Shop Smart Save Big
BLACK FRIDAY Shop Now
Microphone Not Working in Adobe Audition? Here’s How to Fix It
By Hollyland | November 25, 2026
If Zoom detects your microphone, Audition may show no input. Windows Voice Recorder may detect it as well. Your microphone is probably not causing this problem. Audition needs audio settings configured across several levels. These include system permissions, driver type, sample rate, and track setup. Any one setting can block input without showing a warning. Try each fix below in the order listed.
Common Reasons Your Mic Isn’t Working in Adobe Audition
Use this table to match your symptom to the most likely cause, then jump directly to that section.
SymptomLikely CauseGo To
Mic works in other apps, no signal in AuditionOS permissions blocked or Audio Hardware not configuredSteps 1 and 2
No device listed in Audition’s Audio Hardware SettingsWrong device class selected (ASIO / MME / CoreAudio)Step 2
Device listed but meter shows nothingTrack not armed or input monitoring offStep 4
Signal drops after an OS updateSample rate mismatchStep 3
Mic works alone, fails when another app is openExclusive Mode or ASIO driver conflictStep 5
Wireless receiver connected but no signal detectedTX-RX not paired or receiver not set as inputWireless Section
Step 1: Check Microphone Permissions in Windows or macOS
Adobe Audition is a desktop application, and both Windows and macOS require you to explicitly grant it access to your microphone. If access is blocked or set incorrectly, Audition records silence. This is one of the most common causes of the problem and the first thing to verify.
Windows
  1. Open Settings and navigate to Privacy & Security → Microphone.
  1. Confirm that Microphone access is toggled On at the top of the page.
  2. Scroll down to Let desktop apps access your microphone and toggle it On.
  1. Check the list below the toggle to confirm Adobe Audition is not explicitly blocked. If it appears with access disabled, enable it.
  2. Restart Adobe Audition after making any changes.
Note: On Windows 10, the path is Settings → Privacy → Microphone. The global toggle and the desktop apps toggle both need to be enabled — enabling only one will not be enough.
macOS
  1. Open System Settings (macOS Ventura or later) or System Preferences (earlier versions).
  1. Go to Privacy & Security → Microphone.
  1. Locate Adobe Audition in the application list and confirm its toggle is enabled.
  2. If Audition does not appear in the list, it has not yet requested mic access. Launch Audition, attempt to record, and then return here. The entry should now be visible.
  3. Restart Audition after granting access.
After completing these steps, your mic should be visible as an available input inside Audition. If it still does not appear, continue to Step 2.
Step 2: Set the Correct Audio Hardware in Adobe Audition
Adobe Audition can follow your operating system’s default device. You can also choose an input manually through application preferences. Selecting the correct driver class helps Audition detect your hardware properly.
Windows
  1. Open Audition and go to Edit → Preferences → Audio Hardware.
  1. In the Device Class dropdown, select the appropriate driver type:
  • MME or WDM for USB microphones or built-in audio devices
  • ASIO for dedicated audio interfaces with third-party ASIO drivers, or ASIO4ALL
  1. Once you select a Device Class, the Default Input dropdown will populate with available devices.
  1. Select your microphone from the Default Input dropdown.
  2. Click OK to apply.
macOS
  1. Open Audition and go to Adobe Audition > Settings > Audio Hardware.
  2. The Device Class should be set to CoreAudio. This is the correct setting for all microphones on macOS.
  3. In the Default Input dropdown, select your microphone.
  4. Click OK to apply.
If your mic does not appear in the Default Input list, the issue is almost always a Device Class mismatch. A USB microphone connected to a Windows machine will not appear under ASIO. Therefore, switch to MME or WDM and check again.
Step 3: Fix a Sample Rate Mismatch
A sample rate mismatch between your OS microphone and Audition session can cause recording problems. It may also lock devices or change playback speed and pitch. Depending on the driver class, Audition or Windows may show an error. For example, you might see: “The sample rates of the audio input and output devices do not match.”
In other cases, recording may fail until both rates match. A common issue involves different settings across the two applications. Your OS may be set to 44.1 kHz. Meanwhile, your Audition session may run at 48 kHz. The reverse mismatch can cause similar problems.
Check and Set the Device Sample Rate
On Windows:
  1. Right-click your microphone in Settings → System → Sound → Input and select your microphone device properties.
  1. Go to the Advanced tab.
  2. In the Default Format dropdown, note the current sample rate — for example, 44100 Hz or 48000 Hz.
  3. Change it to match your intended Audition session rate. For most voice and video work, 48000 Hz / 24-bit is the standard.
