11 Best Wireless Microphones for Android Phones in 2023
Wireless microphones are becoming increasingly popular among individuals who want to record high-quality audio on their Android phones. With the convenience of no cords, wireless microphones allow users to move around freely while recording without the fear of tangled wires. In this article, we will discuss the top 11 wireless microphones that are compatible with Android phones.
Benefits of Using a Wireless Microphone with an Android Phone
Using a wireless microphone with an Android phone has several benefits, including:
  • Enhanced audio quality: Wireless microphones are designed to capture high-quality audio without any interference from background noise. They use advanced technologies such as noise cancellation and frequency response to ensure that the recorded audio is clear and accurate. This can be particularly useful when recording interviews, speeches, or other audio where clarity is essential.
  • Greater flexibility: One of the primary benefits of using a wireless microphone with an Android phone is the freedom of movement that it provides. Without any cords to restrict movement, users can move around freely while recording, which can be especially useful for vloggers, podcasters, and other content creators.
  • Improved convenience: Using a wireless microphone with an Android phone is also more convenient than using a wired microphone. Wireless microphones eliminate the need for cables, making setup and takedown faster and more straightforward. This is particularly useful when recording in busy or crowded areas, where cables could pose a tripping hazard or get tangled.
  • Better range: The range of wireless microphones is often larger than that of wired microphones., which means that users can record from a greater distance without sacrificing audio quality. This can be particularly useful when recording outdoor events, where the sound source may be far away from the recording device.
  • Compatibility: Many wireless microphones are compatible with a wide range of devices, including Android phones. This means that users can use the same microphone for different recording devices, which can be particularly useful for those who frequently switch between recording on a phone, tablet, or computer.
Factors to Consider when Choosing a Wireless Microphone for Android Phone
There are multiple factors to consider when choosing a wireless microphone for an Android phone such as:
  1. Compatibility: One of the most important factors to consider when choosing a wireless microphone for your Android phone is its compatibility. It is essential to ensure that the microphone you choose is compatible with your specific Android phone model. This is because not all microphones work with all phones, and some may require additional accessories or adapters to function properly.
  2. Range: The range of the wireless microphone is also an important consideration. The range is the maximum distance between the microphone and the recording device that it can operate effectively. The greater the range of the microphone, the more flexibility you will have when recording. However, it is important to note that longer range microphones may be more expensive.
  3. Battery life: Battery life is also a crucial factor to consider when choosing a wireless microphone for your Android phone. The microphone should have a long enough battery life to ensure that you can record for extended periods without worrying about the battery dying. Additionally, it is also important to consider the charging time of the microphone to ensure that it can be recharged quickly.
  4. Recording quality: The recording quality of the wireless microphone is another important factor to consider. A high-quality microphone should be able to capture clear and accurate sound without any background noise or interference. Additionally, the microphone should be able to capture a wide range of frequencies, which will ensure that the recording is rich and full.
  5. Additional features: Finally, it is also important to consider any additional features that the microphone may have. Some microphones come with built-in filters or equalizers that can help to enhance the recording quality. Others may have multiple recording modes, which can be useful for recording different types of audio. Additionally, some microphones may come with accessories such as windshields or pop filters to reduce unwanted noise during recording.
11 Best Wireless Microphones for Android Phone at a Glance
  1. Hollyland Lark C1
  2. Hollyland Lark M1 Compact Wireless Microphone System
  3. Shure MV88 Portable iOS Microphone for iPhone/iPad/iPod via Lightning Connector
  4. Sennheiser Memory Mic Wireless Microphone for Smartphones
  5. Comica CVM-WS50(C) Wireless Smartphone Lavalier Microphone System
  6. Saramonic Blink 500 B3 Ultracompact 2.4GHz Wireless Microphone System with Lavalier for Smartphone and DSLR cameras
  7. Movo PM20 Dual-Headed Lavalier Lapel Clip-on Omnidirectional Condenser Microphone with Headphone Monitoring for Smartphones.
