There are many reasons to have a wireless audio transmitter. For instance, if you have Bluetooth headphones or speakers, you can use the audio transmitter to send audio from your computer, TV, or other devices to your wireless speakers or headphones.
Similarly, an audio transmitter lets you connect your Bluetooth or other wireless-enabled headphones to devices lacking Bluetooth. And guess what? Some wireless audio transmitters even let you connect multiple smartphones to the same source, allowing you to give access to every person in the room to play their favorite jam.
So how to get an exceptional wireless audio transmitter? What are the essential features it should have? This article will show 10 best-selling wireless audio transmitters, their features, pros, cons, and costs.
How to Choose a Perfect Wireless Audio Transmitter?
Here are 5 tips to help you select a reliable audio transmitter.
a. Purpose
There are two types of wireless audio transmitters. Some are used for traveling, while others are best kept at home. So, for instance, if you want to enjoy your flight or a long drive, you can choose battery-powered portable transmitters. Such devices are also compatible with other gadgets, including TVs, laptops, PCs, smartphones, and tablets.
You can also pick an audio transmitter that is solely made for TV. These transmitters are often electric-powered, so you must provide a constant power supply to ensure they operate seamlessly.
b. Transmission Range
Pick a device with maximum transmission range, especially if you want a wireless audio transmitter for your home television. An ideal transmission range starts from 30ft to 170ft. However, you should keep in mind that opting for a high-range audio transmitter can be expensive compared to a low-range device.
c. Battery Timing
Some wireless audio transmitters are cheap but have minimal battery time. Whereas expensive devices offer more playtime compared to inexpensive ones. If pricing is an issue, try to get a device with a running time of at least 10 hours.
d. Audio Codec
Make sure to pick a device that supports a broad range of audio codecs, such as aptX, SBC, and more. The higher the codec support, the more chances you can enjoy high-quality sound through your transmitter.
e. Price
Lastly, do not have impulsive buying behavior. Always select a transmitter that comes within your range. If some features are making the device costly but not required at the moment, look for another gadget at a minimal price that offers features that will satisfy your purpose of having a wireless audio transmitter.
Comparison Table – 10 Best Wireless Audio Transmitter
| Product | Price | Range | Battery Time | Audio Output | Supported Audio Codec |
| Aluratek ABT01F | $19.99 | 33ft | Up to 10 hours | RCA Y and 3.5mm AUX | SBC and AAC |
| Scosche BTTWT-SP | $24.03 | 30ft | Up to 8 hours | AUX | AAC, aptX, and SBC |
| Aluratek ABT05F | $29.99 | 50ft | 10 hours | 3.5mm AUX and RCA | AAC, SBC, aptX, aptX HD, and aptX low-latency |
| MEE Connect Air | $49.99 | Up to 30ft | 20 hours | 3.5mm AUX | SBC and ApTX |
| Avantree Relay | $39.99 | N/A | Up to 20 hours | Dual 3.5mm adapter and AUX | aptX HD, aptX Low Latency, and aptX Adaptive codecs |
| Twelve South AirFly Duo | $44.99 | 33ft | 22+ hours | 3.5mm AUX | aptX Low Latency |
| Avantree Audikast Plus | $49.99 | 100ft | Not required | Optical, RCA, AUX, and USB | FS, SBC, aptX, and aptX-LL |
| ZIIDOO | N/A | 33ft | 23 hours | 3.5mm AUX | RX: aptX, aptX HD, aptX Low Latency, AAC, and SBC TX: SBC, aptX, aptX Low Latency, and aptX HD |
| Avantree Orbit | $99.99 | 164ft | Not required | 3.5mm AUX, RCA, and Optical | aptX, aptX LL, SBC, and FS |
| Jensen RBTTX10 | $19.99 | 32ft | 13 hours | N/A | N/A |
Note: The prices are taken from the official sites and Amazon. The manufacturers of these 10 wireless audio transmitter reserve the right to change pricing with or without informing.
Explore these 10 useful wireless audio transmitters to decide the ideal one for your use.
1. Aluratek ABT01F
The Aluratek ABT01F is another handy wireless audio transmitter that permits you to transmit audio files wirelessly through your stereo, TV, computer, and other audio devices to your Bluetooth sources, such as soundbar, speakers, and headphones. It is a great solution for music lovers, movie fans, and gamers who seek freedom from cables.
This transmitter comes with Bluetooth version 3.0 technology for high-quality wireless performance. It has a great battery life of up to 10 hours, and the signals are reachable within 33ft.
