Are you wondering how to post on CapCut without a TikTok account? You’ve come to the right place! In this article, we’re going to cover everything you need to know about CapCut’s creator program, how to get started, and how to post templates on CapCut.
Can Everyone Post On CapCut Without TikTok?
If you want to post on CapCut without a TikTok account, you need to be a CapCut creator first.
However, this program is exclusive to some countries, such as the UK, the US, and even Canada. This means that users living outside the eligible regions cannot post templates directly to CapCut.
You can use a VPN (Virtual Private Network), but it really needs to be a good one to bypass CapCut’s restrictions. Another way is to use third-party platforms, like TikTok, to share your templates.
Are You a CapCut Creator Yet? How to Become One
As mentioned, becoming a CapCut creator is the first step to sharing your templates on the platform.
To join the creator program, you need to apply by filling out a form and uploading a screen recording of your best template, showcasing the process of how you created the template.
Here’s how you can access the creator program form:
- Open CapCut on your mobile device.
- Go to the Templates tab.
- Now, tap on Tutorial in the upper portion of the screen.
- From there, you’ll see a small ad banner that says “Apply for CapCut Creator”.
- On the next page, you’ll see all the information on how to become a CapCut Creator. When you’re ready, scroll to the bottom and tap Apply Now.
Possible Reasons Why You Can’t Post on CapCut Without TikTok
A. Regional Restrictions
Regional restrictions are the main reason you might not be able to share your templates on CapCut. Currently, CapCut’s creator program is only available to users in the United States. If you’re in another region, you can use a VPN to access the program or use TikTok to share your templates.
Another possible reason for not being able to post from the US or any other eligible country is the change of region. If you have traveled to another country where this program has restrictions, that can cause issues with posting on Capcut. In such a case, you can wait a while to let Capcut analyze your current location. If the problem still exists, you can contact the support team.
B. Connectivity Problem
If you’re in the United States but can’t see the “Post As Template” option on CapCut, it might be due to network connection issues. CapCut is an online platform, so a stable internet connection is essential for all its features to work properly.
C. Glitches in the App
Many users encounter issues sharing templates on CapCut, and you might be one of them. If you can’t see the “Post As Template” option, it could be due to the version of the app you’re using. Make sure you have the latest version of CapCut installed.
D. New Account
If your creator account is still new, try waiting several hours before posting your first template. CapCut’s team could still be setting up your account.
How to Post on CapCut Without TikTok? (When the “Post As Template” Option is Available)
- Open CapCut on your device.
- Start creating the template you want to share.
- Once you’re done, tap on Share.
- Tap the Post as Template option.
What to Do If You Can’t Find the Post As Template Button?
1. Re-Login to Your CapCut Account
Signing out and logging into your account again might solve the missing Post as Template button on the app. This forces the app to refresh your account information and hopefully resolve any bugs or errors that may have occurred during your session.
- Open CapCut.
- Tap on Me on the bottom navigation bar.
- In your Profile, tap the Menu button in the upper right corner.
- Tap Sign Out.
- Wait for 2-3 minutes.
- Log back into your CapCut account.
- Try posting your template again.
2. Update CapCut
There might be a new version of CapCut with the fix for the missing Post as Template button. Check if there’s an update for CapCut on your device.
On Android:
- Open the Google Play Store.
- Tap on your Profile in the upper right corner.
- Go to Manage Apps & Device.
- Tap on Updates.
- Find CapCut and tap the Update button beside it.
On iOS:
- Open the App Store.
- Tap on your Profile.
- Scroll down to see the list of apps with new versions available.
- Find CapCut and tap Update.
3. Use Mobile Data Instead of Wi-Fi
Your local network could be experiencing issues that could cause CapCut to malfunction. Try switching to mobile data to rule out connectivity issues.
On Android:
- Swipe downwards on the upper right corner of your display.
- Find the Cellular Data toggle and tap on it.
- Turn off your phone’s Wi-Fi.
- Go back to CapCut and try posting another template.
On iOS:
- Swipe downwards from the upper right corner of your screen.
- In the Control Center, tap the Wi-Fi icon to turn it off.
- Now, tap the Cellular Data icon to enable it.
4. Use A VPN
A Virtual Private Network might help bypass CapCut’s regional restrictions for the creator program. However, not all VPNs will work, and you may need a reliable one (often paid) for this workaround.
Here are some of the best VPNs that can bypass region locking on most apps:
- ExpressVPN
- PrivateInternetAccess
- SurfShark
- NordVPN
- CyberGhost
5. Clear App Cache
Clearing CapCut’s cache might also resolve the missing “Post as Template” button. This will wipe all temporary data from the app, but your user data, account, and settings will be retained.
- Open CapCut.
- Tap the Gear icon in the upper right corner.
- Tap on Clear Cache.
- When prompted, tap Confirm to proceed.
6. Reinstall CapCut
If the “Post as Template” button is still missing on CapCut, try reinstalling the app. This way, you can ensure that CapCut is installed properly and there are no missing resources or packages from the app.
On Android:
- Go to your home screen and find CapCut.
- Press and hold on to the app until the options menu appears.
- Tap the Uninstall button and follow the prompts.
On iOS:
- Go to your home screen and locate CapCut.
- Hold down its app icon and wait for the popup menu.
- Tap the Remove App button.
7. Contact CapCut Support
At this point, the last thing you can do is seek help from the experts. There might be an issue with your account that can only be fixed on CapCut’s end. To ask for assistance, send an email to capcut.support@bytedance.com.
Sharing templates on CapCut without a TikTok account is possible, but you must join the creator program from an eligible country, like the US. If you’re already a creator but encountering issues, make sure you have the latest version of CapCut installed and connected to a stable network.
By following the troubleshooting steps above, you should be able to resolve the missing “Post as Template” button on CapCut. If not, you can contact CapCut’s support for further assistance.
If you’re looking to enhance your CapCut videos before uploading them independently of TikTok, a reliable streaming camera can provide crystal-clear video quality. Upgrading your gear allows you to easily create polished content, ready for CapCut edits and instant posting to your favorite platforms.
Q1. Can I use CapCut without TikTok?
Yes, you can use CapCut without TikTok. However, if you want to post templates on CapCut, you need to be a part of the CapCut creator program, which is currently in some countries. If you live outside the US, you can use a VPN to bypass restrictions or share your templates on third-party platforms like TikTok.
Q2. How do I remove TikTok from CapCut?
CapCut operates independently from TikTok, so you don’t need to remove TikTok from CapCut. However, if you want to unlink your TikTok account from CapCut, you can do it by going to Me > Menu > Manage Accounts and tapping the Unlink button next to TikTok.
Q3. Is CapCut owned by TikTok?
Yes, CapCut is owned by ByteDance, which is the same company that owns TikTok. However, CapCut functions as a separate app and does not require a TikTok account for its basic functionalities.
Q4. Can I remove the TikTok watermark with CapCut?
There’s no specific feature on CapCut that removes TikTok watermarks. To do this, you’ll need to use video editing techniques to mask or blur the watermark.
Q5. Do CapCut Creators get paid?
Yes, CapCut has monetization features for users to make money from their video templates when they are downloaded by many people.
Q6. What are the benefits of CapCut Creator?
As a CapCut creator, you gain the ability to share your templates directly on the platform so other users can use them. Besides that, you also get:
- Cash rewards for qualified and viral templates.
- Bonuses for top-performing creators.
- Access to PRO membership and CapCut Swags (for top-performing creators)
