8 Best Noise Cancelling Headphones with Microphone for Office
By Hollyland | 4月 19, 2024
If your work mostly concerns receiving calls from clients or attending Zoom meetings, you probably want headphones with a mic attached to them. However, the worst thing that may ruin your work environment and positivity is the noise from the surroundings. These can come from your ceiling fan or talkative colleagues sitting a few feet away from your cubicle. That calls for the noise cancellation feature in a headphone.
But if you search, you may not find a variety of headsets with noise rejection capabilities. Contrarily, some headphones have noise cancellation but don’t have a microphone.
So, in this article, you will explore the 8 best noise cancelling headphones with microphones for the office. All the listed products here provide comprehensive information about pricing, connectivity, battery timing, and much more.
Comparison Table – Best Noise Cancelling Headphones with Microphone for Office
ProductPriceWeightConnectivityBattery TimeCharging TimeFrequency Response
Jabra Evolve 65 Flex$289.99136 gramsBluetooth and USBUp to 32 hours without  ANC
Up to 21 hours with ANC
Up to 2 hoursSpeakers: 20Hz to 20kHz
Microphone: 20Hz to 10kHhz
Poly Voyager Focus 2 UC$153.98175 gramsBluetoothUp to 25 hours of talk time
Up to 40 hours of music time
Microphone: 100Hz to 6.8kHz
Orosound Tilde Pro$389.99N/ABluetooth and Wired USB-CUp to 28 hoursUp to 2 hoursN/A
Kensington H3000$75.00310.99 gramsBluetoothUp to 40 hours of talk time
Up to 60 hours of media time
Up to 1.5 hoursSpeakers: 20Hz to 20kHz
Microphone: 100Hz to 10kHz
Jabra Evolve2 85$320.16286 gramsBluetoothUp to 37 hoursN/ASpeakers: 20Hz to 20kHz
Microphone: 100Hz to 8kHz / 5Hz to 20kHhz
Cyber Acoustics Essential HS-2000BT$128.99184 gramsBluetoothUp to 27 hoursN/ASpeakers: 20Hz to 20kHz
Microphone: 100Hz to 13kHz
SHOKZ OpenComm2 UC$199.9534 gramsBluetoothUp to 16 hoursUp to 1 hour20Hz to 20kHz
Hollyland Lark M2$159.00TX: 9 grams
RX: 14.8 grams
2.4GHzUp to 40 hours (Max)Up to 2 hours20Hz to 20kHz
Note: The prices mentioned for each product may be different, depending on the manufacturers, Amazon sellers, or differences in variants.
If you want to level up your communication while speaking to clients or attending Zoom meetings, here are the 8 best noise cancelling headphones with microphones for the office.
1.  Jabra Evolve2 65 Flex
The Jabra Evolve 65 Flex is a great fold-up headphone with a boom microphone, offering a top-notch noise cancelling feature and outstanding comfort so you can work like a pro. This headphone comes equipped with Hybrid ANC technology and 28mm speakers, allowing you to focus solely on your work no matter how chatty your surroundings are. The Hybrid Active Noise Cancellation puts a barrier to all those noise sounds and uses both internal and external microphones to identify and mitigate ambient noises. This gives you the freedom to work outdoors too, be it a cafe or park, you can experience interruption-free crystal-clear audio.
But it’s not only about blocking the noises but also making your voice loud and clear. Thanks to the Jabra Evolve2 65 Flex’s intelligent microphone for making that possible. Moreover, Also, it is a lightweight headphone with a compact headband backed by the Jabra Air Comfort technology that makes it featherlight when you wear it.
