How to Record Discord Audio: Step-by-Step Methods That Actually Work
By Hollyland | September 23, 2026
Discord is the go-to communication platform for gamers, podcasters, and remote teams — but it comes with a frustrating gap: there is no built-in recording feature. Whether you are capturing a podcast interview, saving a gaming session, or archiving a reference call, you will need a third-party tool to get the job done. This guide covers four practical methods, ranked by use case, so you can find the right fit and start recording in minutes.
Does Discord Have a Built-In Recording Feature?
As of 2025, Discord does not offer any native audio recording functionality. There is no “Record” button in voice channels, no automatic call logging, and no stored audio history. If you want to capture Discord audio, a third-party app or bot is required — there is no workaround within the platform itself.
Before you set anything up, a brief but important note on consent: recording a conversation without informing the other participants may violate local privacy laws. Several U.S. states and many countries require all parties to consent before a call can be recorded. Always inform everyone in the channel before you start recording. Failing to do so can also breach Discord’s Terms of Service, regardless of which recording method you use.
Best Ways to Record Discord Audio — Quick Comparison
Use this table to identify the right method before diving into the full walkthrough.
MethodBest ForPlatformCostAudio Quality Output
OBS StudioStreamers, content creators, regular recordingWindows, Mac, LinuxFreeHigh (WAV/MP3, configurable)
Craig BotPodcasts, multi-person group callsAny (Discord server)Free (paid tier available)High (per-user separate tracks)
Xbox Game BarQuick one-off captures, beginnersWindows onlyFree (built-in)Medium (system audio mix)
QuickTime PlayerQuick captures on Mac (with workaround)macOS onlyFree (built-in)Medium (mic or screen; internal audio needs driver)
Mobile Screen RecordOn-the-go recordingAndroid, iOSFree (built-in)Low to Medium (limited internal audio on iOS)
Method 1 — Record Discord Audio with OBS Studio (Best for Quality)
OBS Studio is the most capable free recording tool available, and it gives you precise control over which audio sources are captured. For anyone recording Discord regularly — whether for streaming, podcasting, or content production — OBS is the recommended starting point.
Here is how to set it up from scratch:
  1. Download and install OBS Studio from obsproject.com. Choose the version for your operating system.
  2. Open OBS and locate the Audio Mixer panel at the bottom of the screen.
  3. In the Sources panel, click the + button and select Application Audio Capture from the list.
  4. Name the source (e.g., “Discord Audio”) and click OK.
  5. In the Application Audio Capture settings, set the Window dropdown to Discord. Click OK.
  1. Confirm the new source appears active in the Audio Mixer — you should see the level meter move when audio plays in Discord.
  2. Click Start Recording before entering your Discord voice channel.
  3. When finished, click Stop Recording. Your file saves to the path set in Settings → Output.
How to Isolate Discord Audio Without Capturing All System Sounds
The most common OBS mistake is relying on Desktop Audio, which captures everything playing through your system — music, notifications, browser tabs, and Discord all mixed together. Application Audio Capture solves this by targeting Discord specifically.
To properly isolate Discord audio:
  1. Open the OBS Audio Mixer.
  2. Find the Desktop Audio source (added by default). Click the gear icon next to it and select Remove — or mute it permanently if you prefer to keep it available for other scenes.
  1. Confirm you have added an Application Audio Capture source pointed at Discord (steps above).
  2. Test by playing audio in Discord while watching the OBS mixer. Only the Discord meter should respond.
  3. If you also want to capture your own microphone input, add a separate Audio Input Capture source pointed at your mic device in the Sources panel.
  4. Verify no other active sources are routing system sounds into the recording.
This approach gives you clean, isolated Discord audio without any background application noise bleeding into the track.
Method 2 — Record Discord Audio with Craig Bot (Best for Servers and Podcasts)
Craig Bot is purpose-built for recording Discord voice channels, and it does something no desktop screen recorder can match: it saves each participant’s audio as a separate file. For podcast hosts, interviewers, or anyone who needs to edit individual speakers independently, this is a significant advantage.
Craig is free to invite and requires no software installation on your computer.
  1. Go to craig.chat and click Invite Craig to your server. Authorize the bot with the required permissions on your Discord server.
  1. In Discord, join the voice channel you want to record.
  2. In any text channel visible to the bot, type the command /join (or :craig:, join depending on bot version). Craig will enter the voice channel and confirm it has started recording.
  1. All participants continue speaking normally — no additional steps are needed on their end.
  2. To stop recording, type /leave or :craig:, stop in the text channel. Craig will leave the voice channel and send a download link via direct message.
  3. Click the download link to access the Craig web portal. From there, download individual per-user audio tracks, a mixed file, or both. Files are available in multiple formats including FLAC, WAV, and MP3.
The per-track output is the key advantage here. If one participant has background noise or audio issues, you can fix that track independently without affecting anyone else’s audio.
Method 3 — Record Discord Audio with a Screen Recorder (Easiest for Beginners)
If you need a quick, one-time recording and do not want to install anything, both Windows and Mac include built-in screen recorders that capture system audio alongside video. Keep in mind that these tools capture all system audio by default — not just Discord — unless you configure your audio routing first. They are fine for occasional use but are not the best choice for ongoing content production.