  8. Movo WMX-1-DUO Dual Wireless Lavalier Microphone System for Smartphones
  9. IK Multimedia iRig Mic Lav compact lavalier microphone for smartphones
  10. Rode SmartLav+ Omnidirectional Lavalier Microphone for iPhone and Smartphones
  11. Movo PM10 Deluxe Lapel Clip-on Omnidirectional Condenser Microphone for Smartphones
Hollyland Lark C1
Price: $119.20 (DUO version)
Product page: https://www.hollyland.com/product/lark-c1?internal_source=blog&internal_medium=1650
Made for Android and iOS smartphones, the Hollyland Lark C1 wireless microphone comes with cutting-edge technology to ensure high-quality audio recording through your mobile. This ultra-compact microphone kit offers an impressive wireless transmission range of up to 650ft. The Hollyland Lark C1 gives you the boons of uninterrupted recording while charging. Moreover, the connectivity is pretty simple. You only need to get the Android version of Lark C1 and attach the receiver to your phone to start recording.
Besides, you get the option to buy a solo (1 x transmitter) or duo (2 x transmitters) version, depending on your requirements. Moreover, you can easily clip the transmitters on the interviewee’s clothing through the clip, making it similar to a wireless lavalier microphone. Lark C1 offers Hi-Fi sound quality throughout 20Hz to 20kHz frequency ranges. When fully charged, both transmitters last up to 32 hours inside the case, and each transmitter stays functional for 8 hours when outside the case. This wireless microphone for Android is also operable through the LarkSound mobile application, making the entire monitoring effective and simple.
Features:
  • Hi-Fi sound
  • 110 dB Max SPL
  • 48kHz and 16-bit
  • 32-hour performance
  • 1.5-hour charging time
  • 200m (650ft) LOS wireless range
  • Integrated noise-canceling in one click
  • 2.4GHz AFH wireless transmission frequency
  • The product is available in two colors
  • No need to remove the RX to playback your recording
  • It is a full plug-and-play wireless microphone for Android
  • You can use both receiver and transmitter while charging
  • Not compatible with most camera brands
Price: $149
Product Page: https://www.hollyland.com/product/lark-m1?internal_source=blog&internal_medium=1650
The Hollyland Lark M1 Compact Wireless Microphone System is a great option for anyone looking for a wireless microphone for their Android smartphone. Its compact design, high-quality audio, and long battery life make it a top choice for vloggers, podcasters, and content creators. However, its limited compatibility with devices that have a Type-C port and higher price point may make it less accessible to some users.
hidden wireless microphone
Features:
  • Compact and lightweight design
  • Dual-mic system for high-quality audio
  • Wireless connection with low latency (20ms)
  • Easy to use with plug-and-play functionality
  • Compatible with Android smartphones and other devices with a Type-C port
  • Long battery life (8 hours) with USB-C charging
  • Windscreen and carrying case included
  • Adjustable gain control to customize the sound level
  • Multiple accessories included in the package such as windscreen and lapel clip
  • LED indicator lights for easy monitoring of battery and connection status
  • Digital audio encryption to ensure secure transmission
  • Can be used in a variety of settings including vlogging, filmmaking, podcasting, and live streaming.
  • Some users may find the price slightly higher compared to other wireless microphones in the market
  • Only compatible with devices that have a Type-C port, limiting its use with older devices
Price: $149
Product Page: https://www.shure.com/en-MEA/products/microphones/mv88?variant=MV88%2FA
The Shure MV88 Portable iOS Microphone is a great option for those looking to improve the audio quality of their iOS device recordings. It offers high-quality sound, a compact design, and adjustable features for versatility. However, it may not be suitable for professional-level audio recording and has limited compatibility with non-iOS devices.
Features:
  • Compatible with iOS devices equipped with a Lightning connector
  • Records high-quality audio in 24-bit/48 kHz resolution
  • Adjustable stereo width and polar pattern for flexibility
  • Includes a windscreen and carrying case
  • Lightweight and portable design
  • Durability with a rugged metal construction
  • 90-degree hinge for flexible positioning and recording angles
  • User-friendly interface with intuitive controls and LED indicator lights
  • Adjustable gain control to customize recording levels
  • Comes with a zippered carrying case for easy transportation and storage
  • Limited compatibility with non-iOS devices
  • Requires a Lightning connector, which may not be available on newer iPhones
Price: $199.95
Product Page: https://en-us.sennheiser.com/memory-mic
The Sennheiser Memory Mic Wireless Microphone is a great option for those who want a high-quality wireless microphone for their smartphone recordings. It offers excellent audio quality, wireless connectivity, and a free app for recording and syncing audio with video. However, it may be relatively expensive compared to other smartphone microphones, and the battery life is limited to up to 4 hours.
