Top 6 Boom Mics Every Filmmaker Should Consider in 2025
By Hollyland | February 19, 2024
If you want to create a great film to enchant your audience, providing only the best visuals is not just good enough. Sound plays a crucial role in bringing the story to life by managing dialogue and background noise. For this purpose, boom microphones redefine the very rhythm of filmmaking, where every subtle sound detail is a stroke on the storytelling canvas.
Filmmakers can experience an immersive sound that stays in the audience’s memory long after the movie’s credits roll. Read this article till the end to explore the best boom microphones with their specifications to make a well-informed decision for your films this year.
Comparison Between Different Boom Microphones for Filmmaking
Recognizing the significance of sound in the film industry is vital. As storytellers, we understand that capturing top-notch audio goes beyond technical requirements. Now, let’s discuss and compare some of the best filmmaking boom microphones to stand out.
Metrics Sennheiser MKE 600Rode NTG4Audio-Technica AT875RDeity S-Mic 2MKH 416Hollyland Lark M2S
Price $330$388$169$359$974.92$119 (2TX 1RX USB-C version)
Impedance 25 ohm200 ohm100 ohm75 ohmNominal Impedance: 25 ohm Terminating Impedance: 800 ohmUnspecified
Sensitivity 21 mV/Pa-32 dB re 1 V/Pa-30 dB re 1V/Pa32±2dB re 1V/Pa25 mV/PA-37 dBV +/- 2 dB @ 1kHz
Frequency Response 40 Hz to 20 kHz20 Hz to 20 kHz 90 Hz to 20 kHz50 Hz to 20 kHz40 Hz to 20 kHz20 Hz to 20 kHz
Polar Pattern Super-cardioidSuper-cardioidLine + Gradient ShotgunSuper-cardioidHyper-cardioidOmnidirectional
S/N Ratio 76 dB78 dB74 dB -18 dB 81 dB> 70 dB
Connectivity Options XLR, XLR to 3.5mm TRS Adapter Cable, Battery PowerWireless Bluetooth 4.2, USB Bluetooth AdapterIntegral 3-pin XLRM-type Output ConnectorXLR, 3-pin XLR Output Connector, Phantom PowerXLRUSB-C, 3.5mm, USB-A to USB-C, and USB-C to Lightning
6 Boom Mics That Will Enhance Your Film’s Audio Quality
In this section, we’ll examine a carefully selected list of the 6 best boom microphones for films to cater to the diverse needs of the community. These bloom mics have superior voice clarity and noise-canceling features to transform the audio aspect of your movies. The following are some of the top 6 boom microphones available in the market.
  1. Sennheiser MKE 600
This boom microphone is specifically crafted for filmmaking in challenging environments. It effectively minimizes undesired side noise, incorporating a specialized filter to diminish wind interference. This microphone is great at capturing clear speech, making it easy to understand. It works well even if the person speaking is far away through its professional boom pole, which makes it easier to handle.
mke-600-boom-microphone
Moreover, it doesn’t need phantom power because you can just use standard AA batteries. Plus, the microphone has a light that tells you when the batteries are running low. It’s a perfect choice for shooting videos in different places, whether it’s a noisy city or a room with bad sound.
Key SpecificationValues
Connectivity TechnologyXLR
Special FeaturesPedestal
Polar PatternUnidirectional
Microphone FormShotgun
Frequency Range40 Hz to 20 kHz
Battery Operating TimeApproximately 150 hrs
Pricing$330
Pros
  • This boom mic’s design is well-thought-out, with accessible controls for users.
  • Its strong windscreen lets you use it in almost any situation or area with satisfactory results.
Con
  • This boom mic has no moisture resistance, which could cause temporary frequency response shifts.
  1. Rode NTG-4
Rode NTG-4 is a great choice for recording in challenging situations. With its durability and lightweight design, it makes extremely low levels of handling noise. Rode’s engineers worked hard to make this microphone affordable for the film and broadcast industries without compromising quality. Also, the carbon-fiber-made boom pole of this microphone can extend up to 3 meters for a professional recording experience.
rode-ntg4-boom-microphone
Furthermore, NTG-4 uses special technology to resist moisture, making it perfect for tricky recording situations. When you’re not using this boom microphone, you can keep it safe in the weather-resistant aluminum container.
