New Product Coming
DAYS
HRS
MINS
SECS
Buy
The Solidcom SE Pro is designed for production teams seeking enhanced communication. With a 400m transmission range and dual-mic noise cancellation, Solidcom SE Pro ensures clear conversations in complex environment. Its 10-hour battery life and USB-C connectivity for seamless charging, making it ideal for dynamic settings like video production and outdoor activities. Plus, with pre-paired setup and water resistance, it’s ready to go when you are.
Every Time
Uninterrupted Communication
Further
Transmission Range Improved to 400m
Experience crystal-clear conversations with an impressive communication range of up to 400 meters (1,300ft). No matter where you are, stay connected.
More Stable, More Reliable
1.9 GHz, Interference-Free
Operating on the 1.9GHz frequency band, the Solidcom SE Pro minimizes interference from 2.4GHz devices like Wi-Fi and Bluetooth for reliable communication. Furthermore, Auto Frequency Hopping ensures stable transmission in complex environments.
Dual-Mic Noise Cancellation
Pro Sound Sensation
Clear Voice, Pure Sound
Imagine a world where your voice stands out amidst the noise. With dual-mic noise cancellation, ambient sound is effectively minimized, allowing you to communicate clearly, no matter where you are.
Audio Enhancement
Acoustic Upgrade
Every Word, Perfectly Clear
Speech Enhancement
With the Solidcom SE Pro, team communication will be effortless. Its intelligent audio system focuses on what matters—amplifying voices and making every conversation sound like it's happening right next to you. Whether you're on set or in the field, listen to every word with stunning precision.
Audio Enhancement
Acoustic Upgrade
Premium Sound Experience
Revolutionized Algorithm Upgrade
Step into the future with our revolutionary algorithm upgrade. Enjoy superior signal clarity, enhanced dual-mic noise cancellation, and voice enhancement for a purer, more distinct sound experience.
Wideband Frequency Response
With an impressive 150Hz–7kHz wideband frequency response, you'll enjoy audio quality that is both rich and immersive. This isn't just a headset; it's your gateway to a superior audio experience.
Supports Up to 11 Users
Designed for Larger Teams
Grow with Your Team
The Solidcom SE Pro is built to adapt as your team evolves from small to medium size. With support for up to 11 users, it's perfect for new teams on a budget, allowing for easy scalability as your needs grow.
*Maximum SKU available: 9-headset
Solidcom SE Pro and Solidcom SE Global Version are not compatible
Remote Headset
>10h
with noise cancellation on
Master Headset
>5h
with noise cancellation on, paired with 5 remote headsets
>4.5h
with noise cancellation on, paired with 7 remote headsets
>3.5h
with noise cancellation on, paired with 11 remote headsets
Remote Headset
Master Headset
*The Solidcom SE Pro is not compatible with the Solidcom C1, Solidcom C1 Pro, or Solidcom SE Global Version.
Effortless Handling
Dependable Mute Control
Your Voice, Your Control
Experience peace of mind with our dedicated MUTE button and adjustable boom microphone mute feature. Effortlessly switch between TALK and MUTE, while also featuring industry-standard PTT mode for seamless communication tailored to your preferences.
PTT Function
Talk
Mute
Dust & Water Resistance
Comprehensive Protection
Stay Connected, Rain or Shine
Designed with dust and water resistance, Solidcom SE Pro protects against rain and splashes. No matter the weather, you can trust that the Solidcom SE Pro will perform reliably, keeping you connected wherever you go.
10-Hour Battery Life
Stay Powered for Every Occasion
Uninterrupted Power
Experience a 10-hour battery life with our detachable battery, perfect for all activities. Each package includes an additional battery for added convenience. When the headset runs low, just swap the battery to restore full power instantly.
Flexible Charging
With USB-C connectivity, you can have your powerbank connected to the headset while using it.
Connect in Your Way
3.5mm Earpiece Compatibility
Universal Compatibility
The headset's USB-C port supports connection with a Hollyland USB-C to 3.5mm adapter, allowing you to use your 3.5mm earpiece. Simply wear the Solidcom SE Pro around your neck, and enjoy clear conversations with your earpiece.
*This feature is only supported by Hollyland adapter, and the adapter is not included in the package.
Sleek and Light
Lightweight Design Under 186g
Lightweight & Comfort
Crafted from lightweight, durable materials, Solidcom SE Pro reduces overall weight to under 186g/6.5oz, ensuring a secure and comfortable fit during filming.
186g/6.5oz
Sponge Ear Cushions
Comfortable and Portable
Always on Standby
Ready When You Are
Rotate Down and Talk
Simply rotate down the boom mic to start communicating. The Solidcom SE Pro is pre-paired and ready for action—no setup required. With battery installed and ear cushion fitted, it's designed for immediate use.
Easy Identification
The headband color design makes role identification effortless, with the green headband offering a subtle, unobtrusive look. Just unbox and start filming.
Choose Your Solidcom SE Pro
Solidcom SE Pro Wireless Master Headset Single-Ear Version x1
Solidcom SE Pro Wireless Remote Headset Single-Ear Version x1
Li-ion Battery Pack 770 x4
6-Slot Charging Base x1
USB-A to USB-C Cable x1
User Manual x1
Number Stickers 01 x1
Warranty Card x1
Solidcom SE Pro Wireless Remote Headset Single-Ear Version x3
Li-ion Battery Pack 770 x8
User Manual x1
Warranty Card x1
Solidcom SE Pro Wireless Remote Headset Single-Ear Version x4
Li-ion Battery Pack 770 x10
User Manual x1
Warranty Card x1
Solidcom SE Pro Wireless Remote Headset Single-Ear Version x5
Li-ion Battery Pack 770 x12
8-Slot Charging Base x1
User Manual x1
Warranty Card x1
Solidcom SE Pro Wireless Remote Headset Single-Ear Version x8
Li-ion Battery Pack 770 x18
User Manual x1
Warranty Card x1
Product Name
Solidcom SE Pro Single-Ear Headset
LOS Range
1,300ft (400m)
Operating Frequency
1.9 GHz (DECT)
Modulation Mode
GFSK
Transmit Power
≤ 21dBm (125.9mW)
Receiver Sensitivity
< -90 dBm
Battery Capacity
770 mAH (2.926Wh)
Charging Time
< 3 hours
Frequency Response
150 Hz – 7 kHz (±10dB)
SNR
71±2dB @94dB SPL,1 kHz
Distortion
< 1%@94dB SPL,150 Hz – 7 kHz
Microphone Type
Electret
Maximum Input SPL
> 115dB SPL
Output SPL
98dB SPL (@94dB SPL, 1 kHz)
Environmental Noise Reduction
> 20dB (from all directions)
Weight
≈185.2g (with battery)
Temperature
0 – 45℃ (working)
-10 – 60℃ (storage)
*Due to differences in various countries and regions, there may be variations in the operating frequency and wireless transmit power of the product.
