12 Best Bluetooth Wireless Microphones for Android in 2023 [Lavalier, Handheld, Headset Included]
Are you an Android enthusiast looking to step up your podcast game? Have you considered purchasing a Bluetooth microphone for greater recording quality and convenience? You’ve come to the right place! We rounded up the 12 best Bluetooth microphones for Android devices – a one-stop shop built with simplicity, sound clarity, and practicality in mind.
With features like background noise cancellation capability and robust battery life, we hope you find something perfect for all your audio needs! Read on to find out which mic is perfect for you.
How to Choose the Best Bluetooth Wireless Microphones for Android
When choosing the best Bluetooth microphones for your Android device, there are a few key factors to consider. Here are some important things to keep in mind:
Compatibility
First and foremost, you’ll want to ensure that the Bluetooth microphone you choose is compatible with your Android device. Some microphones may only work with specific models or operating systems, so check the manufacturer’s specifications before purchasing.
Battery Life
Another important factor to consider is battery life. You don’t want your microphone to die in the middle of an important recording, so look for a model with long battery life or one with the option to use replaceable batteries. Some models may also come with a rechargeable battery.
Range
The range of your Bluetooth microphone is also an important consideration. If you’re using the microphone for a live performance or speech, you’ll want a model that can transmit at least 30 feet or more. For recording purposes, a shorter range may be okay.
Frequency Response
Finally, you’ll want to consider the microphone’s frequency response. This refers to the range of audio frequencies that the microphone can pick up. Look for a model with a wide frequency response range for the best audio quality.
Sound Quality
The sound quality of a Bluetooth microphone is essential when choosing a device. Consider the type of content you’ll be recording, whether it’s interviews, podcasts, or music. Look for a microphone with a frequency range that matches your needs, and one that can capture clear and crisp audio.
Additional Features
Finally, consider any additional features that the microphone may offer. Some microphones have built-in noise reduction or pop filters to minimize background noise and improve audio quality. Others may have a headphone jack or volume controls that provide added convenience.
By considering these factors, you can choose the best Bluetooth microphone for your Android device that meets your needs and delivers high-quality audio.
Our Top Picks
Sony ECM-AW4 Bluetooth Microphone
Keep your distance from yourself and your audio recording! With the Sony ECM-AW4 Bluetooth Microphone, you can record crisp sound up to 164 feet away. This lightweight device is easy to carry while out filming and easy to attach to any camcorder with a mic input minijack.
It is lightweight, easy to use, and compatible with various devices. The package includes two microphones with independent channels, allowing two people to record simultaneously. Its standout feature is recording audio directly onto a paired camera or device using Bluetooth.
Get the best audio recordings without fuss using the Sony ECM-AW4 Bluetooth Microphone – it’s like having an extra set of ears!
Specifications
Brand: Sony
Price: $229.99
Battery life: Up to 3 hours
Dimensions (Approx.): 31/32 x 3 x 1 3/8 inches
Polar pattern: Omnidirectional Microphone
Frequency range: 20 Hz – 20 kHz
Pros
  • Wireless connectivity
  • Long battery life
  • Compact design
  • Good sound quality
  • Easy to use
Cons
  • Lack of wind protection
Alead LiveMIC2 Bluetooth Microphone
The Alead LiveMIC2 Bluetooth Microphone is a must-have for those who need to connect remotely and share the sound of their voice! Whether it’s for distance education, speech, webinars, conference calls, panel sessions, or even online streaming and podcasting – this mic will have you covered.
With its long range of up to 20M/66 feet, low latency, and lip sync feature, you can rest assured that your voice will be heard loud and clear from any remote location. Plus, it’s clear sound feature makes this microphone great for recording voices in high-quality audio for podcasts or videos.
Specifications
Brand: Alead
Price: $99.99
Battery life: 6 hours
Dimensions (Approx.): 2.1×1.1×0.5 inches
Polar pattern: Omnidirectional & unidirectional options
Frequency range: 20Hz – 50KHz
Pros
  • Compatible with most devices
  • Good battery life
  • Compact design
  • Decent sound quality
Cons
  • Limited range
RODE Wireless GO II Wireless Microphone System
Ready for the ultimate sound experience? Look no further than the RODE Wireless GO II Wireless Microphone System! It’s a dual-channel microphone system that lets you record two sound sources simultaneously, with Series IV 2.4GHz digital transmission and 128-bit encryption guaranteeing crystal-clear audio up to 200m away.
