12 Best Noise-Cancelling Wireless Headset With Microphone
By Hollyland | March 25, 2024
Dive into the world of pristine audio quality and ultra-mobility with this comprehensive guide to the best noise-cancelling wireless headsets with microphones. Whether you’re a professional who needs a crystal clear line of communication in a bustling environment or a casual listener looking to cut out the noise of everyday life, we’ve got you covered.
Below, we explore 12 top contenders, each with their unique blend of features. From Sony’s legendary WH-1000XM5 to JBL’s impressive Tune 760 NC, we leave no stone unturned. Additionally, we’ll touch on a bonus recommendation that might just be what you’re looking for. Get ready to enjoy a soundtrack to your life uninterrupted.
12 Best Wireless Headsets With Microphones Available In the Market
1- Sony WH-1000XM5
The Sony WH-1000XM5 emerges as a show-stopper of noise-cancelling headphones, setting a benchmark for auditory excellence. Crafted to deliver unparalleled sound quality, these headphones feature cutting-edge noise cancellation technology that effectively minimizes background noise, allowing you to immerse yourself in music or focus on your calls without interruption.
The WH-1000XM5 boasts an ergonomic design that ensures comfort during extended use. With up to 27 hours of battery life and quick charging capability, these headphones are designed to keep up with you. Furthermore, Sony’s intuitive touch control panel and the customizable “Sony Headphones Connect” app make it easy to tailor your listening experience to your preferences. Whether you’re in a noisy café or working from home, the WH-1000XM5 adapts to your environment.
Key specifications:
  • Sleek design made with recycled plastic
  • Optimized and automized ANC
  • automatic adaptive system
  • Crystal-clear audio with High-Resolution sound.
  • Compatible with a range of devices
  • Re-optimization of ANC with slight head motion
  • Quick Attention mode for instant conversation
  • User-friendly touch controls
  • Premium price point
  • The sound profile is quite bass-heavy
  • Re-optimization of ANC cannot be manually adjusted
2- Jabra Evolve2 85
The Jabra Evolve2 85 emerges as a compelling choice for professionals seeking high-quality audio paired with superior call clarity. It boasts advanced active noise-cancelling technology, effectively isolating you from your surroundings. These wireless headsets can be highly customized using a companion app for individual preferences.
Additionally, it is equipped with a flippable boom microphone that can be discreetly tucked away when not in use, ensuring that your voice is heard clearly without background distractions. The headset’s 37-hour battery life is noteworthy. The design is sleek yet professional, with highly easy-to-use controls, making it appropriate for office environments and remote work settings alike. Jabra evolve2 85 is also available in a Microsoft Teams version, which has more options in the app.
Key specifications:
  • Well-built with premium plastic and silicon
  • Good noise isolation
  • support voice assistance
  • Five-brand graphic EQ
  • Well-balanced sound profile
  • Stable on the head
  • Comes with a hard leather faux carrying case
  • The ear cups are not replaceable
  • No touch panel
  • Microphone not compatible with analog connection
3- Bose QuietComfort Ultra
The Bose Quiet Comfort Ultra takes the listening experience to another level, combining state-of-the-art noise cancellation technology with unsurpassed comfort. With an impressive battery life that ensures up to 29 hours of uninterrupted listening and a design that values comfort, these headphones are perfect for any situation. Additionally, the Bose Connect app enhances control settings, which customizes your listening experience and makes the Quiet Comfort Ultra a personal sound sanctuary.
These adaptive headphones come with immersive audio and Customtune technology that adjusts their sound profile by reading the environment. These over-ear closed-back closure headphones have a pretty decent build and provide outstanding noise isolation. These lightweight headphones with plush ear and headband cushioning come in three innovative colors to choose from.
Key specifications:
  • Adjustable head-tracking
  • Bluetooth 5.3
  • Adptx adaptive codec
  • 2.3 hours of total charging time
  • 102m line of sight range
  • Decent feedback and easy-to-use
  • Auto-off timer and standby mode
  • Voice prompts and chimes for actions
  • Sibilant sounds are a bit dull
  • Volume slider is a bit inconsistent
  • Cannot connect to macOS and Windows
4- Sennheiser Momentum 4 Wireless
The Sennheiser Momentum 4 Wireless headlines are a fusion of impeccable sound quality and sleek design tailored for the discerning listener. Notably, its Active Noise Cancellation (ANC) technology effectively silences external noise, allowing for an immersive listening experience. The Momentum 4 Wireless features plush ear cups and an adjustable headband that ensures a snug, fatigue-free fit during extended listening sessions.
