How to upgrade Solidcom C1 Pro’s master and remote headsets?
March 27, 2023
Firmware version records
Released dateFirmware VersionRelease Log Link to Download
2023.03.091.0.2.2/https://drive.google.com/file/d/1Cur-sgYsExiwXMpw7VKndlGVOjoNHML0/view?usp=share_link
Note:
  • It takes the risk to update the firmware, please avoid updating the firmware when the device is used for the important events
  • To avoid the power being cut off suddenly during the updating, please make sure the device with enough power during  updating.
  • Please feel free to contact our technical support engineer if the updating failure or error causes the malfunction of the device:  support@hollyland-tech.com
  • Upgrade is based on Windows system
Upgrade Steps
  • Download the upgrade file and unzip the file
  • Install the driver 【VCP_V1.5.0_Setup_W8_x64_64bits.exe】
  • Turn on the headset one by one, and connect it to your laptop via USB to Type-C cable
  • Open the 【I5803_Headset_Upgrade.exe】 application
  • It will recognize the headset automatically. Click 【YES】.
  • Wait for the upgrade to complete. Please do not unplug the USB cable during the upgrade.
  • After the upgrade, pair the master headset and remote headset again by long-press the 【A】 button on both headsets.
RELATED POSTS
