5 Best Boom Arms for Microphone in 2024
When it comes to podcasting, streaming, or any professional recording, audio quality is paramount. An often overlooked accessory that can greatly improve your setup is a good boom arm for your microphone. Not only does a boom arm help you position the mic for optimal sound capture, but it also keeps your desk clutter-free and reduces the transfer of unwanted vibrations. Whether you’re a seasoned broadcaster or just starting, choosing the right boom arm can elevate your audio recording experience. In this listicle, we’ll explore the best boom arms to suit every need and budget, ensuring your voice comes through crystal clear.
When selecting the best boom arm for your microphone, consider these criteria to ensure you make an informed choice:
  1. Compatibility: Check whether the boom arm fits your microphone model and comes with adaptable mounting options to suit various microphones.
  2. Adjustability: Look for a boom arm with smooth and secure articulation, allowing you to easily position the microphone at the ideal angle and height without drift or sagging.
  3. Build Quality: A sturdy construction, typically metal, will ensure longevity and resist wear. Avoid flimsy materials that can compromise stability and performance over time.
  4. Ease of Installation: The boom arm should come with straightforward instructions and the necessary tools for a hassle-free setup on desks or studio spaces.
  5. Cable Management: Integrated or attachable pathways that keep cables neat and out of the way help to prevent tangles and maintain a cleaner setup.
  6. Desk Footprint: Consider the space the boom arm base takes up on your desk – a clamp or a desk mount that conserves workspace can be advantageous.
  7. Load Capacity: Ensure the boom arm can hold the weight of your microphone, especially if you’re using heavier, professional-grade equipment.
  8. Price: While not necessarily a reflection of quality, a boom arm should offer good value for its features and durability.
By keeping these criteria in mind, you’ll be able to find a boom arm that provides excellent support and convenience for your recording needs.
Product Price ($) Build Length/Reach Max Weight Other Notable Features
 1. Rode PSA1 Swivel Mount Studio Microphone Boom Arm Varies Metal 32.5 inches 4.4 lbs Internal springs; 360-degree rotation; Silent operation; Includes desk clamp
 2. Heil Sound PL-2T Overhead Broadcast Boom Varies Metal 36 inches 3.5 lbs Internal springs; Removable top and back plates; Cable management system; No tools needed to adjust
 3. Blue Compass Premium Tube-Style Broadcast Boom Arm Varies Aluminum 32 inches 2.4 lbs Internal springs; Hidden channel cable; Hand-tightened friction hinges; Sleek design
 4. InnoGear Microphone Arm Stand Varies Steel 38.6 inches 3.3 lbs Foldable arms; External springs; Adjustable tension; Includes pop filter and windscreen
 5. Gator Frameworks Deluxe Desk-Mounted Broadcast Microphone Boom Stand Varies Steel 32 inches 4.4 lbs Internal springs; 360-degree rotation with minimal noise; Includes both clamp and flange mount; Cable management wraps
For the most accurate and up-to-date information, you should check the specifications and prices on the manufacturer’s website or through a reputable retailer. Remember, the best choice depends on your specific needs, the space where you’ll be using the boom arm, and the weight of your microphone.
Overview:
The Rode PSA1 Swivel Mount Studio Microphone Boom Arm is a widely popular choice for both budding and seasoned broadcasters, podcasters, and any audio aficionados looking for a reliable and smooth-operating boom arm. From my experience, what immediately stands out is its build quality; it feels robust and designed to last. The arm movement is silky smooth, meaning you can reposition your microphone without that unsettling jarring sound that can accompany cheaper models. It’s a professional-grade arm that seems to effortlessly blend into any studio setup.
One aspect I found particularly impressive was the PSA1’s reach and flexibility. It can swing 360 degrees and has a substantial horizontal and vertical reach, providing ample room for maneuver when I’m trying to find that sweet spot during recording. It’s designed in a way that hides the springs, which not only looks better but also eliminates any external noise they might otherwise make.
Setting it up was a breeze thanks to the desk clamp and grommet options, both included. The desk clamp is a solid choice for those who don’t want to drill a hole in their desk, but for a more permanent and clean-looking setup, the grommet mount works wonders. The PSA1 accommodates a range of microphone weights, and it maintained a good hold on my heavier mics without sagging, a testament to its strong internal springs.
  • Horizontal Reach: 820mm
  • Vertical Reach: 840mm
  • Weight Capacity: Up to 2.4kg
  • Rotation: 360 degrees
  • Mounting: Desk-clamp and grommet included
  • Cables: Hidden cable management system
  • The build quality is impressive, offering durability for long-term use.
  • It has very smooth articulation, minimizing any disturbances during recording.
  • Versatile mounting options cater to varying desk setups.
  • The boom arm has excellent reach, making it adaptable to different recording environments and positions.
