How to Get Stream Key Twitch and Use It in OBS & Streamlabs
By Hollyland | September 5, 2025
Starting a stream on Twitch is exciting, but many beginners encounter the same issue: connecting their broadcasting software to Twitch. The solution answer is your stream key. This code connects links your Twitch account with OBS, Streamlabs, or other tools, enabling you to go live.
For smooth and professional streams, your equipment matters too. The Hollyland VenusLiv Air is built for creators who want reliable performance. With 24/7 continuous streaming support and 4K 30fps video quality, it ensures your broadcasts look polished from start to finish.
Here’s everything you need to know about Twitch stream keys and how to use them.
What Is a Twitch Stream Key?
A Twitch stream key is a unique alphanumeric code that allows your streaming software to communicate with Twitch. Think of it as a password for your channel’s broadcast. Without it, software like OBS or Streamlabs has no way of knowing which account to stream to.
Why does Twitch use this system? Because it keeps streams secure and ensures only you can broadcast on your account. Unlike YouTube, which can authenticate directly through your account login, Twitch requires a stream key for more control.
Keeping your stream key private is critical. If someone else gets access, they could broadcast under your name. Fortunately, Twitch allows you to reset your stream key with just one click at any time.
Twitch’s popularity explains why this step matters. In 2023, Twitch hosted more than 7.5 million active streamers. With millions of competitors vying for viewers, ensuring your setup is correct from the start helps you stand out.
How to Get Your Twitch Stream Key Step by Step
Obtaining your Twitch stream key takes only a few minutes. Follow these steps carefully:
  1. Open Twitch in your browser and log in to your account with your username and password (Ensure that two-factor authentication is enabled, as Twitch requires it for streaming)
  1. Click your profile picture in the top-right corner
  1. From the dropdown menu, select Creator Dashboard. This is your central hub for managing streams, analytics, and settings.
  1. In the Creator Dashboard, look at the left-hand menu
  1. Click Settings, then choose Stream
  1. At the top of the Stream page, you’ll see Primary Stream Key. This is the code that connects your account to OBS or other software
  1. Click Show (by default, Twitch hides your stream key for security)
  1. Click “I Understand” underneath the warning about sharing your stream key, and your stream key should be displayed.
  1. Copy the key to your clipboard. You can paste it directly into your broadcasting software or save it in a secure location for later use
Tip: Treat your stream key like a password. Do not share it with friends or post it publicly. If it ever leaks, reset it immediately.
How to Use Your Stream Key in Streamlabs
Streamlabs, built on OBS, has a nearly identical setup process. Many beginners choose it because of its friendly interface.
  1. Open Streamlabs Desktop on your PC
  1. Click the gear icon at the bottom-left to open settings
  1. Go to the Stream section and click on “Stream to custom ingest
  1. From the service list, select Twitch
  1. Paste your stream key in the box provided
Tip: Make sure you save your settings for the future.
Once linked, you can add overlays, alerts, and widgets that Streamlabs offers. These extras can make your channel look more professional, even if you’re just starting out.
1. Can I reset my Twitch stream key?
Yes. If you believe your stream key has been leaked or lost, navigate to Creator Dashboard → Settings → Stream and select ‘Reset’. Twitch will generate a brand-new key immediately, and you can paste it into OBS, Streamlabs, or your preferred software.
2. Do I need a new stream key every time I stream?
No. Your stream key stays the same until you manually reset it.
3. Can I stream on Twitch without using a stream key?
Yes. Many broadcasting tools, including OBS and Streamlabs, allow direct Twitch login through account authorization. This bypasses the need to copy and paste your key. However, using the stream key is still helpful if you’re setting up manually or switching between different streaming software.
4. What happens if someone else gets my stream key?
Anyone with your stream key can broadcast on your channel without permission, which could damage your account. To prevent this, keep your key private and never post it publicly. If compromised, reset it immediately in Twitch settings to block unauthorized access to your channel.
5. Does the stream key affect my video quality?
No. The stream key only acts as a connection between your software and Twitch. Your video quality depends on settings like bitrate, resolution, frame rate, and your internet speed.
A Twitch stream key connects your channel to broadcasting software, enabling live streaming. Once you know where to find it and how to use it, going live becomes simple. Protect it like a password, and you’ll always have secure, reliable access to your Twitch audience.
