Those face-melting solos and breathtaking riffs become more fun when you play them without thinking of cable blocks. However, this was not possible until the world saw the new wireless guitar transmitter invention in the previous years.
These devices allow you to go cableless, no matter if you’re recording in a studio or performing live in front of hundreds of fans. So in this article, you will unearth the 10 best wireless guitar systems with their main features, pros and cons, and official or Amazon pricing.
How to Pick the Best Wireless Guitar Transmitter?
A wireless guitar transmitter and receiver usually come together as a unit. So before losing your hard-earned money, let’s learn what factors to consider to make the right choice.
a. Frequency Band
The first thing you should focus on when choosing a wireless guitar transmitter is its frequency range/band. Most transmitters have a frequency band of 2.4 GHz, which is compatible with most guitars and amplifiers.
On the other hand, a 5.8 GHz band is instilled in a few devices, providing better sound quality compared to 2.4 GHz. So if you opt for this one, ensure your instrument will allow a seamless connection.
b. Latency
Latency means the duration of the audio signal to reach from your transmitter to the receiver so you can hear the sound from the output, such as an amplifier. The best transmitter is the one that gives minimal latency of zero or a few milliseconds, such as 2ms, 3ms, or 5ms.
c. Battery Life
Wireless guitar transmitters come with either built-in or AA-replaceable batteries. Experts suggest selecting a transmitter with an incorporated battery system. But apart from the battery choice, the main element is the playtime. Consider a wireless guitar transmitter that gives you maximum playing hours on a single charge.
d. Wireless Range
Depending on your needs, you should pick the wireless range. A few feet will do the job if you want a wireless transmitter to play in your room. But if you’re looking for outdoor performances with a lot of movements and running, pick the device that covers at least 100ft of distance.
e. Receiver Options
When getting yourself a wireless guitar transmitter, it is wise to choose one with a dedicated receiver unit. It will give you more flexibility and control over your audio quality and overall functionality.
f. Price
Wireless guitar transmitters are available at different pricing. You can find a brand under 100 bucks, as well as a device that’s over $450. So try your best to find a transmitter with all the necessary features at the lowest price possible.
Comparison Table – 10 Best Wireless Guitar Transmitters
| Product | Price | Band | Frequency Response | Range | Latency | Battery Life |
| Xvive U2 | $149.00 | 2.4 GHz | 20Hz to 20kHz | 70ft | 6ms | Up to 5 hours |
| NUX C-5RC | $159.00 | 5.8 GHz | 20Hz to 20kHz | Up to 100ft | < 5.5ms | Up to 4 hours |
| Ibanez WS1 | $179.99 | 2.4 GHz | 20Hz to 20kHz | Up to 100ft | < 5ms | 4 hours |
| Boss WL-20 | $199.50 | 2.4 GHz | 20Hz to 20kHz | 50ft | 2.3ms | Up to 12 hours |
| Boss WL-50 | $229.49 | 2.4 GHz | 20Hz to 20kHz | 65ft | 2.3ms | Up to 7 hours |
| Line 6 Relay G30 | $229.99 | 2.4 Ghz | 10Hz to 20kHz | 100ft | 2.9ms | 8 hours |
| Behringer Airplay Guitar AG10 | N/A | 2.4 GHz | 20Hz to 16kHz | 100ft | 5ms | Up to 6 hours |
| Shure BLX14-H10 | $299.00 | 542 MHz to 572 MHz | 50Hz to 15kHz | 300ft | N/A | Up to 14 hours |
| Sennheiser XSW-D Pedalboard Set | $379.00 | 2.4 GHz | 10Hz to 18kHz | 250ft | 3.9ms | Up to 5 hours |
| Shure GLXD16+ | $499.00 | 2.4 GHz and 5.8 GHz | 20Hz to 20kHz | 200ft | 4.5ms to 8ms | Up to 17 hours on 2.4 GHz Up to 12 hours on 5.8 GHz |
10 Best Wireless Guitar Transmitter Systems
Here are the 10 renowned wireless guitar transmitter and receiver devices popular among new and advanced-level guitarists.
