Where Professional Meets Next-Level.
The Solidcom H1 Wireless Intercom System is a scalable, license-free communication solution designed for productions of any size. Operate up to 30 beltpacks and 12 groups without a central station, or scale up to 80 beltpacks and manage up to 100 groups with the Geo Central Station, covering over 4 million square meters by leveraging advanced roaming cascade technology. With cloud access, smart grouping, and seamless integration with Dante and existing wired intercom systems, Solidcom H1 ensures effortless team coordination. Enjoy true wireless audio, intuitive setup, and massive coverage — empowering production teams to communicate without limits.
Up to 80 Beltpacks.
Up to 80 Beltpacks.
Up to 80 Beltpacks.
Up to 80 Beltpacks.
Up to 80 Beltpacks.
Up to 80 Beltpacks.
Up to 80 Beltpacks.
Up to 80 Beltpacks.
Up to 80 Beltpacks.
Up to 80 Beltpacks.
Up to 80 Beltpacks.
Up to 80 Beltpacks.
Flexible
Configuration.
From small film sets to large broadcast productions, scale your system effortlessly with 1.9 GHz wireless communication.
Compact Setup Up to
30 Beltpacks.
30 Beltpacks.
30 Beltpacks.
30 Beltpacks.
30 Beltpacks.
30 Beltpacks.
30 Beltpacks.
30 Beltpacks.
30 Beltpacks.
30 Beltpacks.
30 Beltpacks.
30 Beltpacks.
No Central Station Needed.
Each Solidcom ANT01 unit operates independently, enabling full-duplex communication for up to 20 beltpack users — without the need for a Geo Central Station. Link up to 3 Solidcom ANT01 units for a streamlined setup supporting as many as 30 beltpacks.
Pro Setup Up to
80 Beltpacks.
80 Beltpacks.
80 Beltpacks.
80 Beltpacks.
80 Beltpacks.
80 Beltpacks.
80 Beltpacks.
80 Beltpacks.
80 Beltpacks.
80 Beltpacks.
80 Beltpacks.
80 Beltpacks.
No License Fees.
For larger teams, pair Solidcom ANT01 with the Geo Central Station to support up to 80 beltpacks in full-duplex mode. No additional license fees. No hassle. Just powerful communication, ready when you are.
* When paired with the Geo Central Station, each Solidcom ANT01 unit supports up to 20 beltpacks (when 4 units or fewer are connected) or up to 10 beltpacks per unit if more than 4 Solidcom ANT01 units are connected (starting from the fifth unit).
Massive Wireless
Coverage.
No Limits in Sight.
No Limits in Sight.
No Limits in Sight.
No Limits in Sight.
No Limits in Sight.
No Limits in Sight.
No Limits in Sight.
No Limits in Sight.
No Limits in Sight.
No Limits in Sight.
No Limits in Sight.
No Limits in Sight.
Engineered for scale — covers the equivalent of 560 soccer fields with a seamless wireless network.
* The signal coverage range depends on the placement of the Solidcom ANT01.
Powerful On Its Own.
A single Solidcom ANT01 unit covers up to 500 meters (1640ft) in radius (in open-field conditions). With 3 Solidcom ANT01 units in IP cascading, the system supports up to 30 beltpacks. For larger deployments, expand through 2W/4W interfaces to connect additional Solidcom ANT01 systems or third-party intercoms — no upper limit.
500m (1640ft)
Extreme Roaming Deployment.
Up to 8 Solidcom ANT01 units can be roaming-cascaded with the Geo Central Station to deliver wireless coverage over 4 million square meters — equivalent to 560 standard soccer fields.
Smart Group Management.
Fully in Control.
Massive Grouping. Built for Scale.
When paired with the Geo Central Station, you can save and manage up to 100 independent groups — ideal for large-scale events and rental applications. Switch, save, and manage groups effortlessly across projects.
Essential Grouping. Fast and Flexible.
Whether you're using one, two, or three ANT01 units, the system supports up to 12 groups. Perfect for compact setups and fast-moving teams.
Lightweight & Compact
Wireless Beltpack.
Under
305g
weight
Lightweight Design.