Features:
  • Wireless microphone for smartphones, compatible with iOS and Android devices
  • Records high-quality audio in 16-bit/48 kHz resolution
  • Bluetooth connectivity for wireless transmission up to 30 meters away from the phone
  • Includes a free app for recording and syncing audio with video
  • Small and lightweight design for portability
  • Rechargeable battery with up to 4 hours of recording time
  • High-quality audio synchronization with video recording for precise and accurate sound
  • Automatic gain control to adjust the recording level based on the sound source
  • Real-time audio monitoring with the Memory Mic App for accurate recording
  • Versatile compatibility with various video and audio recording apps on smartphones
  • Ability to control multiple Memory Mics simultaneously using the Memory Mic App
  • Relatively expensive compared to other smartphone microphones
  • Requires the use of a separate app for recording and syncing audio with video
Price: $109
Product Page: https://www.comica-audio.com/product/Wireless-Lavalier-Mic-6
The Comica CVM-WS50(C) Wireless Smartphone Lavalier Microphone System is a great option for those who want a high-quality wireless lavalier microphone system for their smartphone recordings. It offers excellent audio quality, wireless connectivity, a lavalier microphone for hands-free recording, and a free app for recording and adjusting audio settings. However, it may be relatively expensive compared to other smartphone microphones, and the setup may be more complex.
Features:
  • Wireless lavalier microphone system for smartphones, compatible with both iOS and Android devices
  • Includes a receiver, transmitter, and lavalier microphone
  • Wireless transmission range of up to 50 meters
  • Includes a free app for recording and adjusting audio settings
  • Rechargeable battery with up to 6 hours of recording time
  • Multiple microphone options with the ability to switch between a lavalier mic and handheld mic
  • Omnidirectional polar pattern for versatile sound capture
  • LCD display screen for easy monitoring of battery life and connection status
  • Integrated clip for easy attachment to clothing or accessories
  • Compatible with Comica's smartphone app for additional settings and controls
  • Requires the use of a separate app for recording and adjusting audio settings
Price: $149
Product Page:
https://saramonicusa.com/blog/saramonic-blink-500-b3b4b5b6-dualchannel-wireless-systems-for-apple-lighting-usbc-devices/
The Saramonic Blink 500 B3 Ultracompact 2.4GHz Wireless Microphone System with Lavalier is an excellent option for those who want an ultracompact wireless microphone system for their smartphone and DSLR camera recordings. It offers high-quality audio recording, wireless connectivity, and a long wireless transmission range. However, it may be relatively expensive compared to other smartphone microphones, and it may not be as versatile as other wireless microphone systems that offer more than one microphone option.
Features:
  • Ultracompact wireless microphone system for smartphones and DSLR cameras
  • 2.4GHz wireless transmission technology
  • Includes a transmitter, receiver, and lavalier microphone
  • Wireless transmission range of up to 164 feet
  • Rechargeable battery with up to 5 hours of recording time
  • Multiple accessories included in the package such as windscreen, storage case, and charging cable
  • High-quality sound transmission with no dropouts or interference
  • Expandable system with the ability to add additional receivers and transmitters
  • Lightweight and portable design makes it suitable for outdoor and on-the-go recordings
  • May require additional adapters for use with certain DSLR cameras
Price: $24.95
Product Page: https://www.movophoto.com/products/pm20-dual-headed-condenser-smartphone-mic
The Movo PM20 Dual-Headed Lavalier Lapel Clip-on Omnidirectional Condenser Microphone is an excellent option for those who want an affordable and versatile lavalier microphone system for their smartphone recordings. It offers a dual-headed design for two-person interviews or simultaneous recording of two sources, an omnidirectional condenser mic for clear and accurate sound recording, and a headphone jack for real-time monitoring of audio. However, it may require an adapter for use with newer smartphones that do not have a headphone jack, and it may not be as versatile as other wireless microphone systems.