Key Specifications of Jabra Evolve2 65 Flex
  • Bluetooth 5.2 and USB Type-A/Type-C connectivity
  • Up to 30 meters of wireless range
  • Pairable up to 8 devices
  • Hybrid Active  Noise Cancellation
  • 20Hz to 20kHz speaker frequency response
  • 20Hz to 10kHz microphone frequency response
  • 4 Digital MEMS / 2 Analog MEMES microphone types
  • Up to 32 hours of running time without ANC
  • Up to 21 hours of running time with ANC
Pros
  • It has an amazing sound quality
  • The headset is very comfortable to wear
  • It has a boom-arm microphone that delivers clean sound, especially when the ANC is activated
Cons
  • Sometimes the muting functionality does not work
  • $289.99 (As seen on Amazon)
2. Poly Voyager Focus 2 UC
The Poly Voyager Focus 2 UC is a stereo wireless Bluetooth headphone. Being a part of the HP company, it appears that Poly has focused on the noise-cancelling feature through this model. But its other features are also decent and useful for office use.
The Poly Voyager Focus 2 UC has a 560mAh lithium-ion battery that gives up to 40 hours of listening and approx. 25 hours of talk time and the entire headset gets completely charged within 2 hours. Contrarily, you can also use a USB-A or micro-USB cable to connect the headphones to your computer and continue working while the device keeps charging.
The Poly Voyager Focus 2 UC helps you solely concentrate on your calls with its 3-level Hybrid Active Noise Cancelling, ensuring the external noises are mitigated. On the other hand, the microphone is made with the Poly Acoustic Fence technology that keeps your voice clean and clear.
Key Specifications of Poly Voyager Focus 2 UC
  • Headband wearing style
  • 4x internal microphones
  • Up to 25 hours of talk time
  • Up to 30 days of standby time
  • Up to 40 hours of music time
  • Bluetooth 5.1 wireless connectivity
  • 164ft wireless range (approximately)
  • Closed-back, on-ear, foldable design
  • 100Hz to 6.8kHz microphone frequency response
Pros
  • This headphone has an excellent battery life
  • Powerful noise cancellation, even if someone is grinding coffee in the background
  • Users are fans of its comfort due to the flexible design it possesses that adjusts to the shape of the wearer’s head
Cons
  • Although the noise cancellation is impressive, it doesn’t give complete isolation
  • Sometimes there are glitches in the device causing the noise cancelling to stop during the call
  • $153.98 (As seen on Amazon)
3. Orosound Tilde Pro
Orosound Tilde Pro are noise cancelling office headphones that are versatile and possess premium quality in terms of sound and design. And why not? This headphone is manufactured in France, giving users the freedom of customization. Yes! You heard it right. Tilde Pro lets you change the on-ear pads in both circular and rectangular shapes. Moreover, this device has a detachable microphone. All these traits make these headphones the epitome of comfort in any workplace environment.
The Tilde Pro’s noise cancellation technology enables smooth communication by diminishing distractions due to noisy surroundings. You can adjust the noise cancellation levels to up to -30dB while improving focus through the built-in ‘concentration light.’ On the other hand, these headphones also have a ‘busy light’ indicator to ensure your colleagues know you’re working on something important so they may not disturb you. No wonder these features are unique and one of their own kind.
But the story doesn’t end here. The Tilde Pro by Orosound has an integrated Voice First technology that ensures clear communication by blocking sounds from ambient noises. And guess what? This headphone set has multiple connectivity options. According to the manufacturers, you can use them as a wireless device through Bluetooth or connect them through the wire to your computer’s USB-C port.
The Orosound Tilde Pro headphones have a battery life of up to 28 hours and can be used with multiple devices and operating systems.
Key Specifications of Orosound Tilde Pro
  • Wired USB connection
  • Up to 28 hours of battery life
  • Up to 2 hours required charging time
  • 4x microphones with ANC
  • 6x microphones with Voice First technology
  • Wireless Bluetooth 5.0 connectivity up to 2x devices
Pros
  • The microphone-removal mechanism is not delicate and can withstand rough handling
  • Users admire the interchangeable earcups as this feature adds more comfort to the overall design
  • Users have reported that the sound quality of these headphones is superior to the wearer as well as the person on the other side
Cons
  • You may need to do frequent updates for optimal noise cancellation performance
  • $389.99 (As seen on Amazon)
4. Kensington H3000
The Kensington H3000 is a wireless Bluetooth headphone that provides high-quality audio, suitable for entertainment as well as work. The headphones offer Environmental Passive Noise Cancellation technology backed by Artificial Intelligence.This feature prevents unwanted distracting sounds from disturbing your work routine, allowing you to concentrate on your official tasks without a hitch.
