5 Best Wireless Lapel Microphones for Camcorder in 2024
By Hollyland | January 2, 2024
Whether you’re recording a wedding, conducting an interview, or capturing the magic of a birthday party, the right audio equipment is crucial. A wireless lapel microphone is the unsung hero that can make or break your camcorder footage. It offers the freedom to move around without the hassle of tangled cords, ensuring your subject’s voice is crystal clear even in a bustling environment. To help you find the perfect match for your needs, we’ve rounded up the best wireless lapel microphones for your camcorder, guaranteeing that you capture every word with pristine clarity for those moments that matter most.
When selecting the best wireless lapel microphone for your camcorder, there are several key criteria to consider:
  1. Audio Quality: The core purpose of a microphone is to capture clear and crisp audio. Look for mics with a high-quality preamp to ensure low noise levels and a broad frequency response to capture the full range of sound.
  2. Compatibility: Ensure the microphone is compatible with your camcorder model. Some mics are designed for specific brands or have connectors that may not work with your device without an adapter.
  3. Range: Consider the distance over which the microphone can reliably transmit audio without interference or signal loss. A longer range offers more flexibility for movement and camera placement.
  4. Battery Life: Since they’re wireless, these mics run on batteries. Evaluate how long the microphone can operate on a full charge or set of batteries, and consider the convenience of rechargeability.
  5. Durability: Good build quality means the microphone can withstand some wear and tear, which is especially important for outdoor shoots or frequent transportation.
  6. Ease of Use: Look for mics that are straightforward to set up and connect, with intuitive controls and features that don’t require extensive technical knowledge.
  7. Additional Features: Some mics come with helpful extra features, like the ability to connect multiple transmitters to a single receiver or noise-cancellation capabilities.
By assessing each lapel microphone against these criteria, we can select the optimal choices to recommend.
FeatureRode Wireless GO IISennheiser AVX-MKE2Shure GLXD14/93Sony ECMAW4Tascam DR-10L
Approx. Price$300$900$500$200$200
Frequency Range2.4 GHz1.9 GHz (DECT)2.4 GHz2.4 GHzNo wireless, records on device
Max Range (line of sight)200m30mUp to 30m (depends on environment)50mN/A
Battery LifeUp to 7 hoursUp to 15 hours on receiver, 4 hours on transmitterUp to 16 hours on transmitterUp to 3 hoursUp to 10 hours
Included Microphone TypeBuilt-in mic on transmitter, lav mic optionalMKE2 lavalier microphoneWL93 lavalier microphoneBuilt-in microphone, lavalier mic not includedOmnidirectional lavalier microphone
Recording CapabilitiesYes, on transmitter(ies)NoNoNoYes, records to micro SD/SDHC card
Dimensions (transmitter)44 x 45.3 x 18.3mm63 x 67 x 29mm90.4 x 64.5 x 22.9mmNot specified52 x 55 x 24.4mm
Weight (transmitter)30g87g (incl. battery)132g including battery63g with batteries63g (with battery)
Audio Connectivity3.5mm TRSXLR, 3.5mmTA4F (TQG) connector3.5mm output jack3.5mm stereo mini jack
Multi-Channel SupportUp to 2 transmittersSingle channel per AVX setSingle channel per GLXD setSingle channelN/A
Other FeaturesCompact size, onboard recordingPlug and record, automatic sensitivity adjustmentAutomatic frequency management, metal buildInteractive interface, wireless talk functionsDual recording levels, automatic file closing
In summary, when looking for the best wireless lapel microphone for a camcorder:
  • Rode Wireless GO II is a versatile and compact option with onboard recording capabilities and a moderate price point. It operates on the 2.4 GHz frequency with a considerable operating range.
  • Sennheiser AVX-MKE2 offers professional-grade quality with a plug-and-record feature that simplifies setup. Its price is on the higher end, reflecting the premium components and features like the MKE2 lavalier microphone.
  • Shure GLXD14/93 stands out with its robust build quality and reliable performance, with features like automatic frequency management. This system is also on the higher price range and offers professional audio quality.
  • Sony ECMAW4 is a more budget-friendly wireless microphone with interactive functions and a simpler setup. However, it offers less in terms of professional features and recording quality compared to others.
