Creators are usually worried about noises for ruining their content. But let’s face the reality. Even if you are recording audio in a fully-packed acoustic environment, there are still chances that your mic may end up catching sounds. An ideal solution is to get yourself a good quality microphone with noise-cancellation capabilities.
Sadly, you won’t find many options when you search for mics online, and you are usually taken to headsets. So, if you had no luck finding typical mics with noise reduction features, you landed in the right place. This article will show you the 9 best noise cancelling microphones (not headsets or headphones) in wired and wireless brands.
Comparison Table – 9 Best Noise Cancelling Microphones in 2025
| Product | Price | Mic Type | Polar Pattern | Frequency Response | Sound Pressure Level | Connectivity | Signal-to-Noise Ratio | Wireless Range | Battery Life |
| Hollyland Lark M2S | $119.00 (USB-C version) | Wireless | Omnidirectional | 20Hz to 20kHz | 116dB | 3.5mm TRS, USB-C, USB-A to USB-C, and USB-C to Ligtning | >70dB | 1000ft | TX: Up to 9 hours RX: Up to 8.5 hours (Camera version) |
| Hollyland Lark M2 | $159.00 (USB-C, 3.5mm, or Lighning version) $179.00 (Combo version) | Wireless | Omnidirectional | 20Hz to 20kHz | 115dB | 3.5mm TRS, lightning, and USB-C | >70dB | 1,000ft | TX: Up to 10 hours RX: Up to 9 hours |
| DJI Mic 2 | $349.00 | Wireless | Omnidirectional | 50Hz to 20kHz | 120dB | 3.5mm TRS, lightning, and USB-C | N/A | 820ft | TX: Up to 6 hours RX: Up to 6 hours |
| Saramonic BlinkMe B2 | $249.00 | Wireless | Omnidirectional | 20Hz to 20kHz | 110dB | 3.5mm and USB-C | >80dB | 328ft | TX: Up to 5 hours RX: Up to 5 hours |
| Tonor D510 | $52.99 | Wired/Dynamic | Cardioid | 50Hz to 14kHz | 110dB | XLR and USB | 95dB | Not required | Not required |
| ZealSound K66 | $32.99 | Wired/Condenser | Unidirectional | 40Hz to 18kHz | N/A | USB-C | 85dB | Not required | Not required |
| Shure MV7 | $249.00 | Wired/Dynamic | Cardioid | 50Hz to 16kHz | 132dB | USB and XLR | N/A | Not required | Not required |
| RODE NT-USB Mini | $99.99 | Wired/Condenser | Cardioid | 20Hz to 20kHz | 121dB | USB-C | N/A | Not required | Not required |
| Logitech Blue Yeti Nano | $79.00 | Wired/Condenser | Cardioid and omnidirectional | 20Hz to 20kHz | 120dB | USB | 100dB | Not required | Not required |
Note: Amazon (US) is the main source of pricing information for each product. The brands and Amazon stores may or may not change the price for their offered products at any time.
9 Best Noise Cancelling Microphones in 2024 – Wireless and Wired
Here are some great microphones with active and passive noise-cancellation characteristics.
1. Hollyland Lark M2S
Hollyland Lark M2S wireless microphone offers a wide range of features when it comes to design and noise-cancellation features. This microphone kit has a unique design that sets it apart from the rest of the brands and models. Why so? Because it has a titanium clip-on design that ensures strength and a discreet appearance when you wear it on your clothing. Another remarkable feature is its branding-less style. The units are logo-free, which makes them quite versatile in diverse recording environments.
Lark M2S has a powerful Environmental Noise Cancellation (ENC) technology that eliminates all the background noises. All you need to do is press the ENC button on the transmitter or receiver. You can also set the noise-cancelling intensity through the LarkSound app by opting for the “Weak” or “Strong” levels with just a tap. Passively, Hollyland Lark M2S blocks low-frequency noises through the provided furry windshields.
