Is it necessary to learn the line sequence when using the RJ45 interface to connect to a switcher?
A2: No need (The prime is the wire sequence of the cable conforms to the standard network cable sequence)
Operation process:
  1. Use a standard network cable to connect Wireless Tally System’s RJ45 (Tally in) port and the switcher’s RJ45 Tally signal output port respectively.
  2.  Enter the switcher IP address in the main menu, set the same IP address, subnet mask, and gateway as the switcher, and then you can obtain the switcher’s tally signal.
Subscribe us
to get the latest news!
