New Product Coming
DAYS
HRS
MINS
SECS
Awaken the Power
Brand-new Design
Brand-new
Design
0.1s Low Latency
0.1s
Low Latency
HDMI & SDI
HDMI & SDI
Multiple Fan Modes
Multiple Fan
Modes
Direct Video for Live Streaming
Direct Video for
Live Streaming
Optimized Monitoring Feed
Optimized
Monitoring Feed
Multiple Power Supply Options
Multiple Power
Supply Options
In-App Channel Scan & Firmware Upgrade
In-App Channel Scan
& Firmware Upgrade
Next-Level Wireless
Video Transmission
With a brand-new design, 12Mbps ultra-high data rate, SDI & HDMI dual interfaces, and other features built for professional filmmaking, the Mars 400s Pro brings wireless video transmission to the next level, empowering filmmakers, crews, and content creators.
Next-Level Wireless Video Transmission
12Mbps Data Rate for a Crisp, Fine-Detailed Look
At an upgraded data rate of 12Mbps, the system can easily handle video transmission at 1080p 60 fps, ensuring quality of live broadcasts and preserving details of every picture.
8M
12M
Numbers Matter:
0.1s & 400ft (120m)
With a transmission distance of up to 400ft (120m) and latency of less than 0.1s, wireless video transmission stays uninterrupted even in a studio that is as big as a soccer field. You can see the video immediately from anywhere.
Numbers Matter: 0.1s & 400ft (120m)
SDI & HDMI Dual Interfaces
With the classic SDI + HDMI dual interfaces, you can choose either interface for input or output, and there is no need to use the same type of interface for both input and output. Whether it is a DSLR, mirrorless, or professional camera, you can easily connect it to the transmitter. The receiver supports output via both the SDI and HDMI interfaces at the same time. The system supports video transmission between multiple shooting and monitoring devices, meeting the wireless shooting and monitoring needs of most production teams.
more scene
more scene
Three Cooling Modes Available
There are three cooling modes available: auto, low, and off. The higher the fan speed, the lower the temperature of the device casing. The fan generates very little noise (the maximum noise level is 55dB). You can choose a cooling mode that meets the needs of the actual shooting.
Auto mode: The fan speed is adjusted according to the temperature of the device. To ensure rapid heat dissipation for the device, the fan speed increases as the heat rises.
Low-speed mode: The fan speed is reduced to the minimum, for a lower fan noise level.
Off mode: The fan is completely turned off to ensure no fan noise. This mode is ideal when an absolutely quiet environment is required.
1 Transmitter x 2 Receivers Efficient Monitoring Made Easy
One transmitter can work with up to two receivers. The system allows two parties (such as the director and lighting control personnel) on the shooting site to simultaneously monitor the shooting with high picture quality at the 12 Mbps data rate and ultra-low latency. Using the system, even a big production or live streaming team can achieve efficient team collaboration.
Smart Channel Scan
Smart channel scan finds the best channel for a stable and uninterrupted interference-free wireless transmission.
Note: The optimum channel is automatically selected after powerup, with no manual selection required.
Smart Channel Scan
Multiple power supply options ensure continuous power supply for any production situation. These options include an NP-F battery, a power bank, a USB charger with a USB-C interface, or a DC adapter.
5-12V
USB-C
6-16V
DC Power
Easy Monitoring via Mobile Devices
A mobile phone or tablet, with the app installed, can support monitoring. The app also functions as a tiny monitor and provides multiple auxiliary functions such as brightness histogram, frame marking, and zooming. Up to 4 mobile phones or tablets can be used for monitoring at the same time.
Packing List
Mars 400S Pro - 1TX to 1RX
Mars 400S Pro – 1TX to 1RX
Transmitter
Transmitter x1
Receiver
Receiver x1
Antenna
Antenna x5
DC Adapter
DC Adapter x1
User Manual
User Manual x1
Upgrade Your Setup
HL-ATN03-蘑菇天线(HL)Mushroom-Antenna
Mushroom Antenna
HL-ATN03
HL-ATN06-棒棒糖天线(红色,HL)-Lollipop-Antenna(Red)
Lollipop Antenna (Red)
HL-ATN06
HL-ATN07糖果盒天线(黑色,HL)-Triumph-Antenna(Black)
Triumph Antenna (Black)
HL-ATN07
HL-CS01-1-4Cold-Shoe
1/4 Cold Shoe
HL-CS01
HL-CS02-Cold-Shoe--gimbal
Cold Shoe Gimbal
HL-CS02
HL-DC01-Dual-Slot-Charger
Dual-Slot Charger
HL-DC01
HL-HD01-Mini-HDMI-to-HDMI-Cable
Mini HDMI to HDMI Cable
HL-HD01
HL-SDI500-1000-SDI-Cable(500mm)-SDI-Cable(1000mm)
SDI Cable (1000mm)
HL-SDI1000
Upgrade Your Setup
Mushroom Antenna
HL-ATN03
HL-ATN06
HL-ATN07
1/4 Cold Shoe
HL-CS01
Cold Shoe Gimbal
HL-CS02
Dual-Slot Charger
HL-DC01
HL-HD01
SDI Cable (1000mm)
HL-SDI1000
Specifications
Interface
HDMI Input (Type A Female)
SDI Input
2 Antenna Interfaces (RP-SMA Male)
DC Input
USB-C
Power Supply
DC Power Input: 6-16V
USB-C Power Supply: 5V/2A
Battery Power Supply: 6-16V DC
Power Consumption
<11W
Weight
206g (7.3oz)
Dimensions
(L x W x H): 110mm x 72mm x 33.5mm (4.33" x 2.83" x 1.32")
(Battery Plate Excluded)
Input/Output Video Format
HDMI:
480p60
576p50
720p50/59.94/60
1080i50/59.94/60
1080p23.98/24/25/29.9/30
1080p50/59.94/60
SDI:
1080p60/59.94/50 (Level A)
1080p60/59.94/50 (Level B)
1080i60/59.94/50
1080p30/29.97/25/24/23.98
1080psf25
720p60/59.94/50
1080psf24/23.98
Frequency
5GHz
Modulation Mode
OFDM
TX Power
Maximum 21dBm
RX Sensitivity
Transmission Latency
0.1s
Bandwidth
20MHz
Interface
HDMI Output (Type A Female)
SDI Output
DC Input
USB-C
Power Supply
Power Consumption
<7W
Weight
206g (7.3oz)
Dimensions
HDMI:
480p60
576p50
720p50/60
1080i50/60
1080p24/25/30
1080p50/60
SDI:
1080p60/50 (Level A)
1080i60/50
1080p30/25/24
720p60/50
1080i50 (1080psf25/24/23.98 input)
1080i60 (1080psf30/29.97 input)
Frequency
5GHz
Modulation Mode
OFDM
TX Power
RX Sensitivity
-80dBm
0.1s
Bandwidth
20MHz
