18 Best GoPro Wireless External Microphone Brands for All GoPro Models
Finding an excellent GoPro wireless microphone can bring more views to your shots and multiply the fun of recording. But since so many brands are there, and each has its own claim of uniqueness, it takes time to choose one. Then comes the budget, which has a big wow factor when getting a wireless mic.
This article intends to provide details for the 18 best wireless GoPro mics, including the latest addition, the Hollyland LARK M2S. You will explore the features, specs, and uses of all the mentioned microphones. Besides, there’s a brief guide for picking the correct mic for all GoPro camera models. And finally, the comparison chart to help you quickly decide on the best GoPro wireless microphone.
So let’s get started.
How to Choose a GroPro Wireless Microphone?
When selecting the best external mic for GoPro, make sure you have knowledge about the following factors.
a. Quality
Your GoPro wireless microphone must deliver high-quality sound. So when choosing a mic, make sure it covers a wide frequency range. Also, it’s a plus point if it comes with a shock mount.
b. Ease of Use
Choose a mic that is easily controllable. If you are a new user and unknown to technicalities and controls, selecting a microphone with straightforward options like Hollyland Lark M2 is wise.
c. Connectivity
This is the tricky factor. Remember that GoPro Hero 3, Hero 3+, and Hero 4 require a USB connector. Whereas GoPro Hero 5 and later models need a 3.5mm TRS jack and cable to attach a microphone. Therefore, pick a mic that suits your GoPro connectivity port.
d. Microphone Type
A clip-on mic serves to be the best microphone for GoPro. Since it record sounds wirelessly, you can attach the receiver to your GoPro camera and freely roam around to record sound. On the other hand, if you don’t record long-distance shots, then a shotgun microphone can also be a suitable type.
e. Polar Pattern
Although there are numerous polar patterns of mics, you should select an omnidirectional GoPro wireless microphone as it captures excellent quality audio. The second option is going for a supercardioid mic to record clear sounds from the front side only.
Comparison Table – Best External Wireless Microphones for GoPro
ProductPricePolar PatternMic TypeBattery TimeGoPro CompatibilityFrequency ResponseConnectorPower SourceWeightAdditional Features
Hollyland Lark M2S$149.00 (Combo version)
$119.00 (USB-C version)
OmnidirectionalLavalier/Clip-onTX: Up to 9 hours
RX: Up to 8.5 hours
HERO 5 and newer models20Hz – 20kHz3.5mm, USB-C, and LightningRechargeable batteryTX: 7 grams
RX: 6 grams
LDS and ENC
Hollyland Lark M2$159.00 (Camera version)
$179.00 (Combo version)
OmnidirectionalLavalier/Clip-onTX: Up to 10 hours
RX: Up to 9 hours
HERO 5 and newer models20Hz – 20kHz3.5mm, USB-C, and LightningRechargeable batteryTX: 9 grams
RX: 14.8 grams
LDS and ENC
Hollyland Lark M1$149.00OmnidirectionalLavalier/Clip-onTX and RX: 8 hoursHERO 5 and newer models20Hz – 20kHz3.5mm TRS to TRS/TRRS/USB-C/LightningRechargeable batteryTX: 11.8 grams
RX: 17.5 grams
HearClear Noise Cancellation
Hollyland Lark Max$249.00OmnidirectionalLavalier/Clip-onTX: 7 hours
RX: 9 hours
HERO 5 and newer models20Hz – 20kHz3.5mm, USB-C, and LightningRechargeable batteryTX: 33 grams
RX: 60 grams
MaxTimbre Technology
RODE VideoMicro II$79.00SupercardioidShotgunN/AHERO 5 and newer models20Hz – 20kHz3.5mm and USB-CPlug-in power33 gramsAnnular Line Tube Technology
Sennheiser MKE 200$74.00SupercardioidShotgunN/AHERO 5 and newer models40Hz – 20kHz3.5mm TRS and TRRSPlug-in power48 gramsBuilt-in shockmount and windscreen
RODE Wireless GO II$293.00OmnidirectionalLavalier/Clip-onTX and RX: Up to 7 hoursHERO 5 and newer models50Hz – 20kHz3.5mm TRS, USB-C, and iOS digital outputRechargeable batteryTX: 30 grams
RX: 32 grams
40-hour internal memory
DJI Mic 2$349.00OmnidirectionalLavalier/Clip-onTX and RX: 6 hoursHERO 5 and newer models20Hz – 20kHz (low cut on)
50Hz – 20kHz (low cut off)
3.5mm TRS and USB-CRechargeable batteryTX and RX: 28 grams Dual wireless connectivity
Shure MoveMic$499.00OmnidirectionalLavalier/Clip-onTX: Up to 8 hours
RX: Up to 7 hours
HERO 5 and newer models50Hz – 20kHz3.5mm and USB-CRechargeable batteryTX: 8.2 grams
RX: 81 grams
Water-resistant
RODE VideoMicro$64.95CardioidShotgunN/AHERO 5 and newer models100Hz – 20kHz3.5mm TRSPlug-in power42 gramsUnspecified
Saramonic SR-XM1$20.00OmnidirectionalPlug-inN/AHERO 5 and newer models35 Hz – 15 kHz3.5mm TRSPlug-in power21 grams360-degree rotation
Boya BY-MM1$23.99CardioidShotgunN/AHERO 5 and newer models35Hz – 18kHz3.5mm TRS and TRRS Plug-in power86 gramsUnspecified
Movo VXR10$39.95SupercardioidShotgunN/AHERO 5 and newer models20 Hz – 18 kHz3.5mm TRSPlug-in power51 gramsRun & Gun
