12 Best Noise Cancelling Microphones in 2023 – Pros, Cons, and Features
By Hollyland | October 7, 2023
Noise-canceling microphones are necessary for you if you think your recording environment is noisy. Having mics with noise-canceling features helps mitigate unwanted sound, and you can capture clean and crisp audio. Such microphones use various technologies to reduce noise and ensure delivering high voice quality.
So, in this article, you will find the 12 best noise-cancelling microphones that are popular in 2023. You will learn about their specifications and features, as well as their pros and cons. Moreover, you will also find a short guide to help you purchase the right microphone.
Factors to Consider when Picking the Best Noise Cancelling Microphones in 2023
Here is a brief guide on choosing the best noise-cancelling microphones.
a. Microphone Type
When selecting a noise-cancelling mic, you will find the best options with three microphone types. It will either be a condenser, dynamic, or capsule microphone. The majority of noise cancellation microphones are condenser mics. Likewise, you will find dynamic mic types, and rarely there are microphones with a capsule that offer noise cancellation traits.
b. Noise Cancelling Technology
Usually, there are three types of noise cancellation technologies – adaptive, passive, and active noise cancellation (ANC). Some microphones are made with all three of them, while others are built with adaptive noise cancelling, which is the standard technology found in most noise cancelling microphones. You can also find mics with ANC and adaptive noise cancellation. Such mics will mitigate noise in the microphone as well as in the headphones/speakers.
c. Polar Pattern
When looking for noise cancelling microphones, you should strive to get a cardioid polar pattern since it captures sound from a single direction, reducing the chances of recording noises from sides and behind. Contrarily, you can opt for multi-polar pattern mics, but they are expensive.
d. Price
Mics with standard noise cancelling technology can be found in the price range of $40 to $250. But if you desire dual recording patterns and professional-grade microphones, they can cost you around $1000 or more.
Comparison Table – 12 Best Noise Cancelling Microphones in 2023
ProductPriceMic TypePolar PatternConnectionFrequency Response
Fifine K669B$32.99CondenserCardioidUSB 2.020Hz to 50kHz
Samson C01U Pro$33.86CondenserSupercardioidUSB 20Hz to 18kHz
Bietrun UMKF01$36.99Electret condenserCardioidUSB50Hz to 20kHz
Tonor ORCA-001$69.99CondenserCardioid USB Type-C50Hz to 16kHz
Blue Yeti Nano$89.99CondenserOmnidirectional and cardioidUSB 2.020Hz to 20kHz
RODE NT-USB Mini$99.00Electret condenserCardioidUSB Type-C20Hz to 20kHz
HyperX Quadcast $99.99CondenserStereo, figure-8, omnidirectional, and cardioidUSB and 3.5mm jack20Hz to 20kHz
Cyber Acoustics CVL-2230$49.99Cardioid and omnidirectionalUSB20Hz to 20kHz
Shure MV7$249.00Dynamic capsuleCardioidUSB, 3.5mm jack, and XLR20Hz to 20kHz
Electro-Voice RE20$449.00CondenserCardioidXLR45Hz to 18kHz
Lewitt LCT 840$1,199.00CondenserOmnidirectional, wide cardioid, supercardioid, cardioid, and figure-8XLR 20Hz to 20kHz
Neumann M 149 Tube$5,795.00Capsule Figure-8, Cardioid, Hypercardioid, Omnidirectional, Wide Cardioid, and 4x intermediate positionsXLR 20Hz to 20kHz
List of the 12 Best Noise Cancelling Microphones in 2023
Here is detailed information about the 12 best noise cancelling microphones to use in 2023.
1. Fifine K669B
Fifiine is a great audio company, mainly providing next-level recording equipment at pocket-friendly prices. That is one of the reasons why people prefer this brand over others. Among several products, the Fifine K669B is a cheerful microphone for high-quality sound recordings. It is a USB microphone that is very easy to use.