1. Xvive U2
The Xvive U2 is a budget-friendly and widely embraced wireless guitar transmitter. This mini-sized device has an attractive design and is available in different colors to match the body and strings. Apart from this attribute, this tool has some great features and specifications. Moreover, it has a durable construction that ensures rough handling.
The Xvive U2 transmits signals at a frequency response of 20Hz to 20kHz. The system has a built-in rechargeable battery that gives you 5 hours of playing. So if you’re about to perform a few songs, you can juice up the battery before the show.
Features and Specifications of Xvive U2
- ABS plastic-built body
- 4-channels
- 2.4 GHz frequency band
- 70ft wireless transmission range
- Battery timing up to 5 hours
- 6ms latency
Pros of Xvive U2
- Affordable price
- Good audio quality
- Lightweight and compact design
- Low interference
- The device is easy to use
Cons of Xvive U2
- Occasional dropouts reported by some users
- Guitars with active electronics are likely to experience interference
- $149.00 (As seen on Amazon)
2. NUX C-5RC
The NUX C-5RC is equipped with the 5.8 GHz frequency band, making it the best wireless guitar transmitter for supreme sound quality. Therefore, you can expect very less interference from other musical equipment. So whether you’re playing at home or performing live on stage, this wireless tool provides a reliable and smoother connection.
The NUX C-5RC has an enhanced algorithm due to the NUX technology. Also, this device seamlessly integrates with several string instruments. That includes semi-acoustic guitars, electric guitars, bass guitars, and even ukuleles.
Features and Sepcifications of NUX C-5RC
- Below 5.5ms latency
- 5.8 GHz frequency band
- Up to 100ft of wireless range
- 44.1kHz and 24-bit audio quality
- Maximum 4 hours of playtime when transmitter and receiver are fully charged
Pros of NUX C-5RC
- Affordable pricing
- Lightweight design
- Reasonable wireless coverage
Cons of NUX C-5RC
- Low playtime
- Some users report that the wireless range is unstable
- $159.00 (As seen on Amazon)
3. Ibanez WS1
The Ibanez WS1 is an exceptional wireless guitar transmitter customized for bass and electric guitar instruments. While it has all the streamlined traits, the device also has a unique attribute called the ‘cable-tone mode.’
This feature is made for passive pickups and can be activated with a single button press. By using this trait, you can mimic all the tonal nuances similar to the 10ft high-quality guitar cables. Moreover, the Ibanez WS1 has superb electronic elements to make sure you experience a professional-grade sound output with minimal noise.
Features and Specifications of Ibanez WS1
- 4 hours of battery life
- Up to 100ft wireless range
- 44.1kHz/24-bit audio quality
- Less than 5ms audio latency
- 2.4 GHz frequency/broadcast band
Pros of Ibanez WS1
- Great sound quality for the cost
- The cable tone mode makes the audio rich and clean
Cons of Ibanez WS1
- The price is high with such specifications
- The battery timing is not suitable for long-hour performances
- $179.99 (As seen on Amazon)
4. Boss WL-20
The Boss WL-20 gives you multiple channels and comes with a built-in battery. However, unlike the WL-50, this device comes at a bit low wireless range. But the good side is you don’t have to carry a charger since it comes with a USB charging cable to juice up the battery at your convenience. Also, the battery performs well compared to AA battery devices.
You can run the Boss WL-20 on up to 14 wireless systems from the same location without expecting interference. Moreover, the WL-20 also has a cable emulation feature that can be used to change the tone slightly.
Features and Specifications of Boss WL-20
- 9V power supply
- 2.3ms ultra-low latency
- 50ft range of transmission
- Supports up to 14 channels
- Up to 12 hours of battery life
- DC output for power distribution to multiple pedals
Pros of Boss WL-20
- Good reception
- Extended playtime
- Compatible with both bass and guitars
- Incorporated cable tone simulation
Cons of Boss WL-20
- This model offers a lower range if compared with other devices in the same price range
- $199.50 (As seen on Amazon)
5. Boss WL-50
Boss never disappoints in producing top-notch music equipment, and the WL-50 is another example to prove their claim. The Boss WL-50 is a wireless guitar transmitter and receiver system for pedalboard players. It comes with Boss’s cutting-edge technology that gives minimal transmission delay, impressive frequency range, and wireless transmission to 65ft.
