Shop Smart Save Big
BLACK FRIDAY Shop Now
5 Best iPhone Microphones for Vlogging in 2024
Are you ready to take your vlogging game to the next level with crystal clear audio? An outstanding iPhone microphone is key to capturing your audience’s attention and delivering content that resonates. Whether you’re a seasoned vlogger or just starting out, the right microphone can dramatically enhance your video quality, setting you apart in the crowded world of online content. In this handy listicle, we’ll unveil the best iPhone microphones tailored for vlogging. Prepare to transform your storytelling prowess with tools that promise to make every word you speak as captivating as the visuals you showcase.
When selecting the best iPhone microphone for vlogging, there are several important criteria to consider to ensure you capture high-quality audio for your content. Here’s a quick breakdown of the key factors you should keep in mind:
  1. Audio Quality: The primary purpose of an external microphone is to improve the sound quality of your recordings. Look for a mic that delivers clear, crisp sound and has a good frequency response.
  2. Compatibility: Ensure the microphone works seamlessly with your iPhone model. It should connect easily, whether through the lightning port or via a wireless connection.
  3. Directionality: Mics come with different pickup patterns. For vlogging, a shotgun mic (which captures sound from one direction) is often preferred, as it can focus on your voice and reduce background noise.
  4. Portability: Vloggers are often on the move, so a compact and lightweight microphone that’s easy to carry around is essential.
  5. Ease of Use: You’ll want a plug-and-play type of microphone without complex setups so you can start recording quickly.
  6. Durability: A sturdy build that can handle the wear and tear of frequent use is important, especially if you vlog outdoors.
  7. Battery Life: If the microphone is battery-powered, long battery life is crucial for longer recording sessions.
Please note that the prices for these products can fluctuate due to various factors including sales, promotions, and availability. For the most accurate pricing, you should check current listings on retailers’ websites. The prices listed below are an approximation and may not reflect the exact current prices.
Here’s a simplified table to help compare these iPhone microphones for vlogging:
Microphone ModelApprox. PriceMicrophone TypePickup PatternCompatibilityNotable FeaturesAccessories Included
Shure MV88 Portable iOS Microphone$150CondenserAdjustable, Multiple patternsiOS devices with Lightning connectorBuilt-in headphone output, ShurePlus MOTIV audio app (for recording and editing)Windscreen, headphone adapter cable
Rode VideoMic Me-L Directional Mic$80CondenserCardioidiOS devices with Lightning connectorPlug-and-play, Furry windshield for field recordingWindshield, mic clip, carrying case
Boya BY-M1 Lavalier Microphone$20CondenserOmnidirectionalUniversal (with TRRS jack)Battery-powered, Clip-on design for hands-free useLapel clip, LR44 battery, foam windscreen, 1/4” adapter, carrying pouch
Sennheiser MKE 200 Mobile Kit$130CondenserSupercardioidUniversal (cameras and smartphones with TRS or TRRS jack)Integrated wind protection and shock mounting, Compact designWindscreen, 3.5mm TRS and TRRS cables, cold shoe mount, carrying pouch
Comica CVM-VM10-K2 Smartphone Mic Kit$70CondenserCardioidUniversal (cameras and smartphones with TRS or TRRS jack)All-metal construction, Flexible combination of microphone and accessoriesWindscreen, Smartphone holder, Tripod, Mic and Phone clamp, TRS and TRRS cables
Remember, some microphones may require additional adapters to work with certain iPhone models if the iPhone lacks a compatible jack (like a Lightning connector or a 3.5mm headphone jack). Always check your specific device compatibility before purchasing.
Overview:
The Shure MV88 is a remarkable tool for any vlogger who demands high-quality audio on-the-go. What sets it apart is its impeccable audio performance paired with unparalleled ease of use. The moment you plug it into your iPhone’s Lightning connector, it feels like your vlogging setup has undergone a professional upgrade. The MV88 captures sound with such clarity and depth, that your audience can feel the texture of your voice and the ambiance of your location with little to no background noise – a true feat for outdoor vloggers.