The Aluratek ABT01F transmitter allows you to connect it through 3.5mm or RCA-Y audio cables. It also supports an A2DP Bluetooth profile for excellent streaming quality.
Features and Specifications of Aluratek ABT01F
- RCA Y and 3.5mm AUX audio output
- The device supports SBC and AAC audio codecs
- It comes with an incorporated microphone for handsfree calling when used with compatible headphones
- In the transmitter mode, the device allows you to transmit audio from two separate devices at the same time
Pros of Aluratek ABT01F
- Easy pairing
- Offers hands-free calling feature
- It comes with a rechargeable battery
- The device does not require any software or drivers
Cons of Aluratek ABT01F
- The hands-free calling feature does not support all Bluetooth-enabled devices
- It does not support aptX audio codec
- Some users have reported that this transmitter shows trouble in pairing with Bluetooth devices
- $19.99
2. Scosche BTTWT-SP
The Scosche BTTWT-SP is a small, portable wireless audio transmitter from the FlyTunes series that lets you stream audio from a wide range of non-Bluetooth devices to your Bluetooth speakers or headphones. That’s why people love traveling with it when taking a road trip or a plane journey.
This transmitter is equipped with a powerful built-in battery that lasts for up to 8 hours when you charge it once. Also, it gives you a move-around space of 30 feet without losing connection. After establishing the connection, you can easily begin streaming audio without a hitch.
The device uses Bluetooth 4.1 technology that allows you to enjoy clean and crisp sound without lagging or interference. It also has a multi-function button that is used to turn on/off, pause, play, answer, and end your calls.
Features and Specifications of Scosche BTTWT-SP
- LED indicator
- Compatible with most devices
- Lightweight design and strong construction
- It supports up to 2x Bluetooth devices simultaneously
- 3.5mm foldable audio adapter for quick storage
- The device supports AAC, aptX, and SBC audio formats
Pros of Scosche BTTWT-SP
- Simple usability
- Small design that is easy to carry
- Integrated rechargeable battery
Cons of Scosche BTTWT-SP
- It only works with 3.5mm audio output devices
- $29.99
3. Aluratek ABT05F
The Aluratek ABT05F is a more powerful version of its series. Equipped with the latest Bluetooth 5, this wireless audio transmitter allows transmitting sound to all audio devices with a headset/3.5mm AUX output or RCA output. It permits you to transmit audio from stereo, laptop, desktop PC, CD Player, MP3 player, TV, Bluetooth headphones, speakers, and earbuds.
The Aluratek ABT05F gives you the opportunity to pair two Bluetooth headphones at one time. And both of your devices will stay functional for a maximum of 10 hours. And because it comes with the newest Bluetooth 5 technology, the transmission range has also been increased up to 50ft. Moreover, the company claims you can stream music through this device while charging it via a USB port.
Features and Specifications of Aluratek ABT05F
- Wide range of pairing options
- Cables included in the package
- Auto-sleep function after 5 minutes of inactivity
- Supports the AAC, SBC, aptX, aptX HD, and aptX low-latency audio codecs
Pros of Aluratek ABT05F
- Easy to carry
- Affordable pricing
- Better wireless range
- The auto-sleep function saves battery
Cons of Aluratek ABT05F
- The quality of the included cables is not up to the mark
- $29.99
4. MEE Connect Air AF-CA1-WT
The MEE Connect Air AF-CA1-WT is known for transmitting wireless audio to AirPods and other Bluetooth devices by turning non-Bluetooth sources into powerful ones. Such a characteristic makes MEE AF-CA1-WT one of the most suitable wireless audio transmitters to be taken on airplanes.
This device also works with other audio gadgets that have a 3.5mm audio output, including gaming consoles like PlayStation, Nintendo Switch, and Xbox, as well as laptops. It also supports the aptX technology for Hi-Fi, lag-free, and low-latency audio. So whenever you watch a video or play a game, this trait will ensure that you get the audio with a high sync level.
The MEE Connect Air gives you a playtime of 20 hours when connected to a single device, such as a headphone. And since it lets you connect two headphones simultaneously, the second headphone can stay functional for almost 15 hours.
Features and Specifications of MEE Connect Air AF-CA1-WT
- 30ft operating range
- 2 hours of charging time
- 200 mAh integrated rechargeable battery
- SBC and AptX-supported audio codecs
Pros of MEE Connect Air AF-CA1-WT
- Good playtime
- The setup is very easy
- It is lightweight and small in size
Cons of MEE Connect Air AF-CA1-WT
- It is expensive
- According to some users, this device has an inconsistent audio quality
- $49.99
5. Avantree Relay
If you’re looking for a wireless audio transmitter that’s best not only for an airplane voyage but also for the gym, TV, and smart devices, then Avantree Relay will surely impress you. This device comes with a 3.5mm dual adapter that lets you use it on your flight without worrying about the output audio jack. At the same time, an AUX audio output enables you to transmit audio from your tablet, AirPods, Bluetooth headphones, and more.
