Lark M1 Duo – Top Choice
Hollyland Lark M1 Duo - Top Choice
Hollyland Lark M1 Duo is a lightweight lavalier interview microphone with wireless technology to capture voice in the highest quality. Lark M1 Duo is the best wireless microphone for interviews that is user-friendly and comes with one receiver and two transmitters. The 3.5mm jack lets you connect the receiver to your device while attaching the transmitters to the interviewer and interviewee.
The case charges and holds the receiver and transmitters, so the batteries are juiced up for the next interview session. Setting up Hollyland Lark M1 wireless interview microphone also takes less than a minute. All you need to do is remove the transmitters from the charging case, and they are automatically turned on.
The two separate buttons on the transmitters make Lark M1 the best wireless microphone for interviews. One is used to turn them off/on, and the second button allows you to pair them with the receiver. And this same button can also be used for noise cancellation.
You can make a single press to turn on the noise cancellation. At the same time, holding this button enables pairing or re-pairing the transmitters to the receiver (in case the connection is lost).
Features and Specifications of Hollyland Lark M1 Duo
Hollyland Lark M1 is among the best wireless microphone for interviews because of the following traits:
  • 110dB SPL
  • Type C – USB port
  • 8-hour recording time
  • 650ft voice recording range
  • Omnidirectional microphone
  • 16bit/48kHz HiFi recording quality
  • 3-level volume preset (low-mid-high)
  • 2.4GHz wireless transmitting frequency
Pros of Hollyland Lark M1 Duo
Here are the reasons why you should buy Hollyland Lark MQ Duo, the best wireless microphone for interviews:
  • 11.8-gram weight
  • No sound dropout
  • Great noise reduction
  • Negligible sound latency
  • Available in single transmitter version
  • Wide compatibility with smartphones and DSLRs
  • Fast and simultaneous charging (only takes 1.5 hours to charge transmitters)
Cons of Hollyland Lark M1 Duo
A few disadvantages of the Hollyland Lark M1 Duo are:
  • You need to remove the smartphone case to attach the receiver (only in some brands)
Quantitative Measurement of Hollyland Lark M1 Duo
  • Design: 9/10
  • Durability: 8/10
  • Build quality: 9/10
  • Unique Features: 9/10
$149.00
2. RODE Wireless Go II (Dual Version)
RODE Wireless Go II has a special place in the world of the best wireless microphone for interviews. Many influencers and vloggers have used this mic for podcasts and face-to-face conversations. It is a dual-channel mic that seems wonderful for recording two persons at the same time.
You can plug Wireless Go II comes with a 3.5mm TRS jack for plugging it into your camera. Contrarily, you can attach this device to tablets, computers, and smartphones through the USB output. The dual variant of this microphone is packed with one receiver and two transmitters. You can grab the single variant containing one piece of TX and RX.
RODE Wireless Go II is the best wireless microphone for interviews if you directly want to export WAV files from the transmitter. The latest beta firmware update allows you to start/stop and transfer recordings through the transmitter.
Features and Specifications of RODE Wireless Go II
RODE Wireless Go II interview mic comes with the following features:
  • 100dB SPL
  • 2.4GHz frequency
  • Type-C USB port
  • 656 feet recording range
  • 7-hour max recording time
  • 50Hz – 20kHz recording quality
Pros of RODE Wireless Go II
Let’s see why RODE Wireless Go II is in this list of best wireless microphones for interview:
  • Gain control
  • 32gram weight
  • High-quality clip-on
  • Battery fully charged in 2 hours
  • Connectivity through a mobile app
  • Combine and separate recording options
  • Compatibility with computers, cameras, and mobile devices
Cons of RODE Wireless Go II
A few disadvantages of RODE Wireless Go II are:
  • It doesn’t come with a physical instruction manual
  • PC connection is required for adjusting most of the settings
Quantitative Measurement of RODE Wireless Go II
  • Design: 9/10
  • Durability: 8/10
  • Build Quality: 8/10
  • Unique Features: 8/10
$299.00
3. Movo WMX-2 Duo
Movo WMX-2 Duo
Movo WMX-2 Duo is another best wireless microphone for interviews in this list. It consists of one receiver and two transmitters packed inside a charging case made of hard plastic. Each transmitter has mute, set, and back buttons. Above both transmitters rests an omnidirectional microphone along with a 3.5mm jack for mic connection.
Contrarily, the receiver consists of two 3.5mm jacks. One can be used for headphones for sound monitoring and the other for audio output. There’s also an LED light and power button placed on the charging case to ensure the system is charging correctly.
Movo WMX-2 Duo also has an easy and clean interface. But the power and mute buttons are the same on the receiver. You may need some time to get familiar with their handling. Overall, it is an outstanding lavalier microphone for recording mighty fine sound in mono or stereo modes.
Features and Specifications of Movo WMX-2 Duo
Movo WMX-2 Duo has many interesting features that qualify it among the best wireless microphone for interviews. For instance:
  • 2.4GHz highly-stable transmission
  • Recording range up to 328ft
  • 7-hours battery time
  • USB Type C port
Pros of Movo WMX-2 Duo
There are many pros of the Movo MWX-2 Duo wireless interview microphone, such as:
  • Solid design
  • Dual recording modes
  • 28 grams lightweight mic
  • 1.25-inch OLED display screen
  • Clean and crisp sound recordings
  • Compatible with smartphone, mirrorless, and DSLR cameras
Cons of Movo WMX-2 Duo
Some noticeable cons of WMX-2 Duo are:
  • It takes 14 hours to charge
  • Low build quality of charging case
Quantitative Measurement of Movo WMX-2 Duo
  • Design: 8/10
  • Durability: 7/10
  • Build quality: 5/10
  • Unique Features: 7/10
$199.95
4. Boya BY-XM6-S2
Boya BY-XM6-S2
Boya BY-XM6-S2 has a simple and beautiful design making it to this list of the best wireless microphone for interviews. This microphone is a great pick if you plan to have walking interviews. So no wonder why this device is a perfect choice for capturing documentary interviews.
