5 Best Bluetooth Noise Cancelling Microphones in 2024
In a world bustling with noise, finding a peaceful corner for clear communication can be a challenge. Whether you’re diving into a crucial conference call, gaming with friends, or recording your next hit podcast, a Bluetooth noise-cancelling microphone is your ticket to pristine audio. These wireless wonders cut through the clamor to deliver your voice in all its clarity. So, how do you pick the best one? Fret not! We’ve scoured the market to present you with the top picks that will elevate your audio experience. Sit back as we unveil the best Bluetooth noise-cancelling microphones that promise to make you heard, loud and clear.
When selecting the best Bluetooth noise-cancelling microphones, it’s crucial to consider several key factors to ensure that you’re choosing a quality product that meets your needs. Here’s a breakdown of the criteria to keep in mind:
  1. Noise-Cancellation Quality: The primary feature of these devices is their ability to cancel out background noise. Look for microphones with advanced noise reduction capabilities to ensure clear communication and recording even in noisy environments.
  2. Audio Quality: High-definition sound is fundamental for both the microphone and the headset (if applicable). Ensure that the product delivers crisp, clear audio without distortion or significant quality loss.
  3. Battery Life: Since they’re wireless, Bluetooth devices rely on battery power. Long battery life is essential to avoid frequent recharging, especially if you plan on using the microphone for extended periods.
  4. Connectivity: Bluetooth stability and range determine how well the microphone will perform. Look for devices with the latest Bluetooth version for better connectivity and compatibility with a wide range of devices.
  5. Comfort and Design: If the microphone comes with a headset or earpiece, it should be comfortable to wear for long sessions. Additionally, practical design considerations like button placement and weight can affect user experience.
  6. Durability: A well-built microphone that can withstand regular use and the occasional drop is important for longevity.
  7. Additional Features: Extra features like voice commands, multipoint pairing, or companion apps may offer added convenience and enhance your experience.
By evaluating these elements, you can narrow down the options and select the best Bluetooth noise-cancelling microphone for your purpose.
FeatureBose QuietComfort 35 IISony WH-1000XM4Jabra Elite 85hSennheiser Momentum 3 WirelessPlantronics Voyager 5200
Price RangeMid-rangeHigh-endMid-rangeHigh-endMid-range
Battery LifeUp to 20 hoursUp to 30 hoursUp to 36 hoursUp to 17 hoursUp to 7 hours (talk time)
Noise CancellationActive Noise Cancellation (ANC)Industry-leading ANCSmart Active Noise CancellationActive Noise Cancellation (ANC)Noise Cancelling (for calls)
MicrophoneNoise-rejecting dual-microphoneIntegrated, multiple microphones6-mic technology3-mic arrayFour-mic noise cancelling
Weight0.52 lbs (236g)0.56 lbs (254g)0.65 lbs (296g)0.67 lbs (305g)0.04 lbs (18g)
Bluetooth Version4.15.05.05.05.0
Special FeaturesGoogle Assistant & Alexa compatible, Bose Connect AppTouch Sensor controls, Speak-to-chat technology, Quick Attention modeWater resistant, HearThrough mode, SmartSound audioAuto On/Off, Smart Control App, Tile tracker compatibilityWindSmart technology, P2i nano-coating for water resistance
Overview
The Bose QuietComfort 35 II stands out as a trailblazer in the world of noise-cancelling headphones that feature a robust Bluetooth connection for seamless wireless audio. It’s acknowledged for the unprecedented level of tranquility it brings to your ear, effortlessly drowning out the cacophony of the exterior world. The microphone quality doesn’t disappoint either; it’s engineered to pick up voice with remarkable clarity, ensuring that your communications, whether they’re calls or voice commands, are crystal clear. The additional integration with Google Assistant and Amazon Alexa adds a layer of convenience that tech aficionados will find irresistible.
The design of the QC 35 II is a testament to comfort and sophistication, with an over-ear form factor that you can wear for hours without feeling the burden on your crown or ears. The acoustic prowess of Bose is overflowing throughout this product, providing an audio experience that’s both immersive and pure.
