Shop Smart Save Big
BLACK FRIDAY Shop Now
Microphone Not Working in Webex? 7 Fixes That Actually Work
By Hollyland | November 25, 2026
If your microphone stopped working in Webex, the cause is almost always a misconfigured audio setting, a blocked OS permission, or a device routing conflict. All of these are fixable in a few minutes once you know where to look. Work through the fixes below in order; most users resolve the problem before reaching Fix 4.
Why Your Microphone Stops Working in Webex
Webex microphone failures fall into three distinct layers. Identifying the right layer tells you exactly where to focus.
  • App layer: Webex has selected the wrong input device, the in-app volume is zeroed, or an audio session has become corrupted.
  • OS layer: Windows or macOS is blocking microphone access, routing audio to the wrong device, or running an outdated audio driver.
  • Hardware layer: The microphone is physically muted, disconnected, or not recognized by the operating system.
Before You Troubleshoot: Four Quick Checks
Run through these first. They eliminate the most common time-wasters before you touch any settings.
  1. Check the hardware mute button. Many headsets and external microphones have a physical mute switch. Confirm it is in the live position.
  2. Check the Webex in-call mute button. If the microphone icon at the bottom of the call window shows a red slash, click it to unmute.
  3. Confirm physical connections. Unplug and firmly reseat any USB or 3.5mm cable. A loose connection is often the entire problem.
  4. Test the mic in another app. Open Voice Recorder (Windows) or QuickTime Player (macOS) and record a few seconds. If audio captures correctly, the hardware is functional, and the fault is in Webex or your OS settings.
Fix 1: Select the Correct Microphone in Webex Audio Settings
This is one of the most common root causes for both built-in and external microphone failures. Webex stores its own audio device preference independently of your OS default, and it can quietly switch to the wrong device after a system update, a new USB connection, or a fresh app install.
  1. Open the Webex desktop app and click the gear icon in the bottom-left corner of the navigation sidebar to open Settings.
  2. Select Audio from the left-hand menu.
  3. Under Microphone, open the dropdown and select the correct input device by name.
  4. Speak normally and watch the Input level bar respond. You should see it move as your voice comes through. Conversely, click Test and record a few words. Then, listen to the playback to check your mic.
  5. If the level bar stays flat, confirm the correct device is highlighted and repeat the test.
About “Automatically adjust microphone volume”: Webex enables this checkbox by default. It works well for laptop microphones, but if you are using a professional external microphone with its own gain control, disable it. Automatic adjustments can weaken an already balanced microphone signal. This may make your voice sound distant or cut out. Other participants might struggle to hear you clearly.
Pro Tip: If your voice keeps cutting out, check the input level. This also applies when quiet speech barely registers. In Webex Audio settings, scroll down to Webex Smart Audio. The default setting is Noise Removal or Optimize for My Voice. Try switching to Music Mode instead of the default. This reduces background filtering and preserves your microphone’s original audio.
Fix 2: Allow Microphone Access in Your Operating System
If Webex cannot access your microphone at the OS level, no in-app setting will fix it. This permission is frequently blocked automatically after a Webex update, an OS upgrade, or a fresh installation.
Windows 10 and Windows 11
  1. Open Start and go to Settings.
  2. Navigate to Privacy and Security (Windows 11) or Privacy (Windows 10).
  3. Select Microphone from the left sidebar.
  1. Toggle Microphone access to On.
  2. Scroll down and confirm Let desktop apps access your microphone is also toggled On.
  1. Find Webex in the app list below that toggle and confirm its individual switch is enabled.
  2. Relaunch Webex and run the microphone test in Settings → Audio.
macOS (Ventura and Later)
  1. Click the Apple menu and open System Settings.
  2. Select Privacy and Security from the sidebar.
  1. Click Microphone.
  1. Find Webex in the list and toggle it On.
Note: If Webex does not appear in the macOS microphone list, the app has not yet requested access from the system. Launch a Webex test call first, then return to System Settings. The Webex toggle will now be visible and can be enabled.
Fix 3: Set Your Microphone as the Default Input Device
Even when you have selected the correct microphone inside Webex, the OS may still route audio through a different default device. Fixing this at the OS level ensures both the app layer and the system layer are pointing to the same source.