  • Tascam DR-10L is unique in that it doesn’t transmit wirelessly but records directly to a micro SD/SDHC card. This can be useful if you’re on a budget and can manage without instantaneous audio transmission to your camcorder.
Remember that the “best” wireless lapel microphone will depend on your specific needs, like budget, range requirements, recording capabilities, and audio quality preferences.
Rode Wireless GO II
Overview:
The Rode Wireless GO II is a versatile and user-friendly compact wireless microphone system that has gained much attention for its simplicity and performance. It is an impressive little device suited for those wanting quality audio without the hassle of complex setups. The GO II maintains the original Wireless GO’s simplicity while adding substantial improvements that make it even more versatile.
From my experience, the Rode Wireless GO II stands out because of its plug-and-play functionality, which means you can connect it to your camcorder and start recording within minutes. The built-in rechargeable batteries, crisp sound quality, and impressive wireless range make it a superb choice for content creators, interviewers, and videographers who need reliable wireless audio.
  • Dual channel wireless microphone system
  • In-built memory for up to 24 hours of recording
  • Up to 200m line-of-sight range
  • 3.5mm TRS output to camcorder
  • Rechargeable batteries with up to 7 hours of life
  • Compact and lightweight design
  • Includes two transmitters and one dual-channel receiver
  • The dual channel system means you can record two subjects simultaneously, which is great for interviews or co-hosted videos.
  • Its compact and clip-on design makes it unobtrusive and easy to use, without the need for additional mounting equipment.
  • The on-board recording is a lifesaver if you happen to encounter interference or dropout; it ensures you have a backup.
  • The ease of setup and use is outstanding – no deep dives into menus or complex frequency management.
  • While the audio quality is excellent for most uses, audio professionals may still prefer systems with more options for fine-tuning settings.
  • The built-in non-removable battery means that once the battery degrades, you might have to send the entire unit back for service or replacement.
Prices for the Rode Wireless GO II tend to vary, but as of my latest knowledge, you can expect to pay in the ballpark of $300. This price point makes it an attractive option for both amateur and professional videographers who need a reliable wireless system without breaking the bank.
In my opinion, the Rode Wireless GO II offers an excellent blend of functionality, quality, and ease of use. Its innovative design and additional features like the internal recording make it a standout choice for a wide variety of users. Whether you’re just starting out or you’re a seasoned professional, the versatility and overall performance of the Wireless GO II make it a fantastic investment for improving your video’s audio quality.
Sennheiser AVX-MKE2
Overview:
The Sennheiser AVX-MKE2 is a gem within the world of wireless lapel microphones, especially for those looking to capture professional-grade audio with their camcorders. The standout trait of this system is the ease of use that Sennheiser has baked into its design. You’ll find that it practically configures itself to deliver the clearest sound possible, which is remarkable. One of the aspects I appreciate most is its compact receiver that plugs directly into the XLR audio input of a camcorder; this makes it not only discreet but also incredibly convenient, eliminating any tangles of wire that can often be a hassle. The MKE2 lavalier mic that comes with it is a broadcast-quality mic, ensuring that your sound is as clear and crisp as possible.
While I won’t bog you down with every spec, there are a few worth noting. First, its adaptive frequency selection is top-notch, quickly finding the cleanest channel to avoid any interference. The AVX-MKE2 works within the digital spectrum (1.9 GHz), which is less crowded than the traditional UHF band, translating to less interference and a cleaner sound. Battery life is decent, with the receiver and transmitter boasting around 4 to 15 hours of operation, depending on usage, and they’re rechargeable, which is eco-friendly and convenient.
  • Automatic frequency management simplifies operation to a no-brainer level.
  • Exceptional sound quality, thanks to the MKE2 microphone capsule.
  • Plug-and-play functionality for quick and easy setup.
  • Compact and discreet design of the receiver suited for camcorder use.
  • Price point is quite high, which might deter those on a strict budget.
  • Battery life could be better, especially for those longer shooting days.
The Sennheiser AVX-MKE2 definitely falls into the higher-end spectrum, often priced around the $900 mark. But you’re paying for a blend of performance, convenience, and the pedigree of a reputable brand like Sennheiser.
