Upgrade for Solidcom C1 Without HUB
March 27, 2023
V1.0.4.3 UPDATES:
  • Master Headset supports up to 7 remote headsets.
Download Path:
FIRMWARE_DOWNLOAD
Note:
  • This upgrae only for Window System.
  • For Window 11 system, if the driver is not install successfully, please try to turn off the bluetooth fuction of the PC.
OPERATIONS:
  • Download the upgrade file 【WIN】 and unzip the file
  • Install the driver 【VCP_V1.5.0_Setup_W8_x64_64bits.exe】
  • Turn on the master headset and connect it to the PC via a USB to Type-C cable
  • Open the 【I5802_Headset_Upgrade.exe】 application
  • It will recognize the headset and click 【YES】 to do the upgrade.
  • Wait for the upgrade to complete, Don’t unplug the cable when upgrading
  • Do the same steps to upgrade the remote headset
  • After the upgrade, pair the master headset and remote headset again. Long-press the 【A】 botton on the headset to enter pairing state simultaneously
RELATED POSTS
