New Product Coming
DAYS
HRS
MINS
SECS
Power supply
October 31, 2023
1. What kinds of battery are suggested for M1 Enhanced?
We suggest using SONY NP-F series batteries such as F970, F750, and F550. Alternatively, you can use a V-mount battery, but you will need to power the device via a D-Tap to DC cable.
2. How to check battery capacity?
You can check the battery capacity of the device on the top right side of the screen. There is a battery icon that displays the voltage value. If the voltage is less than 6.8V, please replace the battery.
3. Does it support to use Type-C adapter to power device?
No, it is not supported.
4. Does it support DC adapter to power device?
Yes, you can. The range of voltage input is 7-16V
5. Why the device show battery voltage instead of battery percentage?
The device shows battery voltage instead of battery percentage because there are many brands and models of NP-F batteries in the market. Different brands/models have different battery capacities and discharge curves, and external equipment cannot accurately detect the remaining battery capacity. Therefore, showing one kind of battery percentage has no meaning. However, displaying the battery capacity can more accurately judge the remaining time of the battery.
RELATED POSTS
