OVERVIEWS: Mars M1 has rich interface, this article shows the usage of all the interface for your reference.
| Num | Features | Details |
| ① | Micro-single Camera | SONY, Canon, Fuji, Nikon |
| ② | Video Camera | Panasonic, SONY |
| ③ | Cinematograph | ARRI, RED, SONY Telecine Camera |
| ④ | Sun Shield | Shield from direct sunlight when used outdoors |
| ⑤ | Monitor | Connect to big monitor to review |
| ⑥ | Hand Shank | Mount it to handle the Mars M1 easily |
| ⑦ | USB Disk | Connect USB flash disk to upgrade. |
| ① | DC OUT to Camera | DC OUT to power the camera (Also work when power by battery) |
| ② | D-Tap to DC | Power by V-mount / G-mount battery |
| ③ | DC Adapter | Powre by DC Adapter (6~16V) |
| ④ | Shoulder Girdle | Mount it to hang Mars M1 over your shoulder |
| ⑤ | Tripod | Mount it to the tripod when using as RX |
| ⑥ | Cold shoe to Camera | Mount it on the camera cold shoe when using as TX |
| ⑦ | Camera SDI IN | Camera SDI input only work when using as TX |
| ⑧ | NP-F Battery | NPF970, NPF750, NPF550 battery |
Article Number: 【AS-220623167_8】
