In quiet scenes recommand turn off noise reduction or turn on 【Weak】Noise Cancellation.
In a noisy outdoors environment, you can try turning on strong noise reduction.
【Denoise OFF】
【Weak】 Noise Cancellation: The noise will be reduced by -1dB.
【Strong】 Noise Cancellation: The noise will be reduced by –14dB.
Article Number: 【AS-220926001_9】