Windows Sound Settings
  1. Right-click the speaker icon in the system taskbar and select Sound Settings.
  1. Under Input, open the dropdown and choose the correct microphone.
  1. Alternatively, open Control Panel → Sound → Recording tab, right-click your microphone, and select Set as Default Device.
  2. Click OK, relaunch Webex, and run the built-in mic test.
macOS System Audio Input
  2. Select Sound from the sidebar.
  3. Click the Input tab.
  1. Select your microphone from the device list.
  2. Drag the Input volume slider to at least 50%. A slider at zero produces no signal even from a perfectly functional device.
Fix 4: Update or Roll Back Your Audio Driver (Windows)
Audio driver problems are most common after a Windows Update replaces a working driver with an incompatible version. This fix applies to Windows only. macOS manages audio drivers through system updates and rarely requires manual action.
  1. Press Windows + X and select Device Manager.
  2. Expand Sound, video and game controllers.
  1. Right-click your audio device and select Update driver → Search automatically for drivers.
  2. If the problem started after a recent Windows Update, right-click the same device, choose Properties → Driver tab, and click Roll Back Driver to restore the previous version.
  3. Restart your computer and retest in Webex.
If the Roll Back Driver button is greyed out, no previous driver version is stored. In that case, visit the device manufacturer’s website (Dell, HP, Realtek, or your laptop brand) to download and install the driver package manually.
Fix 5 – Restart or Reinstall the Webex App
A corrupted audio session or stale configuration cache can cause microphone failures that survive every settings change you make. Fully quitting and relaunching Webex resolves most of these cases.
  1. Quit Webex completely. Do not just minimize the window. Right-click the Webex icon in the system tray (Windows) or Dock (macOS) and select Quit.
  2. Relaunch Webex and test the microphone.
  3. If the problem persists, uninstall Webex, download the latest version from webex.com, and reinstall.
  1. On Windows, if issues return after reinstall, navigate to %AppData%\Cisco\Unified Communications in File Explorer and delete the folder contents to clear cached configuration data, then relaunch Webex.
Fix 6: External and Wireless Microphone Not Detected in Webex
External and wireless microphones introduce failure points that built-in microphones do not have. USB receiver recognition, pairing state, transmitter mute status, and firmware compatibility. Start with the generic checks below, then follow the product-specific steps if you are using a Hollyland LARK MAX 2.
Common causes for any external or wireless microphone:
  • USB receiver is not fully seated in the port
  • The OS has not yet assigned a device name (unplug, wait 5 seconds, replug)
  • A firmware mismatch between transmitter and receiver causes intermittent audio dropouts
Connecting the Hollyland LARK MAX 2 to Your Computer
  1. Insert the LARK MAX 2 Camera receiver into your computer’s USB-C port and power it on by pressing the power button for 3 seconds.
  1. Remove the transmitter unit from the charging case. Once both units are out, they should pair automatically.
  2. If automatic pairing fails, press and hold the TX and Camera RX’s power buttons for 3 seconds to turn them off.
  3. With the LARK MAX 2 mic/transmitter (TX) switched off, hold its power/multifunction button for 6 seconds. The LED will activate to indicate pairing mode.
  1. Keep the Camera RX switched off and press and hold its power button for 6 seconds to enter pairing mode.
  1. Wait for the two devices to pair. The Camera RX touchscreen display will show the successful pairing status. You can easily identify whether the TX is paired by viewing the signal strength icon or the volume bar of the connected transmitter unit.
  1. On the other hand, a solid blue LED on the TX confirms that it has connected successfully to the Camera RX.
  1. On Windows, open Sound Settings → Input and confirm “LARK MAX 2” or “USB PnP Audio Device” (or any similar name) appears in the device list.
  2. On macOS, open System Settings → Sound → Input and confirm the same device name is listed.
Selecting the LARK MAX 2 as the Webex Microphone Input
  1. Open Webex and go to Settings → Audio.
  1. Click the Microphone dropdown and select LARK MAX 2. If it is listed as “USB PnP Audio Device,” select that entry instead.