Deity V-Mic D4 Duo$39.96Dual cardioidShotgunN/AHERO 5 and newer models50Hz – 20kHz3.5mm TRSPlug-in powerUnspecifiedDual-directional microphone
Godox MoveLink II$199.00OmnidirectionalLavalier/Clip-onTX: 10 hours
RX: 8 hours
HERO 5 and newer models50Hz – 20kHz3.5mm TRSRechargeable batteryTX and RX: 27 gramsSwitchable audio modes
Klip 5-in-1 Wireless Lavalier Microphone$59.95OmnidirectionalLavalier/Clip-onTX and RX: Up to 8 hoursHERO 5 and newer modelsUnspecified3.5mm, USB-C, and LightningRechargeable batteryTX: 9 grams
DSP
SPORTKEE K2$24.99OmnidirectionalLavalier/Clip-onTX: Above 6 hoursHERO 5 and newer modelsUnspecified3.5mm, USB-C, and LightningRechargeable batteryUnspecifiedNoise reduction chip
RICHCHIP RC100$64.99UnspecifiedWireless microphone and recorderUnspecifiedHERO 12Unspecified3.5mmRechargeable batteryUnspecifiedUnspecified
NOTE: All products included in this list are compatible with GoPro HERO 5 and the latest models. However, you will need the GoPro Media Mod kit or GoPro Pro adapter to make most wireless and external microphones work with GoPros. If you have an older model of GoPro, such as HERO 4 or previous, you will need a mini USB adapter to use these microphones. Moreover, all the prices mentioned here for each product are taken from Amazon. The price may vary at any time depending on the official manufacturers and Amazon sellers.
Top 18 GoPro Wireless Microphone Models
Here’s the section you have been waiting for. Get ready to explore the five great GoPro wireless microphone brands
1. Hollyland Lark M2S
The LARK M2S is a high-quality wireless microphone system designed for content creators. It offers a sleek, logo-free design that can be discreetly clipped to clothing.
The microphone delivers studio-quality 48kHz/24-bit audio with a 70dB signal-to-noise ratio and 116dB maximum sound pressure level. Advanced environmental noise cancellation technology eliminates unwanted low-frequency sounds, ensuring crystal-clear audio recordings.
The LARK M2S features a lightweight titanium construction for enhanced portability and stability. It offers a wireless range of up to 300m in line-of-sight and 30-hour battery life with the charging case. The system is universally compatible with a wide range of devices, including cameras, smartphones, and computers, providing a plug-and-play solution for creators.
The companion LarkSound app allows for easy configuration and firmware upgrades. Tailored accessories like furry windshields and cable adapters further enhance the LARK M2S user experience. With its combination of high-quality audio, advanced features, and considerate design, the LARK M2S empowers content creators to capture their inspirations with exceptional clarity and confidence, whether for live streaming, video production, or any other creative endeavor.
2. Hollyland Lark M2 – The Most Feature-Rich Wireless Microphone for GoPro
The Hollyland Lark M2 is a multi-compatible wireless microphone. It offers high-quality audio recording at a 48kHz/24-bit sample rate. One of the prime features of the Hollyland Lark M2 is its Environmental Noise Cancellation (ENC) technology. This is a great tool for reducing surrounding noises throughout a big range of frequencies. That is why this feature complements the GoPro, as you can record clear audio in the highest way possible while filming adventures with your action camera.
Another valuable feature of the Lark M2 is its long battery time. While plugging the transmitter (TX) unit into the charging case extends the normal battery life to 40 hours. Contrarily, a fully charged TX has a runtime of around 10 hours. Also, charging the units only takes 1.5 hours or less.
The Hollyland Lark M2 tears down the competition by offering a high-gain LDS (Laser Direct Structuring) antenna for strong and continuous wireless transmission. This microphone also has dual anti-interference technology to add more robustness to signal and voice clarity. This mechanism saves the mic from debris and other interferences, such as RFI, infrared, and other 2.4G wireless interferences.
All these characteristics allow the audio signals to travel from TX to RX without degradation. Well, this point also brings us to the wireless range. The Lark M2 can deliver wireless audio up to 1000ft, a better range offered by the most expensive brands.
Last but not least, you can use the Hollyland Lark M2 to record sounds in stereo and mono mode. Also, the transmitters are so tiny that they resemble the shape and size of a coin. You can attach it to your clothing through magnetic attachment, clip it, or put it around your neck like a necklace. Whatever you choose, the Lark M2 looks stunning in your videos, and its audio quality is far more than superior.