With an impressive battery life of up to 62 hours and 2.2 hours of fast charging capabilities, these headphones are built to accompany you throughout your day without skipping a beat. Additionally, the intuitive touch controls and the Sennheiser Smart Control app offer a seamless way to customize your listening experience, making the Momentum 4 Wireless a standout choice for audiophiles seeking both performance and style.
Key specifications:
  • Compatible with both IOS and Android
  • Transparent Hearing mode
  • Use adptX adaptive
  • Bluetooth 5.2 plus multiple device pairing option
  • The fair recording quality of the microphone
  • Responsive and good feedback
  • Bass accuracy is flat and neutral
  • Different modes available
  • Poor passive soundstage
  • Drop in mic audio quality when using headphones via USB
  • Noise handling is mediocre
  • Doesn’t support high-end sound tuning
5- Apple Airpods Max
The Apple AirPods Max redefines the over-ear headphone experience by seamlessly blending high-fidelity audio with cutting-edge Active Noise Cancellation (ANC) technology. These wireless headphones boast an Apple-designed dynamic driver that delivers immersive, top-tier audio quality while effectively minimizing external distractions. The meticulous design, from the headband to the ear cushions, ensures a comfortable fit for extended wear, making them conducive for professional and personal use.
Additionally, the AirPods Max are equipped with a high-quality microphone that enhances voice call clarity and ensures superior communication during calls or virtual meetings. With up to 20 hours of battery life, these headphones provide an unparalleled auditory experience, making them a top choice for individuals seeking a seamless blend of premium audio and advanced microphone technology.
Key specifications:
  • High-fidelity audio delivered through custom drivers.
  • Updated to firmware 4E71
  • Spatial audio with dynamic head tracking
  • Supports wired and wireless option
  • Transparency mode available
  • Acoustic design with knit mesh material
  • Precision control buttons with optical sensors
  • 20 hours of talk time on a single charge
  • Lack of power on/off button
  • Limited compatibility outside of the Apple ecosystem.
  • High price tag.
6- JBL Tune 760 NC
The JBL Tune 760 NC positions itself as a compelling mid-range option for users seeking quality without the premium price tag. It features JBL’s Pure Bass sound, delivering powerful, punchy low frequencies that enrich any music genre. Active Noise Cancellation (ANC) technology effectively reduces external noise.
The headphones offer a comfortable fit with the cushioned ear cups, designed for long listening sessions. With a battery life of up to 35 hours with ANC turned on and a quick charge feature that provides 2 hours of playtime with just 5 minutes of charging, the Tune 760 NC is built for endurance. Bluetooth connectivity, along with a multi-point connection, allows you to switch effortlessly between devices. Despite its budget-friendly price, the Tune 760 doesn’t skimp on performance.
Key specifications:
  • Wireless connectivity: Bluetooth 4.2
  • Battery life: Up to 24 hours with ANC on
  • Charging time: 2 hours for full charge
  • Supports Google Fast Fair for Android users
  • Integrated mic with good recording quality
  • Sound is suitable for phone calls
  • Lightweight and portable
  • Over-ear design for better sound isolation
  • Moderate noise-cancelling capabilities
  • Sound customization unavailable
  • No companion app feature is available
7- Anker Soundcore Life Q35
The Anker Soundcore Life Q35 stands out in the wireless noise-cancelling headset category for its blend of quality, comfort, and value. Equipped with advanced active noise-cancelling technology, it effectively blocks out ambient noise.
The Life Q35 offers a robust and detailed sound signature that caters to a wide range of music genres, thanks to its Hi-Res Audio certification and LDAC support, which delivers three times more data than standard Bluetooth codecs. Comfort is also a priority, with memory foam ear cups ensuring a snug fit for prolonged listening sessions.
The headset boasts an impressive 40-hour battery life, even with noise-cancelling engaged, and features a quick charge function that provides 4 hours of playtime from just 5 minutes of charging.
Key specifications:
  • Advanced Bluetooth 5.0 technology
  • Over-ear and closed back
  • audio quality that balances depth, clarity, and bass
  • Very lightweight, just 0.59lb
  • Built-in dual microphones
  • ANC modes for different environments.
  • Long battery life
  • The multi-point connection
  • Not a very breathable design
  • Touch controls can be overly sensitive.
  • ANC  is a bit inconsistent
8- EPOS Sennheiser ADAPT 360
The EPOS Sennheiser ADAPT 360 stands out as a high-quality wireless Bluetooth headset tailored for a seamless communication experience in diverse work environments. This dual-sided, dual-connectivity over-ear headset is equipped with Active Noise Cancellation (ANC) technology, minimizing background noise while talking on call.
