6 Best Wireless Stage Microphones in 2023
Wireless microphones have revolutionized the way performers and presenters interact with their audiences on stage. Gone are the days when they had to be tethered to a specific spot on stage or worry about tripping over cords. The convenience and freedom that wireless microphones offer have made them essential tools for performers, speakers, and event organizers. In this article, we will explore the best wireless microphones for stage use and highlight their feature.
Criteria for Choosing a Wireless Microphone:
Sound quality:
The microphone should deliver clear and crisp sound without any distortion or interference.
Battery life:
A long battery life is important for uninterrupted performance, so the microphone should have a battery that can last for several hours.
Compatibility:
The microphone should be compatible with your audio system and other equipment used on stage.
Top 6 Wireless Microphone Models:
  1. Hollyland Lark Max
  2. Shure BLX288/PG58
  3. Sennheiser XSW-D Vocal Set
  4. Samson Concert 99 Handheld Wireless System
  5. Rode RodeLink Performer Kit
  6. Audio-Technica System 10 ATW-1102
Hollyland Lark Max
Link:
https://www.hollyland.com/product/lark-max?internal_source=blog&internal_medium=1868
Name and brand of the model:
If you want to experience a superior wireless microphone for the stage, the professionals recommend the Hollyland Lark Max. The more you see it, the more fascinating this stage wireless microphone may look to you. Thanks to the many useful features it offers to all users. Hollyland Lark Max’s has a rigid design with a 360-degree menu knob for quick control. The brand is tailored to user preferences and provides various microphone settings and recording modes. Moreover, it is a touchscreen wireless mic that allows you to adjust all the essential settings in a single tap.
Features and specifications:
The Hollyland Lark Max comes with an expanded EQ section that is easy to view and use, enhancing its value and improving the overall quality. While the TX and RX make a robust pair, you can also use the TX only to capture the sound of up to 8GB directly by tapping the record button. On the other hand, you can talk to the audience up to 820 feet using the pairing mode. Additionally, the Lark Max also comes with the MaxTimbre technology to ensure you sound like a professional whether you’re on stage or inside the studio.
  • It has one of the simplest yet modern menu system
  • Lark Max is equipped with a powerful noise-canceling system
  • The audio quality remains stable with no noticeable latency or signal loss
  • The battery life is pretty impressive – serving up to 7.5 hours on a single charging
  • Some users find a tickling noise in the background when they amplify the audio
Price and Availability: The Hollyland Lark Max is available on Amazon at $249 for the DUO version.
Customer Reviews and Ratings:
The Hollyland Lark Max scores 4.6 out of 5 stars on Amazon with 255+ reviews. Most users appreciate the features of Lark Max and how it supports all major devices.
Shure BLX288/PG58:
Shure BLX288/PG58
Link:
https://www.shure.com/en-MEA/products/wireless-systems/blx_wireless/blx288-pg58-wireless-dual-vocal-set?variant=BLX288E%2FPG58-H8E
Shure BLX288/PG58 is the product of Shure an American company that was founded in 1925 and has been producing high-quality microphones for a variety of purposes ever since. They are known for their reliable and durable products, making them a go-to brand for professionals in the music industry.
The Shure BLX288/PG58 is a wireless dual-channel microphone system that comes with two handheld PG58 microphones. It operates in the 524-542 MHz frequency range and has a range of up to 300 feet. The microphones use dynamic cartridges and have a cardioid polar pattern to reduce background noise and feedback.
  • Up to 14 hours of battery life.
  • Durable construction for reliable use on stage.
  • The dual-channel system allows for two microphones to be used at the same time.
  • A limited frequency range may not be suitable for all locations.
  • Some users have reported occasional dropouts in performance.
Price and Availability: The Shure BLX288/PG58 typically retails for around $549 and is widely available from music equipment retailers both online and in physical stores.
The Shure BLX288/PG58 has received high ratings and positive reviews from customers for its sound quality, reliability, and ease of use. Many users have praised the system’s ability to reduce feedback and background noise, while others have noted its durable construction and long battery life. However, some users have reported occasional dropouts in performance, which can be a concern for those using the system in critical applications such as live performances.