Key Specifications of the Hollyland Lark M2
  • 9-grams of total weight (TX)
  • 14.8 grams of total weight of RX (camera version)
  • Omnidirectional polar pattern
  • 2.4GHz AFH wireless connectivity
  • Up to 1000ft (300 meters) of wireless range
  • 10-hour TX battery life
  • Around 9 hour (RX) battery life
  • Required charging time is 1.5 hours
  • – 37dBV +/- 2dB @ 1kHz mic sensitivity
  • Greater than 70dB signal-to-noise ratio
Pros of the Hollyland Lark M2
  • It has an enhanced battery life
  • You can adjust audio up to three levels
  • The magnetic attachment is very strong
  • The product also comes in a Combo version to use it with all smart devices and cameras, including iPhones and iPads
Cons of the Hollyland Lark M2
  • The RX (camera version) is a bit heavier than the mobile version’s receiver unit, only weighing 6 grams
Quantitative Measurement of the Hollyland Lark M2
  • Design: 9.5/10
  • Durability: 9/10
  • Build quality: 9/10
  • Unique features: 9.5/10
$179.00 (Combo version without discounts and offers as seen on Amazon)
$159.00 (Camera version without discounts and offers as seen on Amazon)
3. Hollyland Lark M1
1. Hollyland Lark M1 - The Most Suitable GoPro Wireless Microphone
If you are looking for a lightweight and aesthetically beautiful wireless microphone for GoPro, nothing beats the Hollyland Lark M1. This mic is available with a single and double receiver backed by a powerful transmitter. It is designed specifically to provide a great user experience when connected to your GoPro.
Hollyland Lark M1 packs transmitters and receivers in a solid-body case that works as your charging unit. So say the last prayers to the charging cables because you don’t need them anymore when you have M1. The receiver gets connected to your GoPro through a 3.5mm jack. And with just a push of a button, the receiver gets paired with the transmitter.
Features and Specifications of Hollyland Lark M1
Hollyland Lark M1 have interesting features and specs, making it an ideal GoPro wireless microphone.
  • 110dB SPL
  • 3.5mm jack for GoPro connectivity
  • 650-feet wireless range
  • Omnidirectional mic pattern
  • 48kHz maximum frequency response
  • 2.4Ghz transmitting power
  • Noise reduction button
  • 8-hour operational time
Pros of Hollyland Lark M1
These are awesome advantages of Hollyland Lark M1 which makes it the best mic for GoPro.
  • Top-notch product at an inexpensive price
  • Easy connectivity to GoPro with a 3.5mm jack
  • Compatibility with other devices via USB Type C
Cons of Hollyland Lark M1
  • Wireless range is limited compared to Lark M2
Quantitative Measurement of Hollyland Lark M1
  • Design: 9/10
  • Durability: 8/10
  • Unique features: 9/10
$149.00 (As seen on Amazon)
4. Hollyland Lark Max
The Hollyland Lark Max is another pick for your GoPro. It is an excellent wireless microphone system that goes with all major GoPro models and other devices, including phones, tablets, computers, and mirrorless cameras. Customized to fulfill the needs of passionate content creators, the Lark Max wireless mic kit provides a series of valuable features to help you overcome several recording challenges with your GoPro device.
One of the biggest boons of Hollyland Lark Max is the inclusion of MaxTimbre Mic technology to ensure you get studio-grade audio no matter what. Besides, this wireless microphone system comes with an Environmental Noise Cancellation (ENC) characteristic to make sure your GoPro recordings have clean audio over a distance of up to 820ft.
The Hollyland Lark Max also comes with an 8GB storage capacity with audio backup of up to 14 hours to help you record audio without a camera or other video devices. However, the most stand-out feature of Lark Max is its water-resistant case that surely adds portability and durability. So, the next time you’re out with your GoPro to record adventures, you don’t have to bother about the wet terrains and rainy season. You can travel, explore, and enjoy the journey without worrying about your mics being raptured by rain as long as they are inside the case.
Features and Specifications of Hollyland Lark Max
The Hollyland Lark Max offers a lot of great features, including:
  • Magnetic attachment
  • 70 dB Signal-to-Noise Ratio
  • Less than 2 hours of charging time
  • AFH technology for stable transmission
  • 820ft (line-of-sight) wireless video transmission
  • 7.5 hours of battery time, extendable up to 22 hours
Pros of Hollyland Lark Max
  • Superior sound quality
  • The kit comes with advanced noise-canceling technology
  • Integrated background noise filtering even without activating the noise-canceling option
  • Clear and clean connectivity to GoPro and other devices through lightning port, USB-C, and 3.5mm audio jack
Cons of Hollyland Lark Max
  • The units are a bit bulky
Quantitative Measurement of Hollyland Lark Max
  • Design: 8/10
  • Durability: 8/10
$249.00 (As seen on Amazon)
5. Sennheiser MKE 200
3. Sennheiser MKE 200
Sennheiser MKE 200, compared to the company’s previous shotgun microphones, is quite impressive. It is a lightweight, sturdy mic covered in black aluminum build. The fact that it sports a built-in shock mount makes it a good GoPro wireless camera, especially if you are into vlogging.
Sennheiser MKE 200 is simple to attach to your GoPro through a TRS 3.5mm coiled cable. So don’t get confused because the package comes with two TRS to TRS and TRSS cables. One for your GoPro and another for your smartphone. Although MKE 200 is not a perfect mic, it is still a good plug-and-go option.
Features and Specifications of Sennheiser MKE 200
Some best qualities of the Sennheiser MKE 200, which makes it the best GoPro microphone, are:
  • 120dB SPL
  • -33dBV mic sensitivity
  • Supercardioid polar pattern
  • 40Hz to 20kHz frequency range
  • Pressure gradient functioning
Pros of Sennheiser MKE 200
Sennheiser MKE 200 is ideal for GoPro users because of the following factors:
  • Highly affordable
  • 48-gram weight
  • Battery-free operation
  • Built-in wind protection
  • Directional pickup
  • Ultracompact body
Cons of Sennheiser MKE 200
Here are a few reasons why Sennheiser MKE 200 may not satisfy you.
