Astra P1
Buy
UHD 4K60
Cinema Clarity.
Shine in Shadows.
Live venues aren’t always well lit — halls, auditoriums, and churches often present challenging and complex lighting environments. The Astra P1’s 1/1.8” sensor increases per-pixel light intake to deliver crisp, noise-free 4K footage.
Church Live Streaming
Hall & Auditorium
Live Production
Face Detection AE
OFF
Face Detection AE
ON
Up to
30x
optical
Effective Pixels
8.42
megapixels
Image Sensor
1/1.8″
CMOS
1x
10x
20x
30x
AI Auto Tracking
Locks on the Presenter.
Tracks Every Move.
Presenter Tracking: The Astra P1 uses human-based logic to follow the presenter, analyzing posture and motion to distinguish them from the background. In crowded environments or complex setups, it maintains a precise lock on every move.
Zone Tracking: Define up to 4 key areas (podium, whiteboard, demo table, etc.). The Astra P1 then tracks between them as the target moves to provide a smooth transition in large spaces. Ideal for large auditoriums where a single operator needs reliable, automatic coverage.
NDI® | HX3 Support
Pro Connectivity.
No Licenses Needed.
An NDI® | HX3 license is included with every Astra P1 — no extra cost. Just connect one Ethernet cable to stream near-lossless 4K video with ultra-low latency. The Astra P1 integrates into your NDI workflow, ready for vMix, OBS, or any professional broadcast studio.
Web Control
Every Setting in
One View
Open a browser tab on your computer for full access to your control panel. Pan, tilt, zoom, and manage every professional setting remotely.
Power of One
A single PoE+ cable delivers 4K video, audio, power, and control.
Broadcast-Grade I/O &
Protocol Support
The Astra P1 supports simultaneous output via HDMI 2.0, 3G-SDI, USB, and LAN. It delivers up to three independent HD streams and supports a full range of protocols, from standard VISCA/Pelco for control systems to USB UVC, IP-based streaming, and FreeD for AR/VR virtual production.
Any Workflow.
Every Stage.
Output independent main and sub streams to handle high-quality recording and low-latency monitoring at once. Whether in churches, halls, or live events, the Astra P1 is built to perform in any professional setup.
Logic Church
Lekki, Lagos, Nigeria
Good Shepherd Parish
Pampanga Province, Philippines
Universele Kerk van Gods Rijk
Netherlands
FAE Instant Support
5-Year Warranty
Every Astra P1 comes with a 5-year warranty. Our field application engineers are on standby to provide instant technical support. At Hollyland, your vision is our mission. We are committed to your long-term success.
Register Now
Astra P1
Professional Precision. Effortless Motion.
UHD 4K60
Face Detection AE
30x Optical
AI Auto Tracking
NDI®|HX3 Support
Ease of Use
Optional PTZ Controller
5-Year Warranty
Buy Now
Your Package List
PTZ Camera x 1
Remote Controller x 1
Power Adapter x 1
USB-B to USB-A Cable x 1
RS232 Cable x 1
Wall Mount Bracket x 1
Ceiling Mount Bracket x 1
Upgrade Your Setup.
Astra P1 PTZ Camera
Remote Controller
RS232 Cable
Power Adapter
Camera
Image Sensor
1/1.8″ High-quality CMOS Sensor
Effective Pixels
8.42 Megapixels (16:9 aspect ratio)
Optical Zoom
30x Zoom (f = 7.1mm ~ 210mm)
Digital Zoom
16x
Video Format
HDMI:
2160p25/29.97/30/50/59.94/60
1080p29.97/30/50/59.94/60
1080i50/59.94/60
720p59.94/60
3G-SDI:
1080p25/29.97/30/50/59.94/60
1080i50/59.94/60
720p59.94/60
Aperture Range
F1.61 ~ F5.19
Field of View (H/V)
Horizontal: 59.2° ~ 2.5°
Vertical: 34.6° ~ 1.4°
Minimum Illumination
0.5 Lux (F1.8, AGC ON)
Shutter Speed
1/30s ~ 1/10000s
Signal-to-Noise Ratio (SNR)
≥55dB
PTZ Performance
Rotation Range
Pan: ±170°
Tilt: -30° ~ +90°
Rotation Speed
Pan: 1.7°/s ~ 100°/s
Tilt: 1.7°/s ~ 69.9°/s
Preset Positions
255 Positions (Accuracy: 0.1°)
I/O Interface
Audio
1 × 3.5mm LINE IN
1 × 3.5mm LINE OUT
Communication
1 × RS485 (2-pin Phoenix Terminal)
1 × RS232 IN (8-pin Mini-DIN)
Network
1 × RJ45 10M/100M/1000M Adaptive Ethernet
USB
1 × USB 2.0 Type-A
1 × USB 3.0 Type-B
Video
1 × 3G-SDI
1 × HDMI 2.0
Power
DC 12V (JEITA Type)
Network Features
Video Compression
H.264 / H.265 / MJPEG
Video Streams
Main Stream (First Stream), Sub Stream (Second Stream)
Main Stream Resolution
3840×2160, 1920×1080, 1280×720, 1024×576, 720×480, 720×408, 640×480, 640×360
Sub Stream Resolution
720×480, 720×408, 640×480, 640×360, 480×320, 320×240
Supported Protocols
NDI®|HX3, TCP/IP, HTTP, RTSP, RTMP(S), DHCP, SRT, Multicast, etc.
General Specifications
Input Voltage
DC 12V/PoE+
Input Current
2A (max.)
Power Consumption
18W (max.)
Operating Temperature
32°F ~ 104°F (0°C ~ 40°C)
Storage Temperature
-40°F ~ 140°F (-40°C ~ 60°C)
Dimensions
(L×W×H): 169×188×226mm
Net Weight
Approx. 2.3kg
apec