Weighing under 305g (battery included), Solidcom BPK01 is lightweight and compact. Clip it to your waist or hang it around your neck — you'll barely notice it's there.
Up to
15-Hour
battery life
15-Hour Battery Life.
Engineered for endurance with a dedicated battery, ensuring up to 15 hours of continuous operation — ready for the longest production days.
Apple Sony Shokz Bose
True Wireless Audio.
Go fully wireless with the built-in Bluetooth module. Compatible with both TWS earbuds and Bluetooth over-ear headsets — leave the cables behind and move freely.
Under
305g
weight
Lightweight Design.
Up to
15-Hour
battery life
Go fully wireless with the built-in Bluetooth module. Compatible with both TWS earbuds and Bluetooth over-ear headsets—leave the cables behind and move freely.
Seamless Roaming.
Solidcom ANT01 maintains stable audio communication across zones with seamless, real-time roaming.
seamless-mask
Tailor Your Talk.
Multi-Function Buttons.
With 4 fully customizable buttons, the Solidcom BPK01 adapts to any workflow. Each button can be assigned as a talk key or call alert, and supports up to 4 stacked actions (totally 16 audio channels) — like talking to multiple channels, sending multiple call signals, or combining both in one press. Powerful control, simplified.
Anywhere, Instantly.
Cloud Access.
Two Flexible Connection Modes.
With Geo Central Station, up to 8 Solidcom ANT01 units can be cascaded over the internet, enabling cloud-based intercom for up to 80 wireless beltpacks — perfect for large-scale productions and distributed teams.
In standalone mode, up to 3 Solidcom ANT01 units can be cascaded over the internet, enabling cloud-based intercom for up to 30 wireless beltpacks — ideal for mobile teams and lightweight productions.
Universal
Compatibility.
Compatibility.
Compatibility.
Compatibility.
Compatibility.
Compatibility.
Compatibility.
Compatibility.
Compatibility.
Compatibility.
Compatibility.
Compatibility.
Back Panel
Equipped with standard 2W/4W interfaces, Geo Central Station connects directly to third-party intercom systems — effortless setup, flawless integration.
1
Power Switch
2
Ventilation Holes
3
SFP Port *2
4
RJ45 4W Interface *2
5
DC Power Port
6
AC Power Port
7
Ethernet Port *2 (With POE++ Power Supply)
8
Ethernet Port *2 (Without POE Power Supply)
9
Ethernet Port *1 (For Central Station Networking)
10
GPIO Interface
11
3-Pin XLR 4W Interface
12
3-Pin XLR PGM IN Interface
13
RJ45 DANTE Interface (4*4)
14
Walkie-Talkie Port
15
16
3-Pin XLR SA Interface
17
3-Pin XLR 2W Interface *2
Front Panel
Equipped with 8 Call Toggle Switches,
allowing for quick and seamless switching between call states.
1
Display Screen
2
Local Volume Knob
3
Speaker
4
Call Toggle Switch
5
Call Status Indicator (Red and green lights indicate talk and listen status.)
6
Menu Knob
Seamless Dante Integration.
Geo Central Station features native Dante support with 4×4 network ports — no extra gear, no added complexity. Just direct integration, reduced rack space, and reliable, independent audio channels ready for professional workflows.
Intuitive Setup.
Smarter Control.
Effortless Pairing & Upgrades
Connect the charging base to the Geo Central Station or Solidcom ANT01 to effortlessly pair beltpacks and deliver firmware or configuration updates in one go — streamlining setup and boosting efficiency for large-scale deployments.
Plug-and-Play Cascade.
Geo Central Station and Solidcom ANT01 connect via a network cable — no manual IP setup required.
Role-Based Grouping.
Pre-configure common roles like Director, Camera Op, or Gaffer, then apply settings across all beltpacks with one-click batch configuration.
Wireless Access.
Manage your system via Wi-Fi or Bluetooth using a browser or HOLLYVOX App on PC or mobile.
Backup. Restore. Deploy.
Export your full system setup as a config file for easy backup or fast recovery. Upload it anytime to instantly sync parameters across multiple devices.
Wireless Access.