Boss WL-50 has a space-efficient and compact design with an integrated docking port to charge the transmitter easily. Also, this device has a DC output, allowing you to enable additional pedals on the pedalboard.
Features and Specifications of Boss WL-50
- 2.3ms latency
- 1/4-inch connector
- 65ft transmission range
- 2.4 GHZ frequency band
- AA batteries that give up 7 hours of playtime
Pros of Boss WL-50
- Longlasting construction
- The device is easy to set up
- It reproduces high sound quality with no interference or latency
Cons of Boss WL-50
- A little expensive guitar wireless system
- The range could be better
- Performance is not good with some guitars
- $229.49 (As seen on Amazon)
6. Line 6 Relay G30
Line 6 Relay G30 is a great wireless guitar system for beginners. While the company claims to be a budget-friendly device, it is slightly pricey as it costs above $200. But if you look at the features, you might be satisfied with what the tool offers. The G30 gives solid frequency coverage throughout the transmission. You can enjoy up to 100ft of wireless freedom without losing the audio quality.
The Line 6 Relay G30 is operatable with AA batteries for several hours. Moreover, this tool also ensures the least noise generation and provides a clean signal transmission.
Features and Specifications of Line 6 Relay G30
- 2.9ms latency
- Supports up to 6 channels
- 100ft wireless range (line-of-sight)
- 10Hz to 20kHz frequency response
- 8 hours of battery time with 2x AA batteries
- 2.4-bit A/D low noise system for high sound quality
Pros of Line 6 Relay G30
- Built-in tuner
- Easy controls
- Long wireless coverage
- The cable tone simulator allows you to match the sound of your desired guitar cable
Cons of Line 6 Relay G30
- Not offered at a low price
- The bodypack cable is short for some guitars
- $229.99 (As seen on Amazon)
7. Behringer Airplay Guitar AG10
The Behringer Airplay Guitar AG10 is an economical wireless guitar transmitter. So if you plan to get one under a hundred bucks, this device is a great option. But you should keep in mind that it has a limited high-frequency response. So don’t expect a high sound quality from it, but it can still serve the purpose.
Although the Behringer Airplay Guitar AG10 is an affordable transmitter, it offers many useful specifications. It allows you to play your guitar wirelessly within 100ft range. Also, the battery time is quite impressive. Plus, you can charge its built-in battery with a USB port.
Features and Specifications of Behringer Airplay Guitar AG10
- Low-latency design
- 5 milliseconds latency
- 24-bit/48kHz resolution
- 100ft transmission range
- Battery time up to 6 hours
- 20Hz to 16kHz frequency response
Pros of Behringer Airplay Guitar AG10
- Good-quality of transmission signals
- You can connect up to 4 guitars with this transmitter
- License-free frequency band to be used in any country
Cons of Behringer Airplay Guitar AG10
- The body is not durable
- Sound quality is not exceptional
- N/A
8. Shure BLX14-H10
The Shure BLX14-H10 is an analog wireless guitar system with a top-notch design, rock-solid construction, and easy usability and setup. In fact, this device is pretty straightforward to use. The BLX14-H10 is incorporated with the QuickScan technology that helps you escape the troubles of choosing frequencies whenever you’re connected to this wireless guitar transmitter.
Moreover, the Shure BLX14-H10 comes with a BLX1 bodypack transmitter, BLX4 receiver, and the WA302 high-quality guitar cable. The receiver box is comparatively larger than most budget wireless systems, equipped with the grouping feature for functioning multiple signals in one output.