An integrated premium microphone ensures crystal-clear voice transmission, making it an ideal choice for professional meetings and calls. Additionally, the Teams and Google Meet certification further accentuates its suitability for modern communication platforms. This graceful and elegant professional headset is no less in looks and features comfortable ear and headband cushions that enable long-term usage without fatigue.
Key specifications:
  • USB, Bluetooth and jack connection
  • Uses “ActiveGuard” ANC technology
  • Built-in controls and high sound quality
  • Mic uses anti-blow and anti-noise system
  •  Up to 46 hours of battery timings
  • Exceptional voice clarity, suitable for professional use.
  • Supports multi-connectivity
  • Ambient sound detection
  • ANC performance is inconsistent in noisy environments.
  • Limited audio codec support
9- Poly Voyager Focus UC B825-M
The Poly Voyager Focus UC B825-M stands out as a premium binaural cordless headset tailored for professional use, featuring advanced Active Noise Cancellation (ANC) technology to ensure clear communication. This over-the-head style headset offers an immersive stereo experience and seamless connectivity to various devices, including PCs and smartphones, making it versatile for modern work setups.
Poly Voyager Focus features USB charging and Bluetooth connections and 3 precision-tuned microphones. Additionally, the Microsoft-optimized B825-M version provides users with a tailored experience for Microsoft applications and platforms and is specially optimized with Microsoft Lync and Skype. This headset can stay connected to a range of 100m and gives a 12-hour talk time with a single charge.
Key specifications:
  • Integrated intelligent sensors
  • USB dongle needed to connect to PC
  • Bluetooth 4.1
  • Weight: 155g
  • Dynamic mute alert and light indication
  • Super lightweight
  • Fast recharge
  • Outstanding quality of audio
  • Standby time is shorter
  • Comes without a headset lifter
10- Jabra Engage 75 Stereo
The Jabra Engage 75 Stereo is a top-of-the-line wireless headset that features clear audio in call and recording thanks to its noise cancellation technology. Its connection range can measure up to 150 meters and connect up to 5 people at the same time. This premium headset offers a range of impressive features, including fast charging and 13 hours of talking time for extended communication. These headsets are extremely easy to use because they have built-in buttons for multiple actions.
With a comfortable and ergonomic design, the Engage 75 Stereo is engineered for all-day wear, providing reliability and comfort during extended use. Its security is enhanced by DECT security step C, allowing users to stay connected without worrying about information leaks.
Key specifications:
  • Adjustable microphone arm
  • Intelligent volume control
  • Integrated busy light for concentration
  • Charging stand included for easy recharge
  • Microphone with directional NC
  • Emergency load
  • High-quality speaker
  • Fats charging
  • Pricey
  • The design is more functional than stylish.
  • Set-up can be complex with multiple connections.
11- Edifier WH950NB
The Edifier WH950NB represents a high-quality wireless headset designed to deliver an exceptional audio experience with advanced noise-cancellation technology. This headset boasts powerful 40mm dynamic drivers, providing rich, immersive sound for music, movies, and calls. The WH950NB also features built-in 4 microphones with clear voice capture along with an audio signal processor. It features bluetooth 5.3 along with fast battery charging and a 55-hour battery timing.
Its ergonomic design and comfortable ear cushions cater to extended usage, and the foldable design adds convenience for portability. Furthermore, these lightweight headsets support dual device connection so that you can multitask with ease. The active noise cancellation feature ensures that external disturbances are effectively minimized, allowing users to focus on their tasks or enjoy their entertainment without interruptions.
Key specifications:
  • High-resolution audio with LDAC certification
  • Ambient sound
  • Battery life up to 34 hours with ANC on
  • Different modes
  • Edifier App control
  • Long battery life
  • Natural and balanced audio
  • Comfortable over-ear fit for extended wear
  • Limited high-resolution audio codec support.
12- OneOdio A30
The OneOdio A30 is a versatile wireless headset designed to deliver high-quality audio performance for various applications. Equipped with 40mm large-aperture drivers, this headset offers a rich and immersive sound experience and Hi-Fi stereo sound, making it suitable for music, movies, and gaming.
The active noise cancellation feature ensures that external distractions are minimized up to 92%, allowing users to focus on their tasks with their 8.0 noise-reduction microphone. The foldable design, soft protein earpads and adjustable headband enhance portability and comfort. With its built-in microphone, the A30 enables clear voice capture. The addition of Bluetooth connectivity provides flexibility for seamless pairing with a range of devices.
Key specifications:
  • Breathable build material
  • C-type fast charging port
  • Battery life up to 25 hours with ANC on
  • Charging time: 2.5 hours
  • Wired option available
  • Comes with an airplane adapter
  • Can be used indoors and outdoors
  • Bass-heavy sound profile with rich details
  • Bass may overpower mids and highs in some tracks.
