How to Stream on Non-Smart TV: Easy Ways to Enjoy Your Favorite Content
By Hollyland | September 20, 2025
Many people still own non-smart TVs that don’t have internet access or streaming apps built in. That doesn’t mean you can’t enjoy Netflix, YouTube, or your favorite live broadcasts. With the right devices and setup, you can turn any old TV into a streaming hub.
For those who want high-quality live video, the Hollyland VenusLiv Air stands out. It delivers 24/7 streaming with crisp 4K at 30fps, giving you a stable and reliable way to enjoy smooth visuals without interruption.
Keep reading to learn about ways to stream on non-smart TVs.
How to Use Streaming Devices via HDMI?
The most common way to bring streaming to a non-smart TV is with an HDMI streaming device. These plug-and-play gadgets are designed for simple use, even if your TV is ten years old.
Popular Streaming Sticks and Boxes
  • Amazon Fire TV Stick: Compact, affordable, and filled with apps like Netflix, Prime Video, and Disney+.
  • Roku Streaming Stick/Box: Known for an easy interface and a huge selection of free channels.
  • Google Chromecast with Google TV: Lets you cast from your phone and also run apps directly.
  • Apple TV: A premium option that works seamlessly with Apple devices through AirPlay.
  • Android TV Boxes: These run Android apps directly on your TV, giving you flexibility and access to Google Play.
Setup Process
Here we would use Google Chromecast.
Here is how to set up:
  1. Plug the device into your TV’s HDMI port.
  1. Connect it to a power source.
  1. Switch your TV input to the correct HDMI channel.
  1. Sign in to your streaming accounts and start watching.
This setup takes less than ten minutes and doesn’t require advanced technical knowledge.
Pros and Cons
  • Simple to install and use
  • Offers thousands of apps
  • Portable between TVs
  • Needs a steady Wi-Fi connection
  • Some models become outdated in a few years
How to Use a Game Console or PC as a Streaming Hub?
If you already own a console or computer, you can stream without buying extra hardware.
Run Streaming Apps via Console
Modern consoles double as media centers. Xbox, PlayStation, and even Nintendo devices offer access to Netflix, YouTube, Twitch, and other popular apps. Just log in with your account and enjoy.
Use a PC or Laptop with HDMI Output
Another option is connecting your computer directly to the TV. Plug an HDMI cable from your PC or laptop to the TV. Once connected, your TV works as an external monitor. You can then open any browser or app to stream content.
Pros and Cons
  • Uses devices you already own
  • Handles a wide range of apps
  • Good for multitasking
  • Consoles and PCs use more power than streaming sticks
  • Not as portable
  • Requires frequent updates and maintenance
How to Use Mobile Devices with Casting or Mirroring?
Sometimes the fastest way to stream on a non-smart TV is by using your phone or tablet.
Screen Mirroring Technologies
  • Miracast: Supported by many Android devices. It mirrors your entire screen wirelessly using Wi-Fi Direct.
  • Chromecast: Works with both Android and iOS. You can cast directly from supported apps like YouTube or Netflix.
  • AirPlay: Apple’s screen mirroring solution, ideal for connecting iPhones and iPads to Apple TV.
All of these require a Wi-Fi connection and a compatible device or adapter.
Pros and Cons
  • Quick to set up
  • Perfect for sharing short clips, photos, or presentations
  • Works without buying a full streaming box if you already have a casting device
  • Drains phone battery quickly
  • Can lag with weaker Wi-Fi
  • Full mirroring shows notifications and background activity, which may distract viewers.
How to Stream via DLNA or Media Extenders?
If you don’t want extra HDMI sticks, you can still stream using your home network with DLNA-based solutions.
Use DLNA Apps
Apps like BubbleUPnP or Plex let you send videos, music, and pictures from your phone or computer to your TV. Many Blu-ray players and set-top boxes also support DLNA, so you may not need new gear at all.
Pros and Cons
  • Works over your existing Wi-Fi
  • Doesn’t require constant cable switching
  • Can share large media libraries stored on PCs or NAS devices
  • Setup can be tricky
  • Limited compatibility across devices
  • Fewer app options compared to HDMI sticks
How to Stream via Localcasting or Web-to-TV Methods?
For those who want complete control, a home theater PC or media extender is another route.
Using Home Theater PCs
You can connect a dedicated PC to your TV, install media center software like Kodi or Plex, and stream anything you like. This option provides full access to the web, desktop apps, and advanced playback settings.
Pros and Cons
  • Ultimate flexibility
  • Works with any website or streaming service
  • Great for tech enthusiasts who like custom setups
  • Requires technical knowledge
  • More expensive than a stick or a console
  • Uses more power and space
Streaming on a non-smart TV is easier than most people think. Whether you use an HDMI device, a console, your phone, or a home theater PC, you can enjoy modern streaming without buying a new television.
Q: Can I stream directly on a non-smart TV without any device?
No. A non-smart TV lacks the necessary apps and Wi-Fi support. You must use a device like a streaming stick, console, or casting tool.
Q: What is the best device for streaming on an older TV?
A Roku or Fire TV Stick works best for simplicity. They plug into HDMI and offer an easy interface with plenty of apps.
Q: Does Hollyland VenusLiv Air support direct TV streaming?
No. The camera is designed for professional live streaming rather than direct TV playback.
Q: Can I use my smartphone to stream content to a non-smart TV?
Yes. You can cast or mirror your screen with Chromecast, AirPlay, or Miracast, but the quality depends on your Wi-Fi.
Q: How do I fix streaming lag on my non-smart TV?
Use a wired Ethernet connection for devices when possible. Also, close unused apps on your phone or PC to free bandwidth.
