New Product Coming
DAYS
HRS
MINS
SECS
Firmware Upgrade
March 27, 2023
Note: V1.1.1.9 and V1.0.2.0 are the latest firmware version
DOWNLOAD PATH:
Download Linkage
Updates:
1. Language menu optimization
Tip: There is no change in functionality and performance, so it doesn’t need to upgrade if the device is working normally.
Please do the operations as below:
1. Prepare a small USB disk(16/32G), then format it to FAT32.
2. Download the upgrade file to the USB disk root directory
3. Connect the USB disk to our device, it will do the upgrade automatically after turning the device on
If the operations above can not solve your problem, please fill out the form below:
https://tqmlk9mc66.jiandaoyun.com/f/604987c7e2b41c000797231d
RELATED POSTS
