6 Best Budget Bluetooth Microphones [Truly Supports] in 2025 for iPhone/Android/Camera/PC
By Hollyland | March 25, 2024
Want better sound without emptying your wallet? Whether you’re recording on your phone, making videos for YouTube, or capturing interviews on the go, a good Bluetooth microphone can make a huge difference.
In 2025, budget-friendly mics have come a long way. Many now offer features you’d expect in much more expensive gear.
We tested a bunch of these mics in real-world settings, from busy streets to quiet home studios, to find the best ones that sound great and cost less.
Why Trust Us?
At Hollyland, we’re serious about wireless audio. Our team of engineers, creators, and tech testers work hands-on with every product we recommend. You’re not just getting marketing claims, you’re getting advice backed by testing, experience, and real-world use.
Top Picks at a Glance
ModelFrequency ResponseBit Depth /Sample RateBattery LifeBest ForPrice
DJI Mic 250Hz – 20kHz24bit/48kHz6 hoursPro Content$349
DJI Mic Mini20Hz – 20kHz24bit/48kHz5.5 hoursLightweight Use$169
Shure MoveMic 88+40Hz – 18kHz24bit/48kHz8 hoursMobile Filmmaking$329
Saramonic BTWNot SpecifiedNot Specified10 hoursDaily Recording$84.49
Razer Seiren BTNot Specified(bit depth unspecified)/48kHz6 hoursStreamers/Online$45
Hollyland LARK MAX 220Hz – 20kHz24bit/48kHz11 hoursAll-Round UseNot Specified
Note: Prices are based on Amazon listings (US) as of June 2025 and are subject to change.
Best Budget Bluetooth Microphones in 2025: Detailed Reviews
Let’s take a closer look at each Bluetooth microphone, which is provided below. These mics were tested in real-world situations, and their performance was evaluated based on clarity, ease of use, battery life, and overall value.
1. DJI Mic 2 — Pro Bluetooth Choice
The DJI Mic 2 delivers professional-grade audio without complicated setup. Its intelligent noise cancellation ensures your voice stays clear, even in outdoor or crowded environments. One standout feature is the 32-bit float internal recording with backup safety tracks. This allows you to recover clipped audio later, giving peace of mind during critical shoots.
Specifications (Wireless Microphone)
  • Polar pattern: Omnidirectional
  • Frequency response: 50 Hz – 20 kHz (low cut off) and 100 Hz – 20 kHz (low cut on)
  • Max SPL: 120 dB
  • Connector: 3.5 mm, USB-C
  • Battery life: 6 hours
  • Transmission range: 250 m
  • Backup recording
  • Strong wireless range
  • Compact charging case
  • Slight bulk
Suitable for: Vloggers, videographers, professionals needing reliable wireless audio
Real review from Amazon: “Wow, this is so much better than my Rode Go. The best feature is that you can record directly into the transmitter, and it records. Then you can plug that into your computer and take the files off for editing. The quality is much better than I expected, too! My first recordings were outside and inside, with wind or with potential echo, and the recordings came out clear without issue. I am amazed and very glad I got this.” — @Rachel
Price: $99-$349
2. DJI Mic Mini — Clear Audio in a Small Pack
The DJI Mic Mini comes with Two-Level Active Noise Cancellation. This allows you to select “Basic” or “Strong” noise-canceling modes, depending on the noise intensity in your surroundings. Contrarily, you can opt for the Automatic Limiting feature to control loud noises and avoid audio clipping.
  • Frequency response: 20 Hz – 20 kHz (low cut off), 100 Hz – 20 kHz (low cut on)
  • Max SPL: 120 dB
  • Connector: USB-C
  • Battery life: 5.5 hours
  • Ultra-light
  • Dual-mic recording
  • Long battery life
  • No backup internal recording
  • Smaller controls
Suitable for: Travel vloggers, content creators on the move, single or dual interviews
Real review from Amazon: “I recently invested in the DJI Mic Mini (2 TX + 1 RX + Charging Case), and I can confidently say it’s one of the best purchases I’ve made for my content creation setup. As someone who regularly records videos for YouTube and podcasts, having a reliable wireless microphone system is essential. The DJI Mic Mini has exceeded my expectations in every way, from build quality and ease of use to sound clarity and battery life.” — @Benjamin
Price: $89- $169
3. Shure MoveMic 88+ — Best for Mobile Filmmaking
The Shure MoveMic 88+ offers 5 customizable presets that enhance your audio recording experience. Plus, this mic comes with adjustable gain, a high-pass filter, and EQ. As a result of these, you can fine-tune the captured audio to avoid spending more time on post-production.