The Fifine K669B has a plug-and-play setup. All you need to do is plug the USB cable into your Playstation, Mac, or Windows system, and you are all set to record or stream. This saves you time since no technical steps or software are involved in the process.
The Fifine K669B comes with an attractive design and solid metal construction, providing a professional vibe in a budget-friendly way. It is portable and lightweight, weighing around 400 grams only.
What’s the best part? The outstanding sound quality through robust noise cancellation features and versatile sound settings enhances your podcasting, instrument recordings, vocals, and streaming to a whole new level. This microphone has an integrated circuit that allows you to hear a less hissing sound and receive a warmer voice.
The Fifine K669B only picks sound from the front area and rejects any pesky noises from the sides and back. It is a good choice for gamers, content creators, YouTubers, or any person who is looking for the best noise-cancelling microphone on a happy budget.
Features and Specifications of Fifine K669B
  • Low self-noise
  • -34 dB sensitivity
  • 130 dB Max SPL
  • Cardioid polar pattern
  • 78 dB Signal-to-Noise Ratio
  • Condenser microphone type
  • Connection through USB 2.0
  • Equal sensitivity to low, mid, and high audio frequencies
Pros of Fifine K669B
  • Extremely low-priced
  • It has a durable construction
  • The audio input and output are clean
  • You can adjust the shock mount as needed
  • There are volume buttons for quick control
Cons of Fifine K669B
  • This microphone comes with an integrated cable, which is of low-quality
  • $32.99 (As seen on the official website)
2. Samson C01U Pro
The Samson C01U Pro is a high-quality mic with a 19mm diaphragm for amazing studio-level audio recordings. It gives you the option of real-time monitoring without delays through the headphone output. It has a 16-bit resolution and 44.1 to 448kHz support. When it comes to audio performance, this mic can surely fill the gap of having a highly expensive playback microphone. Why? Because it captures smooth and rich sounds, which are very natural to the ears.
Besides studio recording, this microphone is great for podcasts and live indoor interviews. Moreover, you can also use this mic for Skyping, Zooming, and gaming. Unlike XLR output microphones, the Samson C01U Pro easily connects to your Mac or Windows PC through its USB connectivity option.
From the noise cancelling perspective, the Samson C01U Pro cuts out unwanted noises remarkably. Its supercardioid pattern makes it easier to record sound in loud environments.
Features and Specifications of Samson C01U Pro
  • LED indicator
  • Shock-mounted
  • USB connectivity
  • 130 dB Max SPL
  • Supercardioid polar pattern
  • 20Hz to 18kHz frequency response
Pros of Samson C01U Pro
  • Simple plug-and-play microphone
  • Inexpensive microphone with good sound quality
  • There is no noticeable interference during the recording
Cons of Samson C01U Pro
  • No mute button
  • It lacks audio controls
  • Some users complain of audio latency while recording
  • $33.86 (Microphone without kit as seen on Amazon)
3. Bietrun UMKF01
The Bietrun UMKF01 is a 1.5-meter cable USB microphone designed to increase your audio experience. It is a simple mic with no hassle of software installation. You can plug it into your computer, and voila. It is ready to capture your voice.
The Bietrun UMKF01 is great for podcasts, Skype conversations, Zoom meetings, gaming, live streaming, and YouTube. The mic comes with an integrated noise-cancelling feature that only requires a single press of the mute button to activate. Once the indicator light turns yellow, you can be assured of eliminating background noises.
The Bietrun UMKF01 has a cardioid polar pattern. Plus, the noise cancellation feature also works effectively to banish mouse clicks, keyboard taps, and more. Moreover, this microphone consists of a 16mm electret condenser with a 16-bit sound that is surely pleasing to the ears.
The Bietrun UMKF01 manufacturers also claim that the mic has zero zero-latency through the headphone jack. You can also adjust the volume of this microphone using the knob and mute the mic. And to ensure you are muted, the LED ring light dances from green to red, indicating that it is safe to go unscripted because no one will listen until you unmute.
