Whether you’re a karaoke enthusiast, a budding public speaker, or just looking for a fun way to amplify your voice, a Bluetooth handheld microphone is an incredibly versatile tool. With their wireless freedom and ease of connection, these mics offer a level of convenience and portability unmatched by traditional wired options. In this review guide, we’ll explore the best Bluetooth handheld microphones on the market.
Review for Best Bluetooth Handheld Microphone
Bluetooth handheld microphones have revolutionized the way we amplify our voices. From impromptu karaoke nights to professional presentations, these wireless wonders offer unmatched convenience and portability. Keep reading to know more.
Best Overall for Vocal Quality: Shure SM58
The Shure SM58 isn’t just a karaoke microphone; it’s the vocal microphone. Its iconic status comes from decades of reliable performance and exceptional sound tailored for singing.
Features
- Dynamic Microphone: Handles high volumes without distortion, perfect for powerful vocals.
- Cardioid Pickup Pattern: Focuses on sound directly in front, minimizing background noise.
- Frequency Response: Shaped to emphasize the clarity and presence of vocals.
- Rugged Build: Roadworthy, able to withstand heavy use and the occasional drop.
- Internal Shock Mount: Reduces noise from accidental bumps and handling.
Pros
- The Vocal Benchmark: The SM58’s sound is the standard by which many other mics are judged. It makes vocals sound natural, articulate, and effortlessly cut through a mix.
- Stage-Ready Reliability: From small gigs to stadiums, the SM58 performs consistently, night after night.
- Versatile Performance: While known for vocals, it also works decently on instruments like guitar amps or drums.
Cons
- Requires Sound System: It’s not a self-contained karaoke solution. Needs speakers, mixer/amp, etc.
- Not for Subtlety: It’s not the best choice for capturing every nuance of a delicate vocal performance.
- Visual Simplicity: Its classic design won’t turn heads like some flashy karaoke mics.
Overall Impressions
The Shure SM58 is the go-to choice if you want a microphone that focuses on pure, powerful vocal delivery. It’s the perfect tool for:
- Singers of Any Skill Level: Makes beginners sound better and helps experienced vocalists shine.
- Live Karaoke: Ensures your voice is heard clearly over the backing track.
- Home Recording: If you want to capture raw vocals with quality that surpasses typical “karaoke” mics.
Important: The SM58 shines brightest when you have a decent sound system to pair it with. Its magic lies in its sound, not flashy features or integrated speakers.
Best All-in-One Karaoke Mic: Bonaok Wireless Bluetooth Karaoke Microphone
The Bonaok Wireless Bluetooth Karaoke Microphone delivers the classic karaoke experience in a portable, budget-friendly package. It combines a microphone, speaker, and basic controls, making it an instant party starter.
Source
Features
- Wireless Bluetooth: Easily connects to smartphones, tablets, and other devices for music streaming.
- Built-in Speaker: Delivers sound for both your vocals and the music.
- Microphone Controls: Adjust volume, echo effect, and sometimes song skipping.
- Rechargeable Battery: Provides several hours of wireless use.
- SD Card/USB Support (Some Models): Allows music playback directly from these sources.
- Colorful Designs: Often available in bright colors or metallic finishes for a playful look.
Pros
- Super Easy to Use: Simple Bluetooth pairing and intuitive controls.
- Affordability: One of the most budget-friendly ways to get a full karaoke experience.
- Entertainment for All: Kids and adults alike can enjoy singing along.
- Portable: Take it to parties, on trips, or just use it around the house.
- Voice Changer Effects (Some Models): Add a silly and entertaining element.
Cons
- Sound Quality: Good for casual karaoke, but audiophiles will find the speaker and mic quality basic.
- Limited Effects: The echo control is rudimentary compared to advanced karaoke machines.
- Build: Can feel less robust than higher-priced professional microphones.
Overall Impressions
The Bonaok Wireless Bluetooth Karaoke Microphone is a great choice for:
- Casual Entertainment: Perfect for spontaneous karaoke sessions, family gatherings, or keeping kids entertained.
- Budget-Conscious Buyers: Offers a lot of fun at a very accessible price point.
- Anyone Who Prioritizes Ease of Use: If complex setups aren’t your thing, the Bonaok delivers karaoke in a flash.
Note: Bonaok has various models, so features like voice changers or SD card support may differ slightly.
the right input connections for the Rode Wireless Go II’s receiver.
Best Budget-Focused Dynamic Mic: Fifine Dynamic Karaoke Microphone (K6/K8)
Fifine’s Dynamic Karaoke microphones offer clear vocal quality and a no-nonsense approach at a price that’s incredibly easy on the wallet. They’re a great way to upgrade your karaoke experience without breaking the bank.