The Bose QuietComfort 35 II boasts the following key specifications:
  • Acoustic Noise Cancelling technology with adjustable levels
  • Bluetooth and NFC pairing options
  • Supports Google Assistant and Amazon Alexa
  • Volume-optimized EQ for balanced audio performance at any volume
  • 20 hours of battery life per charge
  • Lightweight and durable materials with comfortable ear cushions
  • Bose Connect app compatibility for customized settings
  • Superlative noise cancellation that allows you to immerse in your audio bubble.
  • Intuitive controls and voice prompts make for a user-friendly experience.
  • The design and materials used ensure a comfortable all-day wear.
  • Robust build quality that feels worth the investment.
  • Crystal clear microphone quality for taking calls and using voice services.
  • Lack of aptX support which might be a letdown for some audiophiles.
  • Some users might find the sound profile a bit too clinical for their taste.
  • It’s no secret that the tech industry evolves rapidly and newer models might offer more advanced features.
Given the quality and brand reputation, Bose QuietComfort 35 II often falls in the higher price bracket, typically around $300. But remember, you are not just buying headphones; you are investing in an ecosystem of convenience, quality, and acoustic excellence. While the price might be a bit steep for some, the balance of top-notch noise cancellation, audio fidelity, and comfort easily justify the investment for serious listeners and professionals alike.
In Summary
The Bose QuietComfort 35 II remains a formidable contender in its category, even as newer models arrive on the scene. With its tried-and-true noise cancellation, thoughtful design, and reliable performance, it’s a choice that doesn’t just tick all the boxes—it draws new ones.
Sony WH-1000XM4
Brief Intro
The Sony WH-1000XM4 stands at the pinnacle of noise-cancelling headphones that also integrate a high-quality microphone for calls. As the successor to the highly acclaimed WH-1000XM3, this model continues Sony’s legacy of fusing top-notch audio performance with cutting-edge noise cancellation technology, perfect for immersive listening experiences and crystal-clear phone conversations.
Overview
I’ve had a considerable amount of hands-on time with the Sony WH-1000XM4, and it’s safe to say that these headphones are impressive. The noise-cancelling capability is, without doubt, one of the best in the market. Sony has tweaked its algorithm, and the isolation you experience from outside noise is almost eerie in its silence. When you’re on a call, the microphone does an outstanding job of picking up your voice while keeping environmental noises at bay. The touch controls are responsive and intuitive, allowing seamless switching between music and calls. Moreover, the Speak-to-Chat function is a smart addition, pausing your audio automatically when you start talking.
  • Type: Over-ear
  • Connectivity: Bluetooth 5.0 with multipoint connection
  • Noise Cancellation: Active
  • Battery Life: Up to 30 hours with ANC on
  • Charging: USB-C with quick charge feature
  • Additional Features: Touch sensors, Speak-to-Chat technology, Wear detection
Pros & Cons
  • Pros
  • Superb noise cancellation that’s customizable
  • The microphone quality maintains clarity for calls even in noisy environments
  • Comfortable design suitable for long hours of use
  • Long battery life ensures you’re not frequently reaching for a charger
  • The companion app allows detailed customization of sound profiles and controls
  • Cons
  • The aesthetic design is quite similar to its predecessor, which might underwhelm those looking for a refreshed look
  • High-end pricing might not fit everyone’s budget
  • The absence of water resistance makes them less versatile for all situations, like exercise or inclement weather
The Sony WH-1000XM4 usually retails around $349.99, although you might find them on sale occasionally. The price might be a little steep, but considering the premium features and performance, it feels justified for those who are serious about their audio gear and use headphones daily, especially in noisy environments.
In my opinion, the WH-1000XM4’s are a solid investment. If you’re after exceptional noise cancellation, sound quality, and a robust feature set, you’re going to be hard-pressed to find a more complete package. Whether you’re an audiophile, a busy professional, or just someone who cherishes their quiet time, these headphones are built to elevate your listening experience and ensure that your voice is heard loud and clear on every call.