Connectivity TechnologyWith Cable
Polar PatternSupercardioid
Frequency Range20 Hz to 20 kHz
Capsule0.50″
Acoustic PrincipleLine Gradient
Pricing$388
Pros
  • Its durable construction and sturdy buttons make it feel pleasant to use.
  • You can have a natural and clean sound with this boom mic throughout the working range.
Con
  • The super-cardioid pickup pattern is so sensitive that it picks up sound only from in front of the mic and no sound from the side.
  1. Audio-Technica AT875R
It is your fine companion for recording videos and capturing sound, especially in news and filmmaking productions. It’s the shortest shotgun microphone from Audio-Technica, and it easily attaches to small camcorders without making them heavy. Its compact design makes it an excellent companion for use with small digital cameras, ensuring convenience and versatility in various shooting setups.
audio-technica-boom-microphone
Additionally, it excels in rejecting unwanted sound from the sides and back, ensuring clear and focused audio capture in dynamic recording environments. If you’re into making videos with small cameras, this microphone is a handy and reliable choice for getting great audio in different situations.
Connectivity Technology3-pin XLRM
Case StyleSG4
Phantom Power Requirement11-52V DC, 2mA
Microphone FormCondenser Microphone
Frequency Range90 Hz to 20 kHz
Dynamic Range107 dB
Polar PatternLine Gradient
Pricing$169
Pros
  • You can perform a maximum of boom microphone functions for filmmaking at a fantastic low price.
  • This boom microphone has a narrow acceptance angle, which is good for picking up sound from far away.
Con
  • It requires phantom power and cannot be plugged directly into the camera.
  1. Deity S-Mic 2
The S-Mic 2 boom mic is exceptional for recording sounds with its ultra-low off-axis coloration, even if they move around a bit. Even if there’s a boom capturing sound from multiple actors, this shotgun microphone makes it easy for even a beginner boom operator to capture rich and full sounds on a movie set. Its body is entirely made of solid brass, and no plastic is used for its construction.
deity-smic2-boom-microphone
This makes it stand out from other microphones in its price range. Additionally, the S-Mic 2 is designed to operate smoothly in humid environments through an epoxy coating on the PCB, making it water-resistant. The microphone looks professional with its durable black speckled finish, making it a reliable tool for recording high-quality audio on movie sets for a long time.
Sound FieldMono
Phantom Power Requirement48V DC, 1.5mA
Frequency Range50 Hz to 20 kHz
Audio Sensitivity32 dB
Pricing$359
Pros
  • Its metallic body and durable construction make it suitable to use even on a rainy day.
  • You can get impressive and rich sound with its resistance to RF interference.
Con
  • There’s a lack of a low-cut filter switch in this boom mic, which makes it less suitable for low-frequency noise handling.
  1. Sennheiser MKH 416
This boom microphone is among the top-notch boom mics widely used in the film and TV industry. It captures great sound whether you’re recording on location or doing vocals for a movie trailer. With its super-cardioid/lobar pattern and RF condenser design, this boom mic is highly resistant to humidity, ensuring reliable performance even in challenging conditions.
mke-416-boom-microphone
Its compact design and high consonance articulation make it work well for professional broadcast purposes. Plus, it looks nice in matte black and comes with a MZQ 100 microphone clamp and windscreen to make things easier for you.
Connector TypeMicro USB
Special FeatureVoice Activated Recording
Microphone FormRF Condenser
Audio Sensitivity20 dB
Phantom Power Requirements48V, 2mA
Polar PatternSupercardioid/Lobar
Pricing$974.92
Pros
  • Its high directivity and off-axis rejection give a more pointed and unidirectional recording experience.
  • The lightweight and compact design of this boom mic lets you carry and use it with ease.
Con
  • The high cost of this boom microphone makes it not affordable for everyone.
6. Hollyland Lark M2S
Hollyland Lark M2S isn’t a typical boom microphone for filmmaking. However, its hidden design can be used as an alternative. It’s a lightweight microphone with a rigid clip-on mechanism due to its titanium make. Contrarily, it has a logo-free design, which means it can fit into various films regardless of branding. Plus, it blends organically in scenes and frames, eliminating the efforts of hiding logos.
