Streaming to your Fire TV is easier than most people think. Whether you want to mirror your phone, cast from your laptop, or stream directly from a camera, there are several simple ways to make it work.
If you love creating or sharing live content, a camera like the Hollyland VenusLiv Air can take your setup to the next level. With its 24/7 streaming capability and AI-tuned 4K visuals, it delivers smooth, high-quality results without extra equipment. In this guide, you’ll discover clear, reliable methods to stream or mirror your favorite content straight to your Fire TV.
Hollyland VenusLiv Air - Compact 4K Streaming Camera
A compact, all-in-one 4K live streaming camera with a large sensor and fast lens, featuring AI-powered tools.
Key Features: 4K30 | 1/1.3″ CMOS | AI Tuning | 24/7 Streaming
Method 1: Mirroring Your Screen to Fire TV
If your device supports Miracast, then you can stream to your Fire TV by mirroring your screen. However, to view your display on a bigger screen, you’ll first need to enable mirroring mode on your Amazon Fire TV. Here’s what you need to do:
- Open Settings on your Amazon Fire TV.
- Click on Display & Sounds.
- Click on Enable Display Mirroring. You can also enable this option by holding down your remote’s Home button and then selecting Mirroring. If you don’t see this option, then your Fire TV doesn’t support screen mirroring.
Once you’ve enabled display mirroring on your TV, you’ll need to set up the device you’re mirroring from:
How to Stream from Windows 10
- If you’re using a laptop with Windows 10, navigate to the bottom right of your screen and click on the text message icon to open your Notifications.
- Select Connect. If your laptop and TV are connected to the same Wi-Fi network, you should see your Fire TV in the list of options.
- Select your Fire TV, and it should start mirroring the screen.
How to Stream from Windows 11
- If your laptop has Windows 11, press the Windows key + K. You can also access the option by clicking on the Sound, Battery, and Wi-Fi section in your screen’s bottom-right corner. If the option isn’t available, select the Pencil icon, click on Add, and select Cast.
- Find and choose your Fire TV.
- Click Connect.
How to Stream from an Android Device
Note: The following steps are for a Samsung Galaxy device with Smart View. However, other Android devices are designed with similar features, so look for a “screen mirroring,” “casting,” “sharing,” or similar option supported by your model.
- Drag your finger down from the top of your screen to get Quick Settings.
- Find and tap Smart View. Also, make sure your phone is connected to the same Wi-Fi network as your TV.
- Select your Amazon TV, and it should mirror your phone screen.
Once you’ve successfully shared your screen, your TV should reflect everything you do on your device. To stop screen mirroring, simply press any button on the TV remote, and the connection will end.
How to Stream from an Apple Device
If you want to stream from an iPhone, iPad, or Mac, then you’ll need to enable AirPlay on your Fire TV. Here’s what you need to do:
NOTE: Not all Fire TV models may have a direct option to enable AirPlay.
- Turn on your Fire TV and go to Settings.
- Click on AirPlay & HomeKit.
- Follow all the on-screen instructions. You might need to enter the AirPlay code to start mirroring your iOS screen to the Fire TV.
However, it’s important to note that not all Fire TVs are compatible with AirPlay. If your TV doesn’t have AirPlay, you’ll need to use a third-party app. To give you an example, here’s how you can use AirScreen to mirror your screen:
- Turn on your Fire TV, open the Appstore, and search for AirScreen. Download and install the app.
- Once you open AirScreen, you’ll see a QR code. Use your iPad or iPhone to scan it and open the link.
- Select Entire Screen, and screen mirroring should start.
- If you want to cast again, swipe down from the top of your screen to open the Control Center. If you’re on your Mac, you can open the Control Center by navigating to the top-right of your screen and clicking the option that looks like two overlapping sliders.
- Tap Screen Mirroring, then select [AirPlay] to mirror your screen to your TV.
Method 2: Casting Apps to Fire TV
If you don’t want to mirror your entire screen, you can also cast only specific app content (Netflix, YouTube, Prime) to your Fire TV. Simply use your phone or laptop to pick what you want to stream and cast it to your TV. However, keep in mind that you can only cast to Fire TVs running Fire OS 7 or higher.
Here’s how you can cast supported applications to your Amazon Fire TV:
- Make sure your mobile device and Fire TV are connected to the same Wi-Fi network.
- Launch the app you want to cast on your phone. If you’re casting content from Prime Video, make sure you sign in with the same account that’s connected to your Fire TV.
- Tap the Cast icon on your mobile app. It should look like a rectangle with three arcs in the bottom left corner.
- Select your TV from the list.
You can control playback with both your Fire TV remote and your mobile device. To stop casting, tap the Cast icon again, then select the option to disconnect.
There’s more than one way to bring your screen to Fire TV. From mirroring your devices to casting apps directly, each method offers a simple path to seamless streaming. Choose the one that fits your setup, sit back, and enjoy your content on the big screen without any hassle.
Which devices can’t screen mirror to the Amazon Fire TV?
There are a few devices that aren’t compatible with Amazon Fire TV, including Android devices running Android OS 4.2 or older, Android devices without Miracast support, and Windows devices without Wireless Display (WiDi) capability. Some Fire TVs don’t support iOS and macOS devices as well.
Which is better, mirroring or casting?
Mirroring is perfect for showing presentations or when you want to share your entire interface. On the other hand, casting offers greater flexibility, allowing you to use your phone for other tasks while streaming specific content. Ultimately, the decision comes down to what you find more convenient.
Why can’t I cast to a Fire TV?
If you can’t cast to your Fire TV, try clearing the app’s cache on both your phone and TV. To clear your TV’s cache, click on Clear App Data and Cache. If you’re still having problems, make sure the software on both your mobile device and your Fire TV is up to date.
Is there a monthly fee for Fire TV?
No, you don’t need to pay a monthly fee to use your Amazon Fire TV. While an Amazon account is required to set up the TV, you don’t need to have an Amazon Prime subscription.
Why is screen mirroring not detecting my Fire TV?If your devices can’t detect your Fire TV, make sure they’re connected to the same Wi-Fi network and that you have a stable internet connection. Also, check that your devices are compatible and that your TV is set to the correct input source.