In my opinion, while the initial investment is significant, the Sennheiser AVX-MKE2 delivers reliability and quality that can make a world of difference in professional settings. Those who value audio quality and are looking to avoid the technical hassle typically associated with wireless systems will find the AVX-MKE2 to be a wise, albeit sizable, investment.
Shure GLXD14/93 Wireless Lapel Microphone
Overview
The Shure GLXD14/93 stands out in the wireless lapel microphone market as a powerful and reliable tool, perfect for ensuring high-quality audio in video productions. The first thing you’ll notice is its sleek, professional design. It’s built with durability and ease-of-use in mind, making it a go-to choice for video creators who need consistent performance.
What I’ve found impressive with the GLXD14/93 is the clarity it brings to vocal recordings. Its sound quality is pristine, with no noticeable lag or interference, which is crucial when recording with a camcorder. This level of audio fidelity comes from Shure’s well-established reputation for creating microphones that capture the natural tone of the speaker’s voice.
Moreover, the system’s LINKFREQ Automatic Frequency Management makes setup a breeze. This handy feature scans for the best open frequencies and seamlessly switches to them if any interference is detected, saving you the headache of manual adjustments in the middle of a shoot.
While the list of specifications for the GLXD14/93 is extensive, a few key points stand out:
  • Operating Frequency Band: 2.4 GHz
  • Battery Life: Up to 16 hours with the rechargeable battery
  • Transmission Range: Up to 100 feet
  • Automatic Frequency Management: LINKFREQ technology
  • Included Lavalier: WL93 Omnidirectional Condenser Microphone
  • Superb audio quality that captures natural and clear sound.
  • Long battery life, ensuring it lasts through extended shoots.
  • The automatic frequency management is a lifesaver in crowded RF environments.
  • Sturdy build quality means it’s a long-term investment.
  • Price may be on the higher side, potentially over budget for casual users.
  • The operating range might be limiting for some uses, though it’s sufficient for most standard video setups.
  • The 2.4 GHz frequency band can be crowded, which might be an issue in some urban environments.
Without sugarcoating it, the Shure GLXD14/93 is an investment. At the time of writing, it’s priced towards the upper end of the consumer market for wireless microphone systems. Yet, for those who take audio excellence seriously and require a reliable performer during critical shoots, the price reflects its premium capabilities and quality. Remember, it’s not just a microphone; it’s an assurance that your audio will be as professional as your video.
Sony ECMAW4 Wireless Microphone
Overview:
The Sony ECMAW4 is a unique offering in the wireless lapel microphone segment, tailored specifically for those who value ease-of-use alongside compatibility with a range of camcorders, including Sony’s own product lineup. What immediately sets it apart is its simple design and user-friendly interface, making it a solid pick for vloggers, interviewers, and budding filmmakers who need reliable audio without the complexity often associated with professional-level gear.
First and foremost, the Sony ECMAW4 facilitates clear communication up to 150 feet away from your camcorder, which means you have the freedom to move around without compromising audio quality. Unlike some other more cumbersome systems, this microphone is a breeze to set up. You just plug the receiver into your camcorder, clip the transmitter to your belt or pocket, attach the lapel mic, and you are good to go.
Another aspect where the ECMAW4 shines is its interactive communication feature. Not only does the transmitter capture your voice, but it also allows for two-way communication via an earpiece. This offers a novel way for directors or interviewers to guide the talent or subject discreetly during filming.
That said, compared to more robust professional systems, the ECMAW4 does trade off some advanced features for its simplicity and affordability.
  • Transmitter Type: Lavalier microphone with built-in transmitter
  • Communication Range: Up to roughly 150 feet
  • Interactive Communication: Two-way communication via an earpiece
  • Battery Life: Approximately 3 hours with the supplied alkaline batteries
  • Accessories: Comes with an arm band, earphones, and a stable clip for flexible wearability
  • Compatibility: Compatible with a variety of camcorders that support a microphone input
  • Extremely easy to set up and use
  • Portable and lightweight design
  • Interactive two-way communication is a major bonus
  • Affordable for the features offered
  • Battery life is somewhat limited
  • Audio quality might not meet the demands of high-end professional environments
  • Lacks advanced features and customization that come with more specialized microphones
As for the price, the Sony ECMAW4 offers a middle ground in the world of wireless lapel microphones. It’s not the cheapest on the market, but it certainly doesn’t carry the premium price tag of high-end models. The value proposition here lies in the features offered in relation to the cost, striking a balance that will appeal to those on a moderate budget.
