Q1: How to pair the transmitter with the receiver?
1. Turn on the transmitter and the receiver, and press and hold the pairing button on the transmitter to enter pairing mode.
In this case, the transmitter status indicator light flashes quickly.
2. Turn on the [Pairing] button on the receiver [System Setting]
3. If the transmitter status indicator light turns steady blue, pairing is successful.
Q2: What is the battery life of the LARK MAX?
The transmitter can continue working for about 7.5 hours when it is fully charged, the receiver can work for about 9 hours when it is fully charged, and the charging case supports about two times of charging for 2 TX and 1 RX when it is fully charged.
Q3: Does the LARK MAX support Phone Speaker Playback?
Yes, it supports audio playback on the phone speaker. To turn on the Phone Speaker function, enable the Phone Speaker function on the receiver, and it will reboot. Note: Only the USB-C output on the receiver supports Phone Speaker playback, it won’t work with 3.5mm audio output.
Q4: Does the LARK MAX support internal recording?
Yes, each transmitter is supported with 8GB of built-in storage, capable of up to 14-hour audio recording.
Q5: Can the Lark Max be used with the iPhone 15 or iPhone 15 Pro Series?
It can be connected and used normally.
