Spotify is one of the most popular audio and music streaming platforms globally, with over 210 million subscribers. Spotify offers best-in-class features with intuitive user experiences. One of the numerous things listeners love about the platform is that it’s always on the lookout to improve user experience and boost the audio experience of its users. The platform is an excellent streaming service with tons of great tunes, music, and podcasts, and the best way to enjoy streaming this platform is to stream audio at a very high-quality bitrate.
The highest bitrate supported by the streaming platform is 320 kbps. One might assume enabling the auto mode with a strong Wi-Fi connection, the streaming platform would ramp up to 320 kbps, but it doesn’t work like that. The service usually maxes out at 160 kbps with this setting, which explains why many users are always looking for how to stream at a very high audio bitrate. In this article, we will share how you stream on Spotify at a very high quality.
How To Stream Spotify At A Very High-Quality Bitrate
Highlighted below are different ways to stream at a very high-quality bitrate.
Adjust the base volume to match the environment
One of the exciting features Spotify premium users enjoy is adjusting the base volume of Spotify music to match the environment. It’s not every time music streaming services offer features like this to users, so improve your music experience on the app by matching the base volume with your environment.
You can opt for one of the three options – Quiet, Normal, or Loud, and each has its benefit. Quiet will make songs a little quieter and clearer, making it a suitable choice when relaxing at home. With Normal, the songs play at a medium base volume, and the sound is not as crisp as that of Quiet. It’s a popular choice as it’s ideal for most people and situations. Loud is louder than the other options, but the degree of the audio quality comes down a notch because of the loudness. This is a good option if you’re at the gym or other noisy environment.
Steps on how to adjust the base volume on your iPhone:
- Open the Spotify app and tap on your profile picture in the upper left corner.
- Tap the gear icon to open the Setting and Privacy menu.
- Tap Playback.
- Under Volume level, there are three options: Loud, Normal, and Quiet. Choose whichever option suits your environment.
Steps on how to adjust the base volume On Spotify Using an Android device:
- Open Spotify App.
- Click the gear icon to access Settings.
- Under Playback, you will see Volume Level.
- Close to the Volume Level, you will see the Loud, Normal, and Quiet options.
Steps on how to adjust the base volume on a Mac:
- Open Spotify.
- Click on your profile picture, then select Settings.
- Under Audio Quality, you should see Volume level.
- Click the drop-down bar to the right of the Volume level. you should see the Loud, Normal, and Quiet options.
Steps to adjust the base volume in Spotify on a Windows computer.
- Open Spotify.
- Click your account name in the top-right corner.
- Click Settings.
- Go to the Audio Quality; you should see the Volume level. Click the drop-down bar to the right.
- Select either Loud, Normal, or Quiet.
Download Spotify high audio quality to MP3 format
If you want to stream Spotify at a high bitrate, you could also ensure you download high-quality audio to MP3. This is a service enjoyed by only Premium members of Spotify. As a premium member, you could directly download Spotify songs in high quality within the app and enjoy a high-quality bitrate streaming of songs.
However, the downloaded content is usually untransferable and non-extractable, and to enjoy the high-quality audio without limitations, it’s recommended to download them to MP3 format using an efficient Spotify Music Converter like the NoteBurner Spotify Music Converter and TuneCable Spotify Music Downloader.
Steps to Download Spotify High Audio Quality to MP3 Format
- Launch the Spotify Music Convert. Install and launch Spotify Music Converter on the computer before doing anything else.
- Choose Output Quality & Format on the Spotify Music Converter app. Open the app and click Recorded from the Spotify app. Tap the icon “Settings’ ‘, here you can choose Output Format and choose MP3. Choose desired Output Quality and sample rate.
- Then drag music from Spotify to the Converter app or directly copy & paste the Spotify music URL to the app for analysis. Tick on the Spotify songs and click “Add”.
- Click “Convert” to download the Spotify music to the computer as MP3 files with 320kbps high-quality output.
Adjust the quality of your music on Spotify
Another way to stream Spotify at a very high-quality bitrate is to adjust the audio streaming quality. Increasing the audio quality on Spotify allows you to enjoy a clearer and more pleasurable audio experience while letting you hear the finer details and tunes of the music. You should know that only Spotify Premium members can access 320kbps, a very high streaming quality. At the same time, Spotify Free listeners only get 160 kbps a bit rate.
To enjoy the highest audio quality on Spotify; you need to upgrade to a paid account. Additionally, it’s important to know that your cellular data usage increases significantly when you stream exclusive high-resolution audio on Spotify.
Follow the steps below to improve the sound quality on the Spotify app for Windows or Mac systems:
- Open the Spotify desktop app on the computer and log into your music account.
- Click the “down arrow” beside your profile icon, and select “Settings”.
- Click on the section of Audio Quality; you will see the Streaming Quality; choose the “Very High” option in the dropdown list. This automatically means your streaming audio quality will be set to 320 kbps bitrate on Spotify.
Steps to change Spotify streaming quality on a mobile phone(Android and iPhone) includes:
- Go to “Library” at the bottom right, and click the button “Setting” gear icon.
- Scroll down and click “Audio Quality” in the quality section.
- You’ll then find a list of available audio quality settings for Wi-Fi and cellular streaming. Choosing a high streaming quality on the cellular setting will cost you more data usage than usual.
Disable Auto Adjust Quality
The Spotify auto-adjust quality setting is designed to automatically adjust the quality of your streaming based on certain variables such as your internet speed and others so you can get the best quality you can based on your network speed. If your internet speed is consistently high, it’s recommended to turn off the Auto Adjust quality feature and change your audio quality setting to very high to ensure your streaming on the app is always at a Very high quality.
Steps on how to turn off auto-adjust quality on Spotify.
- Scroll down and click “Audio Qualiin” to the tin quality section.
- You’ll then find the “auto adjust quality” feature. Turn it off to enjoy a better experience while streaming with high network speed.
Ramping up the quality bitrate of your audio on Spotify isn’t so difficult; there are various methods mentioned above. Opt for the method that works for you or even combine some of the methods to have your music blasting at the highest level possible.
Enjoying Spotify’s crystal-clear sound quality deserves an equally superb visual stream to share your experience live with your audience. Consider upgrading to a professional streaming camera to complement your high-quality audio streams and engage your viewers like never before.
How do I enable 320kbps on Spotify?
Open your Spotify app for iPhone and Android, tap the ‘Home’ tab, and then tap the Settings icon in the top right corner. Go to ‘Audio Quality’, select ‘WiFi Streaming’ under that tap the ‘Very high’ option. You can also select the ‘Very high’ option under ‘Cellular streaming’ if you don’t mind the increase in cellular data usage.
Is there a way to get high-quality Spotify without paying a premium?
It will help if you are a premium subscriber on the platform to enjoy a higher-quality audio bit rate. Free users of the platform can’t enjoy the customization that premium users do, so it’s recommended to subscribe to a paid plan to improve your audio experience.
Which Streaming Service Sounds the Best: Spotify or Tidal?
Spotify tends to reduce the music quality by compressing the audio so users can minimize data usage and maximize streaming quality, which usually distorts the sound. Tidal uses a lossless format, one as high as 96kHz, 24-bit, so it often delivers better audio quality.
Spotify quality isn’t bad; it’s just not the best, and more so, a lot of people prefer Spotify due to its intuitive user experience and more advanced features. If you’re an audio enthusiast and you want higher quality audio that Spotify offers regardless of the data usage, you can opt for Tidal.