Windows — Xbox Game Bar
  1. Press Win + G to open Xbox Game Bar. If it does not open, enable it via Settings → Gaming → Xbox Game Bar.
  1. Click the Audio widget and confirm your system audio output and microphone are both set to active.
  2. Click the Capture widget (camera icon) and select Start Recording, or press Win + Alt + R.
  1. Switch to Discord and join your voice channel.
  2. When done, press Win + Alt + R again to stop. The recording saves as an MP4 file to Videos → Captures folder.
Mac — QuickTime Player
  1. Open QuickTime Player from Applications or Spotlight.
  2. Go to File → New Screen Recording.
  3. Click the dropdown arrow next to the Record button to expand audio options.
  4. Select your microphone as the audio input.
  5. Note: QuickTime cannot capture internal audio (system sound) natively on macOS. To record Discord’s actual output alongside your mic, you need a virtual audio driver such as BlackHole or Soundflower installed and configured to route internal audio. Without this step, QuickTime will only record microphone input — meaning you will capture your voice but not the other participants.
  6. Click Record, join your Discord voice channel, and click Stop when finished.
How to Record Discord Audio on Mobile
Mobile recording is more limited than desktop, particularly on iOS. Here is what works on each platform.
Android:
  1. Swipe down to open your Quick Settings panel.
  2. Tap the Screen Recorder tile. If it is not visible, tap the edit icon and add it to your Quick Settings.
  3. Before starting, tap the settings icon within the Screen Recorder and enable Internal audio (sometimes labeled “Device audio” or “System sounds”).
  4. Tap Start to begin recording, then open Discord and join your voice channel.
  5. When finished, pull down the notification shade and tap Stop. The file saves to your Gallery or Files app.
iOS:
  1. Open Settings → Control Center and add Screen Recording if it is not already listed.
  2. Open Control Center by swiping down from the top-right corner.
  3. Long-press the Screen Record button and tap the microphone icon to enable Microphone Audio.
  4. Tap Start Recording, then open Discord and join the call.
  5. Important limitation: iOS does not allow apps to capture internal audio from other apps during a screen recording. Enabling the microphone allows the iPhone’s physical mic to pick up sound from the speaker — which produces low quality and captures ambient room noise. For better results, a third-party app such as RecordIt or a Mac-based recording approach is more reliable for iOS Discord calls.
5 Tips to Get Cleaner Discord Audio Recordings
These improvements apply regardless of which recording method you choose.
  1. Raise the voice channel bitrate. Go to your Discord server, right-click the voice channel, select Edit Channel, and increase the bitrate to 96kbps or higher. The default is often 64kbps, which noticeably limits audio quality.
  2. Enable noise suppression in Discord. Go to User Settings → Voice & Video and turn on Noise Suppression (powered by Krisp). This reduces background noise from all participants before the audio even reaches your recording tool.
  3. Record in WAV, not MP3, when editing. WAV is lossless and preserves all audio data for post-production. Switch to MP3 only after your final export when file size matters for storage or distribution.
  4. Have all participants use headphones. Speakers create echo and feedback loops that are difficult to remove in post. Headphones eliminate this problem at the source.
  5. Improve your input quality before it enters Discord. For podcast-quality recordings where your own voice matters, an external wireless microphone like the Hollyland LARK MAX 2 — featuring AI Noise Cancellation and 48kHz/32-bit Float capture — delivers significantly cleaner source audio compared to a built-in laptop mic, giving Discord’s compression less noise to work with from the start.
Troubleshooting — Why Isn’t My Discord Recording Working?
  • Silent recording in OBS: You selected Desktop Audio instead of Application Audio Capture. Remove the Desktop Audio source, add an Application Audio Capture source, and point it directly at Discord.
  • OBS is recording all system audio, not just Discord: You still have Desktop Audio active in the mixer. Either remove it from the Sources panel or mute it, and rely solely on the Application Audio Capture source for Discord.
  • Craig Bot won’t join the voice channel: The bot is missing required server permissions. Go to Server Settings → Roles or the specific voice channel’s permissions and confirm Craig has both Connect and Speak access.
  • Low or distorted audio quality after recording: First, increase the Discord server’s voice channel bitrate (right-click channel → Edit Channel). Second, open Windows Sound Settings → Recording and confirm Discord is using the Default Communication Device — a mismatch here causes OBS to capture the wrong audio stream.
Q1: Is it legal to record Discord audio?
Legality varies by location. Many jurisdictions follow a one-party consent rule, meaning you can legally record a conversation you are part of. However, several U.S. states and many countries require all parties to consent before recording. Check the laws in your jurisdiction and, to be safe, always tell participants before you start recording.
Q2: Can Discord tell if someone is recording?
No. Discord does not monitor for or flag third-party recording software. Your recording activity is invisible to the platform. That said, undetectability does not equal legality — recording without participant awareness still carries legal and Terms of Service risk.
Q3: How do I record only one person’s voice on Discord?
Craig Bot is the best solution. It produces a separate audio track for every participant in the voice channel. During editing, you can isolate, mute, or remove any individual speaker without affecting the others.
Q4: What is the best free method to record Discord audio?
For solo recording with the highest quality and control, OBS Studio is the top free choice. For group calls where you need each speaker on their own track — such as a podcast with multiple guests — Craig Bot is the better free option.
Q5: Why is my OBS Discord recording completely silent?
The most common cause is a device routing mismatch. Discord may be outputting audio through a headset or secondary device while OBS Desktop Audio monitors a different output. Fix this by adding an Application Audio Capture source targeted directly at Discord, which bypasses output device routing entirely and pulls audio straight from the application.
Start Recording and Keep Improving
For regular content creation and streaming, OBS Studio gives you the cleanest results and the most control. For podcast-style group calls where clean per-person editing matters, Craig Bot is the right call. If you just need a quick capture without installing anything, Xbox Game Bar on Windows or QuickTime on Mac will get the job done in under a minute.
Once your recording workflow is in place, the next worthwhile step is optimizing your full audio setup. Check out our guides on the best microphones for streaming and how to reduce background noise in audio recordings to take your production quality further.