And then comes the marvelous, clean, and pristine audio quality you get with Lark M2S’s 48kHz/24-bit audio resolution. If you’re worried about the runtime, you will be glad to know that this microphone’s operating time is approx. 9 hours on a single charge. But that’s not it! You can increase the battery life for longer recordings by using the microphone units inside the fully charged charging case that comes with the package.
The audio wireless transmission range of Lark M2S is up to 1000 feet. Also, the audio quality is quite stable and without lag or signal drops, as this wireless mic comes with an RF interference-resistant circuit. Moreover, you can use this microphone with computers, cameras, smartphones, and tablets.
Key Specifications of Hollyland Lark M2S
- 24-bit depth
- 48kHz sample rate
- 116dB sound pressure level
- > 70dB signal-to-noise ratio
- Omnidirectional polar pattern
- Approx. 9 hours of battery life
- Around 1.5 hours of required charging time
- 2.4GHz AFH wireless connectivity
- Up to 1000ft (300 meters) wireless range
- -37 dBV +/- 2 dB @ 1kHz microphone sensitivity
- Since it is a logo-free microphone, you can focus on creating content instead of hiding the branding in case of any restrictions from the production team or sponsors
- Its titanium clip-on design keeps the TX unit intact on your clothing whether you are running or sitting
- Its dual-level noise cancelling feature lets you record crystal-clear sound that requires less treatment in post-production
- Simple and user-friendly setup and controls
- Battery life could be better compared to Lark M2
- $119.00 (2TX 1RX USB-C version)
2. Hollyland Lark M2
The Hollyland Lark M2 comes equipped with both active and passive noise cancellation features. It offers Environmental Noise Cancellation (ENC) technology that successfully lessens noises throughout all frequencies. This delivers rich and colorless audio and sound reproduction with minimal signal interference.
Lark M2 uses 48kHz/24-bit high-fidelity audio to capture in-depth sound nuances. And to make sure the dusty air doesn’t interfere with the sound quality, this mic uses metallic mesh within the TX design, which protects against debris and dust. Moreover, the Lark M2 includes a dual anti-interference system that shields against infrared, 2.4 wireless, and radio frequencies up to 1,000ft.
The microphone provides different connectivity options, including USB-C, Lightning, and a 3.5mm TRS. This makes it compatible with DSLRs, computers, smartphones, and other mobile devices.
The build quality is also impressive and ensures ease of use and durability, with options to clip on, magnetically attach, or wear the TX as a necklace. Plus, the mic is supported by the LarkSound app which gives you great control over noise cancellation settings and volume.
The Hollyland Lark M2 is a lightweight yet powerful wireless microphone TX and RX kit with a sturdy charging case. Weighing around 9 grams, the 2x transmitters with omnidirectional built-in microphones can capture sound like a pro! Moreover, it gives you a 10-hour battery time, which can be increased to up to 40 hours, when the TX units are used while charging in the case. No wonder, the Lark M2 has been one of the top picks for podcasters, vloggers, and content creators.
Key Specifications of the Hollyland Lark M2
- 115dB SPL
- 1,000ft wireless range
- >70dB signal-to-noise ratio
- 10-hour TX battery life
- Approx. 9-hour RX battery life
- 1.5 hours of charging time for TX and RX
- 2.4GHz AFH wireless microphone system
- 3.5mm TRS, lightning, and USB-C connectivity
Pros
- The mic has a first-rate sound quality
- The pairing between TX and RX is flawless
- It has excellent noise cancellation in various recording environments
- You get complete accessories, including windshields which effectively reduce wind noise
Cons
- The transmitters can be sensitive to wind if not used with the windshield
- $159.00 (Individual USB-C, Lightning, or 3.5mm TRS versions as seen on Amazon)
- $179.00 (Combo version as seen on Amazon)
3. DJI Mic 2
The DJI Mic 2 provides a striking sound capture experience through its wireless and internal recording capabilities backed by advanced noise cancellation. The mic ensures clear and authentic audio recording, ideal for live streams, vlogs, and interviews. Its noise-canceling feature significantly lowers background noise, making this kit perfect for recording in crowded places or busy urban areas. Additionally, it comes with a windscreen that further helps mitigate wind noise during outdoor shoots.