Source
Features
- Dynamic Microphone: Handles loud voices and minimizes background noise, perfect for lively singing sessions.
- Cardioid Pickup Pattern: Focuses on sound directly in front of the mic.
- XLR Connection: Standard audio cable type for connecting to mixers, sound systems, or some karaoke machines.
- On/Off Switch: Conveniently mute the mic without unplugging it.
- Metal Construction: Durable and built to handle regular use.
Pros
- Budget-Friendly: Among the most affordable ways to get a decent dynamic microphone.
- Clear Vocal Sound: Offers a noticeable improvement over built-in mics on laptops or cheap karaoke machines.
- Simple and Reliable: Plug-and-play functionality requiring no batteries or complex setup.
- Durable Build: Can handle the typical bumps and drops of regular use.
Cons
- Requires Sound System: Not a standalone solution, needing speakers, a mixer, etc., to work.
- Basic Sound: Can’t compete with the detailed sound of high-end studio vocal mics.
- No Effects: Lacks the echo or other features found on all-in-one karaoke mics.
- XLR Only: Might require an adapter if your equipment lacks XLR inputs.
Overall Impressions
The Fifine Dynamic Karaoke Microphone (K6/K8) is perfect for:
- Budget-Minded Karaoke Singers: If sound quality matters, but you want maximum bang for your buck.
- Existing Sound Systems: Ideal if you already have a karaoke machine, mixer, or speakers with XLR inputs.
- No-Frills Singing: Great if you simply want a reliable mic that makes you sound good without fancy features.
Important Notes
- XLR Cable Needed: Fifine mics don’t include an XLR cable, so factor that into the cost.
- Pop Filter Recommended: Helps reduce harsh “p” and “b” sounds.
Best for Professional-Grade Sound (With Budget to Match): Rode Wireless Go II (Single Set)
The Rode Wireless Go II is a premium wireless microphone system known for its quality, versatility, and compact size. Using a single transmitter from the kit makes it a superb handheld microphone option.
Features
- Professional-Grade Mic Capsule: Captures clear, detailed vocals with a wider dynamic range than most built-in karaoke mic capsules.
- Reliable Wireless Transmission: Operates in the 2.4GHz frequency band with digital encryption for robust, interference-free signal.
- Built-in Recording: Functions as a standalone recorder, great for capturing your performances.
- Ultra-Compact Transmitter and Receiver: Highly portable system that’s easy to pack with you.
- USB-C Connectivity: For charging, computer connection, and potential use with some smartphones/tablets.
Pros
- Superb Vocal Sound: Delivers a level of clarity and nuance that outclasses typical all-in-one karaoke mics.
- Professional Reliability: Robust wireless signal for worry-free use during your karaoke sessions.
- Future-Proofed Versatility: Can be expanded to a dual-mic setup for interviews, used for content creation, and much more.
- Highly Portable: While pricier, it’s far more travel-friendly than a bulky karaoke machine with similar vocal quality.
Cons
- Price: Significantly more expensive than all-in-one karaoke mics.
- Requires External Speaker: Needs to be paired with a compatible speaker or sound system for karaoke use.
- Minimal Karaoke-Specific Features: Lacks built-in effects or the playful, all-inclusive design of some dedicated karaoke systems.
Overall Impressions
The Rode Wireless Go II (Single Set) is an investment worth considering if:
- Vocal quality is your absolute priority: It delivers a professional-grade sound that’s hard to match in the traditional karaoke mic market.
- You value flexibility: Its future expandability and potential uses beyond just karaoke add to its appeal.
- You have (or plan to have) a compatible sound system: This allows you to create a higher-quality karaoke setup than most all-in-one options offer.
Important: Ensure your chosen speaker/mixer has
Bonus: Smallest Wireless Microphones: Hollyland Lark M2
The Hollyland Lark M2 is a compact and powerful wireless microphone system designed for content creators seeking portability and high-quality audio. With its improved sound capture, versatile receiver options, and impressive feature set, the Lark M2 stands out as a perfect choice for a wide range of applications.
Features:
- One-Tap Setup: Automatic pairing and easy-to-use design.
- Mono/Stereo/Safety Track Modes: Flexibility for different recording scenarios.
- Built-in Magnets: Enable versatile mounting options.
- Real-Time Monitoring: Option to monitor audio via a headphone jack on the receiver (3.5mm version only).
- Volume and Transmitter Status Display: Visual indicators on the receiver for easy monitoring.
Pros
- Exceptional Audio Quality: The Lark M2 delivers crystal-clear, professional-grade audio with minimal background noise, surpassing many competitors in its price range.
- Effortless Setup and Operation: The transmitters and receiver pair automatically out of the box, making it incredibly user-friendly for beginners and on-the-go professionals alike.
