WeVideo’s built-in voiceover tool makes it easy to add narration to any project without leaving your browser. But a surprising number of users hit a wall before they ever record a single word — usually because of a blocked microphone permission or a missed step in the editor. This guide walks you through the full process, from browser setup to your first clean recording, so you can get your voiceover done and move on.
How to Record Audio on WeVideo: Step-by-Step Voiceover Guide
What “Recording Audio” Means in WeVideo
WeVideo’s audio recording feature is called the Voiceover or Narration tool, depending on which version of the editor you are using. It records your voice directly onto the timeline as an audio clip, without any need to leave the editor or import a separate file. The tool uses your computer’s built-in microphone or any connected external mic, and the resulting clip appears on its own audio track, ready to trim and adjust.
Before You Start: Microphone and Browser Setup
This is the step most tutorials skip — and the most common reason recording fails. If your browser does not have permission to access your microphone, WeVideo cannot detect an input source at all. Work through these steps before opening your project.
- Confirm your microphone is connected and active. If you are using an external mic, plug it in before opening WeVideo. For built-in laptop mics, check that it has not been disabled in your system sound settings.
- Grant microphone permission in your browser. In Chrome or Edge, go to Settings → Privacy and Security → Site Settings → Microphone. Make sure WeVideo (or the site is not blocked). Alternatively, click the lock icon or camera/mic icon in the browser address bar while on the WeVideo editor page and set microphone access to “Allow.”
- Test your microphone at the system level. On Windows, open Sound Settings → Input and speak into your mic to confirm the level meter moves. On Mac, go to System Settings → Sound → Input and check for activity. If the meter does not move, the issue is with the mic or system settings, not WeVideo.
- Close other tabs or apps using the microphone. Video calls, voice recorders, or other browser tabs can lock the microphone input. Close them before recording.
Once microphone access is confirmed, refresh the WeVideo editor page and proceed.
How to Record Audio on WeVideo — Step-by-Step
- Open or create your project in WeVideo. Log in and enter the editor with the video or slide content you want to narrate already on the timeline.
- Position the playhead where you want narration to begin. Click on the timeline at the exact point you want the audio clip to start. The playhead (the vertical line) marks where recording will begin.
- Open the Voiceover or Narration tool. Look for the microphone icon in the timeline toolbar, often labeled Voiceover or Narration. In some versions of WeVideo, this appears as a dropdown or a dedicated button above the audio track area. Click it to open the recording panel.
- Select your microphone input. A dropdown menu will show available audio input devices. Choose the correct microphone — if you are using an external mic, select it here rather than leaving the default on your built-in device.
- Click the Record button and wait for the countdown. WeVideo typically shows a short countdown before it starts capturing. Use that moment to get positioned and ready before you speak.
- Deliver your narration, then click Stop. Speak clearly at a consistent distance from the mic. Click the Stop button when you have finished your take.
- Review the audio clip in the timeline. The recorded clip will appear as a block on the audio track. Play it back to check the quality and timing.
- Trim, drag, or reposition the clip as needed. Click and drag the edges of the clip to trim silence from the beginning or end. Drag the clip horizontally to shift its position on the timeline if the timing is off.
Note: UI label names vary slightly between WeVideo plan tiers and editor versions. If you do not see a “Voiceover” button, look for a microphone icon in the toolbar or check the “Add” menu along the left panel.
Tips for Better Audio Quality When Recording in WeVideo
Clean narration makes a project feel polished. A few simple habits will make a noticeable difference.
- Record in a quiet room. Move away from HVAC vents, fans, and windows facing busy streets. Soft furnishings like curtains and carpet help absorb echo.
- Keep the mic 6 to 12 inches from your mouth. Speaking too close causes plosive pops on “p” and “b” sounds; too far away picks up more room noise.
- Record a 5-second test clip first. Play it back before doing your full take. Catching a problem early saves a lot of re-recording.
- Watch your input levels. WeVideo’s input meter should peak in the mid-range during normal speech. If it is redlining, lower your system mic volume before recording.
- Upgrade your microphone if quality is a priority. Laptop built-in mics commonly introduce background hiss and room echo that is difficult to remove after the fact. A compact plug-and-play option like the Hollyland LARK A1 connects via USB-C or Lightning with no drivers required, includes 3-level Intelligent Noise Cancellation, and works directly with browser-based editors like WeVideo for a noticeably cleaner recording without any extra setup.
Troubleshooting: Common Audio Recording Problems in WeVideo
| Problem | Likely Cause | Fix |
| Mic not detected | Browser permission blocked | Enable mic access in browser settings, then refresh |
| Record button grayed out | No active mic input found | Connect mic, close competing apps, refresh the page |
| Audio clip has no sound | Wrong input source selected | Reopen the voiceover tool and select the correct mic |
| Recorded audio is very quiet | Input gain too low | Raise system mic volume before recording |
| Echo or feedback during playback | Speakers on during recording | Use headphones while recording to prevent feedback |
Can I record audio on WeVideo for free?
Yes. The voiceover recording feature is available on WeVideo’s free plan. Recording itself is not locked behind a paywall. Free plans do have limits on export resolution and storage, but those restrictions apply to exporting your finished project, not to using the narration tool during editing.
Can I record multiple audio tracks in WeVideo?
WeVideo supports multiple audio tracks on the timeline. You can record a voiceover on one track and separately add background music or sound effects on another, then adjust the volume of each track independently to balance the final mix.
How do I delete or re-record a voiceover clip in WeVideo?
Click the recorded audio clip in the timeline to select it, then press the Delete key to remove it. Reposition the playhead at the correct start point and open the voiceover tool again to record a new take. The process is identical to the original recording steps.
Next Steps
Recording audio in WeVideo comes down to a few reliable steps: confirm browser permissions, position the playhead, open the voiceover tool, and record. Do a short test clip first to catch any level or quality issues before committing to a full take. Once your narration is in place, the logical next steps are adjusting audio volume on individual clips or adding background music to complete your project.