The DJI Mic 2’s two omnidirectional microphones let you capture 2-person communication and catch sound from all directions. The mic is finely adjusted to pick details of the audio. The connectivity is also user-friendly and flexible as the TX automatically pairs to RX when the units are out of the charging case. This charging + carrying case also includes both Lightning and USB-C adapters to ensure compatibility with iOS and USB Type-C-supported devices, such as laptops and tablets. With that, you also get a 3.5mm TRS connectivity option for cameras and DSLRs.
The DJI Mic 2 has a notable design and build quality with the semi-transparent appearance of the transmitters. The mic also includes a pop filter that helps eliminate plosive sounds to ensure your audio remains clean. What’s more? DJI Mic 2 operates using 2.4GHz and Bluetooth.
Key Specifications of the DJI Mic 2
- 2.4GHz and Bluetooth wireless mic
- 50Hz to 20kHz frequency response
- 120dB SPL
- TX/RX battery life of up to 6 hours
- 70-minute required charging time
- 820ft wireless range
Pros
- Both TX and RX units charge super fast
- You can internally record audio at 32-bit flat
- The intelligent noise-canceling feature is quite impressive at filtering out unwanted background noise
Cons
- The kit lacks separate charging cables for TX and RX units
- The noise cancellation feature does not work when the DJI Mic 2 is connected to the device via Bluetooth
- $349.00 (As seen on Amazon)
4. Saramonic BlinkMe B2
The Saramonic BlinkMe B2 offers great sound quality with an active noise cancellation button. When the noise-canceling feature is enabled, you can record high-quality audio at 48kHz. It is a complete wireless microphone kit with two transmitters and one receiver for 2-person recording. The mic has a touchscreen interface, safe track functionality, and onboard recording.
Using the Saramonic BlinkMe B2 is simple. The credit goes to its user-friendly menu system, which has intuitive and speedy navigation. One great thing that gamers like about this wireless mic is wallpaper customization. You can add your favorite logo or brand to the TX screen using the Saramonic app.
Since the mic has an onboard recording, you can use the transmitter as a recording device to capture audio and use it later. Moreover, this wireless microphone is great at preventing noise from intruding on your recordings regardless of the environment.
Key Specifications of the Saramonic BlinkMe B2
- 110dB SPL
- 328ft wireless range
- >80dB signal-to-noise ratio
- 2.4Ghz wireless microphone
- -39 +/- 2dB microphone sensitivity
- 5 hours of battery life (TX/RX)
- USB-C and 3.5mm connectivity options
- 2.5 hours of required charging time (TX/RX)
- Up to 8 hours of onboard recording duration
Pros
- Clear sound quality with good battery life
- Accessing the audio settings from the TX unit is very convenient
- The active noise cancellation feature reduces noise very effectively
Cons
- The attachment magnet on the TX and RX are not up to the mark
- You cannot charge TX without RX, which limits the charging option
- $249.00 (As seen on Amazon)
5. Tonor D510
The Tonor D510 provides balanced and warm vocal quality through its high-quality dynamic core. This microphone can handle various audio frequencies and high sound levels for natural vocals with great clarity. The Tonor D510 comes with noise-reduction technology that offers a low-noise floor. Plus, the inclusion of a cardioid polar pattern also helps effectively eliminate all off-axis sounds while minimizing ambient noise.
The Tonor D510 supports both XLR and USB outputs. So, if you need to set it up quickly, you can use the USB cable to connect the mic to your computer. On the other hand, if you desire improved spatial quality, you can use this microphone with an XLR connection. Besides, you can use this mic with several audio mixers and interfaces.
Tonor D510 has a strong build quality due to its top-notch zinc alloy design, making it durable and corrosion-resistant. The mic also comes with a premium pop filter that allows you to capture crispier recordings by minimizing consonant sounds. Also, you can attach headphones for live audio monitoring in the provided 3.5mm headphone jack.