What's in the Box
Geo Central Station
Solidcom ANT01
Solidcom BPK01
Geo Central Station
Gooseneck Microphone
10-Pin to 4-Pin XLR Adapter Cable
Geo Central Station WiFi & Bluetooth Antenna
Geo Central Station AC Power Cable
Quick Guide
Warranty Card
Solidcom ANT01
Fiberglass Antenna x 4
Solidcom BPK01 x 10
(No Battrey Included)
Solidcom BPK01 Battery x10
Solidcom Single-Ear Headset x 10
10-Pin to 4-Pin XLR Adapter Cable x 10
Solidcom BPK01 Battery Charging Base
Tempered Glass Screen Protector x 10
RJ45 to Dual XLR Cable
XLR Network Cable
Solidcom ANT01 POE Power Adapter
AC Power Cable x 2
DC Power Adapter
USB-A to USB-C Cable
Solidcom Hard-Shell Carry Case (1 Antenna and 10 Beltpacks)
Quick Guide
Warranty Card
Solidcom ANT01
XLR Network Cable
AC Power Cable
Quick Guide
Warranty Card
Solidcom BPK01
Quick Guide
Warranty Card
Upgrade Your Setup.
Solidcom Double-Ear Headset
Geo Central Station
Solidcom ANT01
Solidcom BPK01
Geo Central Station
Total Power Consumption
44W
PoE Output Power
120W; 60W/Port
DC Input Voltage
46V – 54V
AC Input Voltage
85V – 264V
Dimensions
482.6mm x 88.1mm x 385mm
Weight
7.25kg
Operation Temperature
-10 ℃ – 45 ℃
Storage Temperature
-20 ℃ – 60 ℃
LEMO Audio
Input Frequency Response
150 Hz – 7 kHz
Maximum Input SPL
115dB SPL
Noise Cancellation Depth
20dB
Distortion
< 1%
Signal-to-noise Ratio (SNR)
67dB
Output SPL Level
113dB SPL Max
Solidcom ANT01
LOS Range
500m
Operating Frequency
CE:
DECT: 1880 – 1900 MHz
BT: 2402 – 2480 MHz
WiFi: 2412 – 2472 MHz
FCC:
DECT: 1920 – 1930 MHz
BT: 2402 – 2480 MHz
Transmit Power
CE:
DECT: ≤ 24 dBm
BT: ≤ 5.83 dBm
WiFi: ≤ 12.7 dBm
FCC:
DECT: ≤ 20 dBm
BT: ≤ 4.88 dBm
WiFi: ≤ 22.35 dBm
Bandwidth
DECT: 1.728 MHz
BT: 1 MHz
WiFi: 20 MHz
Modulation Mode
DECT: GFSK
BT: GFSK
WiFi: OFDM
Receiver Sensitivity
-90 dBm
Battery Life
Antenna Gain
4dB
Power Consumption
15.5W
PoE output Power
≤ 45W
PoE Input Power
≤ 60W
V/G Mount Battery Voltage Range
11V – 30V
Dimensions
302mm x 188.56mm x 64.6mm
Weight
1987g
-10 ℃ – 45 ℃
Storage Temperature
-20 ℃ – 60 ℃
Solidcom BPK01
LOS Range
500m
Operating Frequency
CE:
BT: 2402 – 2480 MHz
FCC:
BT: 2402 – 2480 MHz
Transmit Power
CE:
DECT: ≤ 24 dBm
BT: ≤ 5.92 dBm
FCC:
DECT: ≤ 20 dBm
BT: ≤ 7.32 dBm
Bandwidth
DECT: 1.728 MHz
BT: 1 MHz
Modulation Mode
DECT: GFSK
BT: GFSK/π/4 – DQQPSK/8DSK
-90 dBm
Battery Life
> 15h
Antenna Gain
Power Consumption
PoE output Power
PoE Input Power
Dimensions
114.65mm x 89.2mm x 61.8mm
Weight
305g
-10 ℃ – 45 ℃
Storage Temperature
-20 ℃ – 60 ℃
LEMO Audio
150 Hz – 7 kHz
Maximum Input SPL
115dB SPL
20dB
Distortion
< 1%
67dB
Output SPL Level
113dB SPL Max