  • Only good for medium or close range
  • The products lack a light indicator
Quantitative Measurement of Sennheiser MKE 200
  • Design: 6/10
  • Durability: 7/10
  • Build quality: 7/10
  • Unique features: 6/10
$78.99 (As seen on Amazon)
6. RODE Wireless GO II
The RODE Wireless GO II is a dual-channel wireless microphone kit available in single and dual versions. The dual kit has 2x transmitters and 1x receiver, making it suitable for vlogging, interviews, filmmaking, and all other popular content types. The kit distinguishes itself from other devices due to its magnificent features, which meet all your recording needs.
Since we’re talking about the dual version, it lets you capture two audio sources at the same time. However, it gives you the choice to record audio sources combined or separately, depending on your requirements.
This microphone uses its own Series IV technology for signal transmission. This powerful functionality ensures high-quality audio transmission up to 200 meters  (656ft). This makes it best for both indoor studio and outdoor street recordings, as the sound quality remains reliable throughout the session.
It is a travel-friendly device, with each TX and RX unit weighing around 32 grams. So no wonder why most travel vloggers use this lightweight mic with GoPro setups since it doesn’t add burden to their journey. While you can clip the TX units on your clothing, the GO II also easily attaches to boom boles, mobile rigs, cold shoes, and, most importantly, the GoPro Media Mod.
Another selling feature of the RODE Wireless GO II is its battery life. The design includes a rechargeable lithium-ion battery, which gives up to 7 hours of recording time. Additionally, you can use its onboard audio recording function to record and save audio for up to 40 hours in its internal memory. Therefore, both the battery life and onboard recording features ensure uninterrupted recordings with backup audio.
Key Specifications of the RODE Wireless GO II
  • 30-gram TX weight
  • 32-gram RX weight
  • 2.4GHz wireless connectivity
  • 656ft wireless range
  • Up to 7 hours of TX and RX battery life
  • 50Hz to 20kHz frequency response
  • USB-C, 3.5mm TRS, and lightning connectivity (with adapter)
Pros of the RODE Wireless GO II
  • The initial setup is simple and fast
  • Outstanding audio quality, especially when recording outdoors
  • The TX unit keeps on recording even if it’s disconnected
Cons of the RODE Wireless GO II
  • The included storage pouch is of low quality – users had to purchase a third-party bag, which is an additional expense
Quantitative Measurement of the RODE Wireless GO II
  • Design: 9/10
  • Durability: 8/10
  • Build quality: 8.5/10
  • Unique features: 8/10
$293.00 (As seen on Amazon)
7. DJI Mic 2
The DJI Mic 2 is an upgraded version of the renowned DJI Mic. This mic has omnidirectional transmitters and a single receiver to record and transmit high-quality audio for vlogging and interviews. So, it can be a great companion to GoPro cameras since it captures clear sounds of 2 persons simultaneously.
The DJI Mic 2 weighs 28 grams. The system uses dual transmission technology, including 2.4GHz and Bluetooth. This means you can use the device wirelessly with GoPro HERO 12 directly by connecting through Bluetooth. Alternatively, you can use the Media Mod Kit to connect this mic with other GoPro models.
This microphone comes equipped with intelligent noise-cancelling technology to ensure your recordings are free from unwanted noise. It is a powerful feature that minimizes environmental sounds so your main audio stays clean in crowded, urban places.
On the outer level, the DJI Mic 2 allows you to add a windscreen on the transmitters. This further reduces wind sounds while you’re recording videos with GoPro. This is ideal, especially if you’re into Moto vlogging with GoPro. And guess what? The package includes windscreens, saving you from spending on additional gear.
Both TX and RX units have a battery life of up to 6 hours when used after fully charging them. However, if you feel like recording static scenes, which require more battery life, you can use the mics by placing them inside the case. Doing so will extend the battery life to up to 18 hours.
The mic offers a long wireless range of up to 820ft (250 meters). However, you may experience loss of range in obstructed areas. Besides, this wireless microphone works with smartphones and other devices, which gives you more flexibility over recordings in various scenarios.
Key Specifications of the DJI Mic 2
  • 28 grams of TX/RX weight
  • Bluetooth and 2.4GHz wireless connectivity
  • 820ft wireless audio transmission range
  • 6-hour TX/RX battery life
  • Approx. 1.2 hours required charging time (TX/RX)
  • 3.5mm TRX and USB-C connectivity
  • 20Hz to 20kHz frequency response on Low Cut On
  • 50Hz to 20kHz frequency response on Low Cut Off
  • 21dBA signal-to-noise ratio
Pros of the DJI Mic 2
  • The recorded audio sounds have an exceptional and AirPod-quality sound
  • Its RX unit has several rich features that contribute to reliable audio
  • Most users are pleased with its lossless transmission
Cons of the DJI Mic 2
  • The provided documents and instruction manual provide inadequate information
  • You cannot sync multiple mono recordings without using DJI software
Quantitative Measurement of the DJI Mic 2
  • Design: 7/10
  • Durability: 8/10
  • Build quality: 7.5/10
$349.00 (As seen on Amazon)
8. Shure MoveMic
The Shure MoveMic is made to work under different conditions. It’s an IPX-4-rated wireless microphone, which means it can smoothly work in rain. Liquid splashes and spills won’t lower its performance. So, having this microphone with your GoPro means you become unstoppable when it comes to content creation, no matter how unfavorable the weather is.