The Kensington H3000 is compatible with almost all essential apps, including Zoom and Microsoft Teams. Moreover, you can use it on multiple operating systems, such as Android, iOS, Chrome OS, Windows, and macOS, through Google Assistant and Siri.
The Kensington H3000 has an on-ear design that consists of a cooling gel inside the earpads covered by a breathable fabric. Besides, the headband is made of an adjustable leatherette connected with a super-flexible microphone. You can also swivel the earcups up to 90 degrees for a perfect fit. Additionally, both earcups have LED lights that indicate you’re working so no one can bother you.
These noise-cancelling headphones are instilled with fast charging technology that charges the device within 15 minutes and is ready to use for up to 8 hours.
Key Specifications of Kensington H3000
  • Passive Noise Cancellation
  • Bluetooth 5.2 wireless connectivity
  • Up to 98ft wireless range
  • Complete charging time 1.5 hours
  • Maximum talk time of up to 40 hours
  • Maximum music listening of up to 60 hours
  • Partial charging time 15 minutes for 8 hours of runtime
  • 100Hz to 10kHz microphone frequency response
Pros
  • You can connect up to 2 devices at the same time
  • The earcup has a fabric covering that doesn’t let the headphones hurt your ears
  • This noise cancelling headphone is perfect for big heads due to its well-padded headband
Cons
  • These headphones disconnect occasionally
  • $75 (As seen on Amazon)
5. Jabra Evolve2 85
This Jabra Evolve2 85 is a more powerful noise cancelling headphone than the Flex version. However, it’s pricey. This over-ear headset allows you to block most distractions and can handle voices like a pro. This piece of technology comes equipped with 10 microphones in a device, offering ease of communication both indoors and outdoors. All you need to do is extend the boom mic to activate the first four mics for focused conversation. Or, simply put the boom microphone back in its position to activate the remaining six microphones to communicate in noisy environments.
The Jabra Evolve2 85 stays functional for up to 37 hours on a single charge, making you ready for unexpected Zoom calls any time of the day. This headphone is also US-certified, confirming smooth compatibility with Cisco, Avaya, and other unified communication hubs. Moreover, the design is also too comfy due to soft memory foam, an ergonomic headband, and a flexible earcup swivel, allowing for optimal load distribution.
What’s more? The Jabra Evolve2 85 has a ‘busy light’ indicator that turns on whenever you’re taking a call or busy at work, so no one can disturb you even unintentionally. Other than computers, this headphone model can also be paired with mobile phones through a USB adapter (inside the package) or Bluetooth wireless technology. Plus, there are many more useful features in this model, such as interactive earcup controls and auto-mute.
Key Specifications of Jabra Evolve2 85
  • -35dB sensitivity
  • Leatherette cushion design
  • Up to 98.4ft Bluetooth wireless range
  • Bluetooth 5.0 technology
  • 286 grams weight (approx)
  • Up to 37 hours of battery life
  • 5Hz to 20kHz analog mic frequency response
  • 100Hz to 8kHz digital mic frequency response
Pros
  • The microphone quality is more than excellent
  • It is super comfortable if you work more than 8 hours
  • Effective noise cancellation even in a crowded atmosphere
  • Great noise cancelling headphone for gaming, sales, and school work
Cons
  • The microphone pauses the current session to receive the second call
  • $320.16 (As seen on Amazon)
6. Cyber Acoustics Essential HS-2000BT
Manufactured by keeping in mind the bustling work environment of this era, the Cyber AcousticsEssential HS-2000BT offers excellent features to fulfill professional requirements. This headphone lets you enjoy impressive sound quality with unbreakable communication even in the most populated and noisy environments because it has both Active Noise Cancellation and Environmental Noise Cancellation technologies. But still, it is a lightweight audio equipment that you can carry to your office every day.