  • Aesthetic appeal is high, with internal spring design and cable management contributing to a clean look.
  • While it’s a very flexible arm, it may be overkill for those with a very simple or compact setup.
For the quality and features it offers, the Rode PSA1 sits in a mid-to-upper price range, which might be a touch above what beginners are willing to spend. However, for those who are serious about their audio setup and want something that’ll likely outlast their other gear, it’s a worthy investment.
Overall, the Rode PSA1 Swivel Mount Studio Microphone Boom Arm strikes a fine balance between professional-grade functionality and aesthetic appeal. Its durability, smooth operation, and reach capability make it a top contender that’s hard to overlook for anyone aiming to up their audio game. Although it has a higher price point compared to some entry-level arms, it’s an investment that speaks for itself the moment you start using it.
Overview:
The Heil Sound PL-2T is a standout boom arm that’s crafted for the serious broadcaster or podcaster who values a fusion of top-notch functionality and sleek, professional design. This boom arm, unlike some flimsy models I’ve encountered, boasts a sturdy build that immediately imparts a sense of durability and quality when you’re setting it up. It’s made especially appealing by its internal cable management system, which means you won’t be fighting against a tangle of wires on your desk.
Upon testing the PL-2T, I’ve come to appreciate the silent and smooth movement it offers. It feels like a well-oiled machine, quietly doing its job without introducing any noise that could interfere with recording. This is a boon for those crisp audio recordings where background noise is a big no-no. The tension springs are hidden inside the arm itself, so there’s no chance of an accidental clank or spring noise mid-recording.
The balance and flexibility of this boom arm allowed me to position my microphone at any angle with confidence, knowing it would stay put without any drooping – a common issue with lesser quality arms. There’s nothing worse than having to re-adjust mid-stream or recording!
  • Weight Capability: Holds up to 3.5 pounds
  • Reach: Up to 37 inches horizontally
  • Mounting: C-clamp and flush mount options included
  • Cable Management: Internal XLR cable routing
  • The internal springs present a clean look and prevent noise during movement
  • Excellent build quality that ensures longevity and stability
  • Internal cable management keeps your setup tidy and professional
  • Easy mounting with options for different desk types
  • Price might be a bit steep for those on a strict budget
  • Heavier microphones might be at the limit of its holding capability
Regarding price, the Heil Sound PL-2T sits on the higher end of the spectrum, typically found in the range of $120-$140. While this price point might raise eyebrows among budget-conscious shoppers, I believe the investment is justified for the serious user. You’re paying for a superior build and feature set that could very well eliminate the need for any future upgrades.
In my opinion, if you’re serious about your audio production and plan to use your equipment frequently, the Heil Sound PL-2T is a wise investment. It brings a combination of sleek design, ease of use, and reliable performance that will likely serve you well for years to come.
Overview:
The Blue Compass Premium Tube-Style Broadcast Boom Arm stands out for its sleek design and sturdy construction. It’s a stylish boom arm that can add a touch of professionalism to any broadcast setup. In my opinion, what sets the Blue Compass apart is its smooth operation and internal cable management system that keeps your setup tidy and free from clutter. It has a very modern aesthetic that doesn’t just scream “functionality” but also “sophistication”.
  • Full Range of Motion: The boom arm offers 360-degree rotation and a wide range of tilt options.
  • Internal Springs: Equipped with hand-tightened friction hinges for silent, effortless adjustments.
  • Cable Management: Internal cable routing that keeps your setup clean.
  • Compatibility: It comes with a standard C-clamp mount and also includes an adaptor for different mounting options.
  • Weight Capacity: Capable of holding microphones up to 2.4 pounds (1.09 kg).
  • The build quality of the Blue Compass is top-notch. The durable construction instills confidence that this boom arm will last.
  • Its operation is whisper-quiet, making it ideal for live recordings or broadcasts where every little sound matters.
  • The integrated cable management not only aesthetically pleases but also simplifies setup and reduces the risk of snagging or cable wear.
  • The look is sleek and professional, something not all boom arms can boast about.
  • While its weight capacity is adequate for most microphone setups, users with particularly heavy gear might need to look elsewhere.
  • The price point might be a bit high for those just starting out or those who don’t require a boom arm with advanced features.
The Blue Compass Premium Tube-Style Broadcast Boom Arm is usually priced around the mid-range to high end compared to other boom arms on the market. The investment reflects its quality and durability.
In my experience, the Blue Compass Premium Tube-Style Broadcast Boom Arm is not just a tool but also an upgrade to any studio’s visuals and functionality. It provides the flexibility and professional touch that content creators require, packaged in a design that’s both elegant and robust. If you’re after an arm that’s more than just functional, and you’re okay with spending a bit more for that premium feel, this boom arm could well be worth its price tag.
