General
July 27, 2023
Q1:What is the pixel of camera?
The VenusLiv camera has a pixel resolution of 12 megapixels (1200W).
Q2: Does camera support video recording and photographing?
Yes. The VenusLiv camera can store videos and photos on an SD card (up to 512G). You can record 1080p videos and capture pictures with a resolution of 12 megapixels.
Q3:What is the live streaming resolution of the VenusLiv camera?
To adjust your live streaming resolution, tap the settings button in the upper right corner of the starting screen. Once you begin streaming (UVC or RTMP), you can change the resolution in the live streaming settings menu.
  • The camera is connected to the computer. When the stream is pushed through UVC, the camera supports 1080p resolution video output, and the frame rate can be 30fps or 60fps;
  • After the camera is connected to the Internet, when the stream is pushed through the local RTMP, the resolution of the camera can be 1080p and 720p, and the frame rate can be 30fps and 60fps.
Q4:What is the zoom power of the VenusLiv?
The zoom ratio is 1-6 times; The optical zoom between 1-3 times is lossless image quality, and 3-6 times is HD digital zoom;
Q5:What is the focal length of the scene of the VenusLiv?
The VenusLiv camera lens has a focal length range from 24mm to 135mm, with 1x zoom at 24mm, 2x zoom at 50mm, 3x zoom at 70mm, and 6x zoom (digital zoom) at 135mm.
Q6:What is the sensor size of VenusLiv?
1/2 inch
Q7:What video encoding formats are supported by the VenusLiv camera?
The UVC streaming supports YUY2(YUV422) encoding format;
Video recording supports H.264 encoding format;
Q8:What is the type of aperture of the lens of the VenusLiv?
Floating aperture
RELATED POSTS