Sennheiser XSW-D Vocal Set:
Link:
https://en-us.sennheiser.com/xsw-d-vocal-set
The Sennheiser XSW-D Vocal Set is a wireless microphone system from the German audio equipment manufacturer Sennheiser. Sennheiser is a well-known brand in the audio industry and has been producing high-quality audio equipment since 1945.
The Sennheiser XSW-D Vocal Set is a digital wireless microphone system designed for vocal applications. It operates in the 2.4 GHz frequency band and features automatic frequency management, which ensures a stable and reliable connection. The system includes a handheld microphone transmitter with a dynamic cardioid capsule and a receiver with a range of up to 250 feet. It also has a high-resolution OLED display for easy setup and monitoring.
  • Stable and reliable wireless connection
  • Lightweight and compact design
  • Limited frequency options
  • May experience interference in crowded wireless environments
Price and Availability: The Sennheiser XSW-D Vocal Set is priced at around $400 and is widely available at music and audio equipment retailers both online and in-store.
The Sennheiser XSW-D Vocal Set has received positive reviews from customers, with many praising its ease of use, sound quality, and reliability. Some customers have noted limitations in terms of frequency options and potential interference in crowded wireless environments. Overall, it has a rating of 4.5 out of 5 stars on popular retail websites.
Samson Concert 99 Handheld Wireless:
Link:
http://www.samsontech.com/samson/products/wireless-systems/concert-99/concert99hh/
The Samson Concert 99 Handheld Wireless is a wireless microphone system manufactured by Samson Technologies, a company that has been producing professional audio equipment for over 35 years.
The Samson Concert 99 Handheld Wireless is a high-performance UHF wireless system that includes a handheld dynamic microphone with a cardioid pickup pattern. It operates in the 470-937.5 MHz frequency range and features automatic frequency selection and infrared sync for easy setup.
The system has a range of up to 300 feet and includes a true diversity receiver with dual antennas for reliable and clear signal transmission.
  • Easy setup with automatic frequency selection and infrared sync.
  • Long-range operation of up to 300 feet.
  • Battery life of up to 8 hours.
  • Some users have reported issues with interference and signal dropouts in certain environments.
  • The system can be relatively expensive compared to other wireless microphone options.
Price and Availability: The Samson Concert 99 Handheld Wireless is priced at around $299 and is available for purchase through various retailers and online stores.
The Samson Concert 99 Handheld Wireless has received positive reviews from customers for its clear sound quality, long-range operation, and ease of use. However, some users have reported issues with interference and signal dropouts in certain environments. The system has an average rating of 4.4 out of 5 stars on popular online retail websites.
Rode RodeLink Performer Kit:
Link:
https://rode.com/en/microphones/wireless/rodelink-performer-kit
The Rode RodeLink Performer Kit is a wireless microphone system designed and manufactured by Rode, an Australian company that specializes in high-quality audio equipment.
The Rode RodeLink Performer Kit is a wireless handheld microphone system that operates on the 2.4GHz frequency band. It features a range of up to 100 meters, making it ideal for stage performances and events. The system includes a TX-M2 handheld condenser microphone, which delivers clear and detailed sound, and an RX-DESK desktop receiver that connects to a mixer or other audio device.
  • Mute the switch on the microphone.
  • Easy to set up and use.
  • Long battery life of up to 10 hours.
  • May be too advanced for some users.
Price and Availability: The Rode RodeLink Performer Kit is priced at around $399 and is widely available at music and audio equipment retailers, both online and offline.
The Rode RodeLink Performer Kit has received mostly positive reviews from customers, who praise its sound quality, ease of use, and reliability. Many users also appreciate the range of up to 100 meters, which allows for greater flexibility in live performance settings. Some reviewers note that the microphone may be more expensive than other options on the market, but argue that it’s high-quality sound and advanced features justify the price.
Audio-Technica System 10 ATW-1102:
Link:
https://www.audio-technica.com/en-us/microphones/wireless-systems/line-series/system-10
Audio-Technica is a well-known brand in the world of professional audio equipment, and the System 10 ATW-1102 is one of their most popular wireless microphone systems.
The Audio-Technica System 10 ATW-1102 is a digital wireless microphone system that operates in the 2.4 GHz range. It has a range of up to 100 feet and can be used with up to eight channels simultaneously. The system includes a handheld microphone/transmitter, a receiver, and a range of accessories, including power supplies and cables.