The dual version of the MoveMic consists of 2x TX and 1x RX. Each TX has a battery life of up to 8 hours. Using them with the storage/charging case doubles the battery. This means you can use this microphone for 8 hours without the charging case and 16 hours with the case, giving a total running time of 24 hours. This is an excellent feature for those who are looking for impressive battery life in a wireless microphone.
Also, setting up the Shure MoveMic with GoPro doesn’t take forever. Using the Media Mod kit or GoPro Pro adapter, you can attach this microphone to your GoPro model and start recording videos with high-quality audio.
On the other hand, this mic can be used with several devices. Its universal compatibility eases its usability with all popular video recording tools. The microphone comes with 3.5mm and USB-C cables, which can be used to connect it to GoPros, DSLRs, computers, and smartphones.
And not only cables but all essential accessories are boxed in the package. This includes things like lav mics, windscreens, and a carrying case.
Key Specifications of the Shure MoveMic
  • 8.2-gram TX weight
  • 81-gram RX weight
  • 2.4GHz and Bluetooth wireless connectivity
  • Up to 100ft wireless range
  • Up to 8 hours (approx.) TX battery life
  • Up to 7 hours of RX battery life
  • 2.5-hour RX charging time
  • -37 dBFS @ 94dB SPL mic sensitivity
  • 68dB signal-to-noise ratio
Pros of the Shure MoveMic
  • The microphone provides clear audio, especially for cameras and smartphones
  • Users admire its water-resistant functionality
Cons of the Shure MoveMic
  • The RX unit is heavy and bulky, which may cause handling problems when connected to the GoPro
  • Some users reported that the mic is not compatible with all the devices as advertised by the company
Quantitative Measurement of the Shure MoveMic
  • Design:’ 7/10
  • Durability: 8/10
  • Build quality: 8/10
$499.00 (As seen on Amazon)
9. RODE VideoMicro Compact On-Camera Microphone
The RODE VideoMicro is an incredibly compact and lightweight on-camera microphone that’s specifically designed to improve the audio quality of your GoPro videos. As someone who’s tinkered with a fair share of audio equipment, I can vouch for the Rode brand’s reputation for quality. This little marvel is no exception. Ideal for vloggers, hobbyists, and professionals looking to enhance their on-the-go recordings, the VideoMicro doesn’t require any batteries, making it a hassle-free addition to your GoPro gear.
Upon testing, I found that the microphone significantly reduced ambient noise, thanks to its cardioid pickup pattern, which focuses on sounds in front of the camera while minimizing background noise. The included furry windshield was exceptionally handy at eliminating wind noise during an outdoor shoot. The overall build quality feels robust for its size, and its plug-and-play functionality is perfect for those who don’t want to fuss with complex setups.
Key Specifications of the RODE VideoMicro
  • 100Hz – 20kHz frequency response
  • 75 dB SPL signal-to-noise ratio
  • 33.0dB re 1 Volt/Pascal mic sensitivity
  • 3.5mm TRS connector type
  • 42-gram weight
Pros of the RODE VideoMicro
  • No battery needed, plug-and-play convenience.
  • Comes with a shock mount to minimize handling noise.
  • Compact and lightweight design makes it highly portable.
  • The windshield is very effective at mitigating wind noise.
  • Very user-friendly for those less versed in audio tech.
Cons of the RODE VideoMicro
  • The sound may not be as full-bodied as larger, more professional mics.
  • Requires a 3.5mm microphone adapter for the GoPro, which is not included.
  • May struggle to isolate sound in extremely noisy environments.
Quantitative Measurement of the RODE VideoMicro
  • Design: 7/10
  • Durability:8 /10
  • Unique features:8 /10
$64.95 (As seen on Amazon)
10. Saramonic SR-XM1 3.5mm TRS Omnidirectional Microphone
image 768
The Saramonic SR-XM1 is an incredibly lightweight and compact microphone that punches well above its weight class. Unlike larger, more cumbersome microphones, the SR-XM1 is the quintessential plug-and-play solution for GoPro users looking to significantly upgrade their audio quality without the hassle. Its unobtrusive design allows you to keep your setup small and nimble which is especially handy for action cam scenarios.
One striking feature about this mic is its flexibility—literally. The microphone’s swivel joint lets you adjust it to the optimal angle, ensuring that it captures sound from the right direction. This can be a game-changer for on-the-go vlogging where setting up the perfect shot in a hurry is often the norm.
Another aspect that I find particularly impressive is the microphone’s ability to capture clear and natural sound. It’s omnidirectional, which means it picks up audio from all around the microphone. This trait can be a double-edged sword, however, as it’s not just your voice or the intended sound that gets captured—if you’re in a noisy environment, this microphone will pick up that background chatter or wind noise too.
Key Specifications of the Saramonic SR-XM1
  • Electret condenser mic
  • 35 Hz to 15 kHz frequency response
Pros of the Saramonic SR-XM1
  • Remarkably compact and portable, making it perfect for travel.
  • No battery requirement means you’re always ready to record.
  • Swivel joint feature offers flexibility in recording angles.
  • Easy to use; simply plug it into your GoPro and hit record.
Cons of the Saramonic SR-XM1
  • Omnidirectional pattern may capture unwanted ambient noise.
  • Lack of advanced features such as gain control or a low-cut filter.
  • Does not come with a deadcat windscreen, so it’s less effective in windy conditions unless you purchase one separately.