- Ultra-Compact Size: The tiny form factor of the transmitters and receiver makes the Lark M2 extraordinarily portable and discreet.
- Versatile Receivers: Choose from Lightning, USB-C, or 3.5mm receivers to connect seamlessly to smartphones, cameras, and more.
- Long Battery Life: Extended battery life and the convenient charging case ensure you can record all day without interruption.
- Impressive Range Transmission distances of up to 656ft (200m) give you great freedom of movement.
Cons
- Limited Customization: The Lark M2 offers fewer in-depth audio adjustments compared to some higher-end systems.
- Noticeable Magnet: The built-in magnet, while useful, can be slightly visible when used as a lavalier mic.
- No Internal Recording: Unlike some competitors, the Lark M2 lacks the ability to record audio directly to the transmitters.
Who is it for?
The Hollyland Lark M2 is ideal for:
- Vloggers and Content Creators: Its portability and ease of use make it perfect for run-and-gun content creation.
- Interviewers and Journalists: The clear audio and dual-transmitter options are great for interviews.
- Filmmakers: The Lark M2 is a reliable and affordable option for indie filmmaking and documentaries.
How to Choose the Best Bluetooth Handheld Microphone?
Here’s a breakdown of the key aspects to help you make an informed decision:
Intended Use:
- Karaoke/Casual Singing: Prioritize fun features like echo effects, voice changers, and a bright, colorful design.
- Public Speaking/Presentations: Focus on clear audio reproduction, a comfortable grip, and possibly noise-cancellation features.
- Vlogging and Content Creation: Opt for a microphone with excellent sound quality and compatibility with your smartphone or camera.
- Recording Music: Look for a high-fidelity microphone with a wide frequency reaction and the ability to handle higher sound pressure levels.
Sound Quality:
- Frequency Response: A wider frequency response (e.g., 50Hz – 20kHz) typically means better audio capture and a more natural sound.
- Sensitivity: Choose a microphone with a higher sensitivity rating for better sound pickup.
- Noise Cancellation: This feature minimizes background noise, especially useful for outdoor use or in noisy environments.
Connectivity & Compatibility:
- Bluetooth Range: Longer range offers greater freedom of movement (30ft is standard, some reach much further).
- Receiver Options: Ensure the microphone is compatible with your intended device (smartphone, camera, computer, etc.).
Battery Life:
- Consider usage: Choose a longer battery life for extended sessions or outdoor use.
- Charging Case: A charging case provides extra power on the go.
Build Quality & Design:
- Durability: Opt for sturdy construction, especially if the microphone will be used frequently or outdoors.
- Ergonomics: A comfortable grip is essential for longer use.
- Aesthetics: Choose a design that suits your style and preferences.
Features:
- Volume Controls: On-mic controls provide convenient adjustments.
- Mute Button: Handy for quickly pausing audio.
- Echo Effects: Adds a fun touch for karaoke.
- Headphone Jack: Permits for real-time monitoring of audio.
- Establish a budget and research suitable options within that range. Remember, expensive doesn’t always equal the best fit for your specific needs.
Additional Tips:
- Read Reviews: Study out online reviews and user experiences.
- Watch Video Demonstrations: Get a feel for the microphone’s sound quality and features.
- Test it Out (if possible): Try the microphone in person to evaluate its comfort and sound in your own voice.
What is a Bluetooth handheld microphone?
A Bluetooth handheld microphone is a wireless microphone that connects to your devices (smartphone, tablet, computer, etc.) using Bluetooth technology. It offers liberty of movement and eliminates the need for cables.
What are the different types of Bluetooth handheld microphones?
- All-in-one Karaoke Mics: Include a speaker, basic effects, and music streaming.
- Standalone Microphones: High-quality mics without speakers, needing a separate sound system.
- Content Creation Mics: Compact mics designed for recording to smartphones or cameras.
What should I look for in a Bluetooth handheld microphone?
Sound quality, features (echo, voice changers, etc.), battery life, build quality, and your budget/needs.
Is there a Bluetooth microphone that doesn’t need a separate speaker?
Yes! All-in-one karaoke microphones include their own speaker for singing along.
What are some popular brands of Bluetooth handheld microphones?
Rode, Shure, Sennheiser, Hollyland, Sony and more.
How much do Bluetooth handheld microphones cost?
Price varies depending on features, brand, and audio quality. You can find essential models for under $50 and high-end professional options reaching several hundred dollars.
Final Thoughts!
Ultimately, the best Bluetooth handheld microphone for you depends on your priorities and how you plan to use it. Whether you crave professional-grade vocal capture like the Rode Wireless Go II, the all-in-one convenience of the Bonaok, or the sheer value of the Fifine Dynamic Microphone, there’s an option out there to transform your next karaoke session, interview, or spontaneous performance into an unforgettable experience.