Boya BY-XM6-S2 is a 2-person mic system with two lavalier clip-on microphones. Additionally, both mics/transmitters are automatically paired with the receiver, saving you big time reading the ‘how to pair’ manual. More to that, both mics can be protected through the windshield clips to ensure you record a clean sound.
Another characteristic that makes BY-XM6-S2 the best wireless microphone for interviews is the small display. It represents an audio waveform when the interviewee is talking, assuring you that there are no obstacles in receiving signals.
Features and Specifications of Boya BY-XM6-S2
What’s more inside the BY-XM6-S2 box? Here’s the list:
  • 84dB SPL
  • 2.4GHz transmitting frequency
  • 328ft recording range
  • Up to 7 hours of recording time
  • Built-in headphone jack for live sound monitoring
Pros of Boya BY-XM6-S2
Boya BY-XM6-S2 has the following advantages:
  • Adjustable gain
  • Rechargeable battery
  • Plug & play functionality
  • Compatible with smartphones and DSLRs
  • Lightweight microphone system (only 32 grams)
Cons of Boya BY-XM6-S2
The only thing that users don’t like about Boya BY-XM6-S2 is:
  • Signals drop when you are getting closer to the recommended range (328ft)
Quantitative Measurement of Boya BY-XM6-S2
  • Design: 7/10
  • Durability: 7/10
  • Build quality: 7/10
  • Unique Features: 7.5/10
$169.95
5. RODELink TX-M2
RODELink TX-M2 is a handheld wireless condenser microphone best for taking interviews. Previously, it was sold with a complete kit, but now you can get it individually. However, this product is good for those with a RODELink digital wireless system.
Otherwise, you need to purchase one separately to make this mic function. Nevertheless, RODELink TX-M2 is the best wireless microphone for interviews if you think handheld mics are just your type.
You can pair TX-M2 with RX-CAM or RX-DESK receivers to savor high-quality audio. This makes this mic excellent for even singing and presentations. Moreover, this mic offers 128-bit encryption to ensure you get crystal-clear recordings. Besides, the mic is powered by a rechargeable and removable lithium-ion battery.
Features and Specifications of RODELink TX-M2
A few qualities that make RODELink TX-M2 one of the best microphones for interviews are:
  • 140dB SPL
  • 2.4GHz wireless frequency
  • Up to 328ft audio recording range
  • Cardioid condenser capsule mic type
  • 10 hours of recording time on a single charge
  • Built-in handling noise, background noise, and plosive rejections
Pros of RODELink TX-M2
RODELink TX-M2 can be your best wireless microphone for interviews if you are looking for:
  • Portable design
  • Flat treble and mids
  • Good air frequencies
  • It can be functional through two AA batteries
Cons of RODELink TX-M2
RODELink TX-M2 comes with a few issues:
  • Low sensitivity
  • Expensive interview mic
  • Heavyweight mic – 222 grams
  • Requires a receiver to receive recording signals
Quantitative Measurement of RODELink TX-M2
  • Design: 6/10
  • Durability: 7/10
  • Unique Features: 5/10
$299.00
Comparison Table – Best Wireless Microphone for Interviews
ProductPolar PatternMic TypeRangeBattery TimePrice
Hollyland Lark M1 DuoOmnidirectionalLavalier650ft8 hours$149.00
RODE Wireless Go IIOmnidirectionalLavalier656ft7 hours$299.00
Movo WMX-2 DuoOmnidirectionalLavalier328ft7 hours$199.95
Boya BY-XM6-S2OmnidirectionalLavalier328ft7 hours$169.95
RODELink TX-M2CardioidHandheld328ft10 hours$299.00
The best wireless microphone for interviews should be budget-friendly. Such mics should also be far enough to easily record sounds without dropping signals. Brands like RODE, Movo, and Boya qualify as good interview microphones as they provide long battery time and wireless range. But either they are pricey about what they are offering or have some major things that could be improved, such as low build quality, poor design, etc.
Contrarily, Hollyland Lark M1 Duo is the clear winner in this list. It is a lavalier omnidirectional interview mic. Moreover, it offers high battery time and is extremely affordable compared to the other four. Additionally, Lark 1 is durable and includes several useful features beneficial to recording interviews.
FAQs – Best Wireless Microphone for Interviews
Q1. What type of microphone is often used for sit-down interviews?
Lavalier clip-on microphones are widely used for sit-down interviews.
Q2. What is the best wireless microphone for Zoom interviews?
Hollyland Lark M1 and RODE Wireless Go II are the best wireless microphone for interviews on Zoom.
Q3. What is the price of a wireless interview mic?
The price of wireless interview mics ranges from $145 to $300.
Q4. Which of the following mic is ideal for interviews?
Whether sit-in or walking, Hollyland Lark M1 is the best microphone for interviews. It covers almost 200 meters (650ft) and has an omnidirectional pattern grate for recording crystal clear sounds.
RELATED POSTS