Features:
  • Dual-headed lavalier microphone system for smartphones
  • Omnidirectional condenser microphone for crystal-clear, precise sound capture
  • Includes a headphone jack for monitoring audio in real-time
  • Compatible with most smartphones, including iPhone and Android devices
  • Includes a carrying case and foam windscreens
  • 6-meter long cable for flexible recording positions
  • Dual-channel support for recording two microphones simultaneously
  • Clear audio transmission with no interference or dropouts
  • Omnidirectional polar pattern captures sound from all directions
  • Lightweight and compact design makes it easy to carry and use on-the-go
  • Adjustable gain control allows for customization of recording levels
  • Multiple power options including rechargeable batteries or USB power supply
  • May require an adapter for use with newer smartphones that do not have a headphone jack
  • May not be as versatile as other wireless microphone systems
Price: $149.95
Product Page: https://www.movophoto.com/products/wmx-1-duo-wireless-lavalier-microphones
The Movo WMX-1-DUO Dual Wireless Lavalier Microphone System for Smartphones is an excellent option for those who want to record two sources simultaneously. It offers dual wireless lavalier microphones with omnidirectional condenser mics, a long wireless transmission range, and compatibility with most smartphones. However, it may be relatively expensive compared to other smartphone microphones and may require additional adapters for use with certain smartphones or cameras. Additionally, it may not be as versatile as other wireless microphone systems that offer more than two microphone options.
Features:
  • Dual wireless lavalier microphone system for smartphones
  • Includes two transmitters and one receiver
  • Omnidirectional condenser mics for clear and accurate sound recording
  • 200-foot wireless transmission range with a long range
  • Easy setup and pairing process with one-button operation
  • Wireless connectivity with UHF frequency band for stable and reliable transmission
  • Long battery life with up to 6 hours of continuous use
  • Adjustable frequency range allows for interference-free recording
  • May require additional adapters for use with certain smartphones or cameras
Price: $49.99
Product Page: https://www.ikmultimedia.com/products/irigmiclav/
The IK Multimedia iRig Mic Lav compact lavalier microphone for smartphones is an excellent option for those who want a compact and affordable lavalier microphone for their smartphone recordings. It offers an omnidirectional condenser mic for clear and accurate sound recording, compatibility with most smartphones, and a clip-on mounting system for easy attachment to clothing. However, it may not be as versatile as other wireless microphone systems and the cable length may not be long enough for some recording situations. Additionally, it may require an adapter for use with newer smartphones that do not have a headphone jack.
Features:
  • Compact lavalier microphone for smartphones
  • Omnidirectional condenser mic for clear and accurate sound recording
  • Includes a clip-on mounting system for easy attachment to clothing
  • Includes a foam pop shield to minimize wind noise
  • 1.5-meter long cable for flexible recording positions
  • Includes a carrying case for storage and transport
  • Compact and lightweight design for portability
  • No battery or external power required, simply plug and play
  • Adjustable sensitivity allows for customization of recording levels
  • Lightweight and discreet design makes it unobtrusive during recording sessions
  • Comes with a 1-year warranty for added peace of mind.
  • Cable length may not be long enough for some recording situations
Price: $79
Product Page: https://rode.com/en/microphones/mobile/smartlav-plus
The Rode SmartLav+ is a popular omnidirectional lavalier microphone designed for use with smartphones and tablets. It connects to the device's headphone jack or Lightning port, and is compatible with a range of recording apps. Its small size and omnidirectional polar pattern make it ideal for recording spoken-word content like podcasts and interviews. However, it requires a separate recording device and may not be the best choice for recording in noisy environments.
Features:
  • Omnidirectional condenser microphone for smartphones
  • Includes a cable clip to secure the cable to clothing
  • Includes a storage pouch for transport and storage
  • Works with the Rode Rec app for additional recording features
  • audio communication that is unobstructed and uninterrupted
  • Plug & play, no extra power source or batteries needed.
  • It is unnoticeable during recording sessions thanks to its lightweight and subtle design.
  • To give customers more piece of mind, Rode offers a 2-year warranty.
  • For a full audio recording solution, it is compatible with other Rode products.