Quantitative Measurement of the Saramonic SR-XM1
  • Design: 7/10
  • Durability: 7.5/10
  • Unique features: 7/10
$20.00 (As seen on Amazon)
11. Boya BY-MM1 Compact On Camera Shotgun Microphone
image 773
The Boya BY-MM1 is a versatile and affordable external microphone that is designed to improve the audio quality of your GoPro recordings significantly. Right out of the box, you’ll notice its robust build and compact size, making it a convenient add-on without adding too much bulk or weight. Unlike some microphones that require you to fiddle with settings, the BY-MM1 touts a plug-and-play design which I find refreshingly straightforward.
This microphone has impressed me with its ability to capture clearer sound compared to the GoPro’s built-in mic. Its cardioid pickup pattern focuses on the sound in front of the camera while reducing noise from the sides and back, an essential feature for vlogging or conducting interviews in noisy environments. Though it’s not purely professional-grade gear, its performance to price ratio is difficult to beat.
Key Specifications of the Boya BY-MM1
  • Cardioid polar pattern
  • 35Hz to 18kHz frequency response
  • -42dB @ 1kHz sensitivity
  • 76dB SPL signal-to-noise ratio
Pros of the Boya BY-MM1
  • Great value for money, offering decent sound quality at a low price point.
  • No battery required, which cuts down on weight and the need for battery management.
  • Solid metal construction feels durable and can withstand regular use.
  • Highly adaptable with both TRS and TRRS cables included, allowing connectivity with a variety of devices, not just the GoPro.
  • The included shock mount reduces handling noise, which is a boon when moving around.
Cons of the Boya BY-MM1
  • Sound quality isn’t as rich as higher-end mics, lacking a bit in depth and fullness.
  • Wind noise can be an issue without proper shielding, which means the included foam windscreen might need an upgrade in certain outdoor conditions
Quantitative Measurement of the Boya BY-MM1
  • Design: 7/10
  • Durability: 8/10
  • Unique features: 7.5/10
$23.99 (As seen on Amazon)
12. RODE VideoMicro II
RODE VideoMicro II is one of the best microphones for GoPro that records professional-quality sounds. It is an ultra-compact, easy-to-use, and lightweight wireless microphone ideal for content creation and adventurous filmmaking. It is a battery-less mic, so all you need to do is plug it into your GoPro and start recording.
The VideoMicro II is factory-tuned to capture crystal-clear audio without letting you beat complicated controls, making it a perfect GoPro wireless microphone. It is an impressive and highly directional mic that picks up sound from the front while reducing the back and side noises.
Features and Specifications of RODE VideoMicro II
RODE VideoMicro II consist of the following characteristics:
  • 79dB SPL
  • 3.5mm TRS connectivity for GoPro
  • -39dBV audio sensitivity
  • 20hZ to 20kHZ frequency response
  • Shotgun microphone
Pros of RODE VideoMicro II
These are the advantages of using RODE VideoMicro II.
  • Simple to use
  • Lightweight mic (just 39 grams)
  • Great audio quality both outdoors and indoors
  • Does not require controls and batteries
Cons of RODE VideoMicro II
Here’s one disadvantage of using RODE VideoMicro II:
  • There is no USB Type C output
Quantitative Measurement of RODE VideoMicro II
  • Design: 7/10
  • Durability: 7/10
$79.00 (As seen on Amazon)
13. Movo VXR10 Universal Video Microphone
image 789
The Movo VXR10 Universal Video Microphone is a versatile and compact shotgun microphone that significantly enhances audio quality when paired with a GoPro, especially if you’re venturing into vlogging, interviews, or even just wanting to capture clearer dialogue and ambient sounds during your adventures. This microphone strikes a fantastic balance between portability and performance.
In my personal experience, the Movo VXR10 has been a game-changer. It’s ridiculously easy to set up – just plug it in, and you’re good to go. The robust build quality gives it a reassuring heft, but not so much that it becomes cumbersome on the move. The audio capture itself is where the VXR10 shines: it delivers markedly clearer and richer sound than the GoPro’s built-in mic, without catching too much background noise, thanks to its cardioid pickup pattern.
Key Specs of the Movo VXR10
  • 20 Hz to 18 kHz frequency response
  • 3.5mm connector
  • 78dB signal-to-noise ratio
  • -36dB sensitivity
Pros of the Movo VXR10
  • Excellent portability; it’s light and compact, making it a breeze to carry around.
  • No need for battery management; it’s a passive microphone that does not require batteries.
  • Stellar sound improvement over GoPro built-in microphones, with a focus on clarity.
  • Comes with useful accessories, including a sturdy shock mount and a furry windscreen for outdoor recordings.
  • Universal compatibility with a range of devices, making it a versatile investment.
Cons of the Movo VXR10
  • While it does a good job minimizing background noise, it might not completely isolate sound in extremely noisy environments.
  • Some users might prefer a microphone with optional gain control, which the VXR10 lacks.
Quantitative Measurement of the Movo VXR10
  • Design: 7/10
  • Durability: 8/10
$39.95 (As seen on Amazon)
14. Deity V-Mic D4 Duo
The Deity V-Mic D4 Duo is a shotgun microphone that fits most GoPro models. The company claims this microphone is the world’s first with dual directionality. Moreover, Deity feels proud of acquiring the patent for the mic’s dual-capsule configuration. That means this microphone can capture sounds from the rear and front despite being a shotgun-styled device.