  1. Click Test and speak into the transmitter clip. The input level meter should respond visibly.
  1. If Webex does not list the device, unplug the receiver, wait 5 seconds, reconnect it, and reopen the dropdown before selecting.
Diagnosing No Signal from the LARK MAX 2 in a Live Call
If the device is selected in Webex but producing no audio, work through these steps:
  1. Check the transmitter LED. Solid red means the transmitter is muted. Double-press the power/multifunction button to unmute. Solid blue means the transmitter is live and actively capturing.
  1. Reposition the transmitter. Clipping the transmitter inside thick clothing or behind a jacket lapel significantly reduces signal strength. Move it to an exposed position on the chest.
  2. Reduce AI Noise Cancellation. First, check whether the transmitter’s noise cancellation feature is active. If you see a steady green LED indicator, that confirms the function has been enabled. You can press the power/multifunction button on the TX once to turn on / off noise cancellation.
Conversely, open the HollyAudio app, connect the LARK MAX 2 to it, and go to the NC Level section. If noise cancellation is active, the NC Level toggle will be switched on. Below the toggle, you will see the option to adjust the noise cancellation levels. Simply increase or decrease the bar to manage the NC intensity.
Fix 7: When Nothing Works: Advanced and Admin-Level Causes
If every fix above has failed, the problem is likely outside your direct control.
  • IT/enterprise policy lock: On corporate Webex accounts, an administrator can restrict microphone access at the site-configuration level. This presents as Webex refusing to list or activate any input device regardless of OS permissions. Contact your IT administrator and ask them to check the Webex site audio policy settings.
  • Conflicting third-party audio software: Applications like Krisp, NVIDIA RTX Voice, or virtual audio cable drivers install virtual audio devices that can intercept your microphone signal before it reaches Webex. Disable or uninstall these applications, restart your computer, and retest.
For unresolved issues, visit the Cisco Webex Help Center or the Webex Community forum, where Cisco support engineers respond to hardware-specific cases directly.
Why does my microphone work in other apps but not in Webex?
Webex maintains its own audio device selection layer, independent of the OS default. Even if your microphone is set as the system default, Webex may be pointing to a different device internally. Go to Webex Settings → Audio and manually select the correct microphone from the dropdown. Running the built-in test confirms the selection is active.
My microphone shows in Webex settings, but there is no sound. What now?
Your computer detects the mic, but its audio signal is blocked or muted. First, check whether a physical button mutes your microphone. Also, make sure your computer’s input volume stays turned up. On Windows 11, open Settings, then select System and Sound. Scroll down and select More sound settings to open the classic window. Next, open Recording and right-click your microphone. Select Properties, then Advanced, to access additional settings. Uncheck Allow applications to take exclusive control of this device. If left checked, this option lets one app lock the microphone, blocking others. As a result, Webex cannot access the microphone.
Does the Webex browser version have different microphone settings than the desktop app?
Yes. In Chrome, Edge, or Firefox, microphone access is managed by a browser-level site permission. Click the sliders icon in the address bar, open Site Settings, and set Microphone to Allow. The browser version of Webex also offers fewer audio device selection options compared to the full desktop app, which can make troubleshooting harder.
My microphone keeps cutting out during Webex calls. Is this a mic issue or a network issue?
For wireless microphones, intermittent dropout usually points to radio interference or transmitter distance from the receiver. For wired microphones, check for a loose USB connection or a worn 3.5mm cable. If audio is choppy rather than completely silent, the cause is more likely CPU load or insufficient network bandwidth affecting VoIP encoding.
Will Webex work with a wireless USB receiver microphone like the Hollyland LARK MAX 2?
Yes. Webex treats any USB audio device as a standard input source with no special configuration needed. Plug in the receiver, confirm it appears in your OS input device list, then select it in Webex Settings → Audio → Microphone. No additional drivers are required, and the process works identically on Windows and macOS.
Fixes 1 through 3 – selecting the correct device in Webex, enabling OS microphone permissions, and setting the correct default input – resolve the large majority of Webex microphone failures. If you have worked through every step above without success, test the microphone in a voice recorder app before contacting support. That single test confirms whether the fault lies in Webex or in the hardware itself. Isolate the layer, then fix the layer.
apec