Features and Specifications of Shure BLX14-H10
- LCD display
- Supports up to 12 channels
- 1x TA4M transmitter connector
- 50Hz to 15kHz frequency response
- 542 MHz to 572 MHz frequency range
- 12V-15V DC power supply of the receiver
- 300ft wireless transmission range (line-of-sight)
- Up to 14 hours of battery time with 2x AA batteries
Pros of Shure BLX14-H10
- The system is comfortable to wear
- UHF wireless system that ensures a long wireless range
- It automatically selects frequencies and scans channels
Cons of Shure BLX14-H10
- It is pricey
- Some users have complained about feedback problems
- There are better digital guitar wireless systems in the market in the same price range
- $299.00 (As seen on Amazon)
9. Sennheiser XSW-D Pedalboard Set
The Sennheiser XSW-D Pedalboard Set is known for being the best wireless guitar transmitter with a pedalboard system. While the device is super easy to operate, it also offers a wide wireless transmission range compared to other digital systems.
The Sennheiser XSW-D has some really cool features, making it suitable for beginner and professional guitar players. Also, it has been incorporated with a built-in tuner that is a big help if you’re using floating bridge guitars, as they need to be fine-tuned now and then.
The Sennheiser XSW-D is instilled with a built-in battery that you can charge using a USB Type-C cable. Also, the audio signal is interference-free and quite clean.
Features and Specifications of Sennheiser XSW-D Pedalboard Set
- 1/4-inch cable connector
- Up to 5 hours of battery time
- 250ft wireless transmission range (line-of-sight)
- 10Hz to 15kHz frequency response
- LCD display
Pros of Sennheiser XSW-D Pedalboard Set
- Long wireless range
- Built-in tuner
- Durable design
- Excellent audio quality with low latency
Cons of Sennheiser XSW-D Pedalboard Set
- The battery life is not up to the mark at this expensive cost
- It is very expensive as other brands are offering the same features at fewer prices
- $379.00 (As seen on the official site)
10. Shure GLXD16+
The Shure GLXD16+ is tailored for professionals. This wireless guitar transmitter and receiver system operates on both 5.8 GHz and 2.4 GHz wireless bands. This ensures improved versatility with minimal signal interference.
The Shure GLXD16+ is home to many other useful features, such as auto-scanning technology. It lets you monitor wireless signals to determine all the interfering frequencies. Additionally, this system automatically switches the frequency to a cleaner one in case of disruptions in the existing frequency.
At the same time, the Shure GLXD16+ has an extensive battery time without interrupted functionalities. Although the device is a bit bulky, the bodypack is light enough to carry without discomfort.
Features and Specifications of Shure GLXD16+
- 200ft wireless range
- 4.5ms to 5ms audio latency
- 2.4 GHz and 5.8 GHz dual-band frequency
- Simultaneous connectivity of up to 11 channels
- Up to 17 hours on 2.4 GHz and up to 12 hours on 5.8 GHz playtime
Pros of Shure GLXD16+
- Strong metallic construction
- The automatic frequency selector is a great time-saving feature
- This system reproduces high-quality sound with almost zero noticeable latency
Cons of Shure GLXD16+
- The most expensive wireless guitar transmitter on this list
- $499.00 (As seen on the official site)
You explored the 10 best wireless guitar transmitters in this article with similar and exclusive features. In terms of pricing, if you’re on a tight budget, then Xvive U2, NUX C-5RC, Ibanez WS1, and Boss WL-20 are a few options you can look into. However, if you can increase your budget, some professional devices like the Sennheiser XSW-D, Shure BLX14-H10, and Shure GLXD16+ have amazing attributes. Nevertheless, if you want something between pricey and affordable, you do have options like the Boss WL-50 and Line 6 Relay G30.
When performing on stage, clear communication is as essential as reliable audio transmission. To further enhance your on-stage coordination and ensure smooth communication during concerts or live events, consider integrating a professional wireless intercom system into your gear lineup.
Q1. What is a wireless guitar transmitter?
A guitar transmitter is a part of the wireless system that plugs into the guitar’s jack to transmit signals wirelessly to the other part of the system called the receiver. Mostly, a guitar wireless transmitter refers to the entire system, so don’t get confused.
Q2. Are wireless guitar transmitters worth it?
Wireless guitar transmitters are great for practicing and jamming. However, for stage performances, you need to have a high-quality device which can be expensive.
Q3. What is the range of the wireless guitar transmitter?
A wireless guitar transmitter has a signal range from 50ft up to 300ft.