  • Lacks advanced features like smart sensors and auto-pause
Product Recommendation: Hollyland Solidcom C1 Pro
While this is not exactly a product that can fall in the headsets category, Hollyland Solidcom C1 pro deserves to be specially mentioned here as an excellent full-duplex wireless intercom headset system with dual-mic Environmental Noise-Canceling technology in the crowded audio equipment market. This innovative technology is specially tailored for professional event coordinators, production teams, and field operatives in mind who demand clarity and reliability.
Hollyland Solidcom C1 Pro - Pro Noise-Cancelling Intercom
A full-duplex wireless intercom with dual-mic ENC for clear and hands-free communication.
Key Features: Dual-Mic ENC | PTT | 350m | 150Hz–7kHz
Solidcom C1 pro offers premium audio quality, which remains crystal-clear over 350 meters, thanks to its robust interference-free signal with a bandwidth of 150Hz-7kHz. The Solidcom C1 Pro boasts an intuitive design, with a lightweight build that promotes comfort during prolonged use and a battery life extending up to 10 hours on a single charge.
Key specifications:
  • Compact and wights only 170g
  • IP54 rating for dust and water resistance
  • Encryption technology for uncompromised security
  • Built with PC-ABS material
  • Expandable and customizable for up to 9 members
  • Replaceable batteries
  • Very low power consumption
  • Out of the box and ready to use
  • Not ideal for casual use
  • Only useful for two-way communication
How To Choose A Perfect Wireless Noise-Cancelling Headset With A Microphone?
Selecting the perfect wireless noise-cancelling headset with a microphone involves balancing a variety of features against your personal needs and preferences. Here’s a comprehensive guide to making an informed decision:
  • Noise Cancellation Technologies
Active Noise Cancellation (ANC) is a must-have for those in noisy environments. This technology uses microphones to detect and counteract external sounds with opposite sound waves. There are varying degrees of ANC effectiveness, so consider trying out a few options if possible. Passive Noise Isolation, on the other hand, is achieved through the design of the headset itself, physically blocking out noise.
  • Audio Quality
For music lovers or professionals relying on crisp, clear audio for communications, pay close attention to the headset’s drivers and frequency response. Larger drivers tend to deliver richer bass, while a wide frequency range ensures you catch the full spectrum of sound. Determine whether you want to use it for music and movies or work calls and tasks.
  • Microphone Clarity
If your primary use involves making calls or video conferencing, the quality of the microphone cannot be overlooked. Look for headsets with noise-cancelling mics, which minimize background noise and focus on your voice. Some models feature boom mics that can be adjusted closer to your mouth for enhanced clarity.
  • Comfort and Ergonomics
Comfort is paramount for those wearing headsets for extended periods. Check for padded ear cups and adjustable headbands. Materials can make a significant difference—memory foam and breathable fabrics reduce pressure and heat build-up. Additionally, the headset’s weight is a factor to consider when wearing long-term.
  • Battery Life
Battery life ranges widely among wireless headsets, from about 15 to 40+ hours. Assess your typical usage patterns to determine what minimum battery life will be acceptable. Remember that features like ANC can drain batteries faster, so factor this into your decision.
  • Connectivity Options
While Bluetooth® is standard, look for headsets with the latest version for improved range, connectivity, and energy efficiency. For those who may need it, the ability to connect via a traditional 3.5mm jack or USB can be a valuable backup. Furthermore, look for dual connectivity if you have to switch between apps while using a headset.
  • Price vs. Quality
Finally, balance the cost against the features and quality you require. While higher-priced options often offer superior sound quality and build, remember that a higher price does not always mean higher quality. Many mid-range models provide excellent value for money without breaking the bank. The ideal headset blends seamlessly into your daily routine, enhancing your audio experiences without compromise.
When navigating the diverse market of noise-cancelling headphones and professional communication devices, it’s crucial to weigh your priorities, whether they lean towards sound quality, noise-cancellation capabilities, budget, or specific use cases like professional events. The products reviewed range from budget-friendly options to the high-end Hollyland Solidcom C1 Pro, showcasing the wide spectrum of available choices to suit various needs and preferences.
For everyday users and music enthusiasts, models like the JBL Tune 760 NC offer a harmonious blend of performance, comfort, and value. Meanwhile, professionals requiring flawless communication in demanding environments may find the investment in a solution like the Hollyland Solidcom C1 Pro justified by its superior audio clarity, range, and durability. Regardless of your selection, today’s technology ensures a sound solution for everyone.