  • Digital wireless technology minimizes interference and dropouts.
  • Can be used with up to eight channels simultaneously
  • Clear, natural sound quality.
  • No EQ or other sound-shaping controls on the microphone/transmitter.
  • Slightly more expensive than some other wireless microphone systems.
Price and Availability: The Audio-Technica System 10 ATW-1102 is available from a range of online retailers and audio equipment dealers, with prices starting at around $450.
Overall, the Audio-Technica System 10 ATW-1102 has received positive reviews from customers and industry professionals alike. Users have praised its ease of use, sound quality, and reliable wireless performance, although some have reported occasional dropouts or interference in busy RF environments.
More options: Hollyland Lark M1
Regarding the HollyLand Lark M1, it may not be the best choice for stage performances due to its limited range and coverage. While it has a high-quality sound and user-friendly interface, it may not be suitable for larger stages or performances with a lot of movement. However, it could still be a good option for smaller venues or stationary performances.
Link:
Hollyland Lark M1
When comparing and contrasting the different models based on the criteria mentioned in the introduction, here are some key points to consider:
When it comes to wireless stage microphones, there are several top models to consider, each with its strengths and weaknesses. Let’s take a closer look at the Hollyland Lark M1, Shure BLX288/PG58, Sennheiser XSW-D Vocal Set, Samson Concert 99 Handheld Wireless, Rode RodeLink Performer Kit, and Audio-Technica System 10 ATW-1102, comparing them based on key criteria.
Type of Microphone:
The Hollyland Lark M1 is a lavalier microphone, while the Shure BLX288/PG58, Sennheiser XSW-D Vocal Set, Samson Concert 99, Rode RodeLink Performer Kit, and Audio-Technica System 10 ATW-1102 are handheld microphones.
Connectivity:
All of the microphones use digital wireless transmission technology, with some models featuring multiple frequency bands for optimal performance in different environments. The Shure BLX288/PG58 and Audio-Technica System 10 ATW-1102 also offer automatic frequency scanning to quickly find the best available channel.
Battery Life:
Battery life can vary greatly between models, with the Hollyland Lark M1 and Samson Concert 99 offering up to 6 hours of use per charge, while the Sennheiser XSW-D Vocal Set and Rode RodeLink Performer Kit provide up to 5 hours, and the Shure BLX288/PG58 offering up to 14 hours.
The prices of the microphones range from the more affordable Hollyland Lark M1 and Samson Concert 99 at around $200 to mid-range models like the Sennheiser XSW-D Vocal Set and Rode RodeLink Performer Kit at around $400 to the more expensive Shure BLX288/PG58 and Audio-Technica System 10 ATW-1102, which can cost upwards of $500.
Customer Reviews:
Overall, all of these microphones receive positive customer reviews, with many users praising their sound quality, ease of use, and reliability. However, some users have reported issues with interference or dropouts with certain models, particularly in crowded wireless environments.
This article explores the top wireless microphones for stage performances. The criteria for selecting the best wireless microphones include sound quality, battery life, and compatibility.
Based on the comparison, the Hollyland Lark Max and Shure BLX288/PG58 are the recommended choices due to their long battery life, dual-channel system, and durable construction. It also receives high ratings and positive reviews from customers for its sound quality, reliability, and ease of use.
Readers are encouraged to check out the models discussed in this article or leave a comment to share their experiences with wireless microphones.
If you’re looking for discreet yet high-quality audio solutions on stage, a wireless lavalier microphone can provide exceptional clarity and convenience. Perfect for live performances, presentations, or interviews, it ensures your voice reaches every corner of the venue with crystal-clear sound.
Best Seller
Sale
$139
$159
FAQ’s
  • How many microphones can be used simultaneously?
This depends on the specific wireless system, but most systems can handle up to 12 microphones at a time.
  • What type of microphone is best for live performances?
Dynamic microphones are often the best choice for live performances because they are more durable, less sensitive to feedback, and have a more focused pickup pattern.
  • Can I use a wireless microphone for recording in a studio?
Yes, wireless microphones can be used for studio recording, but they are less commonly used in this setting because they are less reliable and can pick up interference.
Facebook
Twitter
Pinterest
How useful was this post?
Click on the stars to rate
Related Posts