The build quality matches its audio prowess; compact and sturdy, it can survive the rigors of mobile journalism. It also boasts flexibility with multiple recording patterns. The cardioid mode is perfect when you need to focus on your voice while diminishing the surrounding noises, and the bidirectional mode can capture interviews with ease, recording both the interviewer and the interviewee with high fidelity. The ShurePlus MOTIV app is another highlight, offering real-time adjustments so you can tweak settings to your preference – talk about customization at your fingertips!
  • Connector Type: Apple Lightning
  • Polar Patterns: Adjustable width stereo, mono cardioid, mono bidirectional, raw mid-side
  • Frequency Response: 20 Hz to 20,000 Hz
  • Weight: 40.5 grams
  • Exceptional audio quality with a range of recording patterns.
  • Direct connection to iPhone via Lightning port ensures a reliable, high-quality digital signal.
  • Real-time audio control with the ShurePlus MOTIV app.
  • Robust construction and sleek design, making it a durable yet stylish addition to your vlogging gear.
  • Premium quality comes with a premium price tag.
  • Direct plug-in design means you can’t use your phone case, which may be inconvenient for some users.
  • Exclusively for iOS; sorry Android users, this one’s not for you.
The Shure MV88 sits in the upper range when it comes to mobile microphones, reflecting its professional-grade performance. It typically retails around $149 to $179. While that might give budget-conscious vloggers pause, the investment is justified for those looking to elevate their audio game significantly.
In my opinion, the Shure MV88’s exceptional audio quality far outweighs its cons. If audio is a high priority for your vlogs and you’re vested in the Apple ecosystem, this microphone should be at the top of your list. The app integration is especially useful as it gives you not only advanced control but also high adaptability to varied vlogging scenarios without needing additional gear. Despite the price, for the quality it delivers, it’s an investment in your vlogging career that you won’t regret.
Product Name: Rode VideoMic Me-L Directional Microphone
Overview:
The Rode VideoMic Me-L is a compact and highly directional microphone designed specifically for Apple iOS devices with a lightning connector, and it’s a solid choice for vloggers looking for a substantial upgrade from their iPhone’s built-in microphone. Straight out of the box, you’ll notice the build quality that Rode is renowned for – sturdy, but still lightweight enough for on-the-go shooting.
What’s particularly impressive about the VideoMic Me-L is its ability to hone in on the audio you’re trying to capture. Vlogging often means recording in dynamic, uncontrolled environments, and the focused pickup pattern helps to cut down on the background noise that can distract from your content. This directional feature ensures your voice remains crystal clear, making it ideal for interviews, presentations, or any scenario where you need your message to cut through the hustle and bustle.
Another standout feature is the inclusion of a 3.5mm headphone jack on the rear, allowing you to monitor audio during recording without any fuss – a real-time saver during post-production and a feature that often goes praised in user reviews.
  • Acoustic Principle: Pressure gradient electret condenser
  • Polar Pattern: Cardioid
  • Signal to Noise Ratio: 74.5 dB
  • Connector: Lightning Connector
  • Headphone Output Jack: 3.5mm TRS
  • Excellent sound quality that captures detailed and clear audio
  • Focused cardioid pickup pattern that reduces unwanted background sounds
  • Solid metal construction that is both durable and discreet
  • Easy to use, plug-and-play setup with no need for additional batteries or charging
  • Exclusive to lightning connector devices, non-compatible with USB-C or older iPhone models without an adapter
  • Lack of flexibility in terms of positioning compared to lavalier or longer shotgun mics
  • Relatively higher price point compared to entry-level microphones
The Rode VideoMic Me-L typically retails around $79.99, which is a moderate price tag when you consider the professional-level sound quality and Rode’s reputation in the microphone market. While it’s not the cheapest option on the list, the investment may be well worth it for serious vloggers who prioritize audio clarity and build quality.
Personal Opinion:
The Rode VideoMic Me-L fills a niche for iPhone videographers who demand superior sound without lugging around heavy equipment. Its compact form factor belies its capability. Despite a few limitations, such as compatibility, this microphone strikes an impressive balance between performance and portability. If you’re someone who vlogs in lively environments and needs to ensure your narration or dialogue pops, the VideoMic Me-L should be high on your consideration list. You’re paying for a piece of gear that not only elevates your audio game but also withstands the rigors of vlogging life.