Features and Specifications of Bietrun UMKF01
  • USB connectivity
  • 110 dB Max SPL
  • 47 dB mic sensitivity
  • Built-in 3.5mm headphone jack
  • 50Hz to 20kHz frequency response
Pros of Bietrun UMKF01
  • Affordable
  • Decent audio recording
  • Lightweight enough to leave huge space on your desk
Cons of Bietrun UMKF01
  • The microphone is not durable
  • $36.99 (As seen on the official website)
4. Tonor ORCA-001
The Tonor ORCA-001 is a noise-cancelling microphone for gamers across multiple platforms, including laptop, PC, Mac, Android, and PS4 (sorry, no Xbox). Wait, not just gamers, but this cheerful mic is your great buddy at work and during regular chitchats with your friends, family, and coworkers through Skype, Zoom, Twitch, and more.
The Tonor ORCA-001 comes with a USB adapter with RGB volume indicators. Also, there’s no fuss with setting it up because you don’t require any extra accessories and drivers. Noise cancellation is the star feature of this microphone. Just tap a button and experience noise being disappear like a ghost. This attribute makes this microphone perfect for live sessions and streaming. Likewise, you can quickly mute the mic by simply pressing the dedicated button.
What’s more inside the Tonor ORCA-001 box? USB-C cables, desk stand, arm adapter, and the microphone itself.
Features and Specifications of Tonor ORCA-001
  • One-tap muting
  • 110 dB Max SPL
  • USB Type-C power source
  • 95 dB Signal-to-Noise Ratio
  • Zero latency audio monitoring
  • -38 dB microphone sensitivity
  • 50Hz to 16kHz frequency response
  • One-button active noise cancellation
  • 90-degree adjustable stand (included)
Pros of Tonor ORCA-001
  • Great value for money
  • It has a strong build quality
  • LED volume display with RGB lights
  • The microphone delivers organic audio
  • You can connect it to different devices
Cons of Tonor ORCA-001
  • Although it has a noise-cancellation feature, it could have been improved.
  • $69.99 (As seen on the official website)
5. Blue Yeti Nano
The Blue Yeti Nano is one of the three models from the Yeti family by Logitechl. It is a USB desktop mic that makes you sound fantastic. This microphone comes with two polar patterns – omnidirectional and cardioid – allowing you to use the one as needed. Also, switching between these two patterns is quite straightforward. You can do it directly from the microphone or using the Blue Sherpa software.
The Blue Yeti Nano has a small twirly knob to control headphone volume. But, like some alternatives, it lacks a fancy indicator for the volume. However, adjusting sound levels is easy through the app. Moreover, muting the mic is at your fingertips (literally, you need to press the dial button to mute the mic).
The Blue Yeti Nano also offers a 3.5mm headphone jack, allowing you to monitor audio in real-time. It also has a USB port to connect your computer to the mic.
So what makes Blue Yeti Nano qualify for the list of best noise cancelling microphones? Well, the Blue VO!CE technology. This mic is made using the VO!CE technology, which reduces noise and delivers cleaner, richer, and professional sound. However, the only struggle is that you first need to download Logitech’s G HUB software to savor this feature.
Features and Specifications of Blue Yeti Nano
  • USB 2.0 powered
  • 54.77 dB mic sensitivity
  • Integrated shock mount
  • Plug-and-play functionality
  • Omnidirectional and cardioid polar patterns
Pros of Blue Yeti Nano
  • Good audio quality in this price range
  • The availability of the headphone jack enables fast monitoring with low latency
Cons of Blue Yeti Nano
  • You cannot use the noise cancelling feature without the desktop app.
  • $89.99 (As seen on the official website)
6. RODE NT-USB Mini
The RODE NT-USB Mini is a sturdy desktop mic known for its efficiency and simple usability. This microphone has a cardioid pattern, making it ideal for capturing instruments and vocals. The mic is also great for several applications, including podcasting, internet calling, and gaming.