Whether you need a 3.5mm TRS analog output, USB-C, or iOS digital output, the Wireless GO II has covered you – it’s universally compatible with cameras, mobile devices, and computers. Plus, its onboard memory allows for over 40 hours of recording – so make sure your voice is heard loud and clear!
With the ability to record each channel separately or combine them for ultimate flexibility in post-production, you won’t miss a beat with the RODE Wireless GO II Wireless Microphone System.
Specifications
Brand: RODE
Price: $299.00
Battery life: 7 hours
Dimensions (Approx.): TX Length: 44 Width: 45.3 Height: 18.3, RX Length: 44 Width: 45.5 Height: 18.3
Frequency range: 50Hz-20kHz
Pros
  • Dual channel receivers
  • Good battery life
  • Compact design
  • Good range
Cons
  • Expensive
Instamic Pro Plus Microphone
Looking for a discreet yet powerful microphone? Look no further than the Instamic Pro Plus Microphone. Boasting three mounting options – magnetic, adhesive tape, and nano suction tape – you can easily attach this tiny device to any surface.
It has four recording modes and allows users to adjust the gain and EQ using the mobile app. Its standout feature is the ability to record 24-bit audio, making it a perfect choice for professional audio recordings.
There is no need to worry about battery life, as it can last up to 3.5 hours on a single charge! Plus, with its one-year warranty, you won’t have to stress over any nasty surprises down the line. So why settle for an average mic when you could have the Instamic Pro Plus? Get recording today!
Specifications
Brand: Instamic Pro
Price: $199.00
Battery life: 3.5 hrs
Dimensions (Approx.): 1.5 x 1 x 0.5 inches
Frequency range: 48/96kHz
Pros
  • Water-resistant
  • Compact design
  • Easy to use
Cons
  • Short battery life
SmartMike+ Wireless Bluetooth Microphone
The SmartMike+ Wireless Bluetooth Microphone is the perfect tool for any content creator who wants to take their audio game to the next level! This mic has incredible sound quality and a battery life of 5 hours, so you can keep recording without worrying about running out of juice.
It uses Bluetooth 5.0 technology and has a range of up to 15 meters. It comes with two microphones and has noise-canceling technology that produces clear audio even in loud environments.
And at just $139, it’s an affordable option — meaning no more excuses for subpar recording! So why wait? Get your SmartMike+ today and start creating great audio content!
Specifications
Brand: SmartMike+
Price: $139.00
Battery life: 5 hours
Dimensions (Approx.): 2.28 x 0.39 x 0.59 inches
Frequency range: 48kHz
Pros
  • Lightweight design
  • Easy to use
  • Affordable
Cons
  • May experience connection issues
The Sennheiser Memory Mic
Say goodbye to having your cameraman follow you around like a lost puppy! Memory Mic has finally arrived to give you the freedom of movement when recording videos.
It can record up to four hours of audio and has a standby time of over a week. Its standout feature is its mobile app-based interface, which allows users to adjust gain and EQ settings.
Its reliable 4-hour battery life allows you to clip the mic onto your family/friends/objects and move away without worrying about getting out of range. Get ready for more action-packed video recordings with Memory Mic – the wireless mic revolutionizing how videos are made!
Specifications
Brand: Sennheiser
Price: $89.95
Battery life: 4 hours
Dimensions (Approx.): 51 x 37 x 16 mm
Frequency range: 100 Hz to 20 kHz
Pros
  • Reliable connectivity
  • Compact design
  • Easy to use
Cons
  • Battery life could be better.
Saramonic Blink500 B3 Microphone
The Saramonic Blink500 B3 Microphone is the perfect choice for anyone who needs broadcast-quality sound on the go. This lightweight, ultra-compact device offers up to 6 hours of battery life and delivers exceptional audio quality for DSLR, mirrorless, video, mobile devices, and more!
It includes a transmitter and a receiver that connects to the camera’s microphone input. It has a range of up to 164 feet and offers crystal-clear sound quality. Its standout feature is the ability to monitor audio levels via its companion mobile app, making it easier to adjust the gain settings.
With its easy-to-use design and an affordable price tag of just $139, it’s no wonder why this microphone has become a must-have tool for content creators everywhere. Get your Saramonic Blink500 B3 Microphone today and create high-quality audio recordings!