Jabra Elite 85h
Overview:
The Jabra Elite 85h is a beautifully crafted, comfortable pair of over-ear headphones that boasts impressive noise-cancellation capabilities along with a solid Bluetooth microphone performance. One of the standout features of this product is its SmartSound technology, which automatically adapts the audio experience based on your environment. In my time using the Jabra Elite 85h, I found its audio quality to be crisp and balanced, with a pleasing soundstage that does justice to a wide variety of music genres. Furthermore, the noise cancellation is quite effective, making it a great option for those who work in noisy environments or frequently travel.
As for the built-in microphones, they perform admirably in various conditions. The voice clarity during calls is commendable, and the microphones do a decent job of isolating your voice from background noise. The headphones also feature an impressive battery life, with up to 36 hours of playtime with ANC activated, which means you’ll rarely be caught needing to recharge in the middle of your day.
  • Type: Over-ear
  • ANC: Yes, Smart Active Noise Cancellation
  • Battery Life: Up to 36 hours with ANC, 41 hours without
  • Charging: USB-C, 2.5 hours for a full charge
  • Water Resistance: Rain-resistant fabric
  • Weight: 296g
Pros & Cons:
  • Long battery life truly stands out, offering worry-free usage for extended periods.
  • SmartSound technology that adapts to your audio needs is a thoughtful touch, catering to both music lovers and call-heavy users.
  • The comfort provided by the cushioned ear cups and headband means that wearing these headphones for long sessions won’t result in discomfort.
  • The Jabra Elite 85h also has a very user-friendly companion app that allows for a good degree of customization.
  • The size and heft of the headphones might not suit everyone, especially if you’re looking for a highly portable option.
  • While the audio quality is good, some audiophiles might prefer a richer sound profile, or more granular control over EQ settings out of the box.
  • The ANC, although competent, may lag behind some of the top competitors in this market.
The Jabra Elite 85h is often priced around $250, but it’s not uncommon to find them on discount for closer to $200. This makes them relatively affordable compared to some other high-end noise-cancelling headphones.
My opinion on the Jabra Elite 85h is largely positive, mostly due to their exceptional battery life and comfortable fit, which are huge plus points in everyday use. The SmartSound environmental adaptation also sets them apart, showing Jabra’s commitment to creating a user-centric listening experience. They strike a nice balance between performance, comfort, and cost that makes them worth considering for anyone in the market for a reliable set of noise-cancelling headphones with a competent microphone for calls.
Overview:
The Sennheiser Momentum 3 Wireless headphones are a blend of high-grade luxury and premium sound quality wrapped into an aesthetic design. My experience with these headphones was nothing short of exceptional, especially when it comes to the audio fidelity which Sennheiser is known for. The noise cancellation feature is robust, making it easy to immerse yourself in music or calls without the distractions from the surrounding environment. What really stands out is how the headphones balance noise cancellation with audio performance – it’s clear that there’s been no compromise on sound quality.
Another aspect that impressed me was the intuitive controls and Smart Pause feature, which automatically stops the music when you remove the headphones. Connectivity is also top-notch, thanks to the latest Bluetooth technology ensuring a seamless and stable connection across all devices.
  • Active Noise Cancellation: Yes
  • Bluetooth Version: 5.0
  • Battery Life: Up to 17 hours
  • Charging Time: Approx. 3 hours
  • Frequency Response: 6Hz to 22kHz
  • Microphone Type: Built-in
Pros & Cons:
  • Superior sound quality that enriches any genre of music.
  • Effective noise cancellation technology that adapts to your environment.
  • Luxurious and robust design with comfortable, plush ear cups.
  • Smart controls including the automatic pause and play feature.
  • Excellent build quality that suggests durability.
  • Battery life is decent but may not match some competitors that extend beyond 20 hours.
  • The high price point may not appeal to budget-conscious consumers.
  • Some may find the design slightly bulky compared to other sleeker models.
Given the premium feel and sound quality of the Sennheiser Momentum 3 Wireless, you’re looking at a relatively high price tag, often within the range of $350 to $400. In my opinion, the price reflects the quality you receive, and if you’re someone who values audio fidelity and premium build, it’s a worthy investment.