Although this mini version lacks DSP and EQ modes, it still qualifies in the list of professional microphones in the market. So, if you love simplicity and are familiar with basic recording methods, this mic can be a great option for you.
The RODE NT-USB Mini homes an LED light, headphone volume control knob, and zero-latency monitoring on the front side. Contrarily, the back panel has the main connectivity options like a 3.5mm headphone jack and USB Type-C to USB. This device also has a built-in amp that can handle headphones with high impedance.
The RODE NT-USB Mini comes with an integrated pop filter that eliminates plosives. However, you need to use an external pop filter with a mic stand if you wish to position this mic close for vocal recording. The noise gate incorporation that mitigates numerous background noises, including air conditioner and outdoor sounds, makes this mic great in terms of noise canceling.
Features and Specifications of RODE NT-USB Mini
  • 121 dB Max SPL
  • USB Type-C connectivity
  • Electret condenser microphone
  • Integration with Noise Gate for noise cancelling
Pros of RODE NT-USB Mini
  • Affordable pricing
  • DSP-free microphone
  • Crisp and clear audio quality
Cons of RODE NT-USB Mini
  • The microphone lacks a gain knob
  • $99.00 (As seen on Amazon)
7. HyperX Quadcast
The HyperX Quadcast offers a clean and easy setup like most USB microphones. But this mic requires some configurations to enjoy the maximum benefits of noise cancellation. Nevertheless, once connected, this mic automatically turns into your computer’s default sound input and output. Its 3.5mm headphone jack lets you route your PC’s audio output through this connectivity option.
The HyperX Quadcast comes with a mute touch button on the top of the frame, allowing you to mute the microphone quickly. It is designed with several great attributes, such as attractive lighting behind its grill that also indicates that the mic is in an active state. To ensure noise cancellation, the microphone includes a foam behind the grill that helps reduce plosive sounds. Besides, the internal pop filter also smoothens the percussive noises during your speech.
The HyperX Quadcast has four polar patterns, including cardioid, perfect for reducing background noises. Therefore, it is recommended to choose this pattern for streaming and podcasting. To do that, you just need to turn the control knob to the inverted heart icon on the mic.
Features and Specifications of HyperX Quadcast
  • -36 dB mic sensitivity
  • 90 dB Signal-to-Noise ratio
  • Anti-vibration shock mount
  • LED indicator for mute sensor
  • 3.5mm jack and USB connectivity options
  • Stereo, figure-8, omnidirectional, and cardioid polar patterns
Pros of HyperX Quadcast
  • It records clear audio
  • Great features at a low price
  • The microphone has a unique RGH lighting
Cons of HyperX Quadcast
  • The shock mount is made of plastic material
  • $99.99 (As seen on the official website)
8. Cyber Acoustics CVL-2230
The Cyber Acoustics CVL-2230 is a highly affordable microphone that is best for new users in the entertainment industry. In fact, the microphone is ideal for live streams, gaming, podcasts, interviews, voiceovers, and video conferencing. Due to its USB connectivity, this mic is compatible with all USB-enabled devices, including PCs and Macs.
The Cyber Acoustics CVL-2230 comes with dual polar patterns that help capture powerful, clean, and broadcast-standard audio at 24-bit. While the company sees this microphone model as one of the best audio gears for professionals, this is more suitable for home projects. However, upon testing, it was noticed that there was a very minute lag between listening and speaking during recordings. But that’s completely avoidable, as it doesn’t affect the main purpose.
From the noise cancelling point of view, Cyber Acoustics CVL-2230 doesn’t claim to offer noise isolation traits. But, in the opinion of users and after testing, this microphone is good at ignoring unwanted noises when switched to a cardioid pick-up pattern.