Specifications
Brand: Saramonic
Price: $139
Dimensions (Approx.): 4.33 x 4.33 x 4.33 inches
Frequency range: 2.4GHZ
Pros
  • Compact size
  • Wireless
  • Omnidirectional mic
  • Includes clip-on transmitter
  • Easy to set up
Cons
  • Limited range
The Hey Mic! Bluetooth Microphone
The Hey Mic! Bluetooth Microphone is an awesome little device, perfect for any aspiring musician or singer looking to take their performance to the next level. The tiny size belies its power – you can use this mic up to 20m/65ft away from the source, and it has a battery capacity of 100 mA, letting you rock out for up to 6 hours!
Its standout feature is its high-quality sound, thanks to its proprietary noise-canceling technology. And with a Signal-to-Noise Ratio of >95dB, your voice will become crystal clear as you fill the room with sound. But that’s not all – it’s also built tough enough to withstand temperatures from -10 to +50 Degrees Celsius.
Specifications
Brand: Hey Mic
Price: $112
Dimensions (Approx.): 4.5 x 1.5 x 2.01 cm
Frequency range: 2.4GHz-2.48GHz
Pros
  • Connects easily to the device
  • It can be used discreetly
  • Lightweight
  • Durable clip
Cons
  • Android compatibility issues
The Lewinner Bluetooth SmartMic
Are you a Vlogger, Blogger, Youtuber, Podcaster, Interviewer, or other video recording lover? Then say goodbye to the days of dealing with messy cables and poor noise cancellation. The Lewinner Bluetooth SmartMic is here to help make your recordings sound perfect!
It uses Bluetooth 5.0 technology and has a range of up to 10 meters. Its standout feature is connecting and recording with multiple devices simultaneously.
The SmartMic utilizes MFI certified wireless Lavalier microphone system with built-in 6mm ECM high sensitivity and Bluetooth Qualcomm Chipset for unparalleled performance. Plus, thanks to its Swiss Intelligent Battery life technology, you’ll get up to 6 hours of use in one go – no more having to plug it back in constantly!
Specifications
Brand: Lewinner
Price: $109.90
Dimensions (Approx.): 4.69 x 2.68 x 1.69 inches
Frequency range: 20-2400 MHz
Pros
  • Lightweight
  • Noise-reducing technology
  • Wireless mic
  • Long battery life
Cons
  • The app interface could be improved.
Bietrun UHF Wireless Headset Microphone
Bietrun UHF Dynamic Microphones
Are you looking for a wireless microphone that’s as easy to use as it is powerful? Look no further than the Bietrun UHF Wireless Headset Microphone! With two simple switches, you can go from “off” to “ready for use” in seconds. No need to waste time on complicated setup procedures – flip the switch and get ready for sound quality that will take your performance to a whole new level.
Their standout feature is their affordable price point and ability to connect to multiple devices via Bluetooth. And thanks to its 2-in-1 design, you can easily switch between headset and handheld modes depending on your needs. Plus, with up to 6 hours of battery life, you won’t have to worry about your mic running out of juice during long sets or broadcasts.
Specifications
Brand: Bietrun
Price: $16
Dimensions (Approx.): 32.68 x 1.18 x 1.18 inches
Polar pattern: Unidirectional
Frequency range: 50Hz-16KHz
Pros
  • Long battery life
  • Good range
  • Great for live performances
  • Easy to use
  • Includes two handhelds
Cons
  • It takes a while to charge fully.
The Razer Seiren BT Microphone
Are you looking for a microphone that can keep up with your on-the-go lifestyle? Introducing the Razer Seiren BT Microphone – your go-to companion for high-quality audio wherever life takes you. This ultra-compact clip-on Bluetooth mic has been designed to provide professional-grade vocal clarity, whether you’re streaming or vlogging indoors or outdoors. With a battery life of 6 hours, know that your content will always stay crystal clear no matter how far the adventure leads!
Specifications
Brand: Razer Seiren
Price: $99.99
Dimensions (Approx.): 4.84 x 3.98 x 1.14 inches
Frequency range: NA
Pros
  • Stylish appearance
  • Clear sound quality
  • It can be used with multiple devices
  • Includes headphone jack for live monitoring
Cons
  • Bulky design
The ModMic Wireless Microphone
Look no further than the ModMic Wireless Microphone for all you audio pros out there. This fully wireless mic has two modes and offers best-in-class audio quality with minimal latency.
It features a unidirectional cardioid microphone with a frequency response of 20 Hz–20 kHz, making it ideal for vocal recordings. Its standout feature is its versatility and compatibility with different headphones.
It works on Android, Windows, Mac, Linux, or PS4 & 5, so you can jump right into the action. And when your gaming session runs long, don’t worry – it’s got more than 12 hours of battery life!