The Avantree Relay supports the aptX Low Latency and aptX Adaptive codecs, which ensures transmitting high-quality audio at minimal latency. This pocket-sized device is instilled with Bluetooth 5.3 technology to make sure you experience a fast and reliable connection.
The Avantree Relay performs up to 20 hours on a single charge. If the battery runs out, you can plug in the USB charger and continue watching or listening to your favorite movie or song.
Features and Specifications of Avantree Relay
- Multi-function button
- Connection indicator
- Clean interface with volume adjustment
- Battery indicator
Pros of Avantree Relay
- Compatible with multiple devices
- Reasonable price
- Supports most aptX codecs
- Good battery life
Cons of Avantree Relay
- The company didn’t mention the wireless transmission range of this device anywhere on the official site and Amazon store
- $39.99
6. Twelve South AirFly Duo
With the Twelve South AirFly Duo, you can wirelessly transmit audio from gym equipment, in-flight entertainment, gaming consoles, TV, or any device that has a 3.5mm audio jack. It lets you savor audio files through your earbuds, wireless headphones, or Airpods without getting caught up with the cables.
The Twelve South AirFly Duo transmits up to 33ft of wireless signals. Moreover, it gives 22+ hours of battery time. Also, you can keep an extra USB cable if you need to charge it during travel. What’s more? The Airfly Duo has Bluetooth 5.0, which ensures minimal latency. But it only supports the aptX Low Latency.
Features and Specifications of Twelve South AirFly Duo
- Status light
- Pairing buttons
- Battery indicator
- USB Type-C charging port
- Pairing up to 2 wireless headphones or AirPods
Pros of Twelve South AirFly Duo
- The battery life is great
- The device is simple to use
- It is a lightweight and small transmitter
Cons of Twelve South AirFly Duo
- The price is high
- It does not support other audio codecs
- Users have reported compatibility issues
- Complicated pairing – the only way to pair your AirPods is to ensure they are in the case
- $44.99
7. Avantree Audikast Plus
The Avantree Audikast Plus is a wireless audio transmitter that holds the official aptX Low-Latency certification. That means if you connect it with a Bluetooth headphone or speaker that also has the Low-Latency aptX or FastStream feature, you will experience a complete ‘no lip sync’ lag.
The Avantree Audikast Plus supports Optical, RCA, AUX, and USB audio outputs. Also, this device is universally compatible with all the televisions in the market. Besides, the device lets you connect two Bluetooth devices together without delay in the audio.
But what makes this different from the most wireless audio transmitter is its long range. The Avantree Audikast Plus comes with a Class 1 Bluetooth range that ensures reliable and stable connectivity up to 100 feet.
Features and Specifications of Avantree Audikast Plus
- USB Type A
- Bluetooth V5.0
- Buttons for volume adjustment
- Dedicated buttons for dual-link connectivity
- Powered by a 5V USB charger or TV’s USB port
- It supports FS, SBS, aptX, and aptX-LL audio codecs
Pros of Avantree Audikast Plus
- Made for home entertainment
- The device offers a wide transmission range
- The price is acceptable for the features this device offers
- The volume adjustment buttons are great for devices that lack built-in volume control
Cons of Avantree Audikast Plus
- This device is not suitable for traveling
- $49.99
8. ZIIDOO Bluetooth 5.0 Transmitter and Reciever
ZIIDOO Bluetooth 5.0 Transmitter and Reciever serves as a wireless audio transmitter and receiver but still has a pocket-friendly size that’s easy to carry around. This device offers Hi-Fi stereo sound with low latency, permitting seamless transmission without delays when used through its transmitter mode. However, you will need a Bluetooth receiver with low latency to enable this feature.
ZIIDOO in the transmitter mode allows you to convert a PC, iPod, CD player, MP3, and TV without Bluetooth into a robust Bluetooth transmitter. In contrast, the receiver mode is suitable for transmitting audio from sound systems at home or in your car. While ZIIDOO can be used as a transmitter and receiver, it also offers a hands-free function. Moreover, ZIIDOO gives you a wireless range of up to 33ft and playtime of up to 23 hours.