The Cyber Acoustics Essential HS-2000BT headphones do not require any software for their functionality. It seamlessly connects to Mac, Windows, and smartphones at the same time via Bluetooth USB dongle. Plus, you can use this noise cancelling headphone for all unified platforms, including Google Meet, Zoom, and Microphone Teams.
The Cyber Acoustics Essential HS-2000BT earcups let you adjust volume through buttons instilled into the design. To provide comfort, this headphone model provides earpads and adjustable headbands to ensure it fits easily on the majority of head sizes. Also, these components are padded with a soft leatherette, making it wearable all day long.
Key Specifications of Cyber Acoustics Essential HS-2000BT
  • Up to 27 hours of battery life
  • Bluetooth wireless range up to 100ft
  • Dual noise cancellation (ENC and ANC)
  • Indicator lights for mute, busy, and power
  • 100Hz to 13kHz microphone frequency response
  • 20Hz to 20kHz headphone/speaker frequency response
Pros
  • Customers appreciate the microphone quality
  • It is very easy to use and comfortable to wear for extended hours
  • Muting is a piece of cake – all you need to do is raise the microphone arm
  • It is a wonderful noise-cancelling headphone available at an affordable price range
Cons
  • Some users complained about the headset getting too hot when charging
  • $128.99 (As seen on Amazon)
7. SHOKZ OpenComm2 UC
The SHOKZ OpenComm2 UC may not appear like a typical, foamy, headphone due to its open-ear design, but it has the feature you’re looking for. This device has a noise cancelling microphone with the DSP technology, making it a great protector of unwanted background noise. It has a unique open-ear design that lets you hear all the calls quite clearly while keeping you aware of the happenings around you.
The OpenComm2 UC is powered with the latest PremiumPitch 2.0 and bone conduction feature that ensures delivering sound free from distortion by adjusting high and medium frequency sounds. Moreover, it has a rotatable boom microphone, adding more convenience during your important calls.
One of the best things about the SHOKZ OpenComm2 UC is its compatibility with smartphones and computers. The USB-A dongle can fit all your regular devices on which you usually take calls. From the comfort point of view, this noise cancelling headset is only 34 grams in weight with a soft silicone finish so you can wrap it around your head all day.
It is also dust and water-resistant allowing you to use it outdoors. Additionally, it has a good listening and talking time that can support all your work calls throughout your working hours.
Key Specifications of SHOKZ OpenComm2 UC
  • Dedicated mute button
  • IP55 sweat and waterproof
  • Up to 1 hour of charging time
  • Up to 16 hours of battery time
  • DSP noise-cancelling microphone
  • 20Hz to 20kHhz frequency response
Pros
  • Great noise cancellation
  • The battery time is quite impressive
  • Very lightweight headset for all-day usability
Cons
  • The comfort level is not up to the mark compared to the on-ear headphones
  • $199.95 (As seen on Amazon)
8. Hollyland Lark M2
If you are thinking why do you even see the Hollyland Lark M2 in this list when it is not a headphone but a wireless microphone? That’s a valid thought. While Lark 2 is not a headset, it has the potential to be your number 1 microphone for communication. You can use it for attending Zoom calls or talking to your customers through your mobile phone using your current headphones.
For example, you already have headphones for the office but they don’t have a microphone in their design. In that case, you can save some good bucks by purchasing a separate wireless microphone with noise cancellation instead of buying expensive headsets. So, basically, the Hollyland Lark M2 can ease your life and save you from spending unnecessarily.
The Lark M2 allows you to hear the voice without even disconnecting the receiver (RX) from your phone. But, if your workspace is too crowded and you prefer privacy with your conversations, you can connect this microphone to your computer to transmit your audio and use some kind of output source for the audio to hear the caller’s voice.  It can be your PC’s built-in speaker, an external speaker, or a simple headset that may be resting on your desk right now.