In conclusion, the Sony ECMAW4 wireless microphone delivers on its promise of convenience and flexibility. It is an excellent entry-level option for someone who is not looking to dive into the complexities of audio equipment but still wants a fair degree of quality and reliability. While it may not have the deep feature set that audio professionals look for, its portability and ease of interaction make it a standout product for everyday users and semi-professionals looking to capture clear sound for their video projects.
Tascam DR-10L Micro Portable Audio Recorder with Lavalier Microphone
Overview:
The Tascam DR-10L is an ultra-compact, incredibly convenient digital recorder/lavalier microphone combo. It’s especially geared towards videographers, interviewers, and anyone needing a simple, high-quality setup for capturing audio on the go. After extensive use, I can say the DR-10L stands out in the market for its simplicity and effectiveness; no bells and whistles, just solid audio performance.
Its discreet size makes it perfect for situations where a full mic pack might be intrusive or difficult to manage. I’ve often found it particularly useful during weddings, documentary shoots, and during stage productions where having a low-profile audio solution is key. The fact that it records directly to microSD cards means you’re not tethered to your camera – an invaluable feature when flexibility and mobility are paramount.
What impressed me the most is the DR-10L’s dual recording ability, which captures audio at two different levels simultaneously to help prevent peaking and distortion. This has saved me in post-production more times than I can count as loud and unexpected noises are no longer a risk to the integrity of your audio capture.
  • Recording media: microSD/SDHC cards (supports 32GB capacities)
  • Built-in lavalier microphone
  • Recording format: BWAV (BWF) 44.1kHz/48kHz, 16/24-bit, mono/poly
  • Dual Recording mode for safety track recording
  • Low-cut filter and limiter to control noise
  • Hold function to prevent accidental operation
  • Time Track Increment function
  • The small stature of the recorder is perfect for discreet recordings.
  • Excellent sound quality for such a tiny device.
  • Dual recording mode significantly reduces the risk of distorted audio, which I find invaluable.
  • A plethora of features for reducing noise and handling errors.
  • Long battery life compared to other small recorders, for worry-free recording during extended sessions.
  • The Tascam DR-10L’s price point is well placed, considering its specialized feature set.
  • The lavalier mic’s cord length might limit mobility, depending on the scenario.
  • It lacks wireless functionality, which while making it more reliable and easier to use, could be a downside for those needing remote monitoring.
  • The menu system and screen are minimalistic, which is a double-edged sword – simple but could be frustrating for those wishing for more immediate control.
The Tascam DR-10L’s price is remarkably reasonable, often found around $199.99. Its value is excellent, considering that several competing products with similar features may come in at a higher cost. For budding videographers or anyone in need of a budget-friendly, reliable audio solution, it’s a steal.
In conclusion, the Tascam DR-10L is a specialized tool in your audio kit that punches above its weight. If you can live without the bells and whistles of more pricey models and appreciate the need for solid, reliable audio capture, this little powerhouse is worthy of serious consideration.
In conclusion, the perfect wireless lapel microphone for your camcorder should enhance your audio recording quality and be compatible with your recording setup. A good mic needs to be reliable, have a strong wireless connection, clear sound, and be easy to use. Whether you are a professional or an amateur, the list above offers a variety of options suited for different needs and budgets. Remember to consider the factors of battery life, range, and durability when making your choice. Invest in the right lapel microphone and witness a significant improvement in your video productions.
FAQs:
  1. What should I look for when choosing a wireless lapel microphone for my camcorder?
  • Look for factors such as compatibility with your camcorder, the quality of audio capture, the transmission range, battery life, the durability of the microphone, and overall build quality.
  1. Can wireless lapel mics interfere with other wireless devices?
  • Yes, they can. It’s crucial to choose a microphone with a frequency band that is less crowded or offers multiple channels to minimize potential interference.
  1. Is it important to get a microphone specific to my camcorder brand?
  • No, it’s not necessary. Many wireless lapel microphones come with universal connectors or adaptors that are compatible with a wide range of camcorder brands. However, ensure the mic you choose works with your specific model.
