Wired microphones can be a real hassle, whether you’re singing your favorite songs, hosting a karaoke party, or recording audio. With a limited range of motion, you can easily become tangled up in wires, leading to awkward moments and taking away from your best vocal performance. That’s why investing in a wireless Bluetooth handheld microphone is a major plus. It allows you to sing and record freely without any worries or accidents. With no cords to worry about, you can move around, dance, and express yourself with ease. So, if you’re looking for a way to ease your mind and take your performances to the next level, a wireless microphone is the way to go.
To help you choose the best microphone for all your creative needs, I compiled a list of the 5 best wireless bluetooth handheld microphones of 2023.
The Criteria
I will be rating each compact microphone based on a few factors. These are factors you want to carefully review and consider so you can find a compact microphone that is best for you.
Those areas I will be looking at are:
1. Battery life – How long the battery will last. This is very important for those of you who travel with your technology. Having a longer battery life helps against unforeseen circumstances.
2. Range – How far away can you be from the microphone and have it work effectively. This is very important when it comes to content creation revolving around a video camera. The farther away you can be from your setup equals the more versatility you have when it comes to recording audio.
3. Frequency Response – The range of frequencies that a microphone can pick up and reduce.
4. Price – The total cost for your microphone.
BONAOK Q37 Wireless Bluetooth Karaoke
The BONAOK Q37 microphone is a wireless bluetooth handheld microphone with a lot of utility. This microphone is great for singing, performing karaoke, recording, and speaking in front of a large audience. This is due to its unidirectional pickup pattern which means it will capture sounds from the front but reject noise coming from other directions. This microphone has the option of wired or bluetooth connectivity to fit your needs at any given time.
| Battery Life | 3-4 Hours | ⭐⭐⭐ |
| Frequency Response | 80 Hz to 12 kHz | ⭐⭐⭐ |
| Range | 10 M / 32 Feet | ⭐⭐⭐⭐ |
| Price | $31.99 | ⭐⭐⭐⭐⭐ |
| Pros | Cons |
| Built in battery ✅ | Micro USB ❌ |
| Sound effects✅ | Built in Speaker Quality not the best❌ |
| Price✅ |
Sennheiser Memory Mic
| Battery Life | 4 Hours | ⭐⭐⭐ |
| Frequency Response | 100Hz-20kHz | ⭐⭐⭐⭐ |
| Range | Unlimited | ⭐⭐⭐⭐⭐ |
| Price | $199.95 | ⭐⭐⭐ |
| Pros | Cons |
| Extremely portable ✅ | Battery life❌ |
| Omnidirectional pickup ✅ | Built in Speaker Quality not the best❌ |
| iOS and anAndroid application ✅ |
Bietrun WXM19
The Bietrun Wxm19 wireless microphone is a bluetooth microphone that operates on the UHF frequency band. This band allows for a distance of 240 feet in open places. This microphone features 15 frequency channels so you can avoid interference when multiple microphones are used at the same time in the same place. The superior sound and low delay makes this one the best wireless bluetooth microphones you can currently buy. What’s even better is this microphone has no additional setup or software, you can simply pair it and use it.
| Battery Life | 7+ hours | ⭐⭐⭐⭐⭐ |
| Frequency Response | 50hz – 16khz | ⭐⭐⭐⭐ |
| Range | 240 ft (UHF) / 32 ft (Bluetooth) | ⭐⭐⭐⭐⭐ |
| Price | $79.99 | ⭐⭐⭐⭐⭐ |
| Pros | Cons |
| Rechargeable Battery ✅ | Limited capability with input devices ❌ |
| Superior sound ✅ | |
| Ease of use ✅ |
The Lewinner Wireless Bluetooth SmartMic
The Lewinner Wireless Bluetooth SmartMic is a microphone that is designed for Yotubers, Vloggers, and Podcasters. Made with sturdy metal this microphone is cool to the touch and is built to withstand daily use. The Lewinner Wireless Bluetooth SmartMic has a size of 2.3” x 0.4”x 0.6” and a weight of 15 grams.This microphone is known for its powerful noise cancellation that is achieved through both hardware and software. This Lewinner Wireless Bluetooth SmartMic is great for indoor environments.
