5 Best Bluetooth Microphones For Car in 2023
A reliable Bluetooth microphone for your car is a must-have accessory when it comes to hands-free calling and streaming music while driving. But with so many options on the market, it can be overwhelming to choose the right one. This article will explore the top five Bluetooth microphones for cars based on factors like sound quality, ease of use, and compatibility with various devices.
Whether you’re a frequent driver or just looking for a reliable way to stay connected on the go, these microphones offer a range of features to meet your needs and enhance your driving experience.
A Guide On How To Choose The Right Bluetooth Microphone?
Choosing the right Bluetooth microphone for your car can be a daunting task, but there are some key criteria to consider that can help you narrow down your options.
Compatibility:
Ensure the microphone is compatible with your car’s Bluetooth and mobile devices. You don’t want to end up with a microphone that won’t connect to your phone or car stereo.
Battery life:
A microphone with a long battery life means you won’t have to recharge it as often, making it more convenient for longer drives.
The range is also important. A microphone with a longer range will allow you to use it even if your phone is not within close proximity.
Frequency response:
A microphone with a wider frequency response will provide clearer sound quality and make it easier for the person on call to understand you.
Ease of use:
Look for a microphone with simple controls that you can easily navigate while driving.
The design and size of the microphone:
A compact design can be more convenient for storage and portability, while a larger microphone may provide better sound quality.
Top 5 Bluetooth Microphones For Cars That You Must Get Today
Here are the top 5 Bluetooth microphones for cars, along with their features, pros, cons, and pricing information.
1. Movo PM10 Deluxe Lapel Clip-on Omnidirectional Condenser Microphone
Price: $14.95
Transducer: Electret condenser
Frequency Response: 35 Hz to 18 kHz
Polar Pattern: Omnidirectional
Signal/Noise Ratio: 74dB SPL
Sensitivity: -30 dB +/- 3 dB (0 dB = 1 V/Pa @ 1 kHz)
Impedance: 1 kΩ +/-30% @ 1 kHz
Cable Length: 1.2m (47″)
Connector: 3.5mm TRRS male connector
The Movo PM10 Deluxe Lapel Clip-on Omnidirectional Condenser Microphone is a budget-friendly option that provides good quality sound and is suitable for various applications.
Features and Specifications:
  • This clip-on lapel microphone is compatible with most smartphones, laptops, and tablets.
  • It has an omnidirectional pickup pattern that captures sound from all directions.
  • It has a 3.5mm TRRS jack for easy connectivity and comes with a foam pop shield to reduce wind noise.
  • It is affordable, lightweight, and easy to use.
  • The omnidirectional pickup pattern ensures clear sound quality from all directions.
  • The foam pop shield helps to reduce wind noise.
  • The cord length may be short for some users.
  • It has no volume control, so you need to adjust the volume on your device.
Quantitative Measurement: 4.3 out of 5 stars on Amazon with over 4,000 reviews.
2. Jabra Speak 510 Wireless Bluetooth Speaker for Softphone and Mobile Phone
Price: $149.99
Wireless Range (ft.): Up to 98 feet
Microphone: Omnidirectional
Speaker Weight: 195g/688 oz.
Connectivity: USB and Bluetooth
Bluetooth Standard: Bluetooth 3.0
Charging Time: Approximately 2 hours
Warranty: 2 years
The Jabra Speak 510 Wireless Bluetooth Speaker is a versatile and portable device that functions as a speakerphone and has a built-in omnidirectional microphone that delivers clear audio for conference calls.
  • This wireless Bluetooth speakerphone has a compact design and comes with a USB cable and a carrying case.
  • It has a 360-degree omnidirectional microphone and a frequency range of 150 Hz to 15 kHz.
  • It can connect to multiple devices and has a battery life of up to 15 hours.
  • It is portable and has a long battery life.
  • The 360-degree omnidirectional microphone provides excellent sound quality from all directions.
  • It can connect to multiple devices at once.
  • It is expensive compared to other options.
  • Some users may find the speaker volume to be too low.
Quantitative Measurement: 4.6 out of 5 stars on Amazon with over 4,000 reviews.
3. Movo WMIC70 Wireless 48-Channel UHF Lavalier Microphone System
Price: $119.95
Frequency Response: 60Hz-15 KHz+/-3 dB
Audio Input Connector: 3.5mm mini jack
Audio Input Level: 600 mV-2000 mV
Sensitivity: -30dB +/-3dB / 0dB=1V/Pa, 1 kHz
Connector: 3.5mm locking mini plug
Length: 1.2m (4′)
Weight (each): 95g (3.4 oz.) without batteries
The Movo WMIC70 Wireless 48-Channel UHF Lavalier Microphone System is a reliable wireless option that provides a range of up to 200 feet and includes multiple accessories for versatility.
  • This wireless microphone system includes a lapel microphone, a receiver, and a transmitter.
  • It has a range of up to 328 feet and has 48 channels to choose from.
  • It has a frequency range of 576.4 MHz to 599.9 MHz and uses UHF transmission to reduce interference.
  • It is wireless and has a long-range.
  • The 48 channels provide clear sound quality and reduce interference.
  • It is easy to set up and use.
  • The battery life may be shorter than expected.