Features and Specifications of Cyber Acoustics CVL-2230
  • -47 dBV sensitivity
  • USB connectivity
  • Plug-and-play mic
  • Multi-colored lighting for control settings
  • Cardioid and omnidirectional polar pattern
  • Controls for headphone volume and gain adjustment
Pros of Cyber Acoustics CVL-2230
  • Very affordable price
  • Fair audio quality for its price
  • No echo during the recording
Cons of Cyber Acoustics CVL-2230
  • The noise cancelling feature is not up to the mark compared to other microphones in this list
  • $49.99 (As seen on the official website)
9. Shure MV7
The Shure MV7 is a great addition to the world of content creation. This microphone has been popular for its noise cancelling features, such as Auto Level mode and Voice Isolation Technology. These attributes are vital in exceptional recordings in the most bizarre acoustic environments.
When it comes to design, the Shure MV7 is lightweight and compact, weighing around 1.2 lbs and 6 inches in size. This makes it easier to position the mic on a stand, especially if you have a small workspace. Unlike traditional mics, the MV7 does not require an expensive stand. However, you need a separate boom arm or stand, as the construction does not include a base.
The Shure MV7 is incorporated with a windscreen that surrounds the mic’s capsule with a cardioid polar pattern, best for front-facing recordings. The microphone also gives you multiple connectivity options, including XLR, 3.5mm jack, and USB. Additionally, this device provides zero latency on your headphone output, allowing you real-time sound monitoring.
Features and Specifications of Shure MV7
  • Integrated pop filter
  • -55 dBV mic sensitivity
  • Dynamic capsule microphone
  • Built-in touch panel for controls
  • USB, 3.5mm jack, and XLR connectivity options
Pros of Shure MV7
  • You can easily mount it
  • The microphone offers professional-grade audio quality
  • It has a hybrid design due to multiple connection possibilities
Cons of Shure MV7
  • You need to install multiple software to access features
  • $249.00 (As seen on the official website)
10. Electro-Voice RE20
The Electro-Voice RE20 suits professionals who want to enjoy high-quality studio recordings. While the mic is labeled as broadcasting equipment, it offers exceptional sound quality for vocals and instruments. This microphone is loved for its stable performance over a wide range of frequencies. A big round of applause goes to its design, which minimizes the proximity effect.
The Electro-Voice RE20 is home to several convenient features, including bass tilt down for balancing the spectrum. This trait makes this microphone best for numerous applications, such as recording electric bass, acoustic guitars, and kick drums.
The Electro-Voice RE20 has a cardioid pattern, which is the first barrier to capturing unwanted noises. Plus, the mic comes with built-in wind and blast filters, ensuring your vocals are reproduced cleanly and without popping sounds.
Moreover, the Electro-Voice RE20 is well-constructed with an Acosutalloy diaphragm and aluminum voice coil, allowing it to handle immense pressure levels without distorting the sound, even if you are using this mic in some challenging environments. Due to its humbucking coil and steel housing, this mic is a great choice if you’re looking for a noise cancelling microphone.
Features and Specifications of Electro-Voice RE20
  • XLR connectivity
  • Variable-D technology
  • 180-degree off-axis noise rejection
  • 45Hz to 18kHz frequency response
Pros of Electro-Voice RE20
  • Great flat frequency response
  • Smooth and crisp sound capturing
  • Powerful noise reflection and rejection
Cons of Electro-Voice RE20
  • Bulky design
  • Expensive microphone
  • $449.00 (As seen on Amazon)
11. Lewitt LCT 840
The Lewitt LCT 840 scouts tube technology with a large diaphragm, providing multiple polar patterns. When you look at it, you will find a 33mm capsule housing right above a 25mm diaphragm constructed from four-micron Mylar. As established earlier, this microphone has 5 selectable recording patterns. You can choose any of the patterns through a dial on the external power supply that comes with this mic.
The Lewitt LCT 840 offers a low self-noise of 9 dBA, although it has a tube design. So, if you’re concerned about this microphone’s noise cancelling feature, this should be good news. Besides, the power supply comes with 3x attenuation levels and 3x high-pass filters that also mitigate handling noises. Moreover, to reduce electromagnetic interference, there is a thick conductive coating on the plexiglass cover.