Key Specifications of the Tonor D510
- Wired dynamic microphone
- Cardioid polar pattern
- 50Hz to 14kHz frequency response
- 110dB SPL
- XLR and USB connectivity
- 95dB signal-to-noise ratio
Pros
- It has a solid construction that ensures durability
- The overall sound quality is impressive at this price range
- This microphone has a very effective noise-canceling filter
Cons
- Headphone monitoring can be noisy
- $52.99 (As seen on Amazon)
6. ZealSound K66
The ZealSound K66 is a USB microphone with a wide range of applications and compatibility. The company claims that the mic can work with Mac, Windows, Android, and iOS devices (iPhone and iPad) by simply connecting through adapters (included in the package). K66 is very easy to attach to your desired device and is ideal for content creation for platforms, like Twitch, TikTok, Instagram, and YouTube.
ZealSound K66 is crafted to provide excellent and well-balanced audio quality across a broad frequency range. It can handle high-pitched sounds without distortion. Most importantly, the microphone’s cardioid polar pattern plays really well at reducing background noise while providing impressive feedback control. Thanks to its built-in chipset for noise cancellation; it enables you to record accurate and clear voice.
Moreover, the microphone also features a mute button. A single press on the mute function turns on the LED light to confirm that your mic is now silent. Whereas, the noise cancellation gets activated by pressing and holding the mute button until the color turns blue.
The ZealSound K66 also has a gain knob that allows you to adjust sensitivity and volume to experience optimal audio quality. You can increase or decrease the sensitivity as per your recording environment. There is also an echo function that you can turn on and off whenever you need it.
And there’s more! The K66 also has a 3.5mm jack output with an adjustable volume control for live audio monitoring with zero latency.
Key Specifications of the ZealSound K66
- Condenser microphone
- Unidirectional polar pattern
- 40Hz to 18kHz frequency response
- USB-C connectivity
- 85dB signal-to-noise ratio
Pros
- Users admire its effective noise-cancellation feature
- Since the microphone allows for manual adjustment of recording levels, it gives you great control in reducing background noise
Cons
- You need to speak closely to get audio clarity
- Some users believe that the audio quality is better on Android devices compared to iOS
- $32.99 (As seen on Amazon)
7. Shure MV7
The Shure MV7 microphone comes with advanced Voice Isolation Technology backed by a cardioid polar pattern to record clean voices while reducing undesired background noise. This technology is based on passive acoustic craftsmanship. In other words, you don’t have to attach any external power to use this technology. Also, the mic has XLR and USB connectivity options, which ease the setup process.
While the MV7 is made for home-based projects, the sound it delivers is no less than a professional mic. Its core cartridge helps mitigate ambient room sound. Plus, the mic offers a suitable frequency response range that improves vocal clarity and rejects noises coming from the front side. This feature also contributes to blocking background noise with a low frequency, such as reverb from ceilings, traffic, and air conditioners.
Since the mic has dual connectivity, you can use it for live streaming, recording, and podcasting. Additionally, the Shure MV7 includes an intuitive touch panel for quick headphone mix, mic muting, volume monitoring, and gain control, along with a 3.5mm headphone output for live monitoring.
The Shure MV7 is constructed with an all-metal frame that gives it a long life and promises durability. Also, the sound quality of MV7 is closer to the original since it is capable of reproducing natural and rich vocals. Moreover, the integration of this mic with the ShurePlus MOTIV app provides more control over audio processing.
Key Specifications of the The Shure MV7
- Dynamic microphone
- 50Hz to 16kHz frequency response
- 132dB SPL
- USB and XLR connectivity options
Pros
- Long USB cables – around 10ft
- The mic is highly effective in lowering external noises and room echoes
- You can further reduce noise through the ShurePlus MOTIV app by applying the sound compression functions
Cons
- You may need to swipe or tap the touch panel multiple times
- Users also find the placement of the touch panel a bit inconvenient
8. RODE NT-USB Mini
The RODE NT-USB Mini is a popular studio microphone in a compact size. It is engineered for rich and clear sound in recordings, allowing you to capture impeccable instruments and vocals. The NT-USB Mini comes with the RODE Connect software, which makes the mic perfect for live streaming and podcasting. This program comes with a noise gate processor that effectively mitigates background noise from traffic or air conditioners.
