Solidcom H1 Wireless Intercom System Support
1. Connect the computer to the LAN port of the central station via a network cable.
2. Change the computer’s network port IP to one within the same subnet as the central station.
(1)Enter the computer settings.
(2)Find Network Settings
(3)Select Ethernet, right-click the mouse and choose “Properties”.
(4)Click the Internet协议版本4(TCP/IPV4)
(5)Select “Use the following IP address,” enter an IP address within the same subnet as the central station (the last digit must differ from the central station’s IP, ranging from 0 to 255; the central station’s current IP is: 192.168.218.10) and the subnet mask. The subnet mask must match that of the central station.
3. Open your computer browser and enter the IP address informations under LAN & SFP Port Settings in the wired network configuration (default: 192.168.218.10) to access the Web page (default password: 12345678).
1. Connect the LAN port of the charging Dock to the antenna or the LAN port of the central station using an Ethernet cable.
2. Look at the indicator light on the charging dock. When the connection is successful, the light changes from red to blue.
3. Place the beltpack into the charging dock and wait for pairing to complete automatically.
1. Enter the menu of Central Station or Antenna, find Network->Wi-Fi & BT, and turn on Wi-Fi & Bluetooth.
2. Tap the “+” icon in the upper-right corner to add a device.
3. Turn on Bluetooth on your phone and select Next.
4. Add the device you wish to connect from the list of available devices found.
  1. Connect the central station’s WAN port to a wired network using an Ethernet cable,If you do not have central station and are using an antenna, connect the network cable to the antenna’s LAN port(DHCP service must be enabled on the central station or antenna for successful connection). Upon successful connection, the IP information will be displayed in network setting.
  2. Access the central station’s system settings and click “Verification Code” (this code binds the central station to the mobile app).
  3. Turn on your phone’s mobile data or connect to Wi-Fi to make sure your phone is online.
  4. Download the Hollyvox app from the app store.
  5. Register an account and log in.
  6. Tap the “+” icon in the upper-right corner of the app’s home screen to add a device. Select Model 57 Series Cloud communication.
  7. Enter the Verification Code from Step 2 to bind the device.
  8. Enter a note to help identify the main site.
  9. Create a room (The account creating the room must have available time; otherwise, it cannot be created. Joining members do not need to purchase time.)
  10. Enter the voice room name and password (custom name and password)
  11. Click “Start” to begin the cloud call timer. Click “” to copy the voice room ID and send it to members who need to join.
  12. The above steps complete the creation of a conference room. Next, we’ll explain how to join a conference room via the app. Similar to the room creation interface, simply click “Join.”
  13. Enter the following information: ID, password, seat number (seat number information can be viewed on the web page).
  14. Entering the call page displays the picture below. The operation logic is the same as the beltpack’s buttons. Use the A, B, C, and D buttons to control the audio source status of the app.