Price: $14.95
Product Page: https://www.movophoto.com/products/pm10-deluxe-lav-lapel-smartphone-mic
The Movo PM10 Deluxe Lapel Clip-on Omnidirectional Condenser Microphone for Smartphones is an affordable option for those who want a lapel microphone for their smartphone recordings. It offers an omnidirectional condenser microphone for clear and accurate sound recording, compatibility with most smartphones, and a foam pop shield to minimize wind noise.
Additionally, the lapel clip makes it easy to attach to clothing, and the 1.2-meter long cable provides flexibility for recording positions. However, the cable length may not be long enough for some recording situations, and it may not be as versatile as other wireless microphone systems. Additionally, the sound quality may not be as high as more expensive microphones.
Features:
  • Omnidirectional condenser lapel microphone for smartphones
  • Includes a lapel clip for easy attachment to clothing
  • 1.2-meter long cable for flexible recording positions
  • Includes a carrying pouch for storage and transport
  • Affordable price
  • Omnidirectional condenser mic provides clear and accurate sound recording
  • Compact and portable design for easy carrying and use on-the-go
  • Long cable length provides flexibility in placement and positioning of the microphone
  • Sound quality may not be as high as more expensive microphones
Comparison of 10 Best Wireless Microphones for Android Phone
Wireless MicrophoneConnectivityTypeFrequency ResponseMic PriceFeatures
Hollyland Lark C1Charging Port and 2.4GhzOmnidirectional20Hz-20kHz$119.20Simultaneous charging and recording, Hi-Fi sound, up to 32-hour battery time
Hollyland Lark M1BluetoothClip-on20Hz-20KHz$149Dual-mic noise reduction, real-time monitoring, auto-pairing, up to 10-hour battery life
Shure MV88LightningCondenser20Hz-20kHz$149Adjustable polar patterns, MFi certified, headphone monitoring, free ShurePlus MOTIV recording app
Sennheiser Memory MicBluetoothClip-on100Hz-20kHz$199.954-hour battery life, wireless range up to 30m, syncs audio and video automatically
Comica CVM-WS50(C)BluetoothLavalier20Hz-18kHz$1096-level gain adjustment, real-time monitoring, wireless range up to 50m, rechargeable battery
Saramonic Blink 500 B32.4GHzLavalier20Hz-16kHz$149Dual-channel receiver, real-time monitoring, up to 6-hour battery life, wireless range up to 30m, includes carrying case
Movo PM203.5mm jackDual Lavalier35Hz-18kHz$24.953.5mm headphone jack for monitoring, dual-lavalier design, omnidirectional condenser mics, 10-foot cable length, compatible with most smartphones and cameras
Movo WMX-1-DUO2.4GHzLavalier35Hz-14kHz$149.95Dual-channel receiver, 2 lavalier mics, wireless range up to 50m, real-time monitoring, includes carrying case
IK Multimedia iRig Mic LavTRRS jackLavalier30Hz-16kHz$49.99Comes with a suite of apps, omnidirectional pickup pattern, TRRS jack, compatible with most smartphones and tablets, includes carrying case
Rode SmartLav+TRRS jackLavalier20Hz-20kHz$79High-quality omnidirectional condenser mic, TRRS jack, includes pop shield and storage pouch, compatible with most smartphones
Movo PM103.5mm jackLavalier35Hz-18kHz$14.95Omnidirectional condenser mic, foam pop shield, lapel clip, 1.2-meter cable, compatible with most smartphones
Best Overall: Sennheiser Memory Mic Wireless Microphone for Smartphones. This microphone offers high-quality sound and reliable wireless connectivity, making it a great choice for a wide range of recording situations. Its compact size and easy-to-use interface also make it a convenient option for on-the-go recording.
Best Value: Rode SmartLav+ Omnidirectional Lavalier Microphone for iPhone and Smartphones. This microphone is an excellent value for its price, offering high-quality audio recording with its omnidirectional pickup pattern and easy connectivity to smartphones. It is also lightweight and portable, making it a great option for recording on the go.