  1. Click Apply.
On macOS:
  1. Open Audio MIDI Setup (Applications → Utilities).
  2. Select your microphone in the left panel.
  3. Change the Format dropdown to match your Audition session sample rate.
Match the Sample Rate in Adobe Audition
  1. Go to Edit → Preferences → Audio Hardware and note the sample rate listed there.
  2. For the current session, go to Edit → Session Properties (Multitrack view) or check the bottom status bar (Waveform view) to confirm the active session sample rate.
  3. Set the OS device, the Audition Audio Hardware settings, and the session properties to the same value. 48 kHz is the recommended standard for voice-over and video production work.
Note: The Hollyland LARK MAX 2 transmits natively at 48 kHz / 32-bit float. If you are using this mic system, setting every layer to 48 kHz from the start eliminates this issue before it can occur.
Step 4 — Arm the Track and Enable Input Monitoring
Even with the microphone correctly configured, a common Audition-specific oversight stops signal from appearing on the meter: the recording track is not armed and input monitoring is turned off. Many users interpret a flat meter as a hardware or driver fault when the fix is a single button press.
In Multitrack View
  1. Open or create a Multitrack session in Audition.
  2. Locate your audio track in the track header on the left side of the session.
  3. Click the R (Record Arm) button. It will highlight red when active.
  1. Click the I (Input Monitoring) button on the same track. This enables live signal preview from your microphone.
  1. Watch the track’s level meter. You should see input activity as you speak or generate sound near the mic.
  2. If the meter is still flat, click the Input selector below the track name and confirm your microphone is assigned to that track’s input channel.
In Waveform View
  1. Confirm your input device is selected in Edit → Preferences → Audio Hardware (see Step 2).
  2. In the Waveform view toolbar, verify that the input channel shown matches your microphone.
  3. Press Record to begin a test capture. Audition will draw a waveform as it records signal.
Step 5: Resolve Driver Conflicts and Exclusive Mode Issues
Windows Exclusive Mode
Windows allows a single application to lock exclusive control of an audio device. When another application holds that lock, Audition receives no signal and shows no error. This commonly happens when Zoom, a browser tab with audio, or another DAW is running in the background while you try to use Audition.
  1. Open Settings → System → Sound→ More sound settings.
  1. Go to the Recording tab, select your microphone, and click Properties.
  2. Uncheck Allow applications to take exclusive control of this device.
  1. Click Apply, then restart Adobe Audition.
ASIO Driver Conflict
If you are using an audio interface with an ASIO driver, only one application can access that driver at a time. If another DAW or audio application is open in the background, Audition will be locked out of the device entirely.
  1. Close other DAWs or audio programs accessing your interface’s ASIO driver.
  2. Open Audition’s Edit > Preferences > Audio Hardware settings. Select your interface’s ASIO driver again, or choose MME/WASAPI for multi-app access.
  3. Restart Audition and test your microphone input.
Note for macOS users: CoreAudio generally supports multiple applications simultaneously, but a stuck audio daemon can occasionally block input. Open Activity Monitor, search for coreaudiod, and force-quit it. The process restarts automatically and often resolves a persistent input conflict without a full reboot.
Wireless Microphone Not Detected in Adobe Audition: Hollyland LARK MAX 2
Wireless microphone systems add a hardware layer between the sound source and the software. When using a Hollyland LARK MAX 2, the troubleshooting runs through three distinct stages before any Audition setting becomes relevant.
Stage 1: Confirm TX-RX Pairing
The LARK MAX 2 transmitter (TX) and Camera receiver (RX) are supposed to pair automatically when taken out of the charging case. If they fail to connect, use the manual method below:
  1. Switch off the two units by pressing their power buttons for 3 seconds.
  2. Make sure the LARK MAX 2 mic/transmitter (TX) is powered off, then press and hold its power/multifunction button for 6 seconds. The LED will activate once the transmitter enters pairing mode.
  1. Keep the Camera RX powered off and hold its power button for 6 seconds to activate pairing mode on this unit.
  1. Wait until the units pair. The Camera RX touchscreen display will show the successful pairing status and the signal strength for the connected TX will appear on the screen.
  1. Confirm the result by checking the TX LED, which will remain solid blue after connecting to the RX.
Stage 2: Verify the Receiver Appears in OS Settings
Once the LARK MAX 2 is paired, connect the Camera RX unit to your computer by plugging the USB-C cable into the RX’s port and the other end into your PC.
Then confirm the OS recognizes it as an input device:
On Windows: Open Settings → System → Sound and check that the Hollyland LARK MAX 2 or your connected audio interface appears under Input devices.
On macOS: Open Audio MIDI Setup (Applications → Utilities) and confirm the receiver or interface appears in the device list on the left.
Stage 3 — Set the Input Device in Adobe Audition
  1. Go to Edit → Preferences → Audio Hardware (Windows) or Audition → Settings → Audio Hardware (macOS).
  2. From the Default Input dropdown, select the Hollyland LARK MAX 2 receiver or your connected audio interface.
  3. Set the session sample rate to 48 kHz — the LARK MAX 2 operates natively at 48 kHz / 32-bit float, and any mismatch will produce silence (refer back to Step 3).