Overview
The InnoGear Microphone Arm Stand sits comfortably in the mix of ‘bang-for-your-buck’ products within the microphone boom arm category. This stand immediately caught my attention with its sleek black design, promising both aesthetics and functionality. Upon unboxing, the arm stand revealed its fairly robust construction, which is impressive given its price point. Setting it up was a breeze; the arm was very cooperative when it came to adjustments, and it held its position admirably once I found the sweet spot for my microphone placement.
Using it for a few recording sessions, I noticed that the InnoGear remained stable and was able to support my microphone without any ominous sagging. The springs are concealed, reducing potential noise when adjusting, which is a thoughtful design aspect for audio work. It’s not the most heavy-duty arm out there, but for podcasters, streamers, and home studio users, it’s a very viable choice that won’t break the bank.
While I didn’t break out the tools to measure every specification to the millimeter, it’s clear that the specifications of the InnoGear Microphone Arm Stand align well with what most casual to intermediate users would need. It offers a decent range of motion and is compatible with a wide array of microphones, especially those of the standard size used by the aforementioned users.
  • The price-performance ratio is excellent. You really are getting a lot without having to spend a small fortune.
  • Ease of installation and use is perfect for beginners or those not wanting to fuss too much over their gear.
  • The arm provides ample stability for standard microphone weights, which instills confidence during use.
  • It’s not built for the high-end market, so professionals with heavy-duty needs might find it lacking in durability and weight capacity.
  • While minimalistic, the design may appear too simplistic for those who value a signature look as part of their setup.
Now, talking about the price – possibly the most appealing aspect of the InnoGear Microphone Arm Stand – is wallet-friendly. While I refrain from stating the exact price due to its tendency to fluctuate, it’s safe to say that it’s positioned well within the ‘affordable’ bracket. This price, combined with the solid performance, makes it a strong contender for anyone looking to set up their microphone rig without financial strain.
Overview:
The Gator Frameworks Deluxe is a robust and versatile boom arm that brings stability and flexibility to any desk-mount scenario. Ideal for podcasters, streamers, and musicians alike, this boom arm stands out for its sturdy construction and the ability to hold heavier mics without sagging. From my experience, the ease of adjustment and secure positioning makes it a reliable choice for various recording setups.
  • Reach: Up to 32 inches horizontally
  • Weight Capacity: Holds up to 4.4 lbs (2 kg)
  • Mount: Clamp and fixed mounting options
  • Cable Management: Hidden cable channels for a neat setup
  • Build Quality: First thing you’ll notice is that this boom arm feels built to last. The heavy-duty steel construction can take the wear and tear of daily use.
  • Stability: Even with heavier mics, it remains stable. I’ve seen some boom arms start to droop after a while, but this one holds its ground, or rather, its position.
  • Versatility: It’s suitable for a myriad of mics, thanks to the multi-directional swivel mount. You’re not constrained in positioning.
  • Extended Reach: The reach is quite generous, which allows you to pull the mic close or push it out of the way effortlessly when not in use.
  • Weight: The robustness comes with added weight, which can be a double-edged sword if portability is a concern for you.
  • Cable Management: While it has channels for cables, they can be fiddly. It’s not a deal-breaker, but I’ve seen smoother solutions in other models.
The Gator Frameworks Deluxe is generally priced in the mid-range tier, making it accessible for professionals and serious hobbyists without breaking the bank. It finds that sweet spot between affordability and professional-grade quality.
In conclusion, the Gator Frameworks Deluxe Desk-Mounted Broadcast Microphone Boom Stand is a solid investment for anyone who takes their recording seriously and prefers a no-nonsense, durable setup. Despite a few minor drawbacks, which are common in most boom arms, it offers great value for its price point.
Finding the perfect boom arm for your microphone can elevate your recording setup to the next level, providing not only convenience but also enhancing sound quality by reducing unwanted noise. Whether you’re a podcaster, musician, or streamer, the right boom arm offers stability and flexibility to fit your space and needs. We hope our listicle has demystified the process and led you to the boom arm that meets your expectations for reliability, ease of use, and budget. Happy recording!
While boom arms elevate your studio audio setups, sometimes your recording situations call for more flexibility and portability. A wireless lavalier microphone can perfectly complement your gear, offering unmatched convenience and mobility without compromising sound quality.
FAQs:
  1. Q: Why do I need a boom arm for my microphone?
    A: A boom arm holds your microphone in the ideal position, reduces desk clutter, and minimizes vibrations and handling noise that can affect sound quality.
  2. Q: How do I know if a boom arm is compatible with my microphone?
    A: Check both the weight capacity of the boom arm and the threading specs to ensure they match your microphone’s weight and mounting requirements.
  3. Q: Can I use a boom arm for both streaming and recording music?
    A: Absolutely, boom arms are versatile tools suitable for any type of audio recording. Just make sure it’s sturdy enough to hold your microphone steadily in the desired position for optimal audio capture.