Features and Specifications of Lewitt LCT 840
  • 12AX7 Tube
  • XLR connectivity
  • 139 dB Max SPL
  • Gold-plated diaphragm
  • 85 dB Signal-to-Noise ratio
  • Remote control functionality
  • Omnidirectional, wide cardioid, supercardioid, cardioid, and figure-8 polar patterns
Pros of Lewitt LCT 840
  • Attractive and unique appearance
  • Good noise cancelling functionality
Cons of Lewitt LCT 840
  • It is pricey for the features it offers
  • $1,199.00 (As seen on the official website)
12. Neumann M 149 Tube
The Neumann M 149 Tube is an expensive microphone with excellent noise cancelling functionality. This mic comes with a sound transducer similar to K47 and K49 microphones with big diaphragm.
The M 149 comes with two diaphragm capsules fixed in a large open head grill to ensure minimum reflection of unwanted noises. When you speak in front of the mic, the signals are amplified through the mini triode tube, which reduces the noise and produces ideal vocal transmission.
The Neumann M 149 Tube offers enhanced sensitivity and extremely low noise compared to other vintage tube mics. Moreover, it is made with the current sensing technology to make sure you get optimal performance even if the cables are as long as 300 meters. Furthermore, the Neumann M 149 Tube microphone has nine polar patterns and 7 low-cut filters for different studio applications.
Features and Specifications of Neumann M 149 Tube
  • High-pass filter
  • Capsule mic type
  • XLR connectivity
  • 120 dB and 136 dB Max SPL
  • Roll-off low-frequency switch
  • 66 dB to 83 dB Signal-to-Noise ratio
  • 34 mV, 47 mV, and 62 mV mic sensitivity
  • 9 polar patterns – Figure-8, Cardioid, Hypercardioid, Omnidirectional, Wide Cardioid, and 4x intermediate positions
Pros of Neumann M 149 Tube
  • Ideal for professional use
  • Next-level noise cancelling
  • Studio-grade audio quality
Cons of Neumann M 149 Tube
  • Extremely pricey
  • Lacks USB and 3.5mm connectivity options
  • $5,795.00 (As seen on Amazon)
So you have just seen the list of the 12 best noise-cancelling microphones in 2023. While all the options are great, some of them are more powerful when it comes to blocking unwanted sounds and background noises. It is because of the different technologies and construction each microphone has.
Nevertheless, if you are looking for some inexpensive noise-cancelling mics, products like Fifine K669B, Bietrun UMKF01, Samson C01U Pro, and Tonor ORCA-001 can be great. Conversely, you can check the Blue Yeti Nano, RODE NT-USB Mini, HyperX Quadcast, and Shure MV7 for medium-priced models. On the other hand, if you are professional and looking for an expensive noise-cancelling mic, you can look for options like Electro-Voice RE20, Lewitt LCT 840, and Neumann M 149 Tube.
If clarity and convenience are key factors in your microphone choice, a wireless lavalier microphone is an exceptional option to consider. Especially great for content creators, vloggers, and presenters on-the-go, wireless lav mics effectively reduce unwanted noise while providing the freedom of movement needed for professional-quality recordings.
Q1. What is noise noise-cancellation microphone?
A noise-cancelling microphone analyzes ambient sound waves in the environment and reproduces the opposite audio waves to reduce noise.
Q2. Which microphone is best for noise cancellation?
Fifine K669B, Bietrun UMKF01, RODE NT-USB Mini, HyperX Quadcast, and Shure MV7 are budget-friendly and high-quality noise-cancelling microphones.
Q3. What are the benefits of a noise-cancellation mic?
Noise-cancelling microphones ensure clean and noise-less communication and recording.
Q4. What is the difference between noise cancellation and active noise canceling?
Noise canceling is a technology found in microphones to reduce background noises that can be captured through the mic. Active Noise Cancelling (ANC) technology mitigates unwanted noises in the speakers/headset. Some mics have both ANC and NC technologies for a better user experience.