Brief Intro:
For vloggers looking to enhance their audio quality without breaking the bank, the Boya BY-M1 Lavalier Microphone is a popular choice that’s often praised for its versatility and clarity. Designed to work with a myriad of devices including iPhones, it’s a straightforward solution for capturing high-quality audio on the go.
Overview:
The Boya BY-M1 is a compact, clip-on lavalier microphone that provides a significant audio upgrade from the built-in microphones on most smartphones and cameras. It’s a fantastic tool for vloggers due to its inconspicuous size and omni-directional pickup pattern, which means it captures sound evenly from all directions. This makes it very forgiving in terms of how it’s positioned on your subject. Moreover, its lengthy cable allows for flexibility in setup, which is particularly helpful when you need to move around or capture audio from a distance.
In my opinion, where the Boya BY-M1 shines is its simplicity and user-friendliness. It requires no complex setup or technical knowledge, making it ideal for those who are new to vlogging or who prefer a ‘plug and play’ solution. The included lapel clip and foam windscreen are thoughtful touches that facilitate outdoor recording and enhance overall audio quality.
  • Polar Pattern: Omni-directional
  • Frequency Range: 65Hz ~ 18KHz
  • Signal/Noise: 74dB SPL
  • Cable Length: 6m (20ft)
  • Power Requirement: LR44 battery (included) or smartphone power
  • Connector: 3.5mm (1/8”) 4-pole gold plug
  • Affordable compared to many competitors.
  • Long cable provides versatility in recording setups.
  • Omni-directional pattern means you don’t have to be too precise with placement.
  • Compatible with numerous devices, not just iPhones.
  • Battery provides a choice between smartphone power or dedicated battery for longer sessions.
  • Audio quality may not be as high as some professional-grade lavalier microphones.
  • The long cable can be cumbersome to manage and may introduce noise if not handled well.
  • Battery compartment can be tricky to open, and changing batteries can be inconvenient.
The Boya BY-M1 Lavalier Microphone is usually priced quite affordably. While specific prices can vary, you can often find it for around $20-$30. Due to its low price point and the value it provides, it remains a top contender for vloggers on a budget.
In conclusion, the Boya BY-M1 is a no-frills, reliable microphone that should be on every budget-conscious vlogger’s radar. While it may not match the audio quality of high-end professional mics, it offers an admirable performance-to-price ratio that’s hard to beat. It’s a tool that proves you don’t need to spend a lot to start producing vlogs with clear, intelligible audio.
Overview:
The Sennheiser MKE 200 Mobile Kit is a compact and versatile microphone designed for content creators looking to elevate their vlogging audio game. My first impression of the MKE 200 was its sleek design and the apparent build quality, which is expected from a brand like Sennheiser. It’s clear that they’ve put thought into this product as a tool for on-the-go creators. When I tested it during a vlogging session, I was pleased by the noticeable clarity and crispness it added to my voice while minimizing the background noise, thanks to its directional pick-up pattern.
  • Transducer principle: Pre-polarized condenser
  • Microphone frequency response: 40 Hz to 20 kHz
  • Pickup pattern: Cardioid / Super-cardioid
  • Connectivity: 3.5 mm TRS and TRRS connection
  • Battery-free operation
  • The directional audio capture ensures your voice stands out against background noise.
  • Its compact size and sturdy build make it ideal for handheld devices, adding minimal weight and bulk to your setup.
  • No battery requirement means you can use it as long as your phone is powered, without worrying about charging another device.
  • The windscreen provided is a nice touch, considerably improving outdoor recording sessions.
  • Compatibility is excellent, but you may need an extra adapter if your iPhone doesn’t have a headphone jack.
  • It does lack the features of higher-end microphones, such as gain control or a digital interface, which could be a setback for some professional users.
The Sennheiser MKE 200 Mobile Kit’s price strikes a balance between affordability and quality. Typically, it ranges from $100 to $130, depending on the retailer and any ongoing deals. Considering its performance and the renowned Sennheiser name, I find the pricing fair, particularly for serious vloggers who are not yet ready to invest in professional-grade equipment.