In conclusion, the Sennheiser Momentum 3 Wireless is an exquisite choice for audiophiles who don’t want to compromise on sound, comfort, or luxury. It stands out in a crowded market of noise-canceling headphones, and while it may make your wallet a bit lighter, the investment translates into a top-tier audio experience, a luxurious feel, and dependable noise cancellation.
Overview
The Plantronics Voyager 5200 is a Bluetooth noise-canceling microphone headset that stands out in the crowd for its exceptional clarity and comfort. Specifically designed for on-the-go phone calls, it’s a favorite among professionals who need to communicate in noisy environments. My experience with the Voyager 5200 has been nothing short of impressive. Its noise-canceling capabilities are top-notch, thanks to its WindSmart technology, which effectively filters out wind and background noise, ensuring your voice is transmitted with crystal clarity.
The design of the Voyager 5200 is sleek and functional, with a single earpiece and a boom mic that can be worn comfortably for hours. The headset’s intuitive controls make it easy to answer calls, adjust the volume, and activate voice commands without missing a beat. Additionally, the headset’s Bluetooth connectivity is reliable, and it pairs seamlessly with devices, providing a stable connection that you can depend on during important calls.
  • Talk Time: Up to 7 hours plus up to 14 extra hours with the charging case
  • Noise Cancellation: Four-mic WindSmart technology
  • Wireless Range: Up to 98 feet/30 meters
  • Voice Control: Compatible with Siri, Google Now, and Cortana
  • Exceptional noise cancellation tailored for voice clarity in windy and noisy environments.
  • Comfortable for extended wear, which is a significant plus for professionals constantly on calls.
  • The extended wireless range is far superior to many of its competitors, allowing more freedom of movement.
  • The impressive battery life, when coupled with the charging case, ensures that you rarely run out of juice in the middle of your day.
  • The design is not the most discreet, and it’s very much a ‘business’ style headset; it might not appeal to those seeking a more subtle look.
  • It lacks some of the high fidelity and audio features found on more music-centric headsets, so audiophiles may not favor it for listening to their favorite tracks.
  • While comfortable, the over-the-ear design may not agree with everyone’s personal preferences, especially during warmer weather conditions or for those who wear glasses.
The Plantronics Voyager 5200 typically retails for around $120, though prices can vary depending on the retailer and whether it’s bundled with the additional charging case. Given its specific use case and the quality it provides for that, I find the price to be quite reasonable for professionals who need a dependable communication tool throughout their workday.
In my opinion, the Voyager 5200 offers substantial value for its price point. While it may not be your go-to for jamming out to high-fidelity tunes, its acoustic performance for calls is superior. It simplifies communication in ways that many headsets fail to, and that alone makes it worth considering for anyone whose work demands clear, uninterrupted phone conversations.
In the bustling world we live in, the perfect Bluetooth noise-canceling microphone can be a game-changer, providing crystal-clear audio even amidst chaos. Whether for vital work calls, immersive gaming, or enjoying a melody in solace, the right mic makes all the difference. From sleek designs to robust battery life, each option on our listicle offers a unique blend of features tailored to meet a variety of needs. Remember to consider your specific requirements – comfort, sound quality, compatibility, and budget – when making your choice. Happy quietude!
If you’re exploring Bluetooth noise-canceling microphones, you might also want to consider a professional wireless lavalier microphone. These compact, wearable microphones offer excellent audio clarity and reliable noise reduction, ideal for clear recording in various settings.
FAQs:
  1. What is noise-canceling technology in microphones?
    Noise-canceling technology in microphones is designed to filter out background sounds, allowing only your voice to be heard clearly. It works by identifying noise patterns and creating inverse waves to cancel them out.
  2. Can I use a Bluetooth noise-canceling microphone with any device?
    Most Bluetooth noise-canceling microphones are designed to be compatible with a range of devices, including smartphones, tablets, laptops, and PCs. However, ensure your device’s Bluetooth version is compatible with the microphone.
  3. How long can I use a Bluetooth noise-canceling microphone on a single charge?
    Battery life varies per model, but generally, you can expect anywhere from 5 to 30 hours of use. Always check the product specifications for battery duration and consider your daily usage to determine adequacy.