The D4 Duo includes dual cardioid polar patterns, which ensures that your captured audio remains as clean as possible from unwanted background noises. Plus, you can use this mic with your GoPro and DSLRs on different recording occasions to record clear sound with its low-noise circuitry.
Additionally, this microphone has an AUX input. You can use it to connect wireless receivers or additional wired microphones. This is a really helpful feature of the D4 Duo if you want to record multiple sound resources.
Of course, one cannot choose a GoPro microphone without knowing its power specs. So, like most shotgun microphones, the D4 Duo uses your GoPro or other camera’s battery to which it is connected. So, as soon as you connect this mic via a 3.5mm jack, it turns on. Yes! As simple as that.
Since you have a GoPro, it’s clear that you’re passionate about capturing adventures. But these voyages come with ups and downs. As a result, you also experience handling noises in your video recordings, especially if you’re relying on the GoPro’s built-in microphones. The Deity V-Mic D4 Duo, with its Rycote shockmount, effectively eliminates this problem, allowing you to capture your adventures with crystal-clear sound.
Key Specifications of the Deity V-Mic D4 Duo
  • Dual cardioid polar pattern
  • 3.5mm TRS AUX input and output connectivity
  • -42 +/- 3dB front mic’s sensitivity
  • -51 +/- 3dB rear mic’s sensitivity
Pros of the Deity V-Mic D4 Duo
  • Unlike traditional shotgun mics, the D4 requires less human involvement for adjusting angles to receive audio clarity due to dual mics
  • The sound quality of both front and back microphones is outstanding
  • Audio is recorded in separate channels (left and right), which assess the editing process later
Cons of the Deity V-Mic D4 Duo
  • The included shockmount is not of high quality
  • Some Amazon users complained about receiving another model
  • Design: 7/10
  • Durability: 8/10
$39.96 (As seen on Amazon)
The Godox MoveLink II wireless microphone system is engineered to multiply your audio recording experience with GoPro cameras and other recording devices. It ensures high-quality audio despite its compact size. Due to its 1.9-inch x 1.5-inch x 0.55-inch dimensions, this portable mic is also easy to hold in your hand or keep inside your pocket. The RX unit has a battery life of 8 hours, while the TX unit functions for up to 10 hours.
MoveLink II has enhanced audio quality due to an advanced noise cancellation feature that minimizes unwanted background noise. TX and RX units permit you to effortlessly adjust volume and change noise reduction levels with the TFT screen displaying major specs’ settings. The mic also offers a mute function and volume control for output audio signals.
The MoveLink II provides a wireless range of up to 328ft (100 meters) for capturing clean, clear, and interference-free audio. The credit goes to the frequency-hopping mechanism that ensures uniterrupted operations by blocking interferences from the surrounding Wi-Fi and Bluetooh signals.
Compatibility-wise, this microphone comes with 3.5mm TRS and TRRS cables. You can also purchase 3.5mm USB-C or Lightning adapters separately to expand compatibility. This makes the MoveLink II workable with different audio recorders, cameras, tablets, iPhones, and Android phones.
The entire kit (2TX and 1RX) can be charged via Type-C ports. Conversely, you can juice up all three units in a fully charged storage case. And if you think that carrying the case will be an extra burden, relax! It is similar to the size of a smartphone, and you can take it with you anywhere.
Key Specifications of the Godox MoveLink II
  • 27 grams TX/RX weight
  • 328ft wireless range
  • 8-hour RX battery life
  • 3.5mm TRS compatibility
  • -32dB +/- 2dB microphone sensitivity
  • 70dB signal-to-noise ratio
Pros of the Godox MoveLink II
  • It has an impressive sound quality
  • The microphone has a robust body
Cons of the Godox MoveLink II
  • The charging case lacks an internal battery, which can be used for charging the units wirelessly
Quantitative Measurement of the Godox MoveLink II
  • Design: 7/10
  • Durability: 8/10
$199.00 (As seen on Amazon)
16. Klip 5-in-1 Wireless Lavalier Microphone
Here’s a low-priced microphone for high-quality sound recording with GoPro. In fact, this Klip 5-in1 wireless lav microphone suits many devices, including GoPros, Androids, iPhones, iPads, Windows laptops, MacBooks, and DSLR cameras.
With the RX unit’s multi-platform functionality, this wireless mic allows quick connectivity with most devices. Plus, the package comes with all required adapters, saving you money when you buy them separately. The manufacturer also claims that it works hassle-free with iPhone’s Bluetooth.
The KLIP 5-in-1 is equipped with a DSP chip and active noise-canceling algorithm. With just one click, this technology helps reduce ambient noises surrounding your recording environment, saving you valuable time in post-production.
From a portability point of view, this KLIP omnidirectional microphone is small and lightweight, weighing only 9 grams. The manufacturer also claims that the microphone has a perfect balance of weight due to its elongated design. This makes it unnoticeable when attached to clothing while shooting with the GoPro. Also, its balanced weight prevents the mic from slipping off your shirt during use.
When fully charged, both TX and RX have runtimes of up to 8 hours. Additionally, each unit has a USB Type-C port, which lets you charge it while audio recording. This GoPro-friendly microphone delivers wireless audio transmission up to 495ft (150 meters) (495 feet). It comprises adaptive FM technology for smooth functionality even in crowded places.
What’s more? You can monitor sound since it offers a headphone jack. This lets you hear the captured audio in real time, so you can make necessary adjustments to experience high-quality audio.