In my opinion, the MKE 200 hits a sweet spot for budding content creators who want to take a step up from their phone’s built-in microphone without going all out on a pro setup. It’s a solid buy for someone who values simplicity, ease of use, and portability, without compromising on sound quality. The kit bridges the gap between amateur and professional audio capture, making it an excellent choice for those dedicated to their vlogging craft.
Overview:
The Comica CVM-VM10-K2 Smartphone Mic Kit is a compelling choice for vloggers looking to enhance their iPhone audio quality without breaking the bank. This kit not only includes a cardioid shotgun microphone which is crucial for focusing on your voice and minimizing background noise, but it also comes with some handy accessories. The build quality is solid, with the microphone boasting a reliable, metal construction.
One of the standout features is the inclusion of a shock mount. This is essential for vloggers on the move as it helps to reduce unwanted vibrations and handling noise. In my personal experience, the shock mount performed admirably when I was shooting outdoors in a breezy environment.
Moreover, it has a universal design for smartphones which adds versatility to the kit. For iPhone users, this means even if you change your phone or use multiple devices, this microphone kit has got you covered. The kit also comes with a furry windshield, which is particularly useful for recording in windy conditions.
The microphone doesn’t require battery power, which is a huge convenience on the go. Just plug it into your iPhone (with a Lightning to 3.5mm adapter if needed) and you’re ready to record. The simplicity of use cannot be overstated; it’s a true ‘plug-and-play’ solution.
  • Frequency Response: 80 Hz to 16 kHz
  • Sensitivity: -34dB ±3dB
  • Signal to Noise Ratio: >58dB
  • Excellent build quality with a durable metal construction.
  • Plug-and-play design means no batteries are needed, reducing prep time.
  • Shock mount included which significantly reduces handling noise.
  • Universal phone clamp and tripod add to the ease of use and stability during recording.
  • The furry windshield included is great for outdoor recording.
  • Some might find the frequency response range limiting for capturing a full, natural sound.
  • An additional adapter is required for iPhones without a headphone jack, which is an extra expense and item to remember.
The Comica CVM-VM10-K2 falls into the affordable category, often found around the $50-$70 range. Considering the quality of audio and the number of accessories included, this microphone kit offers excellent value for money.
The Comica CVM-VM10-K2 Smartphone Mic Kit is a testament to how far mobile audio gear has come. Not only does it amplify the professional touch to your iPhone vlogs, but does so while remaining user-friendly and budget-conscious. For vloggers who are serious about their sound but not necessarily audio professionals, this kit is a wise investment. It deftly strikes the balance between quality and convenience, making it a go-to for those hoping to graduate from the built-in iPhone microphone without delving too deep into the complexities of sound engineering.
In this digital age, vlogging has surged in popularity, and the quest for impeccable audio is unending. We’ve journeyed through the realm of iPhone microphones, discovering versatile options ranging from budget-friendly lapel mics to professional-grade shotgun types. Whether you’re a budding vlogger or a seasoned creator, finding the right mic is pivotal for delivering crystal-clear sound to your audience. Remember, the best microphone is the one that suits your unique needs and enhances your storytelling. Choose wisely and let your voice be heard with clarity and depth.
If you’re seeking convenience, clarity, and ease of use, a wireless lavalier microphone can dramatically improve the audio quality of your vlogs. Its compact wireless design allows you to vlog freely without cumbersome cables, ensuring your audio matches your visual quality seamlessly.
FAQs:
  1. Do I really need an external microphone for iPhone vlogging?
    Yes, while the iPhone’s built-in microphone is sufficient for casual use, an external microphone substantially improves audio quality, reduces background noise, and provides a more professional end result for your vlogs.
  2. What type of microphone is best for vlogging in noisy environments?
    A shotgun microphone with directional audio pickup is usually the best option for vlogging in noisy environments, as it will focus on your voice and minimize surrounding noise.
  3. How do I connect an external microphone to my iPhone?
    It depends on the microphone model. Some microphones plug directly into the iPhone’s Lightning port, while others may require an adapter, such as a 3.5mm to Lightning adapter, if they have a traditional headphone jack connector. Some wireless options connect via Bluetooth.
apec