  4. Click OK, then arm your track and enable input monitoring using the R and I buttons (Step 4).
Bonus Diagnostic: Adjusting TX Gain Levels From the Camera Receiver
Transmitter Gain: You can configure microphone gain through the Camera RX’s own settings. Start with the physical controls before selecting your preferred adjustment method.
  1. Press the physical control knob on the Camera RX. This action opens the main options.
  1. Rotate the dial to browse the menu until Mic Settings appears on the OLED touchscreen. Tap the option to continue.
  1. Select Mic Gain to see the two available ways of configuring gain:
  1. Auto: Automatically adjusts the mic sensitivity and input levels dynamically in real time.
  2. Custom: Set gain intensity levels individually and manually for each connected transmitter.
Last Resort: Reset Adobe Audition Preferences
When all the steps above have been completed and Audition still fails to recognize the microphone, corrupted preference files can prevent correct device initialization on launch. This is uncommon but does occur after major OS updates or Audition version upgrades.
  1. Close Audition completely.
  2. Hold the Shift key while launching Audition
  3. A prompt will ask which settings to reset, such as app preferences, user presets, or plugin caches. Confirm your selection to reset them.
  4. If the modifier key method does not trigger the prompt, delete the preference folder manually:
  • Windows: C:\Users\[YourUsername]\AppData\Roaming\Adobe\Adobe Audition\[version]\
  • macOS: ~/Library/Preferences/Adobe/Adobe Audition/[version]/
  1. Rename or delete the folder, then relaunch Audition. It will recreate default preferences automatically.
  2. Reconfigure Audio Hardware settings from scratch using Step 2 above.
Note: A preference reset clears custom workspaces, key bindings, and saved effect presets. Your recorded audio files, session files, and project folders are stored separately and are not affected.
Why does my microphone show up in Windows but not in Adobe Audition?
Audition usually follows Windows’ “System Default” setting automatically. But newly connected microphones may sometimes go undetected. This can happen when Audition previously selected another device. Another possible cause is a Device Class mismatch. Check this setting in Audio Hardware Preferences. For example, ASIO may be selected for standard USB microphones. These microphones may require MME or WASAPI instead. Windows privacy permissions may also block desktop applications. Another application may hold the device in Exclusive Mode. See Step 2 for device class settings. See Step 5 to disable Exclusive Mode.
Why is there no input level on the meter even though my mic is selected?
In Multitrack view, first assign your microphone to the track. Then enable Record-Arm (R) or Input Monitoring (I). The track meter will then display live audio levels. Choose Input Monitoring (I) to hear your microphone. It also sends audio levels to the main Master meter. Selecting your microphone in preferences is only the first step. You must also route and activate the track correctly.
Does Adobe Audition support USB microphones directly?
Yes. On Windows, open Audio Hardware preferences first. Set Device Class to MME or WASAPI. Use ASIO only with your microphone’s dedicated manufacturer driver. Next, select your USB microphone under Default Input. On macOS, CoreAudio supports USB microphones without extra drivers. Simply select your microphone as the Default Input.
Can I use a wireless microphone like the Hollyland LARK MAX 2 directly with Adobe Audition?
Yes. Connect the LARK MAX 2 Camera receiver via USB-C cable to your computer. Confirm the receiver an input in OS settings first, then select it in Audition’s Audio Hardware Preferences. Set the session sample rate to 48 kHz to match the LARK MAX 2’s native output format.
Why does my mic work in Zoom but not in Adobe Audition?
Zoom and most communication apps automatically select your active microphone. They usually need no additional microphone setup from you. Adobe Audition also starts with your system’s main input selected. Yet it may not switch when you change connected devices. Sample rate conflicts can also prevent automatic device switching. You may need to choose your microphone manually in Audio Hardware preferences. Your operating system may also block Audition’s microphone access. On Windows, Zoom may have exclusive control of your microphone. Close Zoom and allow Audition microphone access in privacy settings. Then choose your microphone in Audition’s Audio Hardware menu. Disable Exclusive Mode in Windows Sound Settings when necessary.
Follow these fixes in the order listed below. First, check your operating system’s microphone permissions. Next, select the correct input in Audition’s Audio Hardware Preferences. Make sure the sample rate matches across all settings. Then arm your track and enable Input Monitoring. Resolve any driver issues or Exclusive Mode conflicts. Wireless microphone users should check TX-RX pairing first. Also confirm Windows or macOS recognizes the microphone. Once your microphone records clearly, check our related guide. It covers Adobe Audition recording settings for podcasts and voiceovers.
apec