Features and Specifications of ZIIDOO Bluetooth 5.0 Transmitter and Reciever
- 3.5mm AUX
- Bluetooth 5.0
- SPDIF port
- Micro USB port
- Charging indication
- Compatible with various devices
- One-click control to switch between TX and RX
- aptX, aptX HD, aptX Low Latency, AAC, and SBC audio codec support by RX and TX
Pros of ZIIDOO Bluetooth 5.0 Transmitter and Reciever
- Easy to set up and use
- The battery lasts an entire day even when the device is in continuous use
Cons of ZIIDOO Bluetooth 5.0 Transmitter and Reciever
- It does not work with Roku TV
- You can’t use this device while charging
- Some users complain about slow pairing
- N/A
9. Avantree Orbit
If you want a wireless audio transmitter for home entertainment, look at the Avantree Orbit. Although this isn’t a tiny device, it does offer great features. The Avantree Orit has an LCD screen display that helps eliminate the bling pairing factor. You can choose the device of your choice, check the codec, and even control the volume of your connected device.
This gadget is compatible with all the televisions currently available in the market. Thanks to the 3.5mm AUX and RCA outputs to make this compatibility possible. Moreover, it has a 5.1CH sound conversion trait that converts audio into a 2.0 stereo channel for instant transmission via Bluetooth. It is a Low Latency aptX certified device that ensures smooth audio transmission without delays.
The Avantree Orbit also has a Pass-Through feature that allows you to connect headphones to external TV speakers, such as Stereo AVR and Soundbar.
Features and Specifications of Avantree Orbit
- 40ms latency
- Bluetooth 5.0
- Long range (Class 1)
- Auto audio decoding
- 164-feet wireless range
- Microphone input support
- Dual-link – up to 2x headphones
- aptX, aptX LL, SBC, and FS codec support
- 3.5mm AUX, RCA, and Optical audio output
Pros of Avantree Orbit
- Ideal for TVs
- Compact design
- Fast connectivity
- User-friendly options
- Broad wireless range
Cons of Avantree Orbit
- Expensive product
- Not a travel-friendly device
- $99.99
10. Jensen RBTTX10
Jensen RBTTX10 is a wireless audio transmitter and receiver that can help convert your non-Bluetooth device into a fully functional Bluetooth transmitter. You can use the TX for streaming audio from non-Bluetooth equipment to Bluetooth speakers and headphones. Likewise, the RX lets you stream audio from any Bluetooth-enabled device, such as a tablet, laptop, or smartphone, to a non-Bluetooth sound source like wired speakers, wired headsets, and home stereo systems.
Although the Jensen RBTTX10 has an average playtime of 13 hours compared to the above RX TX audio transmitters, you may find it a fair deal in terms of price. While this is not the most admired audio transmitter, you can still use it for playing music or watching shows without disturbing other people from a 32-feet range.
Features and Specifications of Jensen RBTTX10
- Integrated microphone for hands-free calling
- Simple plug-and-play construction
- LED indicator
Pros of Jensen RBTXX10
- Economical price
- Compatible with Nintendo Switch
- You can use it with your car audio system
Cons of Jensen RBTXX10
- Scratchy sound
- Some users reported the charging light being turned on without any reason
- There is not enough information about the product on the official site or Amazon store
- $19.99
You have explored the 10 best wireless audio transmitter gadgets in this article. Most of them are portable devices you can take when traveling by airplane or road. If you opt for those transmitters, you can also use them to turn your non-Bluetooth devices into Bluetooth systems.
Some notable inexpensive products in this category are Alurateck ABT01F, Aluratek ABT05F, and Avantree Relay. If price is not your major concern, you can also review the Airfly Duo. On the other hand, if you’re looking for a wireless audio transmitter for your home use, such as connecting with a TV, you have a few options like Avantree Orbit and Avantree Audikast Plus.
Nevertheless, the choice is completely up to you. But it is also suggested to pick a wireless transmitter with all the great features you desire.
Achieving professional-level audio requires a reliable wireless lavalier microphone that provides clarity and ease of use. If you’re exploring wireless audio transmitters, a compact lavalier mic kit can be the ideal solution for capturing high-quality audio effortlessly and wirelessly.
Q1. What does a wireless audio transmitter do?
A wireless audio transmitter converts audio signals (digital or analog) into wireless signals, which can be transmitted through Bluetooth headphones or speakers.
Q2. How can audio be transmitted wirelessly?
The most common way to transmit wireless signals is through Bluetooth. Other mediums include Wi-Fi, infrared, and radio waves.
Q3. Does wireless affect sound quality?
It depends on the quality of your wireless audio transmitter. The sound quality is smooth if it supports several audio codecs, such as aptX, SBC, FS, and more.