Specifications
Brand: Antlion Audio
Price: $139.95
Battery life: 12+ hours
Dimensions (Approx.): 7.3 x 0.6 x 1.4 inches
Polar pattern: Omnidirectional and unidirectional options
Frequency range: 20hz to 20khz
Pros
  • Versatile, it can be used with any headphones
  • Easy to set up
  • Lightweight
Cons
Comparison Chart
Here is a brief comparison:
MicrophoneFeaturesPerformanceQualityValue
Sony ECM-AW4Water-resistant, 2-way communicationGood audio, slight lagSolid, durablePricey
Alead LiveMIC2Clip-on, built-in speakerGood audio, slight noiseDurable, reliableReasonable
RODE Wireless GO IIDual-channel, USB-CExcellent audio, low latencyHigh-quality, sturdyPremium
Instamic Pro PlusCompact, waterproof, adjustable gainImpressive audio, minimal noiseHigh-quality, durableExpensive
SmartMike+Noise reduction, live streamAdvanced noise reductionDurable, reliableMid-range
Sennheiser Memory MicStores 4 hours, lightweightExcellent audio, minimal noiseSleek, lightweightPremium
Saramonic Blink500 B3Dual-channel, lightweightSolid audio, occasional interferenceLightweight, easy to useReasonable
Hey Mic!Multichannel Bluetooth, discreetGood audio, slight noiseLightweight, easy to useMid-range
Lewinner SmartMicCompact, 4 recording modesHigh-quality audioSleek, lightweightMid-range
Bietrun UHFProfessional-grade, multi-deviceExcellent audio, minimal noiseRobust, built to lastMid-range
Razer Seiren BTProfessional-grade, 4 patternsImpressive audio, low latencySleek, durablePremium
ModMic WirelessDual-capsule, noise-cancelingExcellent audio, minimal noiseHigh-quality, built to lastPremium
Regarding sound quality and convenience, Bluetooth microphones are unbeatable and critical for any professional recording studio. If you need a new setup, whether upgrading headphones or replacing an old mic, there’s something on this list for everyone. What could be better than taking the stress out of the creative process by conquering the technical part?
Taking your first steps into the world of Bluetooth mics can be intimidating and expensive, but after reading through these 12 best Bluetooth mics for Android, you can rest assured that there’s a perfect fit out there for you—without breaking the bank. So go ahead and grab yourself one today – what are you waiting for?
What is a Bluetooth microphone for Android?
A Bluetooth microphone is a wireless microphone that connects to your Android device via Bluetooth. It can be used for various purposes, such as recording audio for podcasts, videos, interviews, or live performances.
How do I connect a Bluetooth microphone to my Android device?
First, ensure your Bluetooth microphone is turned on and in pairing mode. Then, navigate to your Android device’s Bluetooth settings and search for available devices. Select your Bluetooth microphone from the list and click “Connect.”
Are all Bluetooth microphones compatible with Android devices?
Some Bluetooth microphones are only compatible with certain devices or operating systems. It is important to check the compatibility of the microphone with your Android device before making a purchase.
What is the battery life of most Bluetooth microphones for Android?
The battery life of Bluetooth microphones for Android varies depending on the model and usage, but on average, it can last between 3-15 hours.
Can a Bluetooth microphone provide high-quality audio recording?
Yes, Bluetooth microphones can provide high-quality audio recording, but it depends on the microphone’s specs and capabilities. Some Bluetooth microphones come with advanced features such as noise cancellation, gain control, and high-quality codecs for improved audio recording.
Are there any recommended apps to use with a Bluetooth microphone on Android?
Some popular apps to use with Bluetooth microphones on Android include Voice Recorder, Parrot Voice Recorder, Open Camera, Cinema FV-5, and Filmic Pro.
Can I use a Bluetooth microphone for live performances?
Yes, Bluetooth microphones can be used for live performances, but it depends on the microphone’s capabilities and the environment. Choosing a microphone with a good range and good noise reduction feature is recommended.
Can I use a Bluetooth microphone for gaming on Android?
Yes, Bluetooth microphones can be used for gaming on Android. Some popular games that support Bluetooth microphones include PUBG, Free Fire, and Call of Duty.
What is the range of a Bluetooth microphone on Android?
The range of a Bluetooth microphone on Android varies depending on the model and environment, but it can reach up to 30 feet in line of sight.
How do I charge a Bluetooth microphone for Android?
Most Bluetooth microphones for Android come with a USB cable for charging. Connect the USB cable to a power source and the microphone to charge. The charging time varies depending on the model and battery capacity.
RELATED POSTS