This microphone also has a headphone amp with a 3.5mm headphone output for live audio monitoring with zero latency. The setup is pretty straightforward while the controls are quite easy to understand even for first-time users. Plus, the mic comes with a built-in pop filter to reduce plosive sounds. The mic has USB connectivity, permitting you to connect it to tablets and computers without needing any drivers.
From the design point, the RODE NT-USB Mini has a detachable magnetic stand, which keeps the mic stable on your desk surface. Besides, you can also effortlessly mount a studio arm through its 360-degree swing mount. This allows you to flexibly position the mic upside down, angled, upright, or sideways. Furthermore, its sleek design also features nylon resin and steel manufacturing, which ensures reliability in all sorts of recording environments.
Key Specifications of the RODE NT-USB Mini
- Electret condenser microphone
- 121dB SPL
Pros
- Very strong build with an all-metal framework
- The sound reproduction is crystal-clear without any changes in the original audio
Cons
- Some users have complained about the short height of the desk stand and recommend using a separate stand to experience minimal background noise
- $99.99 (As seen on Amazon)
9. Logitech Blue Yeti Nano
The Logitech Blue Yeti Nano is a USB mic that offers superb audio quality for Twitch streaming, YouTube videos, podcasting, and Zoom. As per the official site, this microphone comes with the Blue VO!CE technology to improve vocal effects so you can experience professional-grade streaming and recording. You can mitigate noise with Yeti Nano through Blue VO!CE. It lets you customize sound through various tools, including noise reduction, voice modulation, and EQ.
The Yeti Nano has a compact size that easily fits any desktop without messing up with your other hardware. It has a mixture of stylish and classic appearance, which makes it attractive on camera. Its built-in metal stand allows you to easily adjust angles for best positioning. It also has a simple plug-and-play function, using a USB cable.
The Blue Yeti Nano microphone also mainly captures sound through a cardioid polar pattern. Therefore, the mic picks up sounds that are directed toward it from the front side. This pattern is perfect for podcasting, streaming, calls, and voiceovers. Contrarily, you can switch to the omnidirectional polar pattern if you like to add ambient noise for your audience.
Key Specifications of the Logitech Blue Yeti Nano
- Wired condenser microphone
- Cardioid and omnidirectional polar patterns
- 120dB SPL
- USB connectivity
- 100dB signal-to-noise ratio
Pros
- It has a robust build quality
- Dual pickup patterns make this microphone flexible for distinct recording needs
- The design includes a dedicated volume adjustment knob followed by a mute feature
Cons
- Possible issues with the software – Some users have reported transmitting audio even when the mic is muted
- $79.00 (As seen on Amazon)
Factors to Choose Best Noise Cancelling Microphone
Consider the following factors before purchasing a noise-cancellation mic, as they will help you select the best product.
a. Active or Passive Noise Cancellation
Active noise cancellation (ANC) electronically identifies and eliminates unwanted sounds. This technology is really effective for low-frequency noises. Contrarily, passive noise cancellation uses physical barriers, such as padding or foams, to block unwanted sounds. It reduces high-frequency noises and can be found in the form of windshields in a microphone. So, when picking a microphone, make sure to review the specifications and features, as they will help you understand what noise cancellation technology the mic has.
b. Microphone Type
Typically, you come across either a wired microphone or a wireless TX and RX kit. Therefore, the selection of the mic based on these two factors depends on your preference and work requirements. The next thing you will notice is that the device will be a dynamic or condenser mic.