The next remarkable feature that makes Lark M2S an excellent replacement for boom mics is its 1000ft wireless range. This saves your Boom Operator’s arm from the pain and struggle of holding the mic above the actors and subjects as the voice perfectly transmits to the receiver.
The transmitted audio is also quite stable due to Lark M2S’s 48kHz/24-bit audio quality. If the film set is overcrowded, this wireless microphone ensures clean and interference-free audio transmission since it comes with an RF interference-resistant circuit. Also, to eliminate background noises so you can record clean voices and impressions, Hollyland Lark M2S offers a built-in Environmental Noise Cancellation (ENC) technology along with dual-level noise-canceling adjustment through the LarkSound app.
Connectivity Technology2.4GHz AFH wireless, USB-C, 3.5mm, USB-A to USB-C, and USB-C to Lightning
Special FeaturesLogo-free design, Titanium clip-on, ENC, RF interference-resistant technology, and 1000ft wireless range
Polar PatternOmnidirectional
Microphone FormWireless Lavalier
Battery Operating TimeApprox. 9 hours
Pricing$119 (2TX 1RX USB-C version)
  • The no-logo design offers a unique style
  • Titanium clip-on provides a strong grip when attached to a collar or inside of clothing
  • Audio quality is extremely impressive on film sets
  • ENC and RF interference-resistant technologies further clear the voice
  • Some users may find the battery life a bit low for long-hour filmmaking and shooting
How to Choose a Boom Microphone for Filmmaking in 2025
The selection of the perfect boom microphone for an exciting filmmaking experience requires careful consideration of accessories. As technology progresses, the features and abilities of these audio devices also advance.
Moreover, it’s crucial to understand the essential factors that can significantly affect your filmmaking setup. The process of making a decision involves finding a balance between technical specifications and personal preferences. The following are the points you should take care of while choosing a boom microphone:
1. Shotgun Design
The unique characteristic of boom microphones is their shotgun design. This involves a long, cylindrical microphone with a focused pickup pattern. Also, the design allows the microphone to concentrate on specific sounds while minimizing background noise.
2. Low Self-Noise
Low self-noise refers to the minimal electronic noise produced by the microphone itself. Moreover, this crucial quality in boom microphones ensures the removal of unwanted hissing or electronic interference in the recorded audio. It is essential when recording subtle or quiet sounds to prevent any distractions from affecting the audio quality.
3. Extended Reach and Telescopic Design
The extended reach and telescopic design of boom microphones provide flexibility for sound engineers or boom operators. Engineers can position the mics close to the sound source without being visible in the camera frame. Plus, its telescopic design enables precise control over the microphone’s length for capturing clear audio.
4. Low-Cut Filters
Low-cut filters, or high-pass filters, are incorporated into boom microphones to diminish or eliminate low-frequency sounds below a set point. These filters are valuable for reducing unwanted noise like wind rumble or handling vibrations. By removing low-frequency interference, low-cut filters enhance the clarity of audio recordings for outdoor shoots.
5. Compatibility with Boom Poles
Boom poles are crucial accessories for using boom microphones. These lightweight, extendable rods help position the boom microphone near the sound source while keeping the microphone and its operator out of the camera frame. Moreover, the compatibility with boom poles ensures that the microphone can be securely mounted for effective audio capture.
We conclude that the top six boom microphones for 2025 prove to be essential tools. Each brings its own unique strengths to enhance the audio experience in cinematic storytelling. These boom mics, with their special features, redefine what it means to achieve outstanding audio quality on a film set.
As filmmakers strive for the perfect sound, these devices shine as expert conductors, skillfully managing the delicate interplay of dialogue, background noise, and emotions. You can opt for any of the microphones to enhance the immersive journey for viewers by establishing a new standard.
While boom mics offer superior directional audio, sometimes filming conditions demand greater mobility and discretion. In these scenarios, filmmakers should also consider adding a high-quality wireless lavalier microphone to their kit for capturing reliable, crystal-clear dialogue audio in challenging environments.