Quantitative Measurement: 4.4 out of 5 stars on Amazon with over 1,000 reviews.
4. Rode smartLav+ Omnidirectional Lavalier Microphone
Price: $79
Active Electronics: JFET
Polar Pattern: Omni-directional
Frequency Range: 20Hz – 20kHz
Output Impedance: 3k Ω Typical
Signal to Noise Ratio: 67 dB
Sensitivity: -35dB (17.8mV @94dB SPL)
Output Connection: TRRS
The Rode smartLav+ Omnidirectional Lavalier Microphone is a professional-grade option that offers high-quality sound and is compatible with various devices.
  • This lapel clip-on microphone is compatible with most smartphones, laptops, and tablets.
  • It has a TRRS jack for easy connectivity and comes with a foam pop shield to reduce wind noise.
  • It has a frequency range of 20 Hz to 20 kHz and a sensitivity of -35.0dB re 1 Volt/Pascal (17.80mV @ 94 dB SPL) +/- 2 dB @ 1kHz.
  • It is affordable and easy to use.
Quantitative Measurement: The Rode smartLav+ Omnidirectional Lavalier Microphone has received 4.2 out of 5 stars on Amazon with over 3,800 reviews.
5. Sony ECMCS3 Clip style Omnidirectional Stereo Microphone
Price: $20.99
Microphone Type: Omni-directional electret condenser microphone
Frequency: 50 – 15,000 Hz
Output Level: -38.0 dB
Cord Type: OFC Cord
Cord Length: 3.3′ (1.0 m)
Item Weight: 1.6 ounces
Dimensions: 4.37 x 6.26 x 1.5 inches
The Sony ECMCS3 Clip style Omnidirectional Stereo Microphone is an affordable and compact option that provides decent sound quality for casual use.
  • This clip-on microphone is compatible with most smartphones, laptops, and tablets.
  • It has a gold-plated plug for improved signal transfer and a 50 Hz to 15 kHz frequency range.
  • The gold-plated plug helps to improve signal transfer.
  • It doesn’t have any volume control.
Quantitative Measurement: The Sony ECMCS3 Clip style Omnidirectional Stereo Microphone has received 4.3 out of 5 stars on Amazon with over 3,800 reviews.
Which One Is The Best?
When it comes to choosing a microphone, there are several factors to consider, such as features, performance, quality, and value. Let’s take a look at the five microphones mentioned above and compare them based on these factors.
When comparing these five products, it’s clear that each has its unique features, performance, quality, and value.
The Movo PM10 Deluxe Lapel Clip-on Omnidirectional Condenser Microphone is an excellent option for those on a tight budget or those who need a basic lapel microphone for occasional use. It’s compact and easy to use, with an omnidirectional pickup pattern and a thin rubber material for durability.
The Jabra Speak 510 Wireless Bluetooth Speaker for Softphone and Mobile Phones, on the other hand, is a wireless Bluetooth speakerphone that doubles as a microphone. It features a 360-degree omni-directional microphone that captures sound from all angles and can connect to devices via Bluetooth, USB, or 3.5mm. It’s a more expensive option, but it offers greater versatility in terms of its connectivity options.
The Movo WMIC70 Wireless 48-Channel UHF Lavalier Microphone System is a higher-end option that offers greater range and flexibility in terms of its 48 channels. It’s also wireless, which makes it ideal for those who need to move around while speaking.
The Rode smartLav+ Omnidirectional Lavalier Microphone offers high-quality audio recording with its omnidirectional pickup pattern and TRRS connector. It’s designed specifically for use with smartphones and tablets, making it a great option for those who need a portable solution.
Finally, the Sony ECMCS3 Clip style Omnidirectional Stereo Microphone is an affordable clip-on option that offers great value for its price. While it may not have the same level of performance or features as some of the other options, it’s a reliable choice for basic recording needs. Ultimately, the best option will depend on individual needs and preferences, but this comparison should provide a good starting point for those in the market for a microphone.
In conclusion, when it comes to choosing the right microphone for your needs, it is important to consider various factors such as features, performance, quality, and value. Each of these products has its own unique features and advantages, and the best choice for you will depend on your needs and budget. We recommend considering the features and specifications carefully before making a purchase, and reading reviews from other users to ensure you are getting the best value for your money.
If you’re considering a convenient microphone solution beyond Bluetooth for clearer audio clarity during rides, a wireless lavalier microphone can offer ease-of-use and improved audio performance. Its compact and cable-free design ensures excellent sound quality, making it perfect for capturing conversations or recording audio hands-free in your car.
What Are Some Important Factors To Consider When Choosing A Bluetooth Microphone?
 Some important factors to consider when choosing a Bluetooth microphone include compatibility with your devices, range, battery life, frequency response, noise cancellation, and overall sound quality.
Can A Bluetooth Microphone Be Used With Multiple Devices?
Yes, many Bluetooth microphones are designed to connect to multiple devices at once, making them a versatile option for various applications.
How Do I Connect A Bluetooth Microphone To My Device?
The process for connecting a Bluetooth microphone to a device may vary depending on the specific product and device, but generally involves turning on Bluetooth on both devices and pairing them together through the device’s settings menu.
How useful was this post?
Click on the stars to rate