Dynamic microphones can usually handle elevated sound pressure levels and are often great at noise rejection. However, they may have a limited frequency response range. Condenser mics have a broader frequency response, which means they may pick up more ambient noise. That is why they often come with built-in noise reduction features.
c. Polar Pattern
A microphone may have one or multiple polar patterns, such as cardioid, supercardioid, bidirectional, or omnidirectional. A cardioid polar pattern makes the mic pick sounds from the front and side areas and reject noises from the back. The supercardioid pattern follows the same audio pickup direction but is more tighter at consuming sounds. A bidirectional microphone captures sound from the back and front while rejecting audio sources from the sides.
Lastly, omnidirectional mics capture sounds from all directions, which means if you are planning to get one without a dedicated noise cancelling feature, you may not be able to suppress noise from your audio recordings. That is why it is important that if you are buying an omnidirectional mic, it must offer noise cancellation.
d. Signal-to-Noise Ratio
The signal-to-noise ratio (SNR) measures the desired audio level compared to background noise. High SNR means that the mic can record clearer audio with minimal background noise. This is important for noise cancellation as it ensures that the main or targeted audio signals stay distinct from any unwanted sounds or signals.
e. Frequency Response
Frequency response is found in ranges, which means a sound source, such as vocals in a particular range will be captured by the microphone. For instance, if a microphone has a frequency response between 20Hz and 20,000Hz, it means any sound above or below this range will be uncaptured.
f. Accessories for Noise Reduction
When selecting a noise-cancellation mic, look for accessories, such as windshields, shockmounts, or pop filters. These can indirectly facilitate noise reduction, ensuring effective noise cancelling even if the mic uses advanced technology.
g. Price
It is not necessary that higher-priced microphones can surely provide you with noise cancelling features. There are some great examples of budget-friendly wired and wireless mics that offer many beneficial and advanced features, including active or passive noise cancellation. However, expensive mics may have other strong points, such as superior construction and noise cancellation compared to mid or low-cost mics, but that’s not always the case. You should always choose a microphone that you find pocket-friendly, as you can always upgrade later.
The first thing to do to mitigate noise from your sound recordings is to ensure you use the mic in a quiet environment. But if that’s not possible for any reason, such as you usually shoot outdoors or your room is next to the noisy traffic, try these 9 renowned noise cancelling microphone brands.
The list includes mics with wireless and wired connectivity and active or passive noise cancellation processes. If you record in both indoor and outdoor environments, you can choose wireless noise cancelling microphone systems, like the Hollyland Lark M2S, Lark M2, DJI Mic 2, or Saramonic BlinkME B2. Contrarily, if you mostly work with audio from your desk, such as podcasting or live streaming, you can choose wired noise cancelling mics, like Tonor D510, ZealSound, Yeti Nano, Shure MV7, or RODE NT-USB Mini, depending on your budget.
While exploring top-quality noise-canceling microphones, don’t overlook wireless lavalier microphones – they deliver unmatched portability and reliable noise reduction. Ideal for content creators and presenters, these discreet microphones help maintain clear audio even in noisy environments.
Frequently Asked Questions about Best Noise Cancelling Microphones
Q1. Is there a mic that cancels background noise?
There are some excellent wireless and wired microphones, which can reduce environmental noises. You can try the Hollyland Lark M2S, Lark M2, Shure MV7, and RODE NT-USB Mini. The Tonor D510 and ZealSound K66 are also recommended noise cancelling microphones by many users on various platforms, like Reddit.
Q2. Can you stop a standard mic from picking up background noise?
If you are using a standard microphone, you should know that signal interference can cause noise, despite recording in a quiet room. Therefore, turn off any televisions, fans, or radios, as they may be causing the noise. Also, use a pop filter or windshield when using the mic.
Q3. How does a noise cancelling microphone work in general?
A noise cancelling mic is made to filter out ambient noise from the target audio. This makes the mic unresponsive to noises coming from all directions. Some microphone brands use Active Noise Cancellation and Environmental Noise Cancellation technologies to make the noise cancellation process more effective.
Q4. What do you mean by active and passive noise cancellation in a microphone?
In simple words, passive noise cancellation does not require any power source to reduce noise. These are typical accessories, that come with a mic such as a windshield. On the other hand, active noise cancellation uses power to function since it uses more advanced software or hardware technology.