Key Specifications of the Klip 5-in-1 Wireless Lavalier Microphone
  • 9 grams TX weight
  • 495ft (up to 150 meters) wireless range
  • TX and RX battery life of up to 8 hours
Pros of the Klip 5-in-1 Wireless Lavalier Microphone
  • This microphone is best for non-tech-savvy users
  • The mic comes with useful accessories
Cons of the Klip 5-in-1 Wireless Lavalier Microphone
  • Users complain about recording noise from the movement of clothing
Quantitative Measurement of the Klip 5-in-1 Wireless Lavalier Microphone
  • Design: 7/10
  • Durability: 7/10
$59.95 (As seen on Amazon)
17. SPORTKEE K2
The SPORTKEE K2 is a wireless microphone that ensures effortless usability through its plug-and-play functionality. One of the interesting traits of the SPORTKEE K2 wireless mic lies in its noise-cancellation. It comes with an integrated noise reduction chip which is backed by Bluetooth wireless technology.
These features ensure that you can enjoy rich sounds with reduced background noise. Plus, the addition of the furry windscreen works like the icing on the cake, improving the overall audio quality, especially in the outdoor recordings.
To begin recording, attach the RX unit to your GoPro using the 3.5mm or USB-C cable (with or without a GoPro adapter, depending on the model) and turn on both TX and RX units. They will automatically pair, and you will be able to start your session. Also, this mic doesn’t need a third-party app or driver installation.
The K2 by SPORTKEE gives you a 65ft wireless range. Furthermore, it has a runtime of around 6 hours when completely charged. This make the mic suiatble for mostly indoor projects. And it seems like the makers of this product knows the pain of losing the clip. Because of that, the package includes an extra clip so you don’t have to end your session if you don’t find the other one.
Although this wireless microphone works well with GoPros, you can also use it with many other devices, such as smartphones, PCs, and cameras. Even this microphone can be connected to speakers and amplifiers. That is why it’s not only good for travel or Moto vlogging, but it can also work for recording high-quality audio for live streams, podcasts, and interviews.
Key Specifications of the SPORTKEE K2
  • Bluetooth wireless connectivity
  • 65ft wireless transmission range
  • TX battery life is above 6 hours
Pros of the SPORTKEE K2
  • This wireless mic directly plugs into your GoPro without any adapter
  • It has separate channels for audio, which helps reduce noise to an extent
Cons of the SPORTKEE K2
  • Appearance-wise, this microphone is less attractive compared to other alternatives
  • Design: 6.5/10
  • Durability; 7/10
$24.99 (As seen on Amazon)
18. RICHCHIP RC100
The RICHCHIP RC100 is a Bluetooth wireless microphone that delivers decent audio quality. This mic is compatible with smartphones, laptops, and GoPro HERO 12. As a matter of fact, it is a multifunction 3-in-1 device to use for livestreaming, meetings, and vlogging.
The RC100 also acts as a Bluetooth voice recorder. It allows you to use it as a camera shutter controller. Moreover, it has a user-friendly design with straightforward buttons. Since it comes with a 3.5mm jack, you can connect it to all 3.5 mm-supported devices. However, it may only work with the HERO 12 due to Bluetooth sync capabilities. This mic-cum-wireless recorder has many great features, such as a one-touch record and powerful noise canceling.
Key Specifications of the RICHCHIP RC100
  • 3.5mm connector for multiple devices
Pros of the RICHCHIP RC100
  • Straightforward and quick setup with GoPro HERO 12
Cons of the RICHCHIP RC100
  • Extremely inadequate information provided by the manufacturer – the only reason its here on the list is because of its flawless compatibility with GoPro HERO 12
Quantitative Measurement of the RICHCHIP RC100
  • Design: 6/10
  • Durability: 6/10
  • Build quality: 6/10
$64.99 (As seen on Amazon)
Not only the price but several factors, like audio quality, frequency, wireless range, and polar pattern, make a great GoPro wireless microphone. From this point of view, the Hollyland Lark M2 is a clear winner.
Hollyland Lark M2, Lark M1, Lark Max, and the newly introduced Lark M2S qualify as the best wireless GoPro microphones because of their useful features, outstanding clip-on style, omnidirectional sound pick-up, and broad compatibility. The next great options come from brands like Diety, Movo, and Boya. On the other hand, if you are on a super-tight budget and willing to compromise on the features, then RODE VideoMicro II and Sennheiser MKE 200 are two affordable options. If you have a GoPro HERO 12 and are not willing to spend money on a professional GoPro mic, you can try the RICHCHIP RC100 to enjoy basic functions.
Nevertheless, the choice is totally yours. You can choose any model from this list of 17 wireless microphones for external audio recording on your GoPro.
FAQs – GoPro Wireless Microphone
Q1. Does GoPro have a good built-in mic?
The built-in GoPro mic records good-quality sound. Nevertheless, for professional, clean, and crisp audio recording, you are required to use an external GoPro wireless microphone.
Q2. Can GoPro connect to a wireless microphone?
All GoPro camera models, from Hero 4 to Hero 11, support wireless microphones. But you need a Pro Mic Adapter or Media Mod to use an external wireless mic with HERO 8,9.10, and 11.
Q3. Which company wireless mic is best for GoPro?
Hollyland Lark M2, Lark M1, RODE VideoMicro II, and Sennheiser MKE 200 are the best budget wireless GoPro microphones.
[userfeedback-post-ratings]