So what’s so special about the Hollyland Lark M2, which makes it an alternative for headphones for the office? Let’s open the facts now! The Lark M2 wireless microphone is made to break the noise and provide a clear voice to the person you are speaking to. Thanks to the Environmental Noise Cancellation technology it reduces unwanted noises on almost all frequencies, ensuring that your voice remains clean, rich, and free from distractive background sounds.
Moreover, the Hollyland Lark M2 is completely controllable. You can download the LarkSound app to adjust noise cancellation settings, increase or decrease the microphone/transmitter (TX) unit volume, and do a lot more. Plus, you can use this device for up to 40 hours.
Key Specifications of the Hollyland Lark M2
  • Environmental Noise Cancellation
  • High-quality omnidirectional microphone
  • 2.4GHz wireless transmission technology
  • Up to 1000ft of wireless transmission range
  • Max 40 hours and minimum 9 hours of battery time
Pros
  • Its noise cancellation is far more powerful than the majority of call center mics
  • The microphone audio quality is excellent than most built-in mics of headphones
  • Users admire how they can use Lark M2 for official calls as well as hobbies like YouTubing, streaming, and singing
Cons
  • The only drawback in this context is that Lark M2 is not a typical integrated microphone of a headphone
  • $159.00 (The price is seen on Amazon but may vary depending on the variant)
Factors to Consider when Choosing the Best Noise Cancelling Headphone with Microphone for Office
Don’t rush on purchasing a noise cancelling headphone with a mic if you’re not sure what things to look for. These 8 factors will help you pick the right device.
a. Type of Noise Cancellation
The noise cancellation technology has four major types. The ENC or the Environmental Noise Cancellation. The ANC or the Active Noise Cancellation. Then comes the Passive Noise Cancellation, and finally, the Hybrid Noise Cancellation.
ENC helps minimize background noises during calls whereas ANC detects external sources of noise and anti-noise those signals. Passive noise cancellation is usually the component that contributes to noise cancellation by creating physical barriers, such as cushioning on the earcups. Lastly, Hybrid noise cancellation is the combination of all.
Choosing a headphone based on the type of noise cancellation totally depends on the amount and source of noise you want to get rid of during your work.
b. Wired or Wireless
Most latest noise cancelling headphones with microphones for the office have wireless technology. Nevertheless, a few still have the same old wired connection. Some exceptional cases may even have dual connectivity options (working wirelessly or connecting the cord.)  Wired headphones connect directly to your PC’s 3.5mm or USB port, ensuring pretty stable audio transmission, freeing you from the worries of battery life and charging responsibilities.
Contrarily, wireless headphones are usually backed by Bluetooth technology. No wonder they provide freedom of movement up to several feet. Most wireless headsets have a USB dongle that you insert in your computer’s USB port and then pair it with your device to make it functional. However, the connection can be a bit unreliable compared to wired headphones, especially if the device is available at an extremely low price range.
c. Mute Function
The mute function allows you to silence your mic immediately whenever required. While this feature may look tiny, it has many great advantages. Imagine you feel like coughing during an important call. You may feel embarrassed if the loud angry cough is heard by the client. Therefore, muting your noise cancelling headphones can save your day.
In the same way, the mute function lets you keep the calling environment nice and clean in sudden noises. For instance, if working from home, your roommate enters the place while singing a song. In such scenarios, you can mute the microphone and ask your friend humbly to stay quiet because you’re discussing the upcoming project requirements with your long-distance boss.
d. Battery Life
The battery life is essential in wireless noise cancelling headsets for work because it directly affects convenience and productivity. When you are attending important meetings or listening to calls, the last thing you may want is for your headset to die in the middle.
So, make sure you pick a device with a long battery time to ensure you have no interruptions all day. This will diminish disturbances and permit you to solely focus on your daily tasks without thinking of recharging the headset again and again.