  • Polar pattern: Stereo, mono bi-directional, mono cardioid, and raw mid-side
  • Frequency response: 40 Hz – 18 kHz
  • Max SPL: 120 dB
  • Connector: Mini TRS 3.5 mm
  • Battery life: ~8 hours
  • Transmission range: 30 m
  • Auto-level calibration
  • Built-in windscreen
  • Trusted Shure reliability
  • Shorter wireless range
  • Requires adapters for USB-C
Suitable for: Indie filmmakers, run-and-gun videographers, documentary creators
Real review from Amazon: “I had some doubts about how a little microphone like this could handle some loud jam sessions, but it surprised everyone. It’s very easy to use, including the Android app, and it sounds great. It handles the drummer randomly deciding to go hard on his rimshots like a champ while also picking up on some of the more subtle noises in the guitar FX. For this price, this thing is a champion. Anything else of this quality or higher is going to cost you a whole lot more.” — @Thundard
Price: $329
4. Saramonic BTW — Best Ultra-Budget Option
The Saramonic BTW delivers surprisingly good audio for under $100. What impresses us is its Active Noise Reduction filters. You can expect a pretty decent audio while you’re recording.
  • Frequency response: Not specified
  • Connector: 3.5 mm
  • Battery life: 10 hours
  • Transmission range: 80 m
  • Built-in headphone monitoring
  • Plug-and-play
  • Compact transmitter clips
  • Narrower frequency range
  • Less Premium Build
Suitable for: Students, remote workers, beginner vloggers, live-streamers on a budget
Real review from Amazon: “I found a $200 Saramonic kit at Best Buy… it ended up sounding better than both the Sennheiser G3 and Rode Filmmaker systems I usually use.” – @Brian
Price: $85.49
5. Razer Seiren BT — Best for Streamers on a Budget
The Razer Seiren BT offers a reliable clip-on Bluetooth mic with an audio customization option. You can use this feature to adjust the sidetone volume. Also, if you’re into mobile gaming or streaming, you can take advantage of its Low Latency Mode to ensure a seamless audio experience throughout your session.
  • Connector: Bluetooth, USB-C
  • Transmission range: 10 m
  • Easy to use
  • Noise-reduction wind filter
  • Real-time monitoring
  • Limited low-end response
  • Slight latency
Suitable for: Casual streamers, teachers, social media content creators
Real review from Amazon: “Loves this little mic. Recorded my father in a full-day session of lectures and still had 20% of battery left. Crystal clear sound from the person wearing it and doesn’t pick up surrounding noise.”  — @Jerry Vue
Price: $45
6. Hollyland LARK MAX 2 — Best All-Round Performer (Bonus Pick)
The Hollyland LARK MAX 2 delivers top-tier audio performance, which is why it is on this list. Although not a Bluetooth mic, it offers state-of-the-art features, including 32-bit float internal recording so you can always have a high-quality backup. To ensure your recordings are free from clutter, it provides AI noise cancellation. Also, it offers 1,115ft wireless range, so you never have to worry about the distance.
  • Frequency response: 20Hz – 20kHz
  • Max SPL: 128 dB
  • Connector: USB-C, 3.5mm TRS
  • Battery life: 11 hours (TX)
  • Transmission range: 340m
  • Records 4 people at once
  • Wireless monitoring
  • 32-bit float internal backup
  • Slightly bulky
Suitable for: YouTubers, independent filmmakers, serious content creators
Real review from Amazon: “Typical Hollyland design! Everything about this product is fabulous, the mechanical design, the operation and of course the audio is exactly as they say.!!! Thank you, the equipment is a pleasure to use.” Craig Tantalo
Price: Not specified
You don’t have to spend a fortune to get quality sound anymore. Bluetooth microphones in 2025 are smarter, smaller, and more powerful than ever. Whether you’re just getting started or need a reliable backup mic, there’s something on this list for you.
If you’re after ultimate portability, go with the DJI Mic Mini. Need a mic for casual streams or Zoom calls? Razer Seiren BT or Saramonic BTW will handle the job. And if you’re aiming for pro-level polish, the Lark Max 2 will give you top-tier results without the premium price tag.
Can I use a Bluetooth mic with my iPhone or Android?
Yes, most of these mics connect easily via Bluetooth and are compatible with both iOS and Android. Some also include Lightning or USB-C adapters.
Is there any delay in Bluetooth microphones?
Minimal latency is common, but most mics listed here are designed to reduce lag for real-time monitoring or live streaming.
Do Bluetooth mics need apps to work?
Some come with companion apps for adjusting levels or adding effects, but they typically function without them as well.
What’s the difference between Bluetooth and traditional wireless mics?
Bluetooth microphones connect directly to devices like phones and tablets, while traditional wireless systems typically require a separate receiver and additional setup.