Best Budget: Movo PM10 Deluxe Lapel Clip-on Omnidirectional Condenser Microphone for Smartphones. This microphone is a great budget option for those looking to improve their audio quality without breaking the bank. It features an omnidirectional pickup pattern and comes with a clip-on lapel microphone that is compatible with most smartphones. Despite its low price point, it offers reliable and clear audio recording.
Concluding Remarks
In conclusion, having a high-quality wireless microphone can greatly enhance the audio quality of your recordings, whether you're making videos, podcasts, or music. The 11 microphones we've highlighted in this article offer a range of features and benefits to suit different needs and budgets. Whether you're looking for a compact lavalier microphone or a more versatile wireless system, there's a microphone on this list that can help you achieve professional-level audio quality.
With the right microphone, your recordings will sound clear, crisp, and professional, making them more enjoyable and engaging for your audience. So, invest in a good wireless microphone and take your recordings to the next level!
Ours Choice
Based on our personal preference and extensive research, our recommendation for the best wireless microphone for android phones is the Hollyland Lark C1 and Hollyland Lark M1. These microphones offer brilliant sound recording and have a variety of features.
However, personal preference may vary, and it's important to consider factors such as price, features, and connectivity options when making a decision. It's recommended to evaluate before choosing a microphone that best fits your needs and budget.
Thank you for reading this article on the 11 best wireless microphones for android phones. I hope you found it informative and helpful in making your decision on which microphone to purchase. If you have any questions or feedback, please feel free to share them in the comments section below. Your thoughts and opinions are important to us and we welcome any input you may have. Thank you again for reading and happy recording!
Achieving clear audio quality can significantly enhance the impact of your mobile video content. A wireless lavalier microphone designed specifically for Android ensures professional-level sound and convenient operation, allowing you to record effortlessly from anywhere.
Best Seller
Sale
Hollyland LARK M2S - Wireless Clip-on Microphone
$139
$159
What is a microphone's range?
The distance between a microphone's upper and lower limiting frequencies is referred to as its frequency range. Modern microphones are capable of picking up frequencies between 1 Hz and 140 kHz..
Are wireless microphones compatible with all Android phones?
Not all wireless microphones are compatible with all Android phones. You need to check the specifications of the microphone to ensure it's compatible with your phone. Some microphones work with both Android and iOS devices, while others are designed specifically for Android.
How far can I move away from my Android phone with a wireless microphone?
The distance you can move away from your phone depends on the wireless range of the microphone. Most wireless microphones for smartphones have a range of around 30-50 meters. However, the range may vary depending on the environment and any obstructions in the way.
Can I use a wireless microphone with a video recording app on my Android phone?
Yes, most wireless microphones for Android phones can be used with video recording apps. However, you need to check if the microphone is compatible with the specific app you want to use.
How long does the battery last on a wireless microphone for Android phones?
The battery life of a wireless microphone for Android phones varies depending on the brand and model. Some microphones can last up to 10 hours, while others may only last for 3-4 hours. You need to check the specifications of the microphone to know how long the battery will last.
Can I use a wireless microphone for live streaming on my Android phone?
Yes, you can use a wireless microphone for live streaming on your Android phone. However, you need to ensure that the microphone is compatible with the streaming app you want to use.
Do I need any special equipment to use a wireless microphone with my Android phone?
No, you don't need any special equipment to use a wireless microphone with your Android phone. Most wireless microphones for smartphones come with everything you need to get started. However, you may need an adapter if your phone doesn't have a headphone jack.
Can I connect multiple wireless microphones to my Android phone?
Some wireless microphones for Android phones allow you to connect multiple microphones at once. However, you need to check if the microphone you're interested in supports this feature.
How crucial is a good microphone?
Human hearing can detect noises between 20 Hz (think low sub bass) to 20,000 Hz (almost inaudible "airy" sounds), depending on the frequency. Because of this, it's critical that a studio-grade microphone be able to catch the majority of this spectrum.
How can I get the finest audio quality out of my microphone?
Microphone location can affect quality if it is too close to the mouth or angled incorrectly. Distance: Stand 6 to 10 inches (15–25 cm) away from the microphone during recording. This is the setup, and it ought to be the best for the majority of podcasters. You can always try different distances to see which one suits you best.
Facebook
Twitter
Pinterest
Related Posts