Additionally, consider a noise cancelling headphone with a mic that ensures minimal charging time. Remember, in the professional world, every second matters a lot, and waiting for your headphones to charge can be a big disappointment and a reason for frustration.
e. Comfort
Do you think you wear something discomforting on your head every day for several hours? Well, that’s not less than a burden. That is why, it is extremely important to find a noise canelling headset that’s comfortable to wear during working hours. Keep in mind that if the headphones are uncomfortable, you will be distracted. Moreover, it can cause headaches, which will affect your work performance.
Similarly, don’t fall for a headset with tight earcups no matter how aesthetic and feature-rich it is. Imagine, your ears being pressed so tight it causes infection. Therefore, look for comfy, soft cushions with an adjustable headband, as these traits can help you wear the headphones with great pleasure. You will be able to focus more on your work rather than itching the head and changing the position of the headset every now and then.
f. Material
Headphones with good materials are more suitable to wear for extended periods. They also play a vital role in sound quality and durability. For example, if the earcups have a soft memory form, it will not only provide ease to the ears but also prevent the outside noises from intrusion. As a result, you will be able to hear sound more clearly.
Likewise, high-quality plastic or metal components inside the frames can add more life to your headphones, especially if you handle them roughly. Some headsets use leather that also offers additional relaxation to the overall head and makes the product class appearance-wise.
However, avoid materials that feel sharp and pointy, especially in the areas near the ears. Some headsets have a metal extension to join the earcups with the headband. Such designs are not recommended for office use.
g. Weight
One of the leading factors to comfort in a noise cancelling headphone with a mic is the product’s weight. Remember, a lightweight headset will be more comfortable to wear, especially if you work for 8 or more hours a day. This will save you from experiencing strain on your ears and neck. On the other hand, heavyweight headphones can cause stress and fatigue, affecting your creativity and productivity.
For example, you wear a heavy headset and attend back-to-back official meetings on a certain day. Soon there will be a time that you will get annoyed by the heaviness and lose focus. So, ensure purchasing a noise cancelling headphone with a lightweight design to improve efficiency and comfort.
h. Budget
Always think of your spending potential on a noise cancelling headphone with a mic. The market may show you interesting devices with great features. But ask yourself if you can really pay for it without disturbing your other financial needs. So, for instance, if your workplace is not too noisy, you can opt for a budget-friendly noise cancellation headset. It may have less number of internal microphones and basic noise cancellation, but that will be suitable for your current requirements. However, if you think you can afford high-priced products, and they will add more value to your job, feel free to get them.
High-quality headsets with noise cancellation are rare to find. But the listed products in this article are the 8 best noise cancelling headphones with microphones for your office with a proven track record. From the pricing point of view, the Kensington H3000 is the most inexpensive of all. On the other hand, the Orosound Tilde Pro, Jabra Evolve 65 Flex and Jabra Evolve2 85 are the most expensive ones. The SHOKZ OpenComm2 UC, Cyber Acoustics Essential, and Poly Voyager Focus 2 UC fall in the middle range of pricing. On the other hand, if you already have headphones but looking for a noise cancelling microphone for communication, the Hollyland Lark M2 is the option.
FAQs Related to Best Noise Cancelling Headphones with Microphone for Office
Q1. What is the best noise cancelling headset with microphone?
You have limited options when it comes to headphones with mics that can effectively prevent noise from disturbing your work. One of the widely used noise cancelling headphone with a mic is the Jabra Evolve 65 Flex.
Q2. Do noise cancelling headphones work in an office?
It depends on the nature of your work and office environment. Most noise cancelling headphones with microphones are required in call centers. However, due to the rise in remote work, these headphones have become the need of the masses. Moreover, the use of noise cancelling headphones are unharmful for your ears and can be used in an office environment.
Q3. Do noise cancelling headphones work with a microphone?
Yes but only if you have an excellent headset. Remember, a high-quality noise cancelling headphone will be compatible with a variety of devices, including external microphones, desk phones, and mobile apps.
Q4. What is the difference between active and passive noise cancelling headphones with a microphone?
The main difference is the power consumption. If your headset has an Active Noise Cancellation, the feature will consume the battery power to stay functional. But Passive Noise Cancellation headphones are power-free. However, the ANC technology is more effective.