| Battery Life | 6 Hours | ⭐⭐⭐⭐ |
| Range | 50 feet | ⭐⭐⭐⭐⭐ |
| Frequency Response | 20-2400 Mhz | ⭐⭐⭐⭐ |
| Price | $109.00 | ⭐⭐⭐ |
| Pros | Cons |
| High CD sound quality ✅ | Must be used with the SmartMic+ app ❌ |
| Wide range ✅ | Does not support Facebook, Youtube, Instagram live streaming ❌ |
| Easy to operate ✅ |
Hollyland Lark C1
If you can compromise on the handheld style, the Hollyland Lark C1 will ensure its uncompromising benefits over the sound quality. Not an ordinary Bluetooth microphone system, the Lark C1 proves its mettle by delivering Hi-Fi professional-grade sound for those seeking next-level voice quality. This wireless microphone kit is specifically designed for iPhone and Android users. That is one of the reasons behind its high demand among YouTubers, streamers, and content creators.
The Hollyland Lark C1 is a MiFi-certified wireless transmitter and receiver kit with loads of features. This not only ensures compatibility with iOS devices, like iPhone and iPad, but also confirms safe and secure connection. Another excellent trait of Lark C1 is simultaneous charging and recording. At the same time, you can playback the recorded audio without removing the receiver from your device, saving you time and protecting your device’s hardware from damage from frequent plugging and unplugging.
The Hollyland Lark C1 also offers a battery life of 8 hours for both the transmitters and receiver. This runtime extends when you use the units through a fully charged case for up to 22 hours. Also, the receiver and transmitters remain active during the charging process, making you unstoppable in recording your favorite jam.
The Hollyland Lark C1 delivers audio with high clarity because of noise cancellation. It lets you record sounds without capturing unwanted background or ambient noises. It captures sound at 16 bits/48kHz sample rate, equivalent to a professional mic’s quality. Moreover, this power-pack wireless microphone kit can also be used as a discreet microphone because of its overall size.
| Battery Life | 8 hours | ⭐⭐⭐⭐⭐ |
| Frequency Response | 20hz – 20khz | ⭐⭐⭐⭐ |
| Range | 820ft | ⭐⭐⭐⭐⭐ |
| Price | $119.00 | ⭐⭐⭐⭐⭐ |
| Pros | Cons |
| Easy to carry and travel ✅ | You cannot use it with a PC or Laptop ❌ |
| User-friendly menu ✅ | |
| Attractive appearance ✅ | |
| Excellent wireless range with high stability ✅ | |
| Robust charging case made of high-quality material ✅ |
1. What is a wireless handheld Bluetooth microphone?
A wireless handheld Bluetooth microphone is a microphone that can be used without the need for any wires or cables. It connects to a device such as a smartphone or tablet using Bluetooth technology.
2. What are the benefits of using a wireless handheld Bluetooth microphone?
The main benefit of using a wireless handheld Bluetooth microphone is that it allows for greater mobility and freedom of movement while using the microphone. You can move around freely without being restricted by any wires or cables. Additionally, many wireless handheld Bluetooth microphones offer high-quality sound and can be used for a variety of applications such as podcasting, live performances, and video recording.
3. How do I connect a wireless handheld Bluetooth microphone to my device?
To connect a wireless handheld Bluetooth microphone to your device, you’ll need to turn on the microphone and put it in pairing mode. Then, you’ll need to go to the Bluetooth settings on your device and select the microphone from the list of available devices. Once the connection is established, you can start using the microphone.
4. What range can I expect from a wireless handheld Bluetooth microphone?
The range of a wireless handheld Bluetooth microphone can vary depending on the specific microphone model and other factors such as the environment in which it’s being used. However, most wireless handheld Bluetooth microphones have a range of around 30 feet.
5. How long does the battery last on a wireless handheld Bluetooth microphone?
The battery life of a wireless handheld Bluetooth microphone can vary depending on the specific microphone model and how it’s being used. However, most wireless handheld Bluetooth microphones have a battery life of around 4-6 hours of continuous use.
6. Can I use a wireless handheld Bluetooth microphone with multiple devices?
Yes, many wireless handheld Bluetooth microphones can be paired with multiple devices, making it easy to switch between devices when needed.
7. Are there any specific features I should look for when purchasing a wireless handheld Bluetooth microphone?
Some features to consider when purchasing a wireless handheld Bluetooth microphone include the microphone’s sound quality, battery life, range, ease of use, and compatibility with your devices. Additionally, you may want to consider whether the microphone comes with any additional accessories such as a carrying case or microphone stand.
